Painkiller88 250 Posted June 28, 2020 Author Posted June 28, 2020 Works fine and the main movie is starting flawless after the cinema intro. Thanks a lot for your help and adding the features that fast. So this can be seen as solved because the emby for kodi addon isn't developed anymore right now.
sdb 0 Posted July 20, 2020 Posted July 20, 2020 Any update ? I still have the same problem on Xbox One, EmbyCon ok, Emby for Kodi not ok with the curl that fails with 127.0.0.1 address (Why does it want to connect to localhost and not the server like EmbyCon ?) http://paste.kodi.tv/eyizagimaz
Luke 42234 Posted July 22, 2020 Posted July 22, 2020 On 7/20/2020 at 3:12 PM, sdb said: Any update ? I still have the same problem on Xbox One, EmbyCon ok, Emby for Kodi not ok with the curl that fails with 127.0.0.1 address (Why does it want to connect to localhost and not the server like EmbyCon ?) http://paste.kodi.tv/eyizagimaz We'll look into it. The localhost requests you see are actually going to a server that is embedded in Kodi. It's just the way it handles certain kinds of playback.
