vyper013 1 Posted July 2, 2020 Posted July 2, 2020 Hi all, I have a weird problem.....I installed the Trakt plugin in a while ago... configured it all and it worked nicely...... today I went to go and start to configure other users with Trakt and now when I go to choose the user there is nothing there.... I click the drop down and nothing happens and I can't type in the field either?? is there something stupid I am doing?? I have removed the plug-in, deleted the Trakt.xml restarted and re-installed (with a restart) multiple times. I am running in Docker..... any help / additional information etc..... would be really nice!!
Luke 42246 Posted July 2, 2020 Posted July 2, 2020 Hi, do you use a reverse proxy? Sounds like your CSP is restricting the trakt plugin JavaScript.
vyper013 1 Posted July 3, 2020 Author Posted July 3, 2020 I am ...... it’s sitting behind a Traefik reverse proxy for name translation etc.... also Lets Encrypt. it was working perfectly happily when I first setup (bout a month ago?) any ideas ?? I’m still getting my head round some of the Emby confit/setups.... TIA
Luke 42246 Posted July 6, 2020 Posted July 6, 2020 Is the proxy adding a Content Security Policy ? (CSP). The trakt plugin needs to be updated to not get caught up by this, but in the meantime you can workaround it by configuring your proxy's CSP. @pir8radio how did you configure it for yours?
pir8radio 1313 Posted July 6, 2020 Posted July 6, 2020 11 hours ago, Luke said: Is the proxy adding a Content Security Policy ? (CSP). The trakt plugin needs to be updated to not get caught up by this, but in the meantime you can workaround it by configuring your proxy's CSP. @pir8radio how did you configure it for yours?
