JSopha 6 Posted July 18, 2020 Posted July 18, 2020 1 hour ago, Saarfranzos said: I'm not quite shure. there has been different causes. First Ifound that I had a wrong dns-server information in my synology. Then I reinstalled the metadata-scrapers, first without result. And then in two steps I could rescan the database. No idea, if the Emby-guys have changed something in the system. Good luck for your rescan... How did you reinstall the metadata scrapers.... If I uninstall, I cannot load the catalog to reinstall...
MrHMMD 2 Posted July 19, 2020 Author Posted July 19, 2020 14 hours ago, JSopha said: How did you reinstall the metadata scrapers.... If I uninstall, I cannot load the catalog to reinstall... that would have been my next question ... but why not use the witer approach? Since my emby is unusable anyway, I will uninstall all plugins and see if that helps. report follows ...
Luke 42243 Posted July 23, 2020 Posted July 23, 2020 For those interested in testing new things: Thanks.
