fede91it 0 Posted June 17, 2020 Posted June 17, 2020 Although the connection to Trakt.tv is correctly configured, once episodes or movies are watched, Emby does not synchronize the status on Trakt.tv. Browsing the forum I read that many others have the same problem. Can we work on this? Thank you
Luke 42255 Posted June 18, 2020 Posted June 18, 2020 Hi there, please go over an example and attach the emby server log. thanks.
fede91it 0 Posted June 19, 2020 Author Posted June 19, 2020 I'm enclosing the logs, I guess this is the file, otherwise tell me if I have to attach anything else. Concrete example: this morning I saw an anime episode, once finished Emby checked it as "displayed", but on Trakt there wasn't any synchronization and the episode still results "not watched". embyserver.txt
fede91it 0 Posted June 20, 2020 Author Posted June 20, 2020 I'm also enclosing today's logs, where I had enabled the debugging option in Emby embyserver.txt
Luke 42255 Posted June 20, 2020 Posted June 20, 2020 What example should we be looking at in these log files? What time?
fede91it 0 Posted June 21, 2020 Author Posted June 21, 2020 (edited) Look at this part, for example. From the logs it is evident that after the end of the episode with TvDB ID 4315551 Emby tries to communicate with Trakt but an error is generated. 2020-06-20 08:37:55.081 Debug Trakt: POST {"episode":{"ids":{"tvdb":4315551}},"progress":100,"app_version":"4.4.3.0","app_date":"2020-06-20"} 2020-06-20 08:37:55.081 Info HttpClient: POST https://api.trakt.tv/oauth/token 2020-06-20 08:37:55.126 Info HttpServer: HTTP GET http://192.168.8.100:8096/emby/Users/7dd1892c421148c18b2e220eee62b46c/Items/9295?format=json. UserAgent: Dalvik/2.1.0 (Linux; U; Android 7.1.2; AFTMM Build/NS6271) 2020-06-20 08:37:55.151 Info HttpServer: HTTP Response 200 to 192.168.8.177. Time: 25ms. http://192.168.8.100:8096/emby/Users/7dd1892c421148c18b2e220eee62b46c/Items/9295?format=json 2020-06-20 08:37:55.189 Info HttpServer: HTTP GET http://192.168.8.100:8096/emby/Shows/NextUp?Limit=1&UserId=7dd1892c421148c18b2e220eee62b46c&EnableTotalRecordCount=false&SeriesId=919&Fields=Overview&format=json. UserAgent: Dalvik/2.1.0 (Linux; U; Android 7.1.2; AFTMM Build/NS6271) 2020-06-20 08:37:55.194 Info HttpServer: HTTP Response 200 to 192.168.8.177. Time: 5ms. http://192.168.8.100:8096/emby/Shows/NextUp?Limit=1&UserId=7dd1892c421148c18b2e220eee62b46c&EnableTotalRecordCount=false&SeriesId=919&Fields=Overview&format=json 2020-06-20 08:37:55.525 Info HttpServer: HTTP GET http://192.168.8.100:8096/emby/Users/7dd1892c421148c18b2e220eee62b46c/Items/9295?format=json. UserAgent: Dalvik/2.1.0 (Linux; U; Android 7.1.2; AFTMM Build/NS6271) 2020-06-20 08:37:55.531 Info HttpServer: HTTP Response 200 to 192.168.8.177. Time: 6ms. http://192.168.8.100:8096/emby/Users/7dd1892c421148c18b2e220eee62b46c/Items/9295?format=json 2020-06-20 08:37:55.858 Info HttpServer: HTTP GET http://192.168.8.100:8096/emby/Users/7dd1892c421148c18b2e220eee62b46c/Items/9295?format=json. UserAgent: Dalvik/2.1.0 (Linux; U; Android 7.1.2; AFTMM Build/NS6271) 2020-06-20 08:37:55.865 Info HttpServer: HTTP Response 200 to 192.168.8.177. Time: 6ms. http://192.168.8.100:8096/emby/Users/7dd1892c421148c18b2e220eee62b46c/Items/9295?format=json 2020-06-20 08:37:55.899 Info HttpClient: POST