shdwkeeper 15 Posted June 26, 2020 Posted June 26, 2020 I'm running Emby server latest 4.4.3 on a Qnap TVS672x, behind a pfsense firewall. Can not get port forwarding to work on Emby no matter what port. Emby works fine locally, using the browser with internalip:8096. Port 8096 is open on the firewall. Allow remote connections is enabled in Emby. I know port forwarding is working on pfsense, i can access the Qnap and Channels DVR perfectly fine remotely. When i ran canyouseeme and port checkers, Channels DVR and Qnap were open but 8096 was closed. I even closed Channels DVR, changed Emby to the port number of Channels, and now the port is closed again. Changed all the ports back to original and opened Channels DVR and now the port is open again. Thoughts?
Luke 42241 Posted June 26, 2020 Posted June 26, 2020 Hi, are you sure emby server is running when you try this?
shdwkeeper 15 Posted June 26, 2020 Author Posted June 26, 2020 Now its working, no idea why it wasn't. It all of sudden just started working, weird. Anyway, sometimes tech does this to all of us.
