AaronG85 48 Posted July 13, 2014 Posted July 13, 2014 Just wondering what everyone uses to control both WMC and MB3C. I want Bluetooth so I don't have to worry about distance, but want something that takes advantage of all options (right click, ff, rw ect). Thanks in advance
Yogi 367 Posted July 13, 2014 Posted July 13, 2014 Still use the Logitech Harmony here,just bought a second for the bedroom,they work a treat. Not Bluetooth but still the best imo.
CashMoney 94 Posted July 13, 2014 Posted July 13, 2014 Again, not Bluetooth, but I use Unified Remote on android devices. However I too would go the harmony route (and probably will when I get some disposable cash). Iirc there is some sort of new harmony hub remote setup that can use harmony remotes, android and iPhone apps, keyboard, etc, and can control IR devices as well as WiFi, Rf and possibly Bluetooth. http://mobile.logitech.com/en-gb/product/harmony-ultimate-hub That one. 1
Logos302 86 Posted July 13, 2014 Posted July 13, 2014 Logitech makes an RF remote as well, while not Bluetooth will be just a good.
Deihmos 170 Posted July 13, 2014 Posted July 13, 2014 (edited) You can't go wrong with a harmony remote. I use the Harmony 900 which has RF so I don't need a line of sight of the components. The newer RF models are the harmony smart control and Harmony Ultimate. They changed up the design a lot. Smart control allows you to use your smart phone or a simple remote. Edited July 13, 2014 by Deihmos 1
Jvtm 13 Posted July 14, 2014 Posted July 14, 2014 Hipporemote works great. Sent from my iPad using Tapatalk
buddyweiser 105 Posted July 14, 2014 Posted July 14, 2014 I use an xbox 360 remote with xpadder, i have autoprofiles for basic windows controls, with a button mapped to quicklaunch wmc, then xpadder loads the wmc profile, and profiles that auto launch for each of my emulators in gmebrowser as well 1
aspdend 177 Posted July 14, 2014 Posted July 14, 2014 I use a Harmony 555 (I picked it up cheap off Amazon a few years ago now) and supplement that with Unified remote on the smartphones and tablet. imho the Harmony remotes work the best
Cheesegeezer 3106 Posted July 14, 2014 Posted July 14, 2014 I use a Harmony One in the lounge for Main HTPC and a Harmony 1100 remote for the bedroom (The wife like the look of that one, so she wanted it in the bedroom :S ) Both these models are IR only, but work fantastically with every device I have. You need to remember that the Harmony Remotes have 1. Activities - this means that with the press of a button, it can automatically control all devices necessary to go an activity. eg. Activity = MediaBrowser, so the remote ensures the correct AV Input on the TV is selected (HDMI1), it changes the input on my Pioneer AV Rec to DVD(which is what i have selected for my HTPC input). If I then press the activity Xbox, it changes the input on the TV to the Xbox input to HDMI2, pioneer to my Xbox input, then turns on the Xbox. 2. It's a marriage saving remote control and always has a hi WAF. The downside is they are mostly quite expensive and you need to programme them to do exactly what you want them to do, which can take time. If you wanted to hide your AV equipment and just have one hidden IR repeater you can use something like this http://www.keene.co.uk/electronic/keene-electronics/keene-ir-distribution-amp-kit-(inc-irpmr)-/IRBKITPB.html Just trying to give you facts mate 2
Della Dog 19 Posted July 14, 2014 Posted July 14, 2014 Just picked up my first Harmony remote this weekend - the Smart Control. Liked it so much I returned it for the Ultimate. Still trying to work out some the nuances associated with controlling a windows 8 HTPC (keyboard commands, selecting default audio device within Windows, etc.) but all in all I highly recommend it for controlling a system tucked away in a cabinet.
Spaceboy 2573 Posted July 14, 2014 Posted July 14, 2014 Harmony rock Sent from my iPhone using Tapatalk
Cheesegeezer 3106 Posted July 14, 2014 Posted July 14, 2014 Just picked up my first Harmony remote this weekend - the Smart Control. Liked it so much I returned it for the Ultimate. Still trying to work out some the nuances associated with controlling a windows 8 HTPC (keyboard commands, selecting default audio device within Windows, etc.) but all in all I highly recommend it for controlling a system tucked away in a cabinet. Dont want to dampen things but have a read of this and the comments http://www.amazon.co.uk/review/R14UIJ11QJ6YT9/ref=cm_cr_dp_title?ie=UTF8&ASIN=B00C80JFSS&channel=detail-glance&nodeID=560798&store=electronics Anyone..... If you want to buy harmony, find one that uses the old software not the myharmony.com setup.... This is a deal breaker for me, i wont buy any new model as they have removed so many great features from the software.
Della Dog 19 Posted July 14, 2014 Posted July 14, 2014 Dont want to dampen things but have a read of this and the comments http://www.amazon.co.uk/review/R14UIJ11QJ6YT9/ref=cm_cr_dp_title?ie=UTF8&ASIN=B00C80JFSS&channel=detail-glance&nodeID=560798&store=electronics Anyone..... If you want to buy harmony, find one that uses the old software not the myharmony.com setup.... This is a deal breaker for me, i wont buy any new model as they have removed so many great features from the software. Not even slightly damp - yet. I read just about EVERY review on Amazon before purchasing. The review you point to is dated 10 Sep 2013. What I can say for sure is that I've loaded the remote up with several devices & Activities (Smart TV, UMC processor, DirecTV DVR, Nest Thermostat and MediaBrowser on Win8) all sitting in an entertainment center and everything so far works flawlessly. Granted, I had to be careful with device delay timings, but I must say it's nice to click "Watch MB3" & see the processor fire up with the correct input, followed shortly by the TV switching to HDMI-2, then HTPC loading MB Theater full screen. Oh yeah, And then one click "OFF" shuts it all down. Me like so far.
fantaxp7 191 Posted July 15, 2014 Posted July 15, 2014 I picked up the harmony ultimate with the hub and it is fantastic. I had used the 900 for a couple of years and liked that, but the ultimate with the hub is great. I bought a splitter and some extra IR repeaters to control all my devices through the hub which works on wifi. I really like this as you don't have to worry about anyone not pointing the remote straight towards the devices. And it is cool having the app on my phone work with everything. Another very odd but awesome thing for me: my friend used airplay to play a song on my Denon receiver while everything else was turned off. I thought "Oh no, that will mess up when I try to turn on my system later". For one reason or another when hitting the HTPC button on my harmony ultimate, it turned off my receiver then turned it back on...as if it knew it was in the wrong state of power....
