Blob 7 Posted July 1, 2020 Posted July 1, 2020 (edited) Hi, I have a M3U tuner configured. When emby is remuxing the M3U live channel, the web client sometimes just shows "the spinning green circle". When I force transcoding the web client always shows the M3U live channel stream correct. I expect this should work every time I play the same channel and emby is remuxing. How can we make it work with remuxing every time on all channels? I will provide the log from when the M3U channel is remuxed and doesn't work. A side note: EmbyServer.exe seems to keep the M3U stream open when stopping the playback from the webclient when it did had "the spinning green circle". Must restart EmbyServer.exe to make it close the stream. Please help me. Thanks ffmpeg-remux-c27548f3-3f90-4b8e-9a67-a090d9f11c3f_1.txt embyserver.txt Edited July 2, 2020 by Blob
Luke 42244 Posted July 3, 2020 Posted July 3, 2020 Hi there, if you lower the in app quality setting so that it does a full transcode, how does that compare?
Blob 7 Posted July 3, 2020 Author Posted July 3, 2020 1 hour ago, Luke said: Hi there, if you lower the in app quality setting so that it does a full transcode, how does that compare? Hi, force transcode by lower the in app quality setting always play the stream. /Blob
