Wilky13 21 Posted August 16, 2014 Posted August 16, 2014 When will Genre Cleaner be fixed in the stable (non beta) version of MB3? I am having the same issue.
Luke 42254 Posted August 16, 2014 Posted August 16, 2014 When will Genre Cleaner be fixed in the stable (non beta) version of MB3? I am having the same issue. "Same issue" doesn't really help us identify a potential problem. Please start from the beginning and tell us what you're seeing. Please see http://mediabrowser.tv/community/index.php?/topic/790-how-to-report-a-problem/
techywarrior 689 Posted August 17, 2014 Posted August 17, 2014 Luke, is it supposed to be working on pre-existing meta data or only on new media added to the library? If it's supposed to be working on existing meta data then I can also see that it's not working (I'll dump a log tomorrow when I am not about to go to a party). If it's only now working on new media (intentionally) then perhaps that should be conveyed. Although if that's the case I think that it makes the plugin fairly useless.
