jsc1205 51 Posted June 15, 2020 Posted June 15, 2020 Noticed that when I tried to play a movie using Emby that has Dolby Atmos, I get no audio. I stopped the movie, went over to Plex and it played fine. Went back to Emby and all of a sudden it worked. Does Emby have issues playing MKV files with Dolby Atmos???
jsc1205 51 Posted June 15, 2020 Author Posted June 15, 2020 6 minutes ago, ebr said: Hi. What app were you using? Was using my Shield TV Pro (current release)
ebr 16310 Posted June 15, 2020 Posted June 15, 2020 If everything in the audio chain supports both the underlying audio and the atmos layer, then it will support it.
jsc1205 51 Posted June 15, 2020 Author Posted June 15, 2020 1 minute ago, ebr said: If everything in the audio chain supports both the underlying audio and the atmos layer, then it will support it. Yeah that's exactly what my thoughts are. But it was if no audio was detected at all because there was absolutely no sound at all. When I went over to Plex it played fine....did that to ensure I wasnt missing anything. When I went back over to Emby, it played fine. I checked another movie later on and exact same thing happened....then went to Plex, back to Emby and played fine.
ebr 16310 Posted June 15, 2020 Posted June 15, 2020 Can we please look at an example? A log from the app right after no audio is heard would be helpful. How to Report a Problem
