ManiacKill 0 Posted June 20, 2020 Posted June 20, 2020 if I crash under Movies in the recently added folder Kodi always crashes for me !
TeamB 2440 Posted June 20, 2020 Posted June 20, 2020 is it a kodi crash or an EmbyCon add-on error? Log files might help.
ManiacKill 0 Posted June 20, 2020 Author Posted June 20, 2020 Hi, kodi crashes kpl, the loading bar appears and restarts after about 1 minute. Only when I do it under Emby Libraries/Movies Recently under Costom Widgets/Movies Recently it works.
ManiacKill 0 Posted June 21, 2020 Author Posted June 21, 2020 can i create a log only for embycon ? If the debug mode is active, you can only see if I go to the folder that the memory kpl goes to 0 and then restarts !
TeamB 2440 Posted June 21, 2020 Posted June 21, 2020 If it is a Kodi crash then there is not a lot I can do about it, the addon should not be able to crash Kodi. What version of Kodi are you running?
ManiacKill 0 Posted June 21, 2020 Author Posted June 21, 2020 I have the version Libreelec 9.2.1 but already about 2 months
TeamB 2440 Posted June 21, 2020 Posted June 21, 2020 For Kodi crashes you should post on the Kodi forum
