archiel 3 Posted July 1, 2020 Posted July 1, 2020 I am running emby server at home and all devices can connect via the Lan. We are planning to visit family overseas and would like to access the server, either via the web client, iPad or via a Shield TV. I know that Emby Connect on my mobile phone (android) works as I can test this by disabling the wifi connection and just using mobile data. What I would like to do is test Connect on the laptop, iPad (no modem) and Shield before we travel (rather than attempt to troubleshoot after we arrive). Current restrictions make accessing another network difficult and so I am trying to test by adding the devices onto a separate subnet (192.168.xx.xx rather than the default 10.xx.xx.xx) so as to connect via the external interface of the router. After some editing of the settings I was able to run checks for Plex on the laptop, but am having no success with Emby (I have tried disabling the laptop firewall, but it did not help). I can login to my Emby connect account on the web. When logged in I can see the my emby server but cannot connect if I enter external address of the router (either as DDNS or IP) I cannot connect I know that the laptop can see the external address, as running ping or tracert on the DDNS name gives the (current) external ip of the router. When I try to connect there is nothing showing in the server log files. Is there anything else I can try, as noted before I can connect to plex 'remotely', but not emby.
cmacfarlane93 10 Posted July 1, 2020 Posted July 1, 2020 (edited) If using emby connect on your phone's data works in your previous setup worked then I would go back to that. It should not make any difference what device you connect from(By this I mean if you could connect on your phone without the wifi, you should be able to connect from any of your devices). If you want you can PM the external address and I can try to connect. Edit or you could also trying using your phone's data as a hotspot for your shield or laptop and try connecting to the external address. Edited July 1, 2020 by cmacfarlane93 another idea.
rbjtech 5337 Posted July 1, 2020 Posted July 1, 2020 Both 192.168.x.x and 10.x.x.x are 'private' networks and not WAN routable. The best advice is above - if you simply turn on your mobiles hotspot (which turns off the LAN side wifi), connect your laptop to it - then you will be using the 4G WAN address and it should connect exactly the same as if you had used the mobile directly via 4G. Remember if you are connecting directly to use the correct port after the url - ie http:\\myserver.com:8096 or https:\\myserver.com:8920
ebr 16310 Posted July 1, 2020 Posted July 1, 2020 Hi. Connect is just a convenience for not having to know your server's address. If you have a domain or know your public IP address you can also just test using that.
