Happy2Play 9811 Posted January 1, 2021 Posted January 1, 2021 Everything will change for Music in 4.6+ as structure will become irrelevant. The first image shown above would suggest a loose track changing a folder level to a album and absorbing everything below it.
FlapZappa 0 Posted January 1, 2021 Posted January 1, 2021 I did try some experimentation and by dragging the zappa folder up a level it did seem to cure the problem without an need to change any folder or file names or metadata. from F:\Media\music\Albums\Frank Zappa to F:\Media\music\Frank Zappa not sure why that should be as every other album is in the music folder at least 4 levels down from the root directory.
Happy2Play 9811 Posted January 1, 2021 Posted January 1, 2021 46 minutes ago, FlapZappa said: I did try some experimentation and by dragging the zappa folder up a level it did seem to cure the problem without an need to change any folder or file names or metadata. from F:\Media\music\Albums\Frank Zappa to F:\Media\music\Frank Zappa not sure why that should be as every other album is in the music folder at least 4 levels down from the root directory. If is hard to say without knowing exact content per level. But as mentioned this will all change in 4.6+ as Emby will be tag dependent not structure. So pros and cons.
Luke 42239 Posted January 3, 2021 Posted January 3, 2021 Yes you can follow along on that here: Thanks.
