vdatanet 1619 Posted August 9, 2020 Posted August 9, 2020 (edited) Movie Metadata is correct but Collection metadata is not. In collection id is 102940 instead of 735. It is a vicious circle, since collection 735 does not exist, it is created, but 102940 is created by mistake. In the next attempt, as collection 735 does not exist, it is tried to create again, but by mistake 102940 is created. collection 735 never exists, collection 102940 is created over and over again ... I also have the Blade saga and Collection for me is correct. Edited August 9, 2020 by vdatanet
riffy 32 Posted August 9, 2020 Author Posted August 9, 2020 Yup. Wish it would get fixed! Or the very least be able to shift click to select many items.
vdatanet 1619 Posted August 9, 2020 Posted August 9, 2020 The question is, why collection 102940 is created instead of 735?
Luke 42241 Posted August 9, 2020 Posted August 9, 2020 4 hours ago, riffy said: Yup. Wish it would get fixed! Or the very least be able to shift click to select many items. It should hopefully be for the next release so that the collection will not get created multiple times. 1
Carlo 4561 Posted August 10, 2020 Posted August 10, 2020 On 8/9/2020 at 9:40 AM, Luke said: It should hopefully be for the next release so that the collection will not get created multiple times. Next beta release Luke?
floppyhat 3 Posted August 17, 2020 Posted August 17, 2020 I'm having the same problem with the American Pie collection. Will the fix also remove the existing duplicates automatically?
floppyhat 3 Posted August 17, 2020 Posted August 17, 2020 Ah, right — so deleting the collections folder and letting the plugin recreate them would probably be the best way to clean up, then. Thanks.
Happy2Play 9811 Posted August 17, 2020 Posted August 17, 2020 2 minutes ago, floppyhat said: Ah, right — so deleting the collections folder and letting the plugin recreate them would probably be the best way to clean up, then. Thanks. May have to remove the actual items that makeup the collection to clean out the database.
