Geek0601 0 Posted June 26, 2020 Posted June 26, 2020 I have a mu3 playlist in the playlist the url is redirected to the stream emby does not want to play the first url but has no issue playing the redirected url. I would like to figure a way out that emby will redirect to the correct url. VLC has no issue with the m3u playlist just emby. Example http://first-url.net:80 http://ip-of-redirected-url
Luke 42244 Posted June 26, 2020 Posted June 26, 2020 Hi, are you not able to just give it the redirected url? Please attach the emby server log. Thanks.
Geek0601 0 Posted June 26, 2020 Author Posted June 26, 2020 This is one of the redirect url's. http://172.98.93.146:25461/horrorar/NXX1UFLCZM/101524?token=QxsKBEAOFA1DCQMDVlNVDFUGVVJZBwwPUwNXU1BSBlMICwRdBwQDAFATG0QXFhdQAF48WgVDAwYAAlQEUhgXEUtcEDpaAhQNQwQDUFJXUhdNERdaDAQbDQEGWAVXDQBXCglOR0MPUhVbEwVeVFBcF00RBksVBEtZUV8+UgNCXAddG1gLRgpaG0NeWTkABwhUD1dBCUNRGxsSWhJGRA5bEVRVTkdRD0JFAEVSRF5AVgxXAkEfQwJWQl5HE09EDhcxaxtOR1YeQlIPQl4JCkBfFxVAQR9DCEpoQlYSQhRRVAldS0BfEVYUG0NcVh47AQpbD1YARwgOV0QSCUMHRBgXCVdXCxFcFGlHCFUVXEZWVgZVER4= embyserver.txt
Geek0601 0 Posted June 26, 2020 Author Posted June 26, 2020 The tokens on the live stream change that is why I have the url redirect to the current live stream.
Luke 42244 Posted July 5, 2020 Posted July 5, 2020 Did you configure a custom user agent for your m3u tuner?
