fishlmao 2 Posted June 26, 2020 Posted June 26, 2020 I have this problem where the seasons themselves have correct meta data, while the episodes have some issues. For example In season 1, the episodes have correct metadata, but in season 2, the episodes have the same metadata of season 1 episodes. Im still new to this so my folder structure might be broken? Anime\Overlord\Season 2\Overlord II S02E01.mp4 Anime\Overlord\Season 3\Overlord III S03E01.mkv Anime being root folder Ive refreshed, scan lib files, deleted nfos and images, and refreshed, scan lib files again, but they still do that. Any help would be nice, Thanks in advance Images as example: Season 2 (I have no season 1 of overlord) Season 3
ebr 16310 Posted June 26, 2020 Posted June 26, 2020 Hi. Are there any nfo files with the episodes? If so, what is in them?
fishlmao 2 Posted June 28, 2020 Author Posted June 28, 2020 On 6/26/2020 at 9:13 PM, ebr said: Hi. Are there any nfo files with the episodes? If so, what is in them? Yes, thank you for replying Heres season.nfo for 2 seasons, omitting the <plot><outline> as theyre correct anyways Overlord S2 Overlord S3 Im noticing that they have the same premiered As for episodes, im picking s2e01 (left) and s3e01 (right) .... s2 files are mp4 and s3 are mkv, but still, i can notice that the tvdbid for both are the same For s3e01 S2E01 https://pastebin.com/bdsUrTN7 S3E01 https://pastebin.com/iSJgCe1L
Carlo 4561 Posted June 28, 2020 Posted June 28, 2020 I have a feeling it's a naming issue. Instead of this: Anime\Overlord\Season 2\Overlord II S02E01.mp4 Anime\Overlord\Season 3\Overlord III S03E01.mkv Overlord II & Overlord III are a bit strange. Could you try this instead which would fit our suggested naming convention: Anime\Overlord (2007)\Season 2\Overlord - S02E01 - The Dawn of Despair.mp4 Anime\Overlord (2007)\Season 3\Overlord - S03E01 - A Ruler's Melancholy.mkv Remove any NFO and graphic files keeping just your media. FileBot (https://www.filebot.net/) makes this super simple to rename files which is what I used for the above file names.
Happy2Play 9802 Posted June 28, 2020 Posted June 28, 2020 Only thing I can think of would be bad cached metadata, as I can not reproduce with original naming scheme. What providers do you have enabled on the library and what order?
fishlmao 2 Posted June 29, 2020 Author Posted June 29, 2020 5 hours ago, Happy2Play said: Only thing I can think of would be bad cached metadata, as I can not reproduce with original naming scheme. What providers do you have enabled on the library and what order? i have deleted the entire cached metadata folder i have the anime plugin, and ticked their checkboxes across settings, but i put tvdb as high priority whenever possible after deleting the cached metadata folder, it worked itself out somehow, i am very thankful for the support 2
Carlo 4561 Posted June 29, 2020 Posted June 29, 2020 Was this media on a GDrive or local drive? What did you change?
fishlmao 2 Posted June 29, 2020 Author Posted June 29, 2020 9 hours ago, cayars said: Could you try this instead which would fit our suggested naming convention: Anime\Overlord (2007)\Season 2\Overlord - S02E01 - The Dawn of Despair.mp4 Anime\Overlord (2007)\Season 3\Overlord - S03E01 - A Ruler's Melancholy.mkv Remove any NFO and graphic files keeping just your media. FileBot (https://www.filebot.net/) makes this super simple to rename files which is what I used for the above file names. i deleted the nfo and graphics over and over and changed naming a few times then i noticed that its the same everytime, and i thought maybe it is cache, so when i deleted the cache it sorted itself out > i use my own python scripts for the renaming and deleting of files hahahaha
fishlmao 2 Posted June 29, 2020 Author Posted June 29, 2020 2 minutes ago, cayars said: Was this media on a GDrive or local drive? What did you change? local sir just went with the Overlord II S02E01, and delete cache
Happy2Play 9802 Posted June 29, 2020 Posted June 29, 2020 They were not a common naming scheme, but I used your original episode naming with out issue. But in the end it sounds like corrupted/bad cached provider metadata was the issue. You technically only need to delete the specific provider id folder for the series that was having issues, but deleting the entire cache doesn't hurt anything. Emby will just query all providers again.
