antiqued4 1 Posted June 24, 2020 Posted June 24, 2020 (edited) Hi guys, I'm trying to add a series, Chernobyl. Create the folder as follows. TV> Chernobyl 2019. Inside there are the files, example: Chernobyl.S01E01.mkv In the emby I created the type "Serie", I added the path, all right, but when I go to watch, don't download any given goal, the folder is empty, no episode appears. They only appear if I change from "Serie" to "EPISODES: Follow print. Edited June 24, 2020 by antiqued4
Solution Gilgamesh_48 1243 Posted June 24, 2020 Solution Posted June 24, 2020 (edited) Your naming is wrong. The year is not needed in the folder name because "Chernobyl" is unique but it is OK to include it however it needs to be in parenthesis. Try the following - - - - - - - TV Shows <- The TV library points here _______Chernobyl (optional year) ____________Season 01 __________________Chernobyl - S01E01 - 1_23_45.mkv and so on for each episode. - - - - - - - You might make the naming you have work for some shows but Emby would not match shows in that format reliably. Note: everything after the second dash "-" is optional. Edited June 24, 2020 by Gilgamesh_48
pwhodges 2028 Posted June 24, 2020 Posted June 24, 2020 If you omit the season folder from the hierarchy Emby will sort it out in the end, but at first you won't see the season poster with the episodes listed behind it. Paul
daedalus 434 Posted June 24, 2020 Posted June 24, 2020 (edited) season folder is recommended, but not mandatory https://support.emby.media/support/solutions/articles/44001159110-tv-naming For example: \TV \Glee (2009) \Season 1 Glee S01E01.mp4 Glee S01E02.mp4 \TV \Seinfeld (1989) Seinfeld S01E01.mp4 Seinfeld S01E02.mp4 main problem would be probably the missing parentheses for the year, so emby is searching for a series named "Chernobyl 2019" but without a log file its pretty hard to check back only devs can answer how sensitive emby is to deviations here Edited June 24, 2020 by daedalus
antiqued4 1 Posted June 24, 2020 Author Posted June 24, 2020 Hello guys, I removed the 2019 I just left Chernobyl, inside the folder I created a call Season01, and apparently everything worked out, I also managed in the same way creating with a folder of the type "Mixed Content", that way I didn't need the Season folder, very thank you all @daedalus, @pwhodges, @Gilgamesh_48
