Thank you a thousand times pwhodges! The words 'loopback' and 'hairpin' were key. My router is dumb and isn't able to do such fancy things, however there is a work around for garbage routers.
You need to find 'DNS host mapping' for Zycel C3000Z its under advanced -> wan settings. Then enter
DNS host name: <mydomain>.com
IP address: <internal IP of server emby runs on>
and set domain name: (check 'enabled')
This makes it work perfectly from inside the network as well.
