Mohammednt0 1 Posted June 14, 2020 Posted June 14, 2020 (edited) Good Day, problem.1 : Manual Subtitle Downloads dose not work, i followed this tutorial but still it doesn't work, i always get this error, (i'm using opensubtitles plugin) Quote There was an error processing the request. Please try again later. Problem.2: i also noticed something strange the search function sometimes work and sometimes doesn't ! in other words: when i try to search for subtitles for a specific movie and click search emby will find many subtitles, after few minutes i go back to that same movie and i try again to search for subtitles and emby will find nothing !, and message will show-up says Quote No results found. Have you configured subtitle downloading? i did configure the subtitle downloading, any idea on how to solve these 2 problems? Regards, Mohammednt0 Edited June 14, 2020 by Mohammednt0
rechigo 367 Posted June 14, 2020 Posted June 14, 2020 It's hard to tell with just the information given as it could be a variety of things causing it. Would you be able to attach some server logs from around the time when you tried downloading subtitles?
Mohammednt0 1 Posted June 14, 2020 Author Posted June 14, 2020 (edited) 32 minutes ago, rechigo said: It's hard to tell with just the information given as it could be a variety of things causing it. Would you be able to attach some server logs from around the time when you tried downloading subtitles? i hope this help to figure out the problem, please advise embyserver.txt embyserver-63727773378.txt hardware_detection-63727773436.txt embyserver-63727774784.txt hardware_detection-63727774802.txt embyserver-63727776000.txt Edited June 14, 2020 by Mohammednt0
Solution rechigo 367 Posted June 14, 2020 Solution Posted June 14, 2020 I believe this is the issue 2020-06-14 23:34:13.090 Error SubtitleManager: Error downloading subtitles from Open Subtitles *** Error Report *** Version: 4.4.3.0 Command line: C:\Users\Abu-Abbas\AppData\Roaming\Emby-Server\system\EmbyServer.dll -noautorunwebapp Operating system: Microsoft Windows NT 6.2.9200.0 64-Bit OS: True 64-Bit Process: True User Interactive: True Runtime: file:///C:/Users/Abu-Abbas/AppData/Roaming/Emby-Server/system/System.Private.CoreLib.dll System.Environment.Version: 3.1.4 Processor count: 8 Program data path: C:\Users\Abu-Abbas\AppData\Roaming\Emby-Server\programdata Application directory: C:\Users\Abu-Abbas\AppData\Roaming\Emby-Server\system MediaBrowser.Common.Extensions.RateLimitExceededException: MediaBrowser.Common.Extensions.RateLimitExceededException: OpenSubtitles rate limit reached at OpenSubtitles.OpenSubtitleDownloader.SendRequestAsync(ReadOnlyMemory`1 request, CancellationToken cancellationToken) at OpenSubtitles.OpenSubtitleDownloader.Login(CancellationToken cancellationToken) at OpenSubtitles.OpenSubtitleDownloader.Search(SubtitleSearchRequest request, CancellationToken cancellationToken) at MediaBrowser.Providers.Subtitles.SubtitleManager.<>c__DisplayClass17_0.<<SearchSubtitles>b__3>d.MoveNext() Source: OpenSubtitles TargetSite: Void MoveNext() Open Subtitles only allows you to download a certain amount of subtitles within a 24 hour window, for free accounts I believe it is 100. You could try with a new account, wait until the next day (24h), purchase an opensubtitles VIP account (1000 subs/24hours), or try some other subtitle providers that Emby has which can all be found in the catalog (with the exception of subscene), such as subscene (https://emby.media/community/index.php?/topic/83501-new-plugin-subscene-subtitle/), addic7ted, subdb, podnapisi and napisub
Mohammednt0 1 Posted June 15, 2020 Author Posted June 15, 2020 15 hours ago, rechigo said: I believe this is the issue 2020-06-14 23:34:13.090 Error SubtitleManager: Error downloading subtitles from Open Subtitles *** Error Report *** Version: 4.4.3.0 Command line: C:\Users\Abu-Abbas\AppData\Roaming\Emby-Server\system\EmbyServer.dll -noautorunwebapp Operating system: Microsoft Windows NT 6.2.9200.0 64-Bit OS: True 64-Bit Process: True User Interactive: True Runtime: file:///C:/Users/Abu-Abbas/AppData/Roaming/Emby-Server/system/System.Private.CoreLib.dll System.Environment.Version: 3.1.4 Processor count: 8 Program data path: C:\Users\Abu-Abbas\AppData\Roaming\Emby-Server\programdata Application directory: C:\Users\Abu-Abbas\AppData\Roaming\Emby-Server\system MediaBrowser.Common.Extensions.RateLimitExceededException: MediaBrowser.Common.Extensions.RateLimitExceededException: OpenSubtitles rate limit reached at OpenSubtitles.OpenSubtitleDownloader.SendRequestAsync(ReadOnlyMemory`1 request, CancellationToken cancellationToken) at OpenSubtitles.OpenSubtitleDownloader.Login(CancellationToken cancellationToken) at OpenSubtitles.OpenSubtitleDownloader.Search(SubtitleSearchRequest request, CancellationToken cancellationToken) at MediaBrowser.Providers.Subtitles.SubtitleManager.<>c__DisplayClass17_0.<<SearchSubtitles>b__3>d.MoveNext() Source: OpenSubtitles TargetSite: Void MoveNext() Open Subtitles only allows you to download a certain amount of subtitles within a 24 hour window, for free accounts I believe it is 100. You could try with a new account, wait until the next day (24h), purchase an opensubtitles VIP account (1000 subs/24hours), or try some other subtitle providers that Emby has which can all be found in the catalog (with the exception of subscene), such as subscene (https://emby.media/community/index.php?/topic/83501-new-plugin-subscene-subtitle/), addic7ted, subdb, podnapisi and napisub thanks, you are right i just tested it, it worked !