https://api.trakt.tv/oauth/token 2020-06-20 08:37:55.921 Info HttpServer: HTTP POST http://192.168.8.100:8096/emby/Items/9295/PlaybackInfo?format=json. UserAgent: Dalvik/2.1.0 (Linux; U; Android 7.1.2; AFTMM Build/NS6271) 2020-06-20 08:37:55.923 Debug MediaInfoService: GetPostedPlaybackInfo request: {"Id":"9295","UserId":"7dd1892c421148c18b2e220eee62b46c","MaxStreamingBitrate":80000000,"StartTimeTicks":0,"MaxAudioChannels":8,"DeviceProfile":{"Name":"Android-Exo","EnableAlbumArtInDidl":false,"EnableSingleAlbumArtLimit":false,"EnableSingleSubtitleLimit":false,"SupportedMediaTypes":"Audio,Photo,Video","MaxAlbumArtWidth":0,"MaxAlbumArtHeight":0,"MaxStreamingBitrate":110000000,"MusicStreamingTranscodingBitrate":128000,"TimelineOffsetSeconds":0,"RequiresPlainVideoItems":false,"RequiresPlainFolders":false,"IgnoreTranscodeByteRangeRequests":false,"XmlRootAttributes":[],"DirectPlayProfiles":[{"Container":"m4v,mov,xvid,vob,mkv,wmv,asf,ogm,ogv,mp4,webm,m4a,fmp4,ogg,flv,flac","AudioCodec":"aac,mp3,mp2,pcm_s16le,pcm_s24le,pcm_s32le,opus,aac_latm,mp4a_latm,ac3,eac3","VideoCodec":"h264,hevc,vp8,vp9,mpeg,mpeg2video","Type":"Video"},{"Container":"aac,mp3,mpa,wav,wma,mp2,ogg,oga,webma,ape,opus,flac","Type":"Audio"},{"Container":"jpg,jpeg,png,gif","Type":"Photo"}],"TranscodingProfiles":[{"Container":"ts","Type":"Video","VideoCodec":"h264,mpeg2video,hevc,h265","AudioCodec":"aac_latm,mp4a_latm,ac3,eac3,aac,mp3","Protocol":"hls","EstimateContentLength":false,"EnableMpegtsM2TsMode":false,"TranscodeSeekInfo":"Auto","CopyTimestamps":true,"Context":"Streaming","MinSegments":2,"SegmentLength":0,"BreakOnNonKeyFrames":true,"ManifestSubtitles":"vtt"},{"Container":"ts","Type":"Audio","AudioCodec":"aac","Protocol":"hls","EstimateContentLength":false,"EnableMpegtsM2TsMode":false,"TranscodeSeekInfo":"Auto","CopyTimestamps":false,"Context":"Streaming","MinSegments":0,"SegmentLength":0,"BreakOnNonKeyFrames":false}],"ContainerProfiles":[],"CodecProfiles":[{"Type":"Video","Conditions":[{"Condition":"EqualsAny","Property":"VideoProfile","Value":"high|main|baseline|constrained baseline","IsRequired":false},{"Condition":"LessThanEqual","Property":"VideoLevel","Value":"51","IsRequired":false},{"Condition":"LessThanEqual","Property":"Height","Value":"2160","IsRequired":false}],"ApplyConditions":[],"Codec":"h264"},{"Type":"Video","Conditions":[{"Condition":"EqualsAny","Property":"VideoProfile","Value":"Main|Main 10","IsRequired":false}],"ApplyConditions":[],"Codec":"hevc"},{"Type":"VideoAudio","Conditions":[{"Condition":"LessThanEqual","Property":"AudioChannels","Value":"8","IsRequired":false}],"ApplyConditions":[]},{"Type":"Video","Conditions":[{"Condition":"LessThanEqual","Property":"Height","Value":"2160","IsRequired":false}],"ApplyConditions":[]}],"ResponseProfiles":[],"SubtitleProfiles":[{"Format":"srt","Method":"Embed"},{"Format":"srt","Method":"External"},{"Format":"subrip","Method":"Embed"},{"Format":"subrip","Method":"External"},{"Format":"ass","Method":"Embed"},{"Format":"ssa","Method":"Embed"},{"Format":"ass","Method":"External"},{"Format":"ssa","Method":"External"},{"Format":"pgs","Method":"Embed"},{"Format":"pgssub","Method":"Embed"},{"Format":"dvdsub","Method":"Encode"},{"Format":"dvbsub","Method":"Embed"},{"Format":"vobsub","Method":"Encode"},{"Format":"dvb_teletext","Method":"Embed"},{"Format":"dvb_teletext