CyberPoison 33 Posted June 17, 2020 Posted June 17, 2020 Hi i have some issues with trakt.tv in my logs this is the output 2020-06-17 18:27:38.887 Error Trakt: Error sending scrobble *** Error Report *** Version: 4.5.0.13 Command line: /app/emby/EmbyServer.dll -programdata /config -ffdetect /app/emby/ffdetect -ffmpeg /app/emby/ffmpeg -ffprobe /app/emby/ffprobe -restartexitcode 3 Operating system: Unix 4.15.0.101 64-Bit OS: True 64-Bit Process: True User Interactive: True Runtime: file:///app/emby/System.Private.CoreLib.dll System.Environment.Version: 3.1.2 Processor count: 12 Program data path: /config Application directory: /app/emby MediaBrowser.Model.Net.HttpException: MediaBrowser.Model.Net.HttpException: Unauthorized at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsyncInternal(HttpRequestOptions options, String httpMethod) at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsync(HttpRequestOptions options, String httpMethod) at Trakt.Api.TraktApi.<>c__DisplayClass34_0.<<PostToTrakt>b__0>d.MoveNext() --- End of stack trace from previous location where exception was thrown --- at Trakt.Api.TraktApi.Retry[T](Func`1 function) at Trakt.Api.TraktApi.PostToTrakt(String url, Object data, CancellationToken cancellationToken, TraktUser traktUser) at Trakt.Api.TraktApi.RefreshUserAuth(TraktUser traktUser, CancellationToken cancellationToken) at Trakt.Api.TraktApi.SetRequestHeaders(HttpRequestOptions options, TraktUser traktUser, CancellationToken cancellationToken) at Trakt.Api.TraktApi.PostToTrakt(String url, Object data, CancellationToken cancellationToken, TraktUser traktUser) at Trakt.Api.TraktApi.SendMovieStatusUpdateAsync(Movie movie, MediaStatus mediaStatus, TraktUser traktUser, Single progressPercent, CancellationToken cancellationToken) at Trakt.ServerMediator.KernelPlaybackStopped(Object sender, PlaybackStopEventArgs e) Source: Emby.Server.Implementations TargetSite: Void MoveNext() I'm using the latest emby beta version. Kind regards
CyberPoison 33 Posted June 17, 2020 Author Posted June 17, 2020 FALSE ALLERT, WORKING GREAT AFTER NEW PIN. Please mark this post as closed.
keitpark 1 Posted December 5, 2021 Posted December 5, 2021 I am having a similar issue. Trakt will update what is watched when I do the scheduled tasks for the Trakt plugin, but will not scrobble. I think the issue occurred when I switched to Kodi (using the Emby plugin) and the Kodi Trakt addon. Going back to Emby it no longer scrobbles. I have tried deleted the plugin and getting a new PIN but same issue. I've also removed any Emby and Kodi connected apps. Not seeing a whole lot related to Trakt in the log. I've attached the embyserver file. I hope that helps. 2021-12-05 12:44:56.786 Info Trakt: Playback Started embyserver (1).txt
Luke 42246 Posted December 20, 2021 Posted December 20, 2021 On 12/5/2021 at 3:54 PM, keitpark said: I am having a similar issue. Trakt will update what is watched when I do the scheduled tasks for the Trakt plugin, but will not scrobble. I think the issue occurred when I switched to Kodi (using the Emby plugin) and the Kodi Trakt addon. Going back to Emby it no longer scrobbles. I have tried deleted the plugin and getting a new PIN but same issue. I've also removed any Emby and Kodi connected apps. Not seeing a whole lot related to Trakt in the log. I've attached the embyserver file. I hope that helps. 2021-12-05 12:44:56.786 Info Trakt: Playback Started embyserver (1).txt 39.73 MB · 0 downloads @keitpark HI, please try removing the Samsung Smart Things plugin, then restarting the server and see if that helps. Thanks.
keitpark 1 Posted December 20, 2021 Posted December 20, 2021 That did the trick. Never would have thought another plugin was the issue.
chef 3811 Posted December 20, 2021 Posted December 20, 2021 (edited) I'll look at the plugin. Are we sharing a plugin ID or something? Who wrote the trakt plugin? @Luke Edited December 20, 2021 by chef
Luke 42246 Posted December 20, 2021 Posted December 20, 2021 2 hours ago, chef said: I'll look at the plugin. Are we sharing a plugin ID or something? Who wrote the trakt plugin? @Luke Actually I pulled you in to look at the smarthtings errors in his log. 1
chef 3811 Posted December 21, 2021 Posted December 21, 2021 (edited) I've applied fixes the Samsung Plugin, and added a new revision to the catalog. It shouldn't cause any more problems Edited December 21, 2021 by chef 1 1
