brycelarge 1 Posted June 29, 2020 Posted June 29, 2020 (edited) Hi Guys, Apologies if this has been asked before, I did try searching before hand but could not find anything. on the android app when you press up the small guide pops up, can we please have an option on the app to choose between small and main guide? Or switch completely from small guide to main guide. Thanks. Edited June 29, 2020 by brycelarge 1
ebr 16339 Posted June 29, 2020 Posted June 29, 2020 Hi. By "small guide" do you mean the horizontal list of other programs on at the same time?
Tnuctihs 0 Posted July 1, 2020 Posted July 1, 2020 I'd like to chime in here. I think it would be very useful if pressing the up button whilst watching TV, would show the popup guide, rather than having to press down, and then right several times? Maybe short press to show the covers list, or long press to show the popup guide?
ebr 16339 Posted July 1, 2020 Posted July 1, 2020 FYI - if you have a menu button on your remote, that will produce the guide. I'll monitor this request as to changing the hotkey behavior.
Tnuctihs 0 Posted July 3, 2020 Posted July 3, 2020 Thank you. Unfortunately I use an Android TV, and the TV hijacks the command when I press the guide button, so this hotkey would be great.
brycelarge 1 Posted July 4, 2020 Author Posted July 4, 2020 On 6/29/2020 at 10:12 PM, ebr said: Hi. By "small guide" do you mean the horizontal list of other programs on at the same time? Yes that’s the one
brycelarge 1 Posted July 4, 2020 Author Posted July 4, 2020 20 hours ago, Tnuctihs said: Thank you. Unfortunately I use an Android TV, and the TV hijacks the command when I press the guide button, so this hotkey would be great. Yes mine too.
brycelarge 1 Posted July 4, 2020 Author Posted July 4, 2020 On 7/1/2020 at 11:09 PM, ebr said: FYI - if you have a menu button on your remote, that will produce the guide. I'll monitor this request as to changing the hotkey behavior. Not for everyone I don’t see any harm in adding an option to allow users to choose what the up arrow does.
