Itay1778 0 Posted June 13, 2020 Posted June 13, 2020 Hi, everyone has a problem with Emby. I can't edit or change or delete users. Which is a real problem for me because one of the things that keeps me going at Emby is user control. My problem is that the user edit screen opens but I click save so the loading circle just rotates forever and does nothing, it happens to all users. And I can't even delete and restart the user because they aren't deleted. What to do? I've tried from different browsers it doesn't help. Emby server version: 4.4.2.0 Operating System: FreeNAS-11.3-U2.1 and Emby's Jail - 11.2-RELEASE-p15 Waiting for your help. Thanks Itay
Luke 42238 Posted June 16, 2020 Posted June 16, 2020 Hi there, please attach the emby server log from when you tried to do this. Thanks.
Itay1778 0 Posted June 16, 2020 Author Posted June 16, 2020 1 hour ago, Luke said: emby server log from when you tried to do this Hi, thanks for answering This is the log (the error may appear a couple of times because I tried several times to make it appear in the log) ** Note, I was able to create a new user that at least currently seems to have no problem ... very strange 2020-06-16 19:37:00.060 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 2ms. https://192.168.1.29:8920/emby/Localization/ParentalRatings 2020-06-16 19:37:03.238 Info HttpServer: HTTP POST https://192.168.1.29:8920/emby/Users/883af2911301488dadb02054b300057c/Policy. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 19:37:03.239 Debug XmlSerializer: Serializing to file /var/db/emby-server/config/users/883af2911301488dadb02054b300057c/policy.xml 2020-06-16 19:37:03.241 Error HttpServer: Error processing request *** Error Report *** Version: 4.4.2.0 Command line: /usr/local/lib/emby-server/system/EmbyServer.exe -os freebsd -ffdetect /usr/local/lib/emby-server/bin/ffdetect -ffmpeg /usr/local/lib/emby-server/bin/ffmpeg -ffprobe /usr/local/lib/emby-server/bin/ffprobe -programdata /var/db/emby-server -updatepackage emby-server-freebsd12_{version}_amd64.txz Operating system: Unix 11.3.9.0 64-Bit OS: True 64-Bit Process: True User Interactive: False Mono: 5.10.1.57 (5.10.1.57 Thu Apr 9 04:06:41 UTC 2020) Runtime: file:///usr/local/lib/mono/4.5/mscorlib.dll System.Environment.Version: 4.0.30319.42000 Processor count: 4 Program data path: /var/db/emby-server Application directory: /usr/local/lib/emby-server/system System.UnauthorizedAccessException: System.UnauthorizedAccessException: Access to the path "/var/db/emby-server/config/users/883af2911301488dadb02054b300057c/policy.xml" is denied. at System.IO.FileStream..ctor (System.String path, System.IO.FileMode mode, System.IO.FileAccess access, System.IO.FileShare share, System.Int32 bufferSize, System.Boolean anonymous, System.IO.FileOptions options) [0x0019e] in <0e06830de9a44394a7e366951eabca52>:0 at System.IO.FileStream..ctor (System.String path, System.IO.FileMode mode) [0x00000] in <0e06830de9a44394a7e366951eabca52>:0 at (wrapper remoting-invoke-with-check) System.IO.FileStream..ctor(string,System.IO.FileMode) at Emby.Server.Implementations.Serialization.MyXmlSerializer.SerializeToFile (System.Object obj, System.String file) [0x0001a] in <3605319732a64e8282cfdf09a091f02e>:0 at Emby.Server.Implementations.Library.UserManager.UpdateUserPolicy (MediaBrowser.Controller.Entities.User user, MediaBrowser.Model.Users.UserPolicy userPolicy, System.Boolean fireEvent) [0x00060] in <3605319732a64e8282cfdf09a091f02e>:0 at Emby.Server.Implementations.Library.UserManager.UpdateUserPolicy (System.Int64 userId, MediaBrowser.Model.Users.UserPolicy userPolicy) [0x00008] in <3605319732a64e8282cfdf09a091f02e>:0 at MediaBrowser.Api.UserService.Post (MediaBrowser.Api.UpdateUserPolicy request) [0x0011b] in <0390257caaf74c7fb5e30cb51d35bfbc>:0 at (wrapper dynamic-method) System.Object.lambda_method(System.Runtime.CompilerServices.Closure,object,object) at Emby.Server.Implementations.Services.ServiceController+<>c__DisplayClass6_0.<VoidActionDelegate>b__0 (System.Object service, System.Object request) [0x00000] in <3605319732a64e8282cfdf09a091f02e>:0 at Emby.Server.Implementations.Services.ServiceController.Execute (Emby.Server.Implementations.HttpServer.HttpListenerHost appHost, System.Object requestDto, MediaBrowser.Model.Services.IRequest req) [0x00073] in <3605319732a64e8282cfdf09a091f02e>:0 at Emby.Server.Implementations.Services.ServiceHandler+<ProcessRequestAsync>d__4.MoveNext () [0x00168] in <3605319732a64e8282cfdf09a091f02e>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0003e] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00028] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00008] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable+ConfiguredTaskAwaiter.GetResult () [0x00000] in <0e06830de9a44394a7e366951eabca52>:0 at Emby.Server.Implementations.HttpServer.HttpListenerHost+<RequestHandler>d__46.MoveNext () [0x00b52] in <3605319732a64e8282cfdf09a091f02e>:0 Source: mscorlib TargetSite: Void Throw() 2020-06-16 19:37:03.241 Info HttpServer: HTTP Response 500 to 192.168.1.2. Time: 3ms. https://192.168.1.29:8920/emby/Users/883af2911301488dadb02054b300057c/Policy 2020-06-16 19:37:15.259 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Users/883af2911301488dadb02054b300057c. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 19:37:15.260 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 2ms. https://192.168.1.29:8920/emby/Users/883af2911301488dadb02054b300057c 2020-06-16 19:37:15.265 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Channels. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 19:37:15.267 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 1ms. https://192.168.1.29:8920/emby/Channels 2020-06-16 19:37:15.299 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Devices. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 19:37:16.167 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Localization/ParentalRatings. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 19:37:16.168 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 1ms. https://192.168.1.29:8920/emby/Localization/ParentalRatings 2020-06-16 19:37:16.351 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 1052ms. https://192.168.1.29:8920/emby/Devices 2020-06-16 19:37:16.370 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Library/SelectableMediaFolders. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 19:37:16.396 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 26ms. https://192.168.1.29:8920/emby/Library/SelectableMediaFolders 2020-06-16 19:37:21.791 Info HttpServer: HTTP POST https://192.168.1.29:8920/emby/Users/883af2911301488dadb02054b300057c/Policy. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 19:37:21.794 Debug XmlSerializer: Serializing to file /var/db/emby-server/config/users/883af2911301488dadb02054b300057c/policy.xml 2020-06-16 19:37:21.795 Error HttpServer: Error processing request *** Error Report *** Version: 4.4.2.0 Command line: /usr/local/lib/emby-server/system/EmbyServer.exe -os freebsd -ffdetect /usr/local/lib/emby-server/bin/ffdetect -ffmpeg /usr/local/lib/emby-server/bin/ffmpeg -ffprobe /usr/local/lib/emby-server/bin/ffprobe -programdata /var/db/emby-server -updatepackage emby-server-freebsd12_{version}_amd64.txz Operating system: Unix 11.3.9.0 64-Bit OS: True 64-Bit Process: True User Interactive: False Mono: 5.10.1.57 (5.10.1.57 Thu Apr 9 04:06:41 UTC 2020) Runtime: file:///usr/local/lib/mono/4.5/mscorlib.dll System.Environment.Version: 4.0.30319.42000 Processor count: 4 Program data path: /var/db/emby-server Application directory: /usr/local/lib/emby-server/system System.UnauthorizedAccessException: System.UnauthorizedAccessException: Access to the path "/var/db/emby-server/config/users/883af2911301488dadb02054b300057c/policy.xml" is denied. at System.IO.FileStream..ctor (System.String path, System.IO.FileMode mode, System.IO.FileAccess access, System.IO.FileShare share, System.Int32 bufferSize, System.Boolean anonymous, System.IO.FileOptions options) [0x0019e] in <0e06830de9a44394a7e366951eabca52>:0 at System.IO.FileStream..ctor (System.String path, System.IO.FileMode mode) [0x00000] in <0e06830de9a44394a7e366951eabca52>:0 at (wrapper remoting-invoke-with-check) System.IO.FileStream..ctor(string,System.IO.FileMode) at Emby.Server.Implementations.Serialization.MyXmlSerializer.SerializeToFile (System.Object obj, System.String file) [0x0001a] in <3605319732a64e8282cfdf09a091f02e>:0 at Emby.Server.Implementations.Library.UserManager.UpdateUserPolicy (MediaBrowser.Controller.Entities.User user, MediaBrowser.Model.Users.UserPolicy userPolicy, System.Boolean fireEvent) [0x00060] in <3605319732a64e8282cfdf09a091f02e>:0 at Emby.Server.Implementations.Library.UserManager.UpdateUserPolicy (System.Int64 userId, MediaBrowser.Model.Users.UserPolicy userPolicy) [0x00008] in <3605319732a64e8282cfdf09a091f02e>:0 at MediaBrowser.Api.UserService.Post (MediaBrowser.Api.UpdateUserPolicy request) [0x0011b] in <0390257caaf74c7fb5e30cb51d35bfbc>:0 at (wrapper dynamic-method) System.Object.lambda_method(System.Runtime.CompilerServices.Closure,object,object) at Emby.Server.Implementations.Services.ServiceController+<>c__DisplayClass6_0.<VoidActionDelegate>b__0 (System.Object service, System.Object request) [0x00000] in <3605319732a64e8282cfdf09a091f02e>:0 at Emby.Server.Implementations.Services.ServiceController.Execute (Emby.Server.Implementations.HttpServer.HttpListenerHost appHost, System.Object requestDto, MediaBrowser.Model.Services.IRequest req) [0x00073] in <3605319732a64e8282cfdf09a091f02e>:0 at Emby.Server.Implementations.Services.ServiceHandler+<ProcessRequestAsync>d__4.MoveNext () [0x00168] in <3605319732a64e8282cfdf09a091f02e>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0003e] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00028] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00008] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable+ConfiguredTaskAwaiter.GetResult () [0x00000] in <0e06830de9a44394a7e366951eabca52>:0 at Emby.Server.Implementations.HttpServer.HttpListenerHost+<RequestHandler>d__46.MoveNext () [0x00b52] in <3605319732a64e8282cfdf09a091f02e>:0 Source: mscorlib TargetSite: Void Throw() 2020-06-16 19:37:21.796 Info HttpServer: HTTP Response 500 to 192.168.1.2. Time: 5ms. https://192.168.1.29:8920/emby/Users/883af2911301488dadb02054b300057c/Policy 2020-06-16 19:38:33.846 Info HttpServer: HTTP GET https://192.168.1.29:8920/logs. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 19:38:33.846 Info HttpServer: HTTP Response 404 to 192.168.1.2. Time: 1ms. https://192.168.1.29:8920/logs 2020-06-16 19:38:38.267 Info HttpServer: HTTP GET https://192.168.1.29:8920/logs. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 19:38:38.268 Info HttpServer: HTTP Response 404 to 192.168.1.2. Time: 1ms. https://192.168.1.29:8920/logs 2020-06-16 19:38:47.322 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Users/65d0ee59448b4babb59b4bfba1ad3fcf. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 19:38:47.324 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 2ms. https://192.168.1.29:8920/emby/Users/65d0ee59448b4babb59b4bfba1ad3fcf 2020-06-16 19:38:47.331 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/System/Logs. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 19:38:47.331 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/System/Configuration. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 19:38:47.332 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 1ms. https://192.168.1.29:8920/emby/System/Configuration 2020-06-16 19:38:47.333 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 3ms. https://192.168.1.29:8920/emby/System/Logs 2020-06-16 19:38:49.753 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/System/Logs/embyserver.txt. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0
