GrotShot 28 Posted October 10, 2013 Posted October 10, 2013 MBS Version 3.0.5029.36830 Local TV ratings are still an issue for me as previously reported. The server keeps changing ratings to US from GB. I have local metadata saved and Country set as United Kingdom. The scenario was: Boot HTPC Browse Library with MBS Notice series showing as TV-MA etc. Check series.xml which contains TV-MA Edit series in MBS and change Custom Rating to GB-18 from combo box Save Refresh This then gets me to the first image which has no rating Close the browser and re-open the Browse Library Go to show just edited and back as showing TV-MA even though series.xml now has GB-18 in it.
Cheesegeezer 3106 Posted October 10, 2013 Posted October 10, 2013 (edited) in your metadata settings on MBS you need to change both settings Preferred language - English Country - United Kingdom It should work ok then, if not clear your cash and do a rescan. It could be that there is no GB ratings for those shows. Edited October 10, 2013 by Cheesegeezer
Solution ebr 16354 Posted October 10, 2013 Solution Posted October 10, 2013 The problem is the tvdb does not have any support for ratings systems other than US. So, at this time, if you want other ratings on your TV you will need to update them manually and turn off internet metadata fetching for TV. Also, the Custom Rating field is never displayed. It is used for Parental Controls only. That is by design.
GrotShot 28 Posted October 10, 2013 Author Posted October 10, 2013 EBR - I noticed that I was using the wrong rating when I explored the library and it is called Official Rating in there but Parental Rating in MBS. I've edited the ratings to the correct GB and turned off metadata fetching for Parental Rating. I'll see what happens, thanks.
