vanes32 0 Posted July 2, 2020 Posted July 2, 2020 Hi guys, i need an advise. I am going to add gpu to my emby server (ubuntu20.04) for hardware accelerated transcoding. Which one do you recommend from these two, Quadro P400 or Radeon Pro WX 2100 I know quadro will be fine, but it has limited streams, i know that i can patch it and unlock limitations. The main question is: Will transcoding work on wx2100 ?
BAlGaInTl 288 Posted July 2, 2020 Posted July 2, 2020 I don't think the Radeon Pro WX 2100 would be supported. The Quadro P400 looks like it's limited to 1 stream for NVENC - https://developer.nvidia.com/video-encode-decode-gpu-support-matrix
vanes32 0 Posted July 2, 2020 Author Posted July 2, 2020 @Luke, hi, can you please confirm that wx 2100 is not supported and the better way is to buy 1050ti/p400 ??
Luke 42239 Posted July 2, 2020 Posted July 2, 2020 I haven't tried it, but why wouldn't it be supported?
vanes32 0 Posted July 3, 2020 Author Posted July 3, 2020 8 hours ago, Luke said: I haven't tried it, but why wouldn't it be supported? @Luke, i don`t know, i am not a gpu-transcoding guru, thats why i came to official emby forum to ask you Hardware Acceleration on Linux manual says that i need to install AMDGPU-PRO Driver for Linux Radeon™ Software for Linux and that`s all... In amd driver Release Notes i found: OpenCL™ 2.0 (not supported for Radeon™ Pro WX 2100 and Radeon™ Pro WX 3100) How this will affect emby transcoding functionality?
SHSPVR 125 Posted July 3, 2020 Posted July 3, 2020 On 7/2/2020 at 7:21 AM, BAlGaInTl said: I don't think the Radeon Pro WX 2100 would be supported. The Quadro P400 looks like it's limited to 1 stream for NVENC - https://developer.nvidia.com/video-encode-decode-gpu-support-matrix Quadro P400 has a unrestricted steam counts As for the Radeon Pro WX 2100 It is based on the consumer ver of Radeon RX 540X it my support more then 4 steam As for Linux you maybe better off with Nvidia or Intel
BAlGaInTl 288 Posted July 6, 2020 Posted July 6, 2020 On 7/2/2020 at 7:21 PM, Luke said: I haven't tried it, but why wouldn't it be supported? On 7/3/2020 at 4:05 AM, vanes32 said: @Luke, i don`t know, i am not a gpu-transcoding guru, thats why i came to official emby forum to ask you Hardware Acceleration on Linux manual says that i need to install AMDGPU-PRO Driver for Linux Radeon™ Software for Linux and that`s all... In amd driver Release Notes i found: OpenCL™ 2.0 (not supported for Radeon™ Pro WX 2100 and Radeon™ Pro WX 3100) How this will affect emby transcoding functionality? I was thinking the drivers would support that card under Linux. It may work on Windows. On 7/3/2020 at 11:52 AM, SHSPVR said: Quadro P400 has a unrestricted steam counts As for the Radeon Pro WX 2100 It is based on the consumer ver of Radeon RX 540X it my support more then 4 steam As for Linux you maybe better off with Nvidia or Intel Nvidia's page seems to indicate that the P400 is restrictricted, or am I reading it wrong?
SHSPVR 125 Posted July 6, 2020 Posted July 6, 2020 (edited) 5 minutes ago, BAlGaInTl said: Nvidia's page seems to indicate that the P400 is restrictricted, or am I reading it wrong? Ops look at wrong one it actually 3 Edited July 6, 2020 by SHSPVR
