muzicman0 85 Posted June 25, 2020 Author Posted June 25, 2020 That worked. I had clicked update from within the EmbyCon information screen, but that didn't work. This did. Again, thanks. I will test it out.
muzicman0 85 Posted June 25, 2020 Author Posted June 25, 2020 While I have you, is there anyway to get it to refresh (Loading...) less? Seems like it is everytime I go in, or come out of a folder, and then sometimes (often) even when I don't make any navigation. If not, no worries, it just freezes the whole UI for 3-4 seconds (sometimes a little longer).
TeamB 2440 Posted June 25, 2020 Posted June 25, 2020 The way the dynamic reloading works is this: when a path has been viewed before it uses that data it then checks in the background if anything has changed and saved the changed data if something has changed then it triggers a refresh using the new data if nothing has changed then no refresh is triggered The idea is if you are just browsing around then it is much faster but if you are making changes, playing items, marking items as watched etc then you will see refreshing being triggered for these actions. If you are seeing lots of reloading then you can turn this off in the advanced settings EmbyCon->Settings->Advanced->Cache server requests
muzicman0 85 Posted June 25, 2020 Author Posted June 25, 2020 Forgot to report back, 1.9.93 fixed the issue I had. Thanks. I'll try the change you mentioned and see if that refreshes less with my work flow.