","Method":"External"},{"Format":"dvb_subtitle","Method":"Embed"},{"Format":"vtt","Method":"Hls"},{"Format":"vtt","Method":"External"},{"Format":"ttml","Method":"Embed"},{"Format":"ttml","Method":"External"},{"Format":"tx3g","Method":"Embed"},{"Format":"tx3g","Method":"External"},{"Format":"sub","Method":"Encode"},{"Format":"idx","Method":"Encode"}]},"EnableDirectPlay":true,"EnableDirectStream":true,"EnableTranscoding":true,"AllowVideoStreamCopy":true,"AllowAudioStreamCopy":true,"IsPlayback":false,"AutoOpenLiveStream":true,"DirectPlayProtocols":["Http"]} 2020-06-20 08:37:55.927 Info MediaInfoService: User policy for Federico. EnablePlaybackRemuxing: True EnableVideoPlaybackTranscoding: True EnableAudioPlaybackTranscoding: True 2020-06-20 08:37:55.927 Info HttpServer: HTTP Response 200 to 192.168.8.177. Time: 6ms. http://192.168.8.100:8096/emby/Items/9295/PlaybackInfo?format=json 2020-06-20 08:37:56.212 Debug App: Begin Sending Alive Notifications For All Devices 2020-06-20 08:37:56.212 Debug App: Sending alive notification MediaServer - f4b72ed91c434f7995ad95a9ae882894 2020-06-20 08:37:56.213 Debug App: Sending alive notification MediaServer - f4b72ed91c434f7995ad95a9ae882894 2020-06-20 08:37:56.214 Debug App: Sending alive notification MediaServer - f4b72ed91c434f7995ad95a9ae882894 2020-06-20 08:37:56.214 Debug App: Sending alive notification ContentDirectory - f4b72ed91c434f7995ad95a9ae882894 2020-06-20 08:37:56.215 Debug App: Sending alive notification ContentDirectory - f4b72ed91c434f7995ad95a9ae882894 2020-06-20 08:37:56.215 Debug App: Sending alive notification ConnectionManager - f4b72ed91c434f7995ad95a9ae882894 2020-06-20 08:37:56.215 Debug App: Sending alive notification ConnectionManager - f4b72ed91c434f7995ad95a9ae882894 2020-06-20 08:37:56.216 Debug App: Completed Sending Alive Notifications For All Devices 2020-06-20 08:37:56.493 Info HttpServer: HTTP GET http://192.168.8.100:8096/emby/Users/7dd1892c421148c18b2e220eee62b46c/Items/resume?Filters=IsResumable&ImageTypeLimit=1&Fields=PrimaryImageAspectRatio%2COverview%2CCanDelete%2CItemCounts%2CDisplayPreferencesId%2CCriticRating%2CCommunityRating%2COfficialRating%2CPremiereDate%2CEndDate%2CProductionYear&sortOrder=Descending&SortBy=DatePlayed&MediaTypes=Video&EnableTotalRecordCount=false&recursive=true&Limit=30&CollapseBoxsetItems=false&format=json. UserAgent: Dalvik/2.1.0 (Linux; U; Android 7.1.2; AFTMM Build/NS6271) 2020-06-20 08:37:56.503 Info HttpServer: HTTP Response 200 to 192.168.8.177. Time: 10ms. http://192.168.8.100:8096/emby/Users/7dd1892c421148c18b2e220eee62b46c/Items/resume?Filters=IsResumable&ImageTypeLimit=1&Fields=PrimaryImageAspectRatio%2COverview%2CCanDelete%2CItemCounts%2CDisplayPreferencesId%2CCriticRating%2CCommunityRating%2COfficialRating%2CPremiereDate%2CEndDate%2CProductionYear&sortOrder=Descending&SortBy=DatePlayed&MediaTypes=Video&EnableTotalRecordCount=false&recursive=true&Limit=30&CollapseBoxsetItems=false&format=json 2020-06-20 08:37:56.576 Info HttpClient: POST https://api.trakt.tv/oauth/token 2020-06-20 08:37:56.739 Error Trakt: Exception handled sending status update *** Error Report *** Version: 4.4.3.0 Command line: C:\Users\fede9\AppData\Roaming\Emby-Server\system\EmbyServer.dll Operating system: Microsoft Windows NT 6.2.9200.0 64-Bit OS: True 64-Bit Process: True