Guest Posted June 30, 2020 Posted June 30, 2020 When using the audio player is there a way to choose what gets displayed for pictures/album art? Also, this screen is rather dark, is there a way to control the brightness?
seanbuff 1356 Posted July 1, 2020 Posted July 1, 2020 Hi, Yes, you can modify the album art of any album using the Web UI or mobile app. As for the screen being dark, assume you're referring to the Android TV app. You can choose a different theme to see if that helps.
Guest Posted July 1, 2020 Posted July 1, 2020 I have looked in the web UI and do not see it. Where would I find it in the UI?
ebr 16338 Posted July 1, 2020 Posted July 1, 2020 Hi. Right click on an album or select the "..." menu and then select Edit Images... Also, if you have embedded artwork in your songs, we can pick that up.
Guest Posted July 3, 2020 Posted July 3, 2020 Thanks. Is there any kind of documentation explaining what all of the image types are? Primary, art, backdrop, etc
Luke 42246 Posted July 4, 2020 Posted July 4, 2020 @cayars can look at adding that to our knowledge base.