Luke 42238 Posted June 16, 2020 Posted June 16, 2020 Can you please attach the complete emby server log? Also how did you install Emby Server? Thanks.
Itay1778 0 Posted June 16, 2020 Author Posted June 16, 2020 13 minutes ago, Luke said: Can you please attach the complete emby server log? Also how did you install Emby Server? Thanks. I installed the Emby server through FreeBSD ports. Today's full log, hope this is enough (otherwise I can't copy all the log - it's for two years) 2020-06-16 00:00:00.035 Info App: Application version: 4.4.2.0 2020-06-16 00:00:00.036 Info App: Emby Command line: /usr/local/lib/emby-server/system/EmbyServer.exe -os freebsd -ffdetect /usr/local/lib/emby-server/bin/ffdetect -ffmpeg /usr/local/lib/emby-server/bin/ffmpeg -ffprobe /usr/local/lib/emby-server/bin/ffprobe -programdata /var/db/emby-server -updatepackage emby-server-freebsd12_{version}_amd64.txz Operating system: Unix 11.3.9.0 64-Bit OS: True 64-Bit Process: True User Interactive: False Mono: 5.10.1.57 (5.10.1.57 Thu Apr 9 04:06:41 UTC 2020) Runtime: file:///usr/local/lib/mono/4.5/mscorlib.dll System.Environment.Version: 4.0.30319.42000 Processor count: 4 Program data path: /var/db/emby-server Application directory: /usr/local/lib/emby-server/system 2020-06-16 00:00:00.036 Info App: Plugins: Bluray Folder Support 1.0.0.0 Dlna 1.0.37.0 Dvd Folder Support 1.0.0.0 Fanart.tv 1.0.7.0 IMVDb 1.0.8.0 MovieDb 1.3.5.0 MusicBrainz 1.0.13.0 Nfo Metadata 1.0.29.0 OMDb 1.0.9.0 Open Subtitles 1.0.26.0 Port Mapper 1.0.4.0 Studio Images 1.0.3.0 TheAudioDb 1.0.10.0 TheTVDB 1.0.34.0 Webhooks 1.0.11.0 2020-06-16 00:00:00.036 Debug TaskManager: Rotate log file Completed after 0 minute(s) and 0 seconds 2020-06-16 00:01:31.531 Debug TaskManager: IntervalTrigger fired for task: Scan media library 2020-06-16 00:01:31.531 Debug TaskManager: Queueing task RefreshMediaLibraryTask 2020-06-16 00:01:31.531 Debug TaskManager: Executing Scan media library 2020-06-16 00:01:31.590 Debug App: FolderImageProvider reports change to 252 - /var/db/emby-server/root 2020-06-16 00:01:31.603 Debug App: Running FolderImageProvider for /var/db/emby-server/root 2020-06-16 00:01:31.615 Debug XmlSerializer: Deserializing file /var/db/emby-server/root/default/סדרות/options.xml 2020-06-16 00:01:31.625 Debug XmlSerializer: Deserializing file /var/db/emby-server/root/default/סרטי משפחה/options.xml 2020-06-16 00:01:31.678 Debug XmlSerializer: Deserializing file /var/db/emby-server/root/default/סרטי×/options.xml 2020-06-16 00:01:31.821 Debug XmlSerializer: Deserializing file /var/db/emby-server/config/metadata.xml 2020-06-16 00:01:32.271 Debug XmlSerializer: Deserializing file /var/db/emby-server/root/default/סדרות/options.xml 2020-06-16 00:01:32.273 Debug XmlSerializer: Deserializing file /var/db/emby-server/root/default/סרטי משפחה/options.xml 2020-06-16 00:01:32.273 Debug XmlSerializer: Deserializing file /var/db/emby-server/root/default/סרטי×/options.xml 2020-06-16 00:01:32.274 Debug XmlSerializer: Deserializing file /var/db/emby-server/root/default/סדרות/options.xml 2020-06-16 00:01:32.276 Debug XmlSerializer: Deserializing file /var/db/emby-server/root/default/סדרות/options.xml 2020-06-16 00:01:32.307 Debug XmlSerializer: Deserializing file /var/db/emby-server/root/default/סרטי משפחה/options.xml 2020-06-16 00:01:32.308 Debug XmlSerializer: Deserializing file /var/db/emby-server/root/default/סרטי משפחה/options.xml 2020-06-16 00:01:32.377 Debug XmlSerializer: Deserializing file /var/db/emby-server/root/default/סרטי×/options.xml 2020-06-16 00:01:32.377 Debug XmlSerializer: Deserializing file /var/db/emby-server/root/default/סרטי×/options.xml 2020-06-16 00:01:32.401 Debug XmlSerializer: Deserializing file /var/db/emby-server/root/default/סדרות/options.xml 2020-06-16 00:01:32.402 Debug XmlSerializer: Deserializing file /var/db/emby-server/root/default/סדרות/options.xml 2020-06-16 00:01:32.404 Debug XmlSerializer: Deserializing file /var/db/emby-server/root/default/סרטי×/options.xml 2020-06-16 00:01:32.405 Debug XmlSerializer: Deserializing file /var/db/emby-server/root/default/סרטי×/options.xml 2020-06-16 00:01:32.408 Debug XmlSerializer: Deserializing file /var/db/emby-server/root/default/סרטי משפחה/options.xml 2020-06-16 00:01:32.408 Debug XmlSerializer: Deserializing file /var/db/emby-server/root/default/סרטי משפחה/options.xml 2020-06-16 00:01:32.412 Debug XmlSerializer: Deserializing file /var/db/emby-server/root/default/סדרות/options.xml 2020-06-16 00:01:32.413 Debug XmlSerializer: Deserializing file /var/db/emby-server/root/default/סרטי משפחה/options.xml 2020-06-16 00:01:32.414 Debug XmlSerializer: Deserializing file /var/db/emby-server/root/default/סרטי×/options.xml 2020-06-16 00:01:44.804 Debug App: FolderImageProvider reports change to 4888 - /mnt/Streamer/סדרות/The 100/Season 4/Episode 13 2020-06-16 00:01:44.804 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/The 100/Season 4/Episode 13 2020-06-16 00:01:44.986 Debug App: FolderImageProvider reports change to 4910 - /mnt/Streamer/סדרות/The 100/Season 5/Episode 1 2020-06-16 00:01:44.986 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/The 100/Season 5/Episode 1 2020-06-16 00:01:44.987 Debug App: FolderImageProvider reports change to 4911 - /mnt/Streamer/סדרות/The 100/Season 5/Episode 10 2020-06-16 00:01:44.987 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/The 100/Season 5/Episode 10 2020-06-16 00:01:44.988 Debug App: FolderImageProvider reports change to 4912 - /mnt/Streamer/סדרות/The 100/Season 5/Episode 11 2020-06-16 00:01:44.988 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/The 100/Season 5/Episode 11 2020-06-16 00:01:44.989 Debug App: FolderImageProvider reports change to 4913 - /mnt/Streamer/סדרות/The 100/Season 5/Episode 12 2020-06-16 00:01:44.989 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/The 100/Season 5/Episode 12 2020-06-16 00:01:44.990 Debug App: FolderImageProvider reports change to 4914 - /mnt/Streamer/סדרות/The 100/Season 5/Episode 13 2020-06-16 00:01:44.990 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/The 100/Season 5/Episode 13 2020-06-16 00:01:44.991 Debug App: FolderImageProvider reports change to 4915 - /mnt/Streamer/סדרות/The 100/Season 5/Episode 2 2020-06-16 00:01:44.991 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/The 100/Season 5/Episode 2 2020-06-16 00:01:44.992 Debug App: FolderImageProvider reports change to 4916 - /mnt/Streamer/סדרות/The 100/Season 5/Episode 3 2020-06-16 00:01:44.992 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/The 100/Season 5/Episode 3 2020-06-16 00:01:45.012 Debug App: FolderImageProvider reports change to 4917 - /mnt/Streamer/סדרות/The 100/Season 5/Episode 4 2020-06-16 00:01:45.012 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/The 100/Season 5/Episode 4 2020-06-16 00:01:45.038 Debug App: FolderImageProvider reports change to 4918 - /mnt/Streamer/סדרות/The 100/Season 5/Episode 5 2020-06-16 00:01:45.038 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/The 100/Season 5/Episode 5 2020-06-16 00:01:45.064 Debug App: FolderImageProvider reports change to 4919 - /mnt/Streamer/סדרות/The 100/Season 5/Episode 6 2020-06-16 00:01:45.064 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/The 100/Season 5/Episode 6 2020-06-16 00:01:45.077 Debug App: FolderImageProvider reports change to 4920 - /mnt/Streamer/סדרות/The 100/Season 5/Episode 7 2020-06-16 00:01:45.077 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/The 100/Season 5/Episode 7 2020-06-16 00:01:45.078 Debug App: FolderImageProvider reports change to 4921 - /mnt/Streamer/סדרות/The 100/Season 5/Episode 8 2020-06-16 00:01:45.078 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/The 100/Season 5/Episode 8 2020-06-16 00:01:45.079 Debug App: FolderImageProvider reports change to 4922 - /mnt/Streamer/סדרות/The 100/Season 5/Episode 9 2020-06-16 00:01:45.079 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/The 100/Season 5/Episode 9 2020-06-16 00:01:46.111 Debug App: FolderImageProvider reports change to 10107 - /mnt/Streamer/סדרות/The Good Place/Season 4/Episode 1 2020-06-16 00:01:46.111 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/The Good Place/Season 4/Episode 1 2020-06-16 00:01:46.113 Debug App: FolderImageProvider reports change to 10108 - /mnt/Streamer/סדרות/The Good Place/Season 4/Episode 10 2020-06-16 00:01:46.113 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/The Good Place/Season 4/Episode 10 2020-06-16 00:01:46.135 Debug App: FolderImageProvider reports change to 10109 - /mnt/Streamer/סדרות/The Good Place/Season 4/Episode 11 2020-06-16 00:01:46.135 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/The Good Place/Season 4/Episode 11 2020-06-16 00:01:46.151 Debug App: FolderImageProvider reports change to 10110 - /mnt/Streamer/סדרות/The Good Place/Season 4/Episode 12 2020-06-16 00:01:46.151 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/The Good Place/Season 4/Episode 12 2020-06-16 00:01:46.152 Debug App: FolderImageProvider reports change to 10111 - /mnt/Streamer/סדרות/The Good Place/Season 4/Episode 13 2020-06-16 00:01:46.152 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/The Good Place/Season 4/Episode 13 2020-06-16 00:01:46.153 Debug App: FolderImageProvider reports change to 10112 - /mnt/Streamer/סדרות/The Good Place/Season 4/Episode 2 2020-06-16 00:01:46.153 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/The Good Place/Season 4/Episode 2 2020-06-16 00:01:46.154 Debug App: FolderImageProvider reports change to 10113 - /mnt/Streamer/סדרות/The Good Place/Season 4/Episode 3 2020-06-16 00:01:46.154 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/The Good Place/Season 4/Episode 3 2020-06-16 00:01:46.156 Debug App: FolderImageProvider reports change to 10114 - /mnt/Streamer/סדרות/The Good Place/Season 4/Episode 4 2020-06-16 00:01:46.156 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/The Good Place/Season 4/Episode 4 2020-06-16 00:01:46.156 Debug App: FolderImageProvider reports change to 10115 - /mnt/Streamer/סדרות/The Good Place/Season 4/Episode 5 2020-06-16 00:01:46.157 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/The Good Place/Season 4/Episode 5 2020-06-16 00:01:46.157 Debug App: FolderImageProvider reports change to 10116 - /mnt/Streamer/סדרות/The Good Place/Season 4/Episode 6 2020-06-16 00:01:46.158 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/The Good Place/Season 4/Episode 6 2020-06-16 00:01:46.174 Debug App: FolderImageProvider reports change to 10117 - /mnt/Streamer/סדרות/The Good Place/Season 4/Episode 7 2020-06-16 00:01:46.174 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/The Good Place/Season 4/Episode 7 2020-06-16 00:01:46.176 Debug App: FolderImageProvider reports change to 10118 - /mnt/Streamer/סדרות/The Good Place/Season 4/Episode 8 2020-06-16 00:01:46.176 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/The Good Place/Season 4/Episode 8 2020-06-16 00:01:46.193 Debug App: FolderImageProvider reports change to 10119 - /mnt/Streamer/סדרות/The Good Place/Season 4/Episode 9 2020-06-16 00:01:46.193 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/The Good Place/Season 4/Episode 9 2020-06-16 00:01:46.840 Debug App: FolderImageProvider reports change to 4531 - /mnt/Streamer/סדרות/Agents Of S.H.I.E.L.D/Season 5/Episode 10 2020-06-16 00:01:46.840 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Agents Of S.H.I.E.L.D/Season 5/Episode 10 2020-06-16 00:01:46.841 Debug App: FolderImageProvider reports change to 4532 - /mnt/Streamer/סדרות/Agents Of S.H.I.E.L.D/Season 5/Episode 11 2020-06-16 00:01:46.841 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Agents Of S.H.I.E.L.D/Season 5/Episode 11 2020-06-16 00:01:46.848 Debug App: FolderImageProvider reports change to 4533 - /mnt/Streamer/סדרות/Agents Of