Kyuss 0 Posted June 24, 2020 Posted June 24, 2020 Hi, I am struggling with emby behind a reverse proxy with apache2 on debian. I used the configuration in this topic: https://emby.media/community/index.php?/topic/40461-emby-server-with-apache-reverse-proxy/ here is my emby.conf located in /etc/apache2/site-available/ : <IfModule mod_ssl.c> <VirtualHost *:80> ServerName nas-emby.myvnc.com ServerAdmin mon@email.fr RewriteEngine on RewriteCond %{SERVER_NAME} =nas-emby.myvnc.com RewriteRule ^ https://%{SERVER_NAME}%{REQUEST_URI} [END,QSA,R=permanent] </VirtualHost> <VirtualHost *:443> ServerName nas-emby.myvnc.com ServerAdmin mon@email.fr <proxy *> AddDefaultCharset off Order Allow,Deny Allow from all </proxy> ProxyRequests Off ProxyPreserveHost On ProxyPass "/embywebsocket" "ws://127.0.0.1:8096/embywebsocket" ProxyPassReverse "/embywebsocket" "ws://127.0.0.1:8096/embywebsocket" ProxyPass "/" "http://127.0.0.1:8096/" ProxyPassReverse "/" "http://127.0.0.1:8096/" Include /etc/letsencrypt/options-ssl-apache.conf SSLCertificateFile /etc/letsencrypt/live/nas-emby.myvnc.com/fullchain.pem SSLCertificateKeyFile /etc/letsencrypt/live/nas-emby.myvnc.com/privkey.pem </VirtualHost> </IfModule> I can connect with any web browser outside/inside my local network without any errors. But with the android app i have the message "Invalid login/password" In emby's log i have : Error HttpServer: Access token is invalid or expired. Kodi and Android app works fine in my local network and if i don't disconnect from android app, out of my local network it still work. I don't know what's wrong in my apache2 or why i have this error. Someone could help ? Thanks embyserver.txt
Luke 42246 Posted June 24, 2020 Posted June 24, 2020 How about the online web app using https://app.emby.media ?
Kyuss 0 Posted June 24, 2020 Author Posted June 24, 2020 Thanks for your replies For the certificates I use certbot for 3 domain name, one for nextcloud, one for transmission and one for emby. My domain name for emby and transmission are cname redirecting on nextcloud. I just used this command: certbot renew --dry-run just to be shure they are updated and no error returned. How can i provide more informations about it ? I tried to connect using https://app.emby.media but it didn't work, it can't find my server.
Luke 42246 Posted June 24, 2020 Posted June 24, 2020 2 hours ago, Kyuss said: Thanks for your replies For the certificates I use certbot for 3 domain name, one for nextcloud, one for transmission and one for emby. My domain name for emby and transmission are cname redirecting on nextcloud. I just used this command: certbot renew --dry-run just to be shure they are updated and no error returned. How can i provide more informations about it ? I tried to connect using https://app.emby.media but it didn't work, it can't find my server. What do you mean by "can't find my server" ? You're right, the web app can't find your server because web apps aren't able to do that. You need to connect to your server by entering connection info.
Kyuss 0 Posted June 24, 2020 Author Posted June 24, 2020 I go to https://app.emby.media/ then i use my Emby Connect to log on, then it ask me to add a new server, i enter my server information ( i leave port number blank) then: I tried to go in emby server settings on my profil, i added to my profil my emby connect username. After doing that my server appear in the connection screen (maybe because i already added the server ?) but same error. The server is online. i don't see any error in the logs about https://app.emby.media/ embyserver.txt
Luke 42246 Posted June 24, 2020 Posted June 24, 2020 2 minutes ago, Kyuss said: I go to https://app.emby.media/ then i use my Emby Connect to log on, then it ask me to add a new server, i enter my server information ( i leave port number blank) then: I tried to go in emby server settings on my profil, i added to my profil my emby connect username. After doing that my server appear in the connection screen (maybe because i already added the server ?) but same error. The server is online. i don't see any error in the logs about https://app.emby.media/ embyserver.txt 1.24 MB · 0 downloads Have you setup https with your server? If not then you may need to use http://app.emby.media instead
Kyuss 0 Posted June 24, 2020 Author Posted June 24, 2020 Same error, i'm doing it on my local network.
Luke 42246 Posted June 24, 2020 Posted June 24, 2020 Most likely the browser is rejecting your certificate. Where did the SSL certificate come from?
Kyuss 0 Posted June 24, 2020 Author Posted June 24, 2020 (edited) The only certificate I have is from let's encrypt using certbot, in my apache2 conf at the end of it, you have the path to the certificate. I didn't convert it to a PKCS #12 and didn't added the path in emby network configuration. my domain name is from no-ip Edit: when i naviguate to : nas-emby.myvnc.com i copy paste the url after my connection and i have: https://nas-emby.myvnc.com/web/index.html#!/home it use https Edited June 24, 2020 by Kyuss
Kyuss 0 Posted June 24, 2020 Author Posted June 24, 2020 Ok sorry i found my mistake... i was using nas-emby.myvnc.com instead of https://nas-emby.myvnc.com It work on android and I installed kodi on my laptop and it work too. Sorry for the unnecessary topic.
