CyberPoison 33 Posted June 14, 2020 Posted June 14, 2020 Hi everyone. Today i bought a new LG 65C9PLA TV and I have some 5000 movies and when i try to browse it, it takes many time so scroll down, fortunately the browsing works well with the same library on plex. It also have that 5000 movies and i can browse the movies smoothly so i think it was a emby app performance issue. Can anyone confirm me than it have the same issue with huge library? Cheers and Regards.[emoji1635] Sent from my VOG-L29 with Tapatalk
Luke 42237 Posted June 14, 2020 Posted June 14, 2020 Hi, this will be resolved in the next update to the app. Thanks.
CyberPoison 33 Posted June 14, 2020 Author Posted June 14, 2020 Just do the same thing plex do, i like it to show me the whole library the only issue it's than it take many time to load looks like it have some lazyload or whatever. i don't like the idea of 400 limit by page i suggest something to adjust the page limit or something but still to fix the issue is the best way. regards
SamES 1084 Posted June 15, 2020 Posted June 15, 2020 Do you use the cover-art plugin? If you do, try turning it off as a test
CyberPoison 33 Posted June 15, 2020 Author Posted June 15, 2020 Do you use the cover-art plugin? If you do, try turning it off as a testYes but i would like to stay using it.Anyway i test it tomorrow when I get time for this.Regards [emoji1635]Sent from my VOG-L29 using Tapatalk
SamES 1084 Posted June 15, 2020 Posted June 15, 2020 12 minutes ago, CyberPoison said: Yes but i would like to stay using it. Anyway i test it tomorrow when I get time for this. Regards Sent from my VOG-L29 using Tapatalk Sure, I can understand that. I'm interested to know just as a test if this has an impact. Thanks