S.H.I.E.L.D/Season 5/Episode 12 2020-06-16 00:01:46.848 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Agents Of S.H.I.E.L.D/Season 5/Episode 12 2020-06-16 00:01:46.849 Debug App: FolderImageProvider reports change to 4534 - /mnt/Streamer/סדרות/Agents Of S.H.I.E.L.D/Season 5/Episode 13 2020-06-16 00:01:46.849 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Agents Of S.H.I.E.L.D/Season 5/Episode 13 2020-06-16 00:01:46.853 Debug App: FolderImageProvider reports change to 4535 - /mnt/Streamer/סדרות/Agents Of S.H.I.E.L.D/Season 5/Episode 14 2020-06-16 00:01:46.853 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Agents Of S.H.I.E.L.D/Season 5/Episode 14 2020-06-16 00:01:46.854 Debug App: FolderImageProvider reports change to 4536 - /mnt/Streamer/סדרות/Agents Of S.H.I.E.L.D/Season 5/Episode 15 2020-06-16 00:01:46.854 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Agents Of S.H.I.E.L.D/Season 5/Episode 15 2020-06-16 00:01:46.855 Debug App: FolderImageProvider reports change to 4537 - /mnt/Streamer/סדרות/Agents Of S.H.I.E.L.D/Season 5/Episode 16 2020-06-16 00:01:46.855 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Agents Of S.H.I.E.L.D/Season 5/Episode 16 2020-06-16 00:01:46.856 Debug App: FolderImageProvider reports change to 4538 - /mnt/Streamer/סדרות/Agents Of S.H.I.E.L.D/Season 5/Episode 17 2020-06-16 00:01:46.856 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Agents Of S.H.I.E.L.D/Season 5/Episode 17 2020-06-16 00:01:46.857 Debug App: FolderImageProvider reports change to 4539 - /mnt/Streamer/סדרות/Agents Of S.H.I.E.L.D/Season 5/Episode 18 2020-06-16 00:01:46.857 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Agents Of S.H.I.E.L.D/Season 5/Episode 18 2020-06-16 00:01:46.869 Debug App: FolderImageProvider reports change to 4540 - /mnt/Streamer/סדרות/Agents Of S.H.I.E.L.D/Season 5/Episode 19 2020-06-16 00:01:46.869 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Agents Of S.H.I.E.L.D/Season 5/Episode 19 2020-06-16 00:01:46.870 Debug App: FolderImageProvider reports change to 4541 - /mnt/Streamer/סדרות/Agents Of S.H.I.E.L.D/Season 5/Episode 20 2020-06-16 00:01:46.870 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Agents Of S.H.I.E.L.D/Season 5/Episode 20 2020-06-16 00:01:46.871 Debug App: FolderImageProvider reports change to 4542 - /mnt/Streamer/סדרות/Agents Of S.H.I.E.L.D/Season 5/Episode 21 2020-06-16 00:01:46.871 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Agents Of S.H.I.E.L.D/Season 5/Episode 21 2020-06-16 00:01:46.872 Debug App: FolderImageProvider reports change to 4543 - /mnt/Streamer/סדרות/Agents Of S.H.I.E.L.D/Season 5/Episode 22 2020-06-16 00:01:46.872 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Agents Of S.H.I.E.L.D/Season 5/Episode 22 2020-06-16 00:01:46.875 Debug App: FolderImageProvider reports change to 4547 - /mnt/Streamer/סדרות/Agents Of S.H.I.E.L.D/Season 5/Episode 6 2020-06-16 00:01:46.875 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Agents Of S.H.I.E.L.D/Season 5/Episode 6 2020-06-16 00:01:46.903 Debug App: FolderImageProvider reports change to 4548 - /mnt/Streamer/סדרות/Agents Of S.H.I.E.L.D/Season 5/Episode 7 2020-06-16 00:01:46.903 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Agents Of S.H.I.E.L.D/Season 5/Episode 7 2020-06-16 00:01:46.904 Debug App: FolderImageProvider reports change to 4549 - /mnt/Streamer/סדרות/Agents Of S.H.I.E.L.D/Season 5/Episode 8 2020-06-16 00:01:46.904 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Agents Of S.H.I.E.L.D/Season 5/Episode 8 2020-06-16 00:01:46.905 Debug App: FolderImageProvider reports change to 4550 - /mnt/Streamer/סדרות/Agents Of S.H.I.E.L.D/Season 5/Episode 9 2020-06-16 00:01:46.905 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Agents Of S.H.I.E.L.D/Season 5/Episode 9 2020-06-16 00:01:48.879 Debug App: FolderImageProvider reports change to 5470 - /mnt/Streamer/סדרות/Chernobyl/Season 1/Episode 2 2020-06-16 00:01:48.879 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Chernobyl/Season 1/Episode 2 2020-06-16 00:01:48.881 Debug App: FolderImageProvider reports change to 5471 - /mnt/Streamer/סדרות/Chernobyl/Season 1/Episode 3 2020-06-16 00:01:48.881 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Chernobyl/Season 1/Episode 3 2020-06-16 00:01:48.895 Debug App: FolderImageProvider reports change to 5472 - /mnt/Streamer/סדרות/Chernobyl/Season 1/Episode 4 2020-06-16 00:01:48.895 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Chernobyl/Season 1/Episode 4 2020-06-16 00:01:48.896 Debug App: FolderImageProvider reports change to 5473 - /mnt/Streamer/סדרות/Chernobyl/Season 1/Episode 5 2020-06-16 00:01:48.896 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Chernobyl/Season 1/Episode 5 2020-06-16 00:01:49.660 Debug App: FolderImageProvider reports change to 5495 - /mnt/Streamer/סדרות/Arrow/Season 7/Episode 1 2020-06-16 00:01:49.660 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Arrow/Season 7/Episode 1 2020-06-16 00:01:49.661 Debug App: FolderImageProvider reports change to 5496 - /mnt/Streamer/סדרות/Arrow/Season 7/Episode 10 2020-06-16 00:01:49.661 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Arrow/Season 7/Episode 10 2020-06-16 00:01:49.662 Debug App: FolderImageProvider reports change to 5497 - /mnt/Streamer/סדרות/Arrow/Season 7/Episode 11 2020-06-16 00:01:49.662 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Arrow/Season 7/Episode 11 2020-06-16 00:01:49.663 Debug App: FolderImageProvider reports change to 5498 - /mnt/Streamer/סדרות/Arrow/Season 7/Episode 12 2020-06-16 00:01:49.663 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Arrow/Season 7/Episode 12 2020-06-16 00:01:49.688 Debug App: FolderImageProvider reports change to 5499 - /mnt/Streamer/סדרות/Arrow/Season 7/Episode 13 2020-06-16 00:01:49.689 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Arrow/Season 7/Episode 13 2020-06-16 00:01:49.690 Debug App: FolderImageProvider reports change to 5500 - /mnt/Streamer/סדרות/Arrow/Season 7/Episode 14 2020-06-16 00:01:49.690 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Arrow/Season 7/Episode 14 2020-06-16 00:01:49.691 Debug App: FolderImageProvider reports change to 5501 - /mnt/Streamer/סדרות/Arrow/Season 7/Episode 15 2020-06-16 00:01:49.691 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Arrow/Season 7/Episode 15 2020-06-16 00:01:49.718 Debug App: FolderImageProvider reports change to 5502 - /mnt/Streamer/סדרות/Arrow/Season 7/Episode 16 2020-06-16 00:01:49.718 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Arrow/Season 7/Episode 16 2020-06-16 00:01:49.719 Debug App: FolderImageProvider reports change to 5503 - /mnt/Streamer/סדרות/Arrow/Season 7/Episode 17 2020-06-16 00:01:49.719 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Arrow/Season 7/Episode 17 2020-06-16 00:01:49.720 Debug App: FolderImageProvider reports change to 5504 - /mnt/Streamer/סדרות/Arrow/Season 7/Episode 18 2020-06-16 00:01:49.720 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Arrow/Season 7/Episode 18 2020-06-16 00:01:49.721 Debug App: FolderImageProvider reports change to 5505 - /mnt/Streamer/סדרות/Arrow/Season 7/Episode 19 2020-06-16 00:01:49.721 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Arrow/Season 7/Episode 19 2020-06-16 00:01:49.722 Debug App: FolderImageProvider reports change to 5506 - /mnt/Streamer/סדרות/Arrow/Season 7/Episode 2 2020-06-16 00:01:49.722 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Arrow/Season 7/Episode 2 2020-06-16 00:01:49.723 Debug App: FolderImageProvider reports change to 5507 - /mnt/Streamer/סדרות/Arrow/Season 7/Episode 20 2020-06-16 00:01:49.723 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Arrow/Season 7/Episode 20 2020-06-16 00:01:49.724 Debug App: FolderImageProvider reports change to 5508 - /mnt/Streamer/סדרות/Arrow/Season 7/Episode 21 2020-06-16 00:01:49.724 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Arrow/Season 7/Episode 21 2020-06-16 00:01:49.725 Debug App: FolderImageProvider reports change to 5509 - /mnt/Streamer/סדרות/Arrow/Season 7/Episode 22 2020-06-16 00:01:49.725 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Arrow/Season 7/Episode 22 2020-06-16 00:01:49.726 Debug App: FolderImageProvider reports change to 5510 - /mnt/Streamer/סדרות/Arrow/Season 7/Episode 3 2020-06-16 00:01:49.726 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Arrow/Season 7/Episode 3 2020-06-16 00:01:49.752 Debug App: FolderImageProvider reports change to 5511 - /mnt/Streamer/סדרות/Arrow/Season 7/Episode 4 2020-06-16 00:01:49.752 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Arrow/Season 7/Episode 4 2020-06-16 00:01:49.753 Debug App: FolderImageProvider reports change to 5512 - /mnt/Streamer/סדרות/Arrow/Season 7/Episode 5 2020-06-16 00:01:49.753 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Arrow/Season 7/Episode 5 2020-06-16 00:01:49.754 Debug App: FolderImageProvider reports change to 5513 - /mnt/Streamer/סדרות/Arrow/Season 7/Episode 6 2020-06-16 00:01:49.754 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Arrow/Season 7/Episode 6 2020-06-16 00:01:49.755 Debug App: FolderImageProvider reports change to 5514 - /mnt/Streamer/סדרות/Arrow/Season 7/Episode 7 2020-06-16 00:01:49.755 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Arrow/Season 7/Episode 7 2020-06-16 00:01:49.756 Debug App: FolderImageProvider reports change to 5515 - /mnt/Streamer/סדרות/Arrow/Season 7/Episode 8 2020-06-16 00:01:49.756 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Arrow/Season 7/Episode 8 2020-06-16 00:01:49.757 Debug App: FolderImageProvider reports change to 5516 - /mnt/Streamer/סדרות/Arrow/Season 7/Episode 9 2020-06-16 00:01:49.757 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Arrow/Season 7/Episode 9 2020-06-16 00:01:50.191 Debug App: FolderImageProvider reports change to 6201 - /mnt/Streamer/סדרות/Homeland/Season 1/Episode 10 2020-06-16 00:01:50.191 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 1/Episode 10 2020-06-16 00:01:50.192 Debug App: FolderImageProvider reports change to 6202 - /mnt/Streamer/סדרות/Homeland/Season 1/Episode 11 2020-06-16 00:01:50.192 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 1/Episode 11 2020-06-16 00:01:50.193 Debug App: FolderImageProvider reports change to 6203 - /mnt/Streamer/סדרות/Homeland/Season 1/Episode 12 2020-06-16 00:01:50.193 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 1/Episode 12 2020-06-16 00:01:50.196 Debug App: FolderImageProvider reports change to 6210 - /mnt/Streamer/סדרות/Homeland/Season 1/Episode 8 2020-06-16 00:01:50.196 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 1/Episode 8 2020-06-16 00:01:50.197 Debug App: FolderImageProvider reports change to 6211 - /mnt/Streamer/סדרות/Homeland/Season 1/Episode 9 2020-06-16 00:01:50.197 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 1/Episode 9 2020-06-16 00:01:50.211 Debug App: FolderImageProvider reports change to 6224 - /mnt/Streamer/סדרות/Homeland/Season 2/Episode 1 2020-06-16 00:01:50.211 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 2/Episode 1 2020-06-16 00:01:50.212 Debug App: FolderImageProvider reports change to 6225 - /mnt/Streamer/סדרות/Homeland/Season 2/Episode 10 2020-06-16 00:01:50.212 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 2/Episode 10 2020-06-16 00:01:50.213 Debug App: FolderImageProvider reports change to 6226 - /mnt/Streamer/סדרות/Homeland/Season 2/Episode 11 2020-06-16 00:01:50.213 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 2/Episode 11 2020-06-16 00:01:50.226 Debug App: FolderImageProvider reports change to 6227 - /mnt/Streamer/סדרות/Homeland/Season 2/Episode 12 2020-06-16 00:01:50.227 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 2/Episode 12 2020-06-16 00:01:50.228 Debug App: FolderImageProvider reports change to 6228 - /mnt/Streamer/סדרות/Homeland/Season 2/Episode 