maxt.v 10 Posted June 26, 2020 Posted June 26, 2020 Would be great if can limit the device per users. The simultaneous streams don't prevent to user to login on another device and it will consume the space for the devices limits on Emby Premiere. 7 3
Punch 19 Posted June 26, 2020 Posted June 26, 2020 Yes thisss !! I was about to bring this up. It should have been both....
Happy2Play 9812 Posted June 27, 2020 Posted June 27, 2020 You can already sort of do this with User device access. But in the end it sounds more like limiting a user to logged into only one device at a time. But at the same time how can you limit a user to device that Emby does not currently know about? How would this model actually work?
Punch 19 Posted June 27, 2020 Posted June 27, 2020 9 minutes ago, Happy2Play said: You can already sort of do this with User device access. But in the end it sounds more like limiting a user to logged into only one device at a time. But at the same time how can you limit a user to device that Emby does not currently know about? How would this model actually work? We're basically talking about the same control as the number of streams but for number of device log ins. So user X has "3" device logins. After which you get a similar message saying limit reached contact admin .....
Punch 19 Posted June 27, 2020 Posted June 27, 2020 This was put to a vote but it really should have been both adn call it a day
Happy2Play 9812 Posted June 27, 2020 Posted June 27, 2020 Still sounds like you are talking about something different then OP as your 3 devices would/could still require 3 premiere device slots. But still sounds like device access if you are restricting a user to specific device.
Punch 19 Posted June 27, 2020 Posted June 27, 2020 2 minutes ago, Happy2Play said: Still sounds like you are talking about something different then OP as your 3 devices would/could still require 3 premiere device slots. But still sounds like device access if you are restricting a user to specific device. No no, what he is talking about is User X can currently log into any amount of devices... we dont want to ony limit them to 1 device, but set a specifed number. User X "3", user Y "2" etc etc
Happy2Play 9812 Posted June 27, 2020 Posted June 27, 2020 So no control over what device, just a limit of how many devices. To me that is still somewhat covered on a stream limit as there are slim odds of any user watching 3 streams on the same device. But limiting premiere devices per users is still something different.
maxt.v 10 Posted June 27, 2020 Author Posted June 27, 2020 How hard is to add this to a server code: If allowed-devices > connected-devices then block-login, else dont-block login, endif.
Happy2Play 9812 Posted June 27, 2020 Posted June 27, 2020 2 minutes ago, maxt.v said: How hard is to add this to a server code: If allowed-devices > connected-devices then block-login, else dont-block login, endif. But that is what User access does. Dashboard-Users-the user-Access-Device Access
maxt.v 10 Posted June 27, 2020 Author Posted June 27, 2020 ebr: that does not limit the devices login that counts on emby-premiere suscription xbox login and iphone login consumes and slot on login not on playing content few words: an user with 5 xbox and 1 simultaneous stream consumes 5 slots for emby premiere 5 iphones with 1 simultaneous stream consumes 5 slots for emby premiere
maxt.v 10 Posted June 27, 2020 Author Posted June 27, 2020 Happy2Play: it makes a lot of work daily checking if user got login on another device, rename the device, delete the device, block user to not login on another device, what I ask is to limit user to login only in 1,2,3 or whatever devices, and before login the server check if devices limit reached.
ebr 16337 Posted June 27, 2020 Posted June 27, 2020 Hi. We are primarily designed as a home media server so it is not really anticipated that you have people you cannot just talk to and say "Hey, please don't use so many devices" or "Don't give out your login credentials to others". We may have more control of these types of things in the future but, for now, we have extended device plans if you have users you cannot control. Thanks.
Happy2Play 9812 Posted June 27, 2020 Posted June 27, 2020 So simultaneous logins. So said user can not be login into more the x amount of devices. But since devices hold a premiere slot for x amount of time it really doesn't matter.
maxt.v 10 Posted June 27, 2020 Author Posted June 27, 2020 ebr: So, buy more spaces, I don't care if you can't control who logs to your server. In this case, you should do more clear on devices in use, for example, a list of devices consuming my premiere license.
maxt.v 10 Posted June 27, 2020 Author Posted June 27, 2020 Happy2Play: if user can't login it will not consume slot of Premiere suscription. Of course it matters, since if user had 1 device allowed and allready ussed he can't login on another device
ebr 16337 Posted June 27, 2020 Posted June 27, 2020 Hi. If you are using your server in a manner other than for just your family and very close friends then we have device plans more suited to that (as long as it in compliance with our TOS). Thanks.
maxt.v 10 Posted June 27, 2020 Author Posted June 27, 2020 Oh, I forgot to tell, when you login on the web-bassed(I'm ussing google chrome) it counts as device, for example, I have 1 cellphone, 1 laptop and 1 desk, it consumes 3 devices, no matter if I play or not any stream on it. Basically, If any of my users log on web-bassed they consumes a slot, and this is the response from billing deppartment: Hi Thomas V., You had a lot of devices in use. They will roll off the count within a week if you don't still have that many devices. https://github.com/MediaBrowser/Wiki/wiki/Is-there-a-limit-to-Emby-Premiere Thanks, The Emby Team
Punch 19 Posted June 27, 2020 Posted June 27, 2020 33 minutes ago, Happy2Play said: So simultaneous logins. So said user can not be login into more the x amount of devices. But since devices hold a premiere slot for x amount of time it really doesn't matter. Oh is that right ? Nice, how long ?
ebr 16337 Posted June 27, 2020 Posted June 27, 2020 10 hours ago, maxt.v said: when you login on the web-bassed(I'm ussing google chrome) it counts as device, That is incorrect. Browsers do not count against your limit. Is there a limit to Emby Premiere
damien_c2 7 Posted January 22, 2021 Posted January 22, 2021 (edited) Im also voting for this feature. it realy hard for me to manage device premier slot. Yes im telling my family to only use on 1 device but as soon i dont check they install in 2nd device and 3rd etc and i cannot lock device since they use browser. Edited January 22, 2021 by damien_c2
Georg22 2 Posted November 25, 2021 Posted November 25, 2021 hallo ich habe eine frage ich habe 45 Geräte erreicht mit 28 benutzer ich werde jetzt upgraden auf 75 Geräte aber was mach ich dann wenn ich die 75 Geräte auch erreicht habe kann ich z.b für 100 oder 150 geräte kaufen oder so ein sonder option. oder z.b wenn ich bei Jeden kauf 75 +75 kaufe bekomme ich dann 150 geräte ???? ja/nein
neik 874 Posted November 25, 2021 Posted November 25, 2021 26 minutes ago, Georg22 said: oder z.b wenn ich bei Jeden kauf 75 +75 kaufe bekomme ich dann 150 geräte ???? ja/nein Nein. Bei mehr musst du dich individuell an den Support melden, die machen dann wohl ein individuelles Angebot. 1
