Stlrsnk2 0 Posted June 26, 2020 Posted June 26, 2020 I’m having trouble with my account. apparently I have 2 usernames I only wanna use 1 everytime my server resets it kicks me out and I’m not sure which one is which . It’s getting all mixed up please help
Stlrsnk2 0 Posted June 27, 2020 Author Posted June 27, 2020 Who do I talk to about having multiple accounts I need just 1 linked to my email and the other one is messing stuff up.
Stlrsnk2 0 Posted June 27, 2020 Author Posted June 27, 2020 (edited) When I open my emby app I have no server to choose. I’m doing my pin code at Emby media pin that it tells me to to when I select log in with connect but for some reason the only username and passsword it will take is not the one I need. I do not know how to fix this Edited June 27, 2020 by Stlrsnk2
pir8radio 1313 Posted June 27, 2020 Posted June 27, 2020 it sounds like you pay someone to use their server? You are not trying to access your own emby server that you setup with your own media on it. This is the forums for the company that makes the server software. you need to reach out to the people you are paying to use their server system. If I understood you correctly... otherwise sorry, and ignore this.