2 2020-06-16 00:01:50.228 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 2/Episode 2 2020-06-16 00:01:50.229 Debug App: FolderImageProvider reports change to 6229 - /mnt/Streamer/סדרות/Homeland/Season 2/Episode 3 2020-06-16 00:01:50.229 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 2/Episode 3 2020-06-16 00:01:50.229 Debug App: FolderImageProvider reports change to 6230 - /mnt/Streamer/סדרות/Homeland/Season 2/Episode 4 2020-06-16 00:01:50.230 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 2/Episode 4 2020-06-16 00:01:50.230 Debug App: FolderImageProvider reports change to 6231 - /mnt/Streamer/סדרות/Homeland/Season 2/Episode 5 2020-06-16 00:01:50.231 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 2/Episode 5 2020-06-16 00:01:50.231 Debug App: FolderImageProvider reports change to 6232 - /mnt/Streamer/סדרות/Homeland/Season 2/Episode 6 2020-06-16 00:01:50.232 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 2/Episode 6 2020-06-16 00:01:50.232 Debug App: FolderImageProvider reports change to 6233 - /mnt/Streamer/סדרות/Homeland/Season 2/Episode 7 2020-06-16 00:01:50.233 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 2/Episode 7 2020-06-16 00:01:50.233 Debug App: FolderImageProvider reports change to 6234 - /mnt/Streamer/סדרות/Homeland/Season 2/Episode 8 2020-06-16 00:01:50.234 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 2/Episode 8 2020-06-16 00:01:50.235 Debug App: FolderImageProvider reports change to 6235 - /mnt/Streamer/סדרות/Homeland/Season 2/Episode 9 2020-06-16 00:01:50.235 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 2/Episode 9 2020-06-16 00:01:50.297 Debug App: FolderImageProvider reports change to 6248 - /mnt/Streamer/סדרות/Homeland/Season 3/Episode 1 2020-06-16 00:01:50.297 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 3/Episode 1 2020-06-16 00:01:50.298 Debug App: FolderImageProvider reports change to 6249 - /mnt/Streamer/סדרות/Homeland/Season 3/Episode 10 2020-06-16 00:01:50.298 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 3/Episode 10 2020-06-16 00:01:50.299 Debug App: FolderImageProvider reports change to 6251 - /mnt/Streamer/סדרות/Homeland/Season 3/Episode 12 2020-06-16 00:01:50.299 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 3/Episode 12 2020-06-16 00:01:50.300 Debug App: FolderImageProvider reports change to 6252 - /mnt/Streamer/סדרות/Homeland/Season 3/Episode 2 2020-06-16 00:01:50.300 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 3/Episode 2 2020-06-16 00:01:50.301 Debug App: FolderImageProvider reports change to 6253 - /mnt/Streamer/סדרות/Homeland/Season 3/Episode 3 2020-06-16 00:01:50.301 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 3/Episode 3 2020-06-16 00:01:50.302 Debug App: FolderImageProvider reports change to 6254 - /mnt/Streamer/סדרות/Homeland/Season 3/Episode 4 2020-06-16 00:01:50.302 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 3/Episode 4 2020-06-16 00:01:50.303 Debug App: FolderImageProvider reports change to 6255 - /mnt/Streamer/סדרות/Homeland/Season 3/Episode 5 2020-06-16 00:01:50.303 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 3/Episode 5 2020-06-16 00:01:50.304 Debug App: FolderImageProvider reports change to 6256 - /mnt/Streamer/סדרות/Homeland/Season 3/Episode 6 2020-06-16 00:01:50.304 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 3/Episode 6 2020-06-16 00:01:50.305 Debug App: FolderImageProvider reports change to 6257 - /mnt/Streamer/סדרות/Homeland/Season 3/Episode 7 2020-06-16 00:01:50.305 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 3/Episode 7 2020-06-16 00:01:50.306 Debug App: FolderImageProvider reports change to 6258 - /mnt/Streamer/סדרות/Homeland/Season 3/Episode 8 2020-06-16 00:01:50.306 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 3/Episode 8 2020-06-16 00:01:50.308 Debug App: FolderImageProvider reports change to 6259 - /mnt/Streamer/סדרות/Homeland/Season 3/Episode 9 2020-06-16 00:01:50.308 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 3/Episode 9 2020-06-16 00:01:50.360 Debug App: FolderImageProvider reports change to 6272 - /mnt/Streamer/סדרות/Homeland/Season 4/Episode 1 2020-06-16 00:01:50.360 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 4/Episode 1 2020-06-16 00:01:50.361 Debug App: FolderImageProvider reports change to 6273 - /mnt/Streamer/סדרות/Homeland/Season 4/Episode 10 2020-06-16 00:01:50.361 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 4/Episode 10 2020-06-16 00:01:50.362 Debug App: FolderImageProvider reports change to 6274 - /mnt/Streamer/סדרות/Homeland/Season 4/Episode 11 2020-06-16 00:01:50.362 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 4/Episode 11 2020-06-16 00:01:50.363 Debug App: FolderImageProvider reports change to 6275 - /mnt/Streamer/סדרות/Homeland/Season 4/Episode 12 2020-06-16 00:01:50.363 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 4/Episode 12 2020-06-16 00:01:50.364 Debug App: FolderImageProvider reports change to 6276 - /mnt/Streamer/סדרות/Homeland/Season 4/Episode 2 2020-06-16 00:01:50.364 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 4/Episode 2 2020-06-16 00:01:50.365 Debug App: FolderImageProvider reports change to 6277 - /mnt/Streamer/סדרות/Homeland/Season 4/Episode 3 2020-06-16 00:01:50.365 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 4/Episode 3 2020-06-16 00:01:50.366 Debug App: FolderImageProvider reports change to 6278 - /mnt/Streamer/סדרות/Homeland/Season 4/Episode 4 2020-06-16 00:01:50.366 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 4/Episode 4 2020-06-16 00:01:50.371 Debug App: FolderImageProvider reports change to 6279 - /mnt/Streamer/סדרות/Homeland/Season 4/Episode 5 2020-06-16 00:01:50.371 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 4/Episode 5 2020-06-16 00:01:50.372 Debug App: FolderImageProvider reports change to 6280 - /mnt/Streamer/סדרות/Homeland/Season 4/Episode 6 2020-06-16 00:01:50.372 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 4/Episode 6 2020-06-16 00:01:50.373 Debug App: FolderImageProvider reports change to 6281 - /mnt/Streamer/סדרות/Homeland/Season 4/Episode 7 2020-06-16 00:01:50.373 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 4/Episode 7 2020-06-16 00:01:50.389 Debug App: FolderImageProvider reports change to 6282 - /mnt/Streamer/סדרות/Homeland/Season 4/Episode 8 2020-06-16 00:01:50.389 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 4/Episode 8 2020-06-16 00:01:50.390 Debug App: FolderImageProvider reports change to 6283 - /mnt/Streamer/סדרות/Homeland/Season 4/Episode 9 2020-06-16 00:01:50.390 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 4/Episode 9 2020-06-16 00:01:50.420 Debug App: FolderImageProvider reports change to 6296 - /mnt/Streamer/סדרות/Homeland/Season 5/Episode 1 2020-06-16 00:01:50.420 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 5/Episode 1 2020-06-16 00:01:50.421 Debug App: FolderImageProvider reports change to 6297 - /mnt/Streamer/סדרות/Homeland/Season 5/Episode 10 2020-06-16 00:01:50.421 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 5/Episode 10 2020-06-16 00:01:50.422 Debug App: FolderImageProvider reports change to 6298 - /mnt/Streamer/סדרות/Homeland/Season 5/Episode 11 2020-06-16 00:01:50.422 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 5/Episode 11 2020-06-16 00:01:50.423 Debug App: FolderImageProvider reports change to 6300 - /mnt/Streamer/סדרות/Homeland/Season 5/Episode 2 2020-06-16 00:01:50.423 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 5/Episode 2 2020-06-16 00:01:50.424 Debug App: FolderImageProvider reports change to 6301 - /mnt/Streamer/סדרות/Homeland/Season 5/Episode 3 2020-06-16 00:01:50.424 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 5/Episode 3 2020-06-16 00:01:50.430 Debug App: FolderImageProvider reports change to 6416 - /mnt/Streamer/סדרות/Homeland/Season 5/Episode 4 2020-06-16 00:01:50.430 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 5/Episode 4 2020-06-16 00:01:50.452 Debug App: FolderImageProvider reports change to 6417 - /mnt/Streamer/סדרות/Homeland/Season 5/Episode 5 2020-06-16 00:01:50.452 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 5/Episode 5 2020-06-16 00:01:50.467 Debug App: FolderImageProvider reports change to 6418 - /mnt/Streamer/סדרות/Homeland/Season 5/Episode 6 2020-06-16 00:01:50.467 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 5/Episode 6 2020-06-16 00:01:50.470 Debug App: FolderImageProvider reports change to 6423 - /mnt/Streamer/סדרות/Homeland/Season 5/Episode 7 2020-06-16 00:01:50.470 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 5/Episode 7 2020-06-16 00:01:50.471 Debug App: FolderImageProvider reports change to 6424 - /mnt/Streamer/סדרות/Homeland/Season 5/Episode 8 2020-06-16 00:01:50.471 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 5/Episode 8 2020-06-16 00:01:50.472 Debug App: FolderImageProvider reports change to 6425 - /mnt/Streamer/סדרות/Homeland/Season 5/Episode 9 2020-06-16 00:01:50.472 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 5/Episode 9 2020-06-16 00:01:50.501 Debug App: FolderImageProvider reports change to 6432 - /mnt/Streamer/סדרות/Homeland/Season 6/Episode 1 2020-06-16 00:01:50.501 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 6/Episode 1 2020-06-16 00:01:50.502 Debug App: FolderImageProvider reports change to 6433 - /mnt/Streamer/סדרות/Homeland/Season 6/Episode 10 2020-06-16 00:01:50.502 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 6/Episode 10 2020-06-16 00:01:50.503 Debug App: FolderImageProvider reports change to 6434 - /mnt/Streamer/סדרות/Homeland/Season 6/Episode 11 2020-06-16 00:01:50.503 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 6/Episode 11 2020-06-16 00:01:50.517 Debug App: FolderImageProvider reports change to 6435 - /mnt/Streamer/סדרות/Homeland/Season 6/Episode 12 2020-06-16 00:01:50.517 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 6/Episode 12 2020-06-16 00:01:50.518 Debug App: FolderImageProvider reports change to 6436 - /mnt/Streamer/סדרות/Homeland/Season 6/Episode 2 2020-06-16 00:01:50.518 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 6/Episode 2 2020-06-16 00:01:50.518 Debug App: FolderImageProvider reports change to 6437 - /mnt/Streamer/סדרות/Homeland/Season 6/Episode 3 2020-06-16 00:01:50.518 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 6/Episode 3 2020-06-16 00:01:50.519 Debug App: FolderImageProvider reports change to 6438 - /mnt/Streamer/סדרות/Homeland/Season 6/Episode 4 2020-06-16 00:01:50.519 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 6/Episode 4 2020-06-16 00:01:50.520 Debug App: FolderImageProvider reports change to 6439 - /mnt/Streamer/סדרות/Homeland/Season 6/Episode 5 2020-06-16 00:01:50.520 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 6/Episode 5 2020-06-16 00:01:50.521 Debug App: FolderImageProvider reports change to 6440 - /mnt/Streamer/סדרות/Homeland/Season 6/Episode 6 2020-06-16 00:01:50.521 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 6/Episode 6 2020-06-16 00:01:50.522 Debug App: FolderImageProvider reports change to 6441 - /mnt/Streamer/סדרות/Homeland/Season 6/Episode 7 2020-06-16 00:01:50.522 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 6/Episode 7 2020-06-16 00:01:50.523 Debug App: FolderImageProvider reports change to 6442 - /mnt/Streamer/סדרות/Homeland/Season 6/Episode 8 2020-06-16 00:01:50.523 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 6/Episode 8 2020-06-16 00:01:50.523 Debug App: FolderImageProvider reports change to 6443 - /mnt/Streamer/סדרות/Homeland/Season 6/Episode 9 2020-06-16 00:01:50.524 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 6/Episode 9 2020-06-16 00:01:50.536 Debug App: FolderImageProvider reports change to 6457 - /mnt/Streamer/סדרות/Homeland/Season 7/Episode 10 2020-06-16 00:01:50.536 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 