User Interactive: True Runtime: file:///C:/Users/fede9/AppData/Roaming/Emby-Server/system/System.Private.CoreLib.dll System.Environment.Version: 3.1.4 Processor count: 8 Program data path: C:\Users\fede9\AppData\Roaming\Emby-Server\programdata Application directory: C:\Users\fede9\AppData\Roaming\Emby-Server\system MediaBrowser.Model.Net.HttpException: MediaBrowser.Model.Net.HttpException: Unauthorized at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsyncInternal(HttpRequestOptions options, String httpMethod) at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsync(HttpRequestOptions options, String httpMethod) at Trakt.Api.TraktApi.<>c__DisplayClass34_0.<<PostToTrakt>b__0>d.MoveNext() --- End of stack trace from previous location where exception was thrown --- at Trakt.Api.TraktApi.Retry[T](Func`1 function) at Trakt.Api.TraktApi.PostToTrakt(String url, Object data, CancellationToken cancellationToken, TraktUser traktUser) at Trakt.Api.TraktApi.RefreshUserAuth(TraktUser traktUser, CancellationToken cancellationToken) at Trakt.Api.TraktApi.SetRequestHeaders(HttpRequestOptions options, TraktUser traktUser, CancellationToken cancellationToken) at Trakt.Api.TraktApi.PostToTrakt(String url, Object data, CancellationToken cancellationToken, TraktUser traktUser) at Trakt.Api.TraktApi.SendEpisodeStatusUpdateAsync(Episode episode, MediaStatus status, TraktUser traktUser, Single progressPercent, CancellationToken cancellationToken) at Trakt.ServerMediator.KernelPlaybackStopped(Object sender, PlaybackStopEventArgs e) Source: Emby.Server.Implementations TargetSite: Void MoveNext() Edited June 21, 2020 by fede91it
vdatanet 1619 Posted June 22, 2020 Posted June 22, 2020 Long ago I had the same issue. I deleted trakt config file and I configured again the plugin. You have authorization issues.
fede91it 0 Posted June 22, 2020 Author Posted June 22, 2020 Do you remember where this file to delete is?
vdatanet 1619 Posted June 22, 2020 Posted June 22, 2020 28 minutes ago, fede91it said: Do you remember where this file to delete is?
fede91it 0 Posted June 23, 2020 Author Posted June 23, 2020 Thank you, I deleted the file now it works properly!
miniliQuid 95 Posted June 24, 2020 Posted June 24, 2020 Hadn't taken the effort yet to look into this since installing trakt plugin. Have had the auth problem since installing the plugin but deleting trakt.xml and then replacing the pin worked.
BTerrell721 0 Posted September 16, 2020 Posted September 16, 2020 Any guidance as to where this trakt.xml plugin can be found when using the Emby plugin for Kodi? Struggling to find it but having the same problem connecting to Trakt, even after reinstalling plugin entirely.
Sab39 8 Posted September 17, 2020 Posted September 17, 2020 20 hours ago, BTerrell721 said: Any guidance as to where this trakt.xml plugin can be found when using the Emby plugin for Kodi? Struggling to find it but having the same problem connecting to Trakt, even after reinstalling plugin entirely. the key to doing this is stopping emby before deleting the xml. So stop Emby, go into Emby/plugins/configurations, then delete the xml, then restart the emby server, then go to the settings of the trakt plugin and reauthorize whichever account you need to work (all old authorizations are gone so you'll need to do it for each user).