7/Episode 10 2020-06-16 00:01:50.537 Debug App: FolderImageProvider reports change to 6458 - /mnt/Streamer/סדרות/Homeland/Season 7/Episode 11 2020-06-16 00:01:50.537 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 7/Episode 11 2020-06-16 00:01:50.538 Debug App: FolderImageProvider reports change to 6459 - /mnt/Streamer/סדרות/Homeland/Season 7/Episode 12 2020-06-16 00:01:50.538 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 7/Episode 12 2020-06-16 00:01:50.601 Debug App: FolderImageProvider reports change to 6466 - /mnt/Streamer/סדרות/Homeland/Season 7/Episode 8 2020-06-16 00:01:50.601 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 7/Episode 8 2020-06-16 00:01:50.602 Debug App: FolderImageProvider reports change to 6467 - /mnt/Streamer/סדרות/Homeland/Season 7/Episode 9 2020-06-16 00:01:50.602 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 7/Episode 9 2020-06-16 00:01:50.668 Debug App: FolderImageProvider reports change to 6480 - /mnt/Streamer/סדרות/Homeland/Season 8/Episode 1 2020-06-16 00:01:50.668 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 8/Episode 1 2020-06-16 00:01:50.669 Debug App: FolderImageProvider reports change to 6481 - /mnt/Streamer/סדרות/Homeland/Season 8/Episode 10 2020-06-16 00:01:50.669 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 8/Episode 10 2020-06-16 00:01:50.670 Debug App: FolderImageProvider reports change to 6482 - /mnt/Streamer/סדרות/Homeland/Season 8/Episode 11 2020-06-16 00:01:50.670 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 8/Episode 11 2020-06-16 00:01:50.670 Debug App: FolderImageProvider reports change to 6483 - /mnt/Streamer/סדרות/Homeland/Season 8/Episode 12 2020-06-16 00:01:50.670 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 8/Episode 12 2020-06-16 00:01:50.671 Debug App: FolderImageProvider reports change to 6484 - /mnt/Streamer/סדרות/Homeland/Season 8/Episode 2 2020-06-16 00:01:50.671 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 8/Episode 2 2020-06-16 00:01:50.704 Debug App: FolderImageProvider reports change to 6485 - /mnt/Streamer/סדרות/Homeland/Season 8/Episode 3 2020-06-16 00:01:50.704 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 8/Episode 3 2020-06-16 00:01:50.704 Debug App: FolderImageProvider reports change to 6486 - /mnt/Streamer/סדרות/Homeland/Season 8/Episode 4 2020-06-16 00:01:50.704 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 8/Episode 4 2020-06-16 00:01:50.705 Debug App: FolderImageProvider reports change to 6487 - /mnt/Streamer/סדרות/Homeland/Season 8/Episode 5 2020-06-16 00:01:50.705 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 8/Episode 5 2020-06-16 00:01:50.706 Debug App: FolderImageProvider reports change to 6488 - /mnt/Streamer/סדרות/Homeland/Season 8/Episode 6 2020-06-16 00:01:50.706 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 8/Episode 6 2020-06-16 00:01:50.707 Debug App: FolderImageProvider reports change to 6489 - /mnt/Streamer/סדרות/Homeland/Season 8/Episode 7 2020-06-16 00:01:50.707 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 8/Episode 7 2020-06-16 00:01:50.707 Debug App: FolderImageProvider reports change to 6490 - /mnt/Streamer/סדרות/Homeland/Season 8/Episode 8 2020-06-16 00:01:50.707 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 8/Episode 8 2020-06-16 00:01:50.708 Debug App: FolderImageProvider reports change to 6491 - /mnt/Streamer/סדרות/Homeland/Season 8/Episode 9 2020-06-16 00:01:50.708 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 8/Episode 9 2020-06-16 00:01:51.182 Debug App: FolderImageProvider reports change to 7052 - /mnt/Streamer/סדרות/Stranger Things/Season 1/Episode 8 2020-06-16 00:01:51.182 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Stranger Things/Season 1/Episode 8 2020-06-16 00:01:51.211 Debug App: FolderImageProvider reports change to 7068 - /mnt/Streamer/סדרות/Stranger Things/Season 2/Episode 8 2020-06-16 00:01:51.211 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Stranger Things/Season 2/Episode 8 2020-06-16 00:01:51.212 Debug App: FolderImageProvider reports change to 7069 - /mnt/Streamer/סדרות/Stranger Things/Season 2/Episode 9 2020-06-16 00:01:51.212 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Stranger Things/Season 2/Episode 9 2020-06-16 00:01:51.221 Debug App: FolderImageProvider reports change to 7079 - /mnt/Streamer/סדרות/Stranger Things/Season 3/Episode 1 2020-06-16 00:01:51.221 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Stranger Things/Season 3/Episode 1 2020-06-16 00:01:51.222 Debug App: FolderImageProvider reports change to 7080 - /mnt/Streamer/סדרות/Stranger Things/Season 3/Episode 2 2020-06-16 00:01:51.222 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Stranger Things/Season 3/Episode 2 2020-06-16 00:01:51.223 Debug App: FolderImageProvider reports change to 7081 - /mnt/Streamer/סדרות/Stranger Things/Season 3/Episode 3 2020-06-16 00:01:51.223 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Stranger Things/Season 3/Episode 3 2020-06-16 00:01:51.224 Debug App: FolderImageProvider reports change to 7082 - /mnt/Streamer/סדרות/Stranger Things/Season 3/Episode 4 2020-06-16 00:01:51.224 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Stranger Things/Season 3/Episode 4 2020-06-16 00:01:51.225 Debug App: FolderImageProvider reports change to 7083 - /mnt/Streamer/סדרות/Stranger Things/Season 3/Episode 5 2020-06-16 00:01:51.225 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Stranger Things/Season 3/Episode 5 2020-06-16 00:01:51.226 Debug App: FolderImageProvider reports change to 7084 - /mnt/Streamer/סדרות/Stranger Things/Season 3/Episode 6 2020-06-16 00:01:51.226 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Stranger Things/Season 3/Episode 6 2020-06-16 00:01:51.227 Debug App: FolderImageProvider reports change to 7085 - /mnt/Streamer/סדרות/Stranger Things/Season 3/Episode 7 2020-06-16 00:01:51.227 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Stranger Things/Season 3/Episode 7 2020-06-16 00:01:51.228 Debug App: FolderImageProvider reports change to 7086 - /mnt/Streamer/סדרות/Stranger Things/Season 3/Episode 8 2020-06-16 00:01:51.228 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Stranger Things/Season 3/Episode 8 2020-06-16 00:01:51.850 Debug App: FolderImageProvider reports change to 7197 - /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 1/Episode 1 2020-06-16 00:01:51.850 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 1/Episode 1 2020-06-16 00:01:51.851 Debug App: FolderImageProvider reports change to 7198 - /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 1/Episode 10 2020-06-16 00:01:51.851 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 1/Episode 10 2020-06-16 00:01:51.852 Debug App: FolderImageProvider reports change to 7199 - /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 1/Episode 11 2020-06-16 00:01:51.852 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 1/Episode 11 2020-06-16 00:01:51.852 Debug App: FolderImageProvider reports change to 7200 - /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 1/Episode 12 2020-06-16 00:01:51.852 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 1/Episode 12 2020-06-16 00:01:51.853 Debug App: FolderImageProvider reports change to 7201 - /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 1/Episode 13 2020-06-16 00:01:51.853 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 1/Episode 13 2020-06-16 00:01:51.854 Debug App: FolderImageProvider reports change to 7202 - /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 1/Episode 14 2020-06-16 00:01:51.854 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 1/Episode 14 2020-06-16 00:01:51.855 Debug App: FolderImageProvider reports change to 7203 - /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 1/Episode 15 2020-06-16 00:01:51.855 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 1/Episode 15 2020-06-16 00:01:51.855 Debug App: FolderImageProvider reports change to 7204 - /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 1/Episode 16 2020-06-16 00:01:51.855 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 1/Episode 16 2020-06-16 00:01:51.856 Debug App: FolderImageProvider reports change to 7205 - /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 1/Episode 17 2020-06-16 00:01:51.856 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 1/Episode 17 2020-06-16 00:01:51.857 Debug App: FolderImageProvider reports change to 7206 - /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 1/Episode 18 2020-06-16 00:01:51.857 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 1/Episode 18 2020-06-16 00:01:51.858 Debug App: FolderImageProvider reports change to 7207 - /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 1/Episode 19 2020-06-16 00:01:51.858 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 1/Episode 19 2020-06-16 00:01:51.858 Debug App: FolderImageProvider reports change to 7208 - /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 1/Episode 2 2020-06-16 00:01:51.858 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 1/Episode 2 2020-06-16 00:01:51.859 Debug App: FolderImageProvider reports change to 7209 - /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 1/Episode 20 2020-06-16 00:01:51.859 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 1/Episode 20 2020-06-16 00:01:51.860 Debug App: FolderImageProvider reports change to 7210 - /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 1/Episode 21 2020-06-16 00:01:51.860 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 1/Episode 21 2020-06-16 00:01:51.861 Debug App: FolderImageProvider reports change to 7211 - /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 1/Episode 22 2020-06-16 00:01:51.861 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 1/Episode 22 2020-06-16 00:01:51.861 Debug App: FolderImageProvider reports change to 7212 - /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 1/Episode 3 2020-06-16 00:01:51.861 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 1/Episode 3 2020-06-16 00:01:51.862 Debug App: FolderImageProvider reports change to 7213 - /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 1/Episode 4 2020-06-16 00:01:51.862 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 1/Episode 4 2020-06-16 00:01:51.863 Debug App: FolderImageProvider reports change to 7214 - /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 1/Episode 5 2020-06-16 00:01:51.863 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 1/Episode 5 2020-06-16 00:01:51.864 Debug App: FolderImageProvider reports change to 7215 - /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 1/Episode 6 2020-06-16 00:01:51.864 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 1/Episode 6 2020-06-16 00:01:51.864 Debug App: FolderImageProvider reports change to 7216 - /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 1/Episode 7 2020-06-16 00:01:51.864 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 1/Episode 7 2020-06-16 00:01:51.865 Debug App: FolderImageProvider reports change to 7217 - /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 1/Episode 8 2020-06-16 00:01:51.865 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 1/Episode 8 2020-06-16 00:01:51.866 Debug App: FolderImageProvider reports change to 7218 - /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 1/Episode 9 2020-06-16 00:01:51.866 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 1/Episode 9 2020-06-16 00:01:51.866 Debug App: FolderImageProvider reports change to 7219 - /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 2/Episode 1 2020-06-16 00:01:51.867 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 2/Episode 1 2020-06-16 00:01:51.867 Debug App: FolderImageProvider reports change to 7220 - /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 2/Episode 10 2020-06-16 00:01:51.867 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 2/Episode 10 2020-06-16 00:01:51.868 Debug App: FolderImageProvider reports change to 7221 - /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 2/Episode 11 2020-06-16 00:01:51.868 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 2/Episode 11 2020-06-16 00:01:51.869 Debug App: FolderImageProvider reports change to 7222 - /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 2/Episode 12 2020-06-16 00:01:51.869 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 2/Episode 12 2020-06-16 00:01:51.869 Debug App: FolderImageProvider reports change to 7223 - /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 2/Episode 13 2020-06-16 00:01:51.869 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 2/Episode 13 2020-06-16 00:01:51.870 Debug App: FolderImageProvider reports change to 7224 - /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 2/Episode 14 2020-06-16 00:01:51.870 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 2/Episode 14 2020-06-16 00:01:51.871 Debug App: FolderImageProvider reports change to 7225 - /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 2/Episode 15 2020-06-16 00:01:51.871 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 2/Episode 15 2020-06-16 00:01:51.872 Debug App: FolderImageProvider reports change to 7226 - /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 2/Episode 16 2020-06-16 00:01:51.872 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 2/Episode 16 2020-06-16 00:01:51.872 Debug App: FolderImageProvider reports change to 7227 - /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 2/Episode 17 2020-06-16 00:01:51.873 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 2/Episode 17 2020-06-16 00:01:51.873 Debug App: FolderImageProvider reports change to 7228 - /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 2/Episode 18 2020-06-16 00:01:51.873 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 2/Episode 18 2020-06-16 00:01:51.874 Debug App: FolderImageProvider reports change to 7229 - /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 2/Episode 19 2020-06-16 00:01:51.874 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 2/Episode 19 2020-06-16 00:01:51.875 Debug App: FolderImageProvider reports change to 7230 - /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 2/Episode 2 2020-06-16 00:01:51.875 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 2/Episode 2 2020-06-16 00:01:51.876 Debug App: FolderImageProvider reports change to 7231 - /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 2/Episode 20 2020-06-16 00:01:51.876 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 2/Episode 20 2020-06-16 00:01:51.876 Debug App: FolderImageProvider reports change to 7232 - /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 2/Episode 21 2020-06-16 00:01:51.876 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 2/Episode 21 2020-06-16 00:01:51.877 Debug App: FolderImageProvider reports change to 7233 - /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 2/Episode 22 2020-06-16 00:01:51.877 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 2/Episode 22 2020-06-16 00:01:51.878 Debug App: FolderImageProvider reports change to 7234 - /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 2/Episode 23 2020-06-16 00:01:51.878 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 2/Episode 23 2020-06-16 00:01:51.878 Debug App: FolderImageProvider reports change to 7235 - /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 2/Episode 3 2020-06-16 00:01:51.879 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 2/Episode 3 2020-06-16 00:01:51.879 Debug App: FolderImageProvider reports change to 7236 - /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 2/Episode 4 2020-06-16 00:01:51.879 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 2/Episode 4 2020-06-16 00:01:51.880 Debug App: FolderImageProvider reports change to 7237 - /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 2/Episode 5 2020-06-16 00:01:51.880 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 2/Episode 5 2020-06-16 00:01:51.881 Debug App: FolderImageProvider reports change to 7238 - /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 2/Episode 6 2020-06-16 00:01:51.881 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 2/Episode 6 2020-06-16 00:01:51.882 Debug App: FolderImageProvider reports change to 7239 - /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 2/Episode 7 2020-06-16 00:01:51.882 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 2/Episode 7 2020-06-16 00:01:51.882 Debug App: FolderImageProvider reports change to 7240 - /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 2/Episode 8 2020-06-16 00:01:51.882 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 2/Episode 8 2020-06-16 00:01:51.883 Debug App: FolderImageProvider reports change to 7241 - /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 2/Episode 9 2020-06-16 00:01:51.883 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 2/Episode 9 2020-06-16 00:01:52.956 Debug App: FolderImageProvider reports change to 7374 - /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 6/Episode 1 2020-06-16 00:01:52.956 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 6/Episode 1 2020-06-16 00:01:52.957 Debug App: FolderImageProvider reports change to 7375 - /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 6/Episode 10 2020-06-16 00:01:52.957 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 6/Episode 10 2020-06-16 00:01:52.958 Debug App: FolderImageProvider reports change to 7376 - /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 6/Episode 11 2020-06-16 00:01:52.958 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 6/Episode 11 2020-06-16 00:01:52.959 Debug App: FolderImageProvider reports change to 7377 - /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 6/Episode 12 2020-06-16 00:01:52.959 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 6/Episode 12 2020-06-16 00:01:52.960 Debug App: FolderImageProvider reports change to 7378 - /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 6/Episode 13 2020-06-16 00:01:52.960 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 6/Episode 13 2020-06-16 00:01:52.961 Debug App: FolderImageProvider reports change to 7379 - /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 6/Episode 14 2020-06-16 00:01:52.962 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 6/Episode 14 2020-06-16 00:01:52.963 Debug App: FolderImageProvider reports change to 7380 - /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 6/Episode 15 2020-06-16 00:01:52.963 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 6/Episode 15 2020-06-16 00:01:52.964 Debug App: FolderImageProvider reports change to 7381 - /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 6/Episode 16 2020-06-16 00:01:52.964 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 6/Episode 16 2020-06-16 00:01:52.965 Debug App: FolderImageProvider reports change to 7382 - /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 6/Episode 17 2020-06-16 00:01:52.965 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 6/Episode 17 2020-06-16 00:01:52.966 Debug App: FolderImageProvider reports change to 7383 - /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 6/Episode 18 2020-06-16 00:01:52.966 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 6/Episode 18 2020-06-16 00:01:52.966 Debug App: FolderImageProvider reports change to 7384 - /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 6/Episode 2 2020-06-16 00:01:52.967 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 6/Episode 2 2020-06-16 00:01:52.967 Debug App: FolderImageProvider reports change to 7385 - /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 6/Episode 3 2020-06-16 00:01:52.967 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 6/Episode 3 2020-06-16 00:01:52.968 Debug App: FolderImageProvider reports change to 7386 - /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 6/Episode 4 2020-06-16 00:01:52.968 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 6/Episode 4 2020-06-16 00:01:52.969 Debug App: FolderImageProvider reports change to 7387 - /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 6/Episode 5 2020-06-16 00:01:52.969 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 6/Episode 5 2020-06-16 00:01:52.970 Debug App: FolderImageProvider reports change to 7388 - /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 6/Episode 6 2020-06-16 00:01:52.970 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 6/Episode 6 2020-06-16 00:01:52.971 Debug App: FolderImageProvider reports change to 7389 - /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 6/Episode 7 2020-06-16 00:01:52.971 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 6/Episode 7 2020-06-16 00:01:52.972 Debug App: FolderImageProvider reports change to 7390 - /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 6/Episode 8 2020-06-16 00:01:52.972 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 6/Episode 8 2020-06-16 00:01:53.159 Debug App: FolderImageProvider reports change to 7391 - /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 6/Episode 9 2020-06-16 00:01:53.159 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 6/Episode 9 2020-06-16 00:01:54.455 Debug App: FolderImageProvider reports change to 8807 - /mnt/Streamer/סדרות/American Housewife/Season 4/Episode 1 2020-06-16 00:01:54.455 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/American Housewife/Season 4/Episode 1 2020-06-16 00:01:54.456 Debug App: FolderImageProvider reports change to 8808 - /mnt/Streamer/סדרות/American Housewife/Season 4/Episode 10 2020-06-16 00:01:54.456 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/American Housewife/Season 4/Episode 10 2020-06-16 00:01:54.457 Debug App: FolderImageProvider reports change to 8809 - /mnt/Streamer/סדרות/American Housewife/Season 4/Episode 11 2020-06-16 00:01:54.457 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/American Housewife/Season 4/Episode 11 2020-06-16 00:01:54.457 Debug App: FolderImageProvider reports change to 8810 - /mnt/Streamer/סדרות/American Housewife/Season 4/Episode 12 2020-06-16 00:01:54.457 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/American Housewife/Season 4/Episode 12 2020-06-16 00:01:54.458 Debug App: FolderImageProvider reports change to 8811 - /mnt/Streamer/סדרות/American Housewife/Season 4/Episode 13 2020-06-16 00:01:54.458 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/American Housewife/Season 4/Episode 13 2020-06-16 00:01:54.459 Debug App: FolderImageProvider reports change to 8812 - /mnt/Streamer/סדרות/American Housewife/Season 4/Episode 14 2020-06-16 00:01:54.459 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/American Housewife/Season 4/Episode 14 2020-06-16 00:01:54.460 Debug App: FolderImageProvider reports change to 8813 - /mnt/Streamer/סדרות/American Housewife/Season 4/Episode 15 2020-06-16 00:01:54.460 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/American Housewife/Season 4/Episode 15 2020-06-16 00:01:54.460 Debug App: FolderImageProvider reports change to 8814 - /mnt/Streamer/סדרות/American Housewife/Season 4/Episode 16 2020-06-16 00:01:54.460 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/American Housewife/Season 4/Episode 16 2020-06-16 00:01:54.461 Debug App: FolderImageProvider reports change to 8815 - /mnt/Streamer/סדרות/American Housewife/Season 4/Episode 17 2020-06-16 00:01:54.461 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/American Housewife/Season 4/Episode 17 2020-06-16 00:01:54.462 Debug App: FolderImageProvider reports change to 8816 - /mnt/Streamer/סדרות/American Housewife/Season 4/Episode 18 2020-06-16 00:01:54.462 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/American Housewife/Season 4/Episode 18 2020-06-16 00:01:54.463 Debug App: FolderImageProvider reports change to 8817 - /mnt/Streamer/סדרות/American Housewife/Season 4/Episode 19 2020-06-16 00:01:54.463 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/American Housewife/Season 4/Episode 19 2020-06-16 00:01:54.463 Debug App: FolderImageProvider reports change to 8818 - /mnt/Streamer/סדרות/American Housewife/Season 4/Episode 2 2020-06-16 00:01:54.463 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/American Housewife/Season 4/Episode 2 2020-06-16 00:01:54.464 Debug App: FolderImageProvider reports change to 8819 - /mnt/Streamer/סדרות/American Housewife/Season 4/Episode 20 2020-06-16 00:01:54.464 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/American Housewife/Season 4/Episode 20 2020-06-16 00:01:54.465 Debug App: FolderImageProvider reports change to 8820 - /mnt/Streamer/סדרות/American Housewife/Season 4/Episode 21 2020-06-16 00:01:54.465 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/American Housewife/Season 4/Episode 21 2020-06-16 00:01:54.466 Debug App: FolderImageProvider reports change to 8821 - /mnt/Streamer/סדרות/American Housewife/Season 4/Episode 3 2020-06-16 00:01:54.466 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/American Housewife/Season 4/Episode 3 2020-06-16 00:01:54.466 Debug App: FolderImageProvider reports change to 8822 - /mnt/Streamer/סדרות/American Housewife/Season 4/Episode 4 2020-06-16 00:01:54.466 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/American Housewife/Season 4/Episode 4 2020-06-16 00:01:54.467 Debug App: FolderImageProvider reports change to 8823 - /mnt/Streamer/סדרות/American Housewife/Season 4/Episode 5 2020-06-16 00:01:54.467 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/American Housewife/Season 4/Episode 5 2020-06-16 00:01:54.476 Debug App: FolderImageProvider reports change to 8824 - /mnt/Streamer/סדרות/American Housewife/Season 4/Episode 6 2020-06-16 00:01:54.476 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/American Housewife/Season 4/Episode 6 2020-06-16 00:01:54.477 Debug App: FolderImageProvider reports change to 8825 - /mnt/Streamer/סדרות/American Housewife/Season 4/Episode 7 2020-06-16 00:01:54.477 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/American Housewife/Season 4/Episode 7 2020-06-16 00:01:54.478 Debug App: FolderImageProvider reports change to 8826 - /mnt/Streamer/סדרות/American Housewife/Season 4/Episode 8 2020-06-16 00:01:54.478 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/American Housewife/Season 4/Episode 8 2020-06-16 00:01:54.479 Debug App: FolderImageProvider reports change to 8827 - /mnt/Streamer/סדרות/American Housewife/Season 4/Episode 9 2020-06-16 00:01:54.479 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/American Housewife/Season 4/Episode 9 2020-06-16 00:01:59.179 Debug App: FolderImageProvider reports change to 9155 - /mnt/Streamer/סרטי×/Sully (2016) 2020-06-16 00:01:59.179 Debug App: Running FolderImageProvider for /mnt/Streamer/סרטי×/Sully (2016) 2020-06-16 00:01:59.201 Debug ProviderManager: Saving image to /var/db/emby-server/metadata/library/55/555fb85512e3e5e6ab9f48d7625fa6c5/poster.jpg 2020-06-16 00:01:59.558 Debug App: FolderImageProvider reports change to 9258 - /mnt/Streamer/סרטי×/Gemini Man (2019) 2020-06-16 00:01:59.558 Debug App: Running FolderImageProvider for /mnt/Streamer/סרטי×/Gemini Man (2019) 2020-06-16 00:01:59.641 Debug ProviderManager: Saving image to /var/db/emby-server/metadata/library/62/623569509f840cffc8448daa4c01fe82/poster.jpg 2020-06-16 00:01:59.825 Debug App: FolderImageProvider reports change to 9262 - /mnt/Streamer/סרטי×/Has Fallen/Has Fallen(1) Olympus (2013) 2020-06-16 00:01:59.825 Debug App: Running FolderImageProvider for /mnt/Streamer/סרטי×/Has Fallen/Has Fallen(1) Olympus (2013) 2020-06-16 00:01:59.880 Debug ProviderManager: Saving image to /var/db/emby-server/metadata/library/75/75f7393fa126697294e3d343611b20a1/poster.jpg 2020-06-16 00:02:00.209 Debug App: FolderImageProvider reports change to 9263 - /mnt/Streamer/סרטי×/Has Fallen/Has Fallen(2) London (2016) 2020-06-16 00:02:00.210 Debug App: Running FolderImageProvider for /mnt/Streamer/סרטי×/Has Fallen/Has Fallen(2) London (2016) 2020-06-16 00:02:00.264 Debug ProviderManager: Saving image to /var/db/emby-server/metadata/library/ac/ac855cba9ef8f14e0d6c74a2c7674112/poster.jpg 2020-06-16 00:02:00.317 Debug App: FolderImageProvider reports change to 9264 - /mnt/Streamer/סרטי×/Has Fallen/Has Fallen(3) Angel (2019) 2020-06-16 00:02:00.317 Debug App: Running FolderImageProvider for /mnt/Streamer/סרטי×/Has Fallen/Has Fallen(3) Angel (2019) 2020-06-16 00:02:00.365 Debug ProviderManager: Saving image to /var/db/emby-server/metadata/library/1c/1ce8229ace02727ec61bf761644bb0ec/poster.jpg 2020-06-16 00:02:00.425 Debug App: FolderImageProvider reports change to 9268 - /mnt/Streamer/סרטי×/Jumanji/Jumanji(1) Welcome To The Jungle (2017) 2020-06-16 00:02:00.425 Debug App: Running FolderImageProvider for /mnt/Streamer/סרטי×/Jumanji/Jumanji(1) Welcome To The Jungle (2017) 2020-06-16 00:02:00.484 Debug ProviderManager: Saving image to /var/db/emby-server/metadata/library/a4/a47218de9f70e4281e12c96f13ef6401/poster.jpg 2020-06-16 00:02:00.625 Debug App: FolderImageProvider reports change to 9491 - /mnt/Streamer/סרטי×/The Informer (2020) 2020-06-16 00:02:00.625 Debug App: Running FolderImageProvider for /mnt/Streamer/סרטי×/The Informer (2020) 2020-06-16 00:02:00.679 Debug ProviderManager: Saving image to /var/db/emby-server/metadata/library/d5/d51b8edb0be7e149fcec94ae6d9ab0f1/poster.jpg 2020-06-16 00:02:00.765 Debug App: FolderImageProvider reports change to 9535 - /mnt/Streamer/סרטי×/G.I.Jane (1997) 2020-06-16 00:02:00.765 Debug App: Running FolderImageProvider for /mnt/Streamer/סרטי×/G.I.Jane (1997) 2020-06-16 00:02:00.848 Debug ProviderManager: Saving image to /var/db/emby-server/metadata/library/5f/5f436822d0d4582c4aba0d226491c9f8/poster.jpg 2020-06-16 00:02:00.954 Debug App: FolderImageProvider reports change to 10167 - /mnt/Streamer/סרטי×/Contagion (2011) 2020-06-16 00:02:00.954 Debug App: Running FolderImageProvider for /mnt/Streamer/סרטי×/Contagion (2011) 2020-06-16 00:02:01.024 Debug ProviderManager: Saving image to /var/db/emby-server/metadata/library/d8/d85d1e33c5d59e93bb6d753312aec086/poster.jpg 2020-06-16 00:02:01.321 Debug App: FolderImageProvider reports change to 252 - /var/db/emby-server/root 2020-06-16 00:02:01.321 Debug App: Running FolderImageProvider for /var/db/emby-server/root 2020-06-16 00:02:01.322 Debug XmlSerializer: Deserializing file /var/db/emby-server/root/default/סדרות/options.xml 2020-06-16 00:02:01.343 Debug XmlSerializer: Deserializing file /var/db/emby-server/root/default/סרטי משפחה/options.xml 2020-06-16 00:02:01.343 Debug XmlSerializer: Deserializing file /var/db/emby-server/root/default/סרטי×/options.xml 2020-06-16 00:02:01.355 Debug XmlSerializer: Deserializing file /var/db/emby-server/root/default/סדרות/options.xml 2020-06-16 00:02:01.356 Debug XmlSerializer: Deserializing file /var/db/emby-server/root/default/סרטי משפחה/options.xml 2020-06-16 00:02:01.357 Debug XmlSerializer: Deserializing file /var/db/emby-server/root/default/סרטי×/options.xml 2020-06-16 00:02:01.357 Debug XmlSerializer: Deserializing file /var/db/emby-server/root/default/סדרות/options.xml 2020-06-16 00:02:01.358 Debug XmlSerializer: Deserializing file /var/db/emby-server/root/default/סדרות/options.xml 2020-06-16 00:02:01.360 Debug XmlSerializer: Deserializing file /var/db/emby-server/root/default/סרטי משפחה/options.xml 2020-06-16 00:02:01.361 Debug XmlSerializer: Deserializing file /var/db/emby-server/root/default/סרטי משפחה/options.xml 2020-06-16 00:02:01.362 Debug XmlSerializer: Deserializing file /var/db/emby-server/root/default/סרטי×/options.xml 2020-06-16 00:02:01.363 Debug XmlSerializer: Deserializing file /var/db/emby-server/root/default/סרטי×/options.xml 2020-06-16 00:02:01.366 Debug XmlSerializer: Deserializing file /var/db/emby-server/root/default/סדרות/options.xml 2020-06-16 00:02:01.376 Debug XmlSerializer: Deserializing file /var/db/emby-server/root/default/סדרות/options.xml 2020-06-16 00:02:01.379 Debug XmlSerializer: Deserializing file /var/db/emby-server/root/default/סרטי×/options.xml 2020-06-16 00:02:01.380 Debug XmlSerializer: Deserializing file /var/db/emby-server/root/default/סרטי×/options.xml 2020-06-16 00:02:01.383 Debug XmlSerializer: Deserializing file /var/db/emby-server/root/default/סרטי משפחה/options.xml 2020-06-16 00:02:01.383 Debug XmlSerializer: Deserializing file /var/db/emby-server/root/default/סרטי משפחה/options.xml 2020-06-16 00:02:01.386 Debug App: Running post-scan task TvdbPrescanTask 2020-06-16 00:02:01.392 Debug App: Running post-scan task ArtistsPostScanTask 2020-06-16 00:02:01.394 Debug App: Running post-scan task GenresPostScanTask 2020-06-16 00:02:01.401 Debug App: GenreImageProvider reports change to 2254 - /var/db/emby-server/metadata/Genre/מדע ×‘×“×™×•× ×™ 2020-06-16 00:02:01.406 Debug App: GenreImageProvider reports change to 2255 - /var/db/emby-server/metadata/Genre/מותחן 2020-06-16 00:02:01.406 Debug App: GenreImageProvider reports change to 2256 - /var/db/emby-server/metadata/Genre/מלחמה 2020-06-16 00:02:01.407 Debug App: GenreImageProvider reports change to 2257 - /var/db/emby-server/metadata/Genre/מסתורין 2020-06-16 00:02:01.407 Debug App: GenreImageProvider reports change to 2258 - /var/db/emby-server/metadata/Genre/משפחה 2020-06-16 00:02:01.408 Debug App: GenreImageProvider reports change to 2259 - /var/db/emby-server/metadata/Genre/×¤× ×˜×–×™×” 2020-06-16 00:02:01.408 Debug App: GenreImageProvider reports change to 2260 - /var/db/emby-server/metadata/Genre/פשע 2020-06-16 00:02:01.409 Debug App: GenreImageProvider reports change to 2261 - /var/db/emby-server/metadata/Genre/קומדיה 2020-06-16 00:02:01.409 Debug App: GenreImageProvider reports change to 2297 - /var/db/emby-server/metadata/Genre/×ימה 2020-06-16 00:02:01.410 Debug App: GenreImageProvider reports change to 2363 - /var/db/emby-server/metadata/Genre/×קשן 2020-06-16 00:02:01.410 Debug App: GenreImageProvider reports change to 2364 - /var/db/emby-server/metadata/Genre/דרמה 2020-06-16 00:02:01.411 Debug App: GenreImageProvider reports change to 2365 - /var/db/emby-server/metadata/Genre/הרפתק×ות 2020-06-16 00:02:01.414 Debug App: GenreImageProvider reports change to 5698 - /var/db/emby-server/metadata/Genre/Sci-Fi 2020-06-16 00:02:01.414 Debug App: Running GenreImageProvider for /var/db/emby-server/metadata/Genre/Sci-Fi 2020-06-16 00:02:01.418 Debug App: Running post-scan task StudiosPostScanTask 2020-06-16 00:02:01.498 Debug App: Running post-scan task TagsPostScanTask 2020-06-16 00:02:01.499 Debug App: Running post-scan task CleanDatabaseScheduledTask 2020-06-16 00:02:01.578 Debug TaskManager: Scan media library Completed after 0 minute(s) and 30 seconds 2020-06-16 02:00:00.021 Debug TaskManager: DailyTrigger fired for task: Thumbnail image extraction 2020-06-16 02:00:00.021 Debug TaskManager: Queueing task ChapterImagesTask 2020-06-16 02:00:00.022 Debug TaskManager: Executing Thumbnail image extraction 2020-06-16 02:00:00.022 Debug TaskManager: Scheduled task Thumbnail image extraction will run with a time limit of 240 minutes 2020-06-16 02:00:00.480 Debug TaskManager: Thumbnail image extraction Completed after 0 minute(s) and 0 seconds 2020-06-16 02:12:30.621 Info HttpServer: HTTP HEAD https://mydomain.domain:8920/. UserAgent: Mozilla/5.0+(compatible; UptimeRobot/2.0; http://www.status.mydomain.domain/) 2020-06-16 02:12:30.621 Info HttpServer: HTTP Response 302 to 216.245.221.84. Time: 0ms. https://mydomain.domain:8920/ 2020-06-16 02:12:55.853 Info HttpServer: HTTP GET https://mydomain.domain:8920/. UserAgent: Mozilla/5.0+(compatible; UptimeRobot/2.0; http://www.status.mydomain.domain/) 2020-06-16 02:12:55.853 Info HttpServer: HTTP Response 302 to 216.245.221.84. Time: 0ms. https://mydomain.domain:8920/ 2020-06-16 02:17:54.704 Info HttpServer: HTTP HEAD https://mydomain.domain:8920/. UserAgent: Mozilla/5.0+(compatible; UptimeRobot/2.0; http://www.status.mydomain.domain/) 2020-06-16 02:17:54.704 Info HttpServer: HTTP Response 302 to 216.245.221.84. Time: 0ms. https://mydomain.domain:8920/ 2020-06-16 02:18:16.436 Info HttpServer: HTTP GET https://mydomain.domain:8920/. UserAgent: Mozilla/5.0+(compatible; UptimeRobot/2.0; http://www.status.mydomain.domain/) 2020-06-16 02:18:16.436 Info HttpServer: HTTP Response 302 to 216.245.221.84. Time: 0ms. https://mydomain.domain:8920/ 2020-06-16 02:23:15.833 Info HttpServer: HTTP HEAD https://mydomain.domain:8920/. UserAgent: Mozilla/5.0+(compatible; UptimeRobot/2.0; http://www.status.mydomain.domain/) 2020-06-16 02:23:15.833 Info HttpServer: HTTP Response 302 to 216.245.221.84. Time: 0ms. https://mydomain.domain:8920/ 2020-06-16 02:23:37.594 Info HttpServer: HTTP GET https://mydomain.domain:8920/. UserAgent: Mozilla/5.0+(compatible; UptimeRobot/2.0; http://www.status.mydomain.domain/) 2020-06-16 02:23:37.595 Info HttpServer: HTTP Response 302 to 216.245.221.84. Time: 0ms. https://mydomain.domain:8920/ 2020-06-16 02:28:37.488 Info HttpServer: HTTP HEAD https://mydomain.domain:8920/. UserAgent: Mozilla/5.0+(compatible; UptimeRobot/2.0; http://www.status.mydomain.domain/) 2020-06-16 02:28:37.489 Info HttpServer: HTTP Response 302 to 216.245.221.84. Time: 0ms. https://mydomain.domain:8920/ 2020-06-16 02:29:02.302 Info HttpServer: HTTP GET https://mydomain.domain:8920/. UserAgent: Mozilla/5.0+(compatible; UptimeRobot/2.0; http://www.status.mydomain.domain/) 2020-06-16 02:29:02.302 Info HttpServer: HTTP Response 302 to 216.245.221.84. Time: 0ms. https://mydomain.domain:8920/ 2020-06-16 02:34:00.112 Info HttpServer: HTTP HEAD https://mydomain.domain:8920/. UserAgent: Mozilla/5.0+(compatible; UptimeRobot/2.0; http://www.status.mydomain.domain/) 2020-06-16 02:34:00.112 Info HttpServer: HTTP Response 302 to 216.245.221.84. Time: 0ms. https://mydomain.domain:8920/ 2020-06-16 02:34:21.956 Info HttpServer: HTTP GET https://mydomain.domain:8920/. UserAgent: Mozilla/5.0+(compatible; UptimeRobot/2.0; http://www.status.mydomain.domain/) 2020-06-16 02:34:21.957 Info HttpServer: HTTP Response 302 to 216.245.221.84. Time: 0ms. https://mydomain.domain:8920/ 2020-06-16 02:39:21.956 Info HttpServer: HTTP HEAD https://mydomain.domain:8920/. UserAgent: Mozilla/5.0+(compatible; UptimeRobot/2.0; http://www.status.mydomain.domain/) 2020-06-16 02:39:21.956 Info HttpServer: HTTP Response 302 to 216.245.221.84. Time: 0ms. https://mydomain.domain:8920/ 2020-06-16 02:39:43.685 Info HttpServer: HTTP GET https://mydomain.domain:8920/. UserAgent: Mozilla/5.0+(compatible; UptimeRobot/2.0; http://www.status.mydomain.domain/) 2020-06-16 02:39:43.685 Info HttpServer: HTTP Response 302 to 216.245.221.84. Time: 0ms. https://mydomain.domain:8920/ 2020-06-16 02:44:42.826 Info HttpServer: HTTP HEAD https://mydomain.domain:8920/. UserAgent: Mozilla/5.0+(compatible; UptimeRobot/2.0; http://www.status.mydomain.domain/) 2020-06-16 02:44:42.826 Info HttpServer: HTTP Response 302 to 216.245.221.84. Time: 0ms. https://mydomain.domain:8920/ 2020-06-16 02:45:04.577 Info HttpServer: HTTP GET https://mydomain.domain:8920/. UserAgent: Mozilla/5.0+(compatible; UptimeRobot/2.0; http://www.status.mydomain.domain/) 2020-06-16 02:45:04.577 Info HttpServer: HTTP Response 302 to 216.245.221.84. Time: 0ms. https://mydomain.domain:8920/ 2020-06-16 02:50:03.803 Info HttpServer: HTTP HEAD https://mydomain.domain:8920/. UserAgent: Mozilla/5.0+(compatible; UptimeRobot/2.0; http://www.status.mydomain.domain/) 2020-06-16 02:50:03.803 Info HttpServer: HTTP Response 302 to 216.245.221.84. Time: 0ms. https://mydomain.domain:8920/ 2020-06-16 02:50:43.007 Info HttpServer: HTTP GET https://mydomain.domain:8920/. UserAgent: Mozilla/5.0+(compatible; UptimeRobot/2.0; http://www.status.mydomain.domain/) 2020-06-16 02:50:43.008 Info HttpServer: HTTP Response 302 to 216.245.221.84. Time: 0ms. https://mydomain.domain:8920/ 2020-06-16 02:55:25.559 Info HttpServer: HTTP HEAD https://mydomain.domain:8920/. UserAgent: Mozilla/5.0+(compatible; UptimeRobot/2.0; http://www.status.mydomain.domain/) 2020-06-16 02:55:25.559 Info HttpServer: HTTP Response 302 to 216.245.221.84. Time: 0ms. https://mydomain.domain:8920/ 2020-06-16 02:55:47.516 Info HttpServer: HTTP GET https://mydomain.domain:8920/. UserAgent: Mozilla/5.0+(compatible; UptimeRobot/2.0; http://www.status.mydomain.domain/) 2020-06-16 02:55:47.516 Info HttpServer: HTTP Response 302 to 216.245.221.84. Time: 0ms. https://mydomain.domain:8920/ 2020-06-16 03:00:46.783 Info HttpServer: HTTP HEAD https://mydomain.domain:8920/. UserAgent: Mozilla/5.0+(compatible; UptimeRobot/2.0; http://www.status.mydomain.domain/) 2020-06-16 03:00:46.784 Info HttpServer: HTTP Response 302 to 216.245.221.84. Time: 0ms. https://mydomain.domain:8920/ 2020-06-16 03:01:08.701 Info HttpServer: HTTP GET https://mydomain.domain:8920/. UserAgent: Mozilla/5.0+(compatible; UptimeRobot/2.0; http://www.status.mydomain.domain/) 2020-06-16 03:01:08.701 Info HttpServer: HTTP Response 302 to 216.245.221.84. Time: 0ms. https://mydomain.domain:8920/ 2020-06-16 03:01:59.205 Info HttpServer: HTTP GET https://mydomain.domain:8920/. UserAgent: Mozilla/5.0+(compatible; UptimeRobot/2.0; http://www.status.mydomain.domain/) 2020-06-16 03:01:59.206 Info HttpServer: HTTP Response 302 to 54.67.10.127. Time: 0ms. https://mydomain.domain:8920/ 2020-06-16 03:02:01.857 Info HttpServer: HTTP GET https://mydomain.domain:8920/. UserAgent: Mozilla/5.0+(compatible; UptimeRobot/2.0; http://www.status.mydomain.domain/) 2020-06-16 03:02:01.857 Info HttpServer: HTTP Response 302 to 54.64.67.106. Time: 0ms. https://mydomain.domain:8920/ 2020-06-16 11:54:13.335 Debug TaskManager: IntervalTrigger fired for task: Refresh Internet Channels 2020-06-16 11:54:13.335 Debug TaskManager: Queueing task RefreshChannelsScheduledTask 2020-06-16 11:54:13.335 Debug TaskManager: Executing Refresh Internet Channels 2020-06-16 11:54:13.335 Debug TaskManager: Refresh Internet Channels Completed after 0 minute(s) and 0 seconds 2020-06-16 12:01:31.600 Debug TaskManager: IntervalTrigger fired for task: Scan media library 2020-06-16 12:01:31.600 Debug TaskManager: Queueing task RefreshMediaLibraryTask 2020-06-16 12:01:31.600 Debug TaskManager: Executing Scan media library 2020-06-16 12:01:31.640 Debug App: FolderImageProvider reports change to 252 - /var/db/emby-server/root 2020-06-16 12:01:31.640 Debug App: Running FolderImageProvider for /var/db/emby-server/root 2020-06-16 12:01:31.754 Debug XmlSerializer: Deserializing file /var/db/emby-server/root/default/סדרות/options.xml 2020-06-16 12:01:31.803 Debug XmlSerializer: Deserializing file /var/db/emby-server/root/default/סרטי משפחה/options.xml 2020-06-16 12:01:31.845 Debug XmlSerializer: Deserializing file /var/db/emby-server/root/default/סרטי×/options.xml 2020-06-16 12:01:32.038 Debug App: FolderImageProvider reports change to 2306 - /var/db/emby-server/root/default 2020-06-16 12:01:32.039 Debug App: Running FolderImageProvider for /var/db/emby-server/root/default 2020-06-16 12:01:32.076 Debug ProviderManager: Saving image to /var/db/emby-server/metadata/library/e9/e9d5075a555c1cbc394eec4cef295274/poster.png 2020-06-16 12:01:32.477 Debug XmlSerializer: Deserializing file /var/db/emby-server/root/default/סדרות/options.xml 2020-06-16 12:01:32.478 Debug XmlSerializer: Deserializing file /var/db/emby-server/root/default/סרטי משפחה/options.xml 2020-06-16 12:01:32.479 Debug XmlSerializer: Deserializing file /var/db/emby-server/root/default/סרטי×/options.xml 2020-06-16 12:01:32.479 Debug XmlSerializer: Deserializing file /var/db/emby-server/root/default/סדרות/options.xml 2020-06-16 12:01:32.480 Debug XmlSerializer: Deserializing file /var/db/emby-server/root/default/סדרות/options.xml 2020-06-16 12:01:32.509 Debug XmlSerializer: Deserializing file /var/db/emby-server/root/default/סרטי משפחה/options.xml 2020-06-16 12:01:32.509 Debug XmlSerializer: Deserializing file /var/db/emby-server/root/default/סרטי משפחה/options.xml 2020-06-16 12:01:32.510 Debug XmlSerializer: Deserializing file /var/db/emby-server/root/default/סרטי×/options.xml 2020-06-16 12:01:32.511 Debug XmlSerializer: Deserializing file /var/db/emby-server/root/default/סרטי×/options.xml 2020-06-16 12:01:32.527 Debug XmlSerializer: Deserializing file /var/db/emby-server/root/default/סדרות/options.xml 2020-06-16 12:01:32.527 Debug XmlSerializer: Deserializing file /var/db/emby-server/root/default/סדרות/options.xml 2020-06-16 12:01:32.529 Debug XmlSerializer: Deserializing file /var/db/emby-server/root/default/סרטי×/options.xml 2020-06-16 12:01:32.530 Debug XmlSerializer: Deserializing file /var/db/emby-server/root/default/סרטי×/options.xml 2020-06-16 12:01:32.533 Debug XmlSerializer: Deserializing file /var/db/emby-server/root/default/סרטי משפחה/options.xml 2020-06-16 12:01:32.533 Debug XmlSerializer: Deserializing file /var/db/emby-server/root/default/סרטי משפחה/options.xml 2020-06-16 12:01:32.535 Debug XmlSerializer: Deserializing file /var/db/emby-server/root/default/סדרות/options.xml 2020-06-16 12:01:32.536 Debug XmlSerializer: Deserializing file /var/db/emby-server/root/default/סרטי משפחה/options.xml 2020-06-16 12:01:32.536 Debug XmlSerializer: Deserializing file /var/db/emby-server/root/default/סרטי×/options.xml 2020-06-16 12:01:44.085 Debug App: FolderImageProvider reports change to 4888 - /mnt/Streamer/סדרות/The 100/Season 4/Episode 13 2020-06-16 12:01:44.085 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/The 100/Season 4/Episode 13 2020-06-16 12:01:44.267 Debug App: FolderImageProvider reports change to 4910 - /mnt/Streamer/סדרות/The 100/Season 5/Episode 1 2020-06-16 12:01:44.267 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/The 100/Season 5/Episode 1 2020-06-16 12:01:44.269 Debug App: FolderImageProvider reports change to 4911 - /mnt/Streamer/סדרות/The 100/Season 5/Episode 10 2020-06-16 12:01:44.269 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/The 100/Season 5/Episode 10 2020-06-16 12:01:44.270 Debug App: FolderImageProvider reports change to 4912 - /mnt/Streamer/סדרות/The 100/Season 5/Episode 11 2020-06-16 12:01:44.270 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/The 100/Season 5/Episode 11 2020-06-16 12:01:44.271 Debug App: FolderImageProvider reports change to 4913 - /mnt/Streamer/סדרות/The 100/Season 5/Episode 12 2020-06-16 12:01:44.271 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/The 100/Season 5/Episode 12 2020-06-16 12:01:44.272 Debug App: FolderImageProvider reports change to 4914 - /mnt/Streamer/סדרות/The 100/Season 5/Episode 13 2020-06-16 12:01:44.272 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/The 100/Season 5/Episode 13 2020-06-16 12:01:44.273 Debug App: FolderImageProvider reports change to 4915 - /mnt/Streamer/סדרות/The 100/Season 5/Episode 2 2020-06-16 12:01:44.273 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/The 100/Season 5/Episode 2 2020-06-16 12:01:44.274 Debug App: FolderImageProvider reports change to 4916 - /mnt/Streamer/סדרות/The 100/Season 5/Episode 3 2020-06-16 12:01:44.274 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/The 100/Season 5/Episode 3 2020-06-16 12:01:44.291 Debug App: FolderImageProvider reports change to 4917 - /mnt/Streamer/סדרות/The 100/Season 5/Episode 4 2020-06-16 12:01:44.291 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/The 100/Season 5/Episode 4 2020-06-16 12:01:44.319 Debug App: FolderImageProvider reports change to 4918 - /mnt/Streamer/סדרות/The 100/Season 5/Episode 5 2020-06-16 12:01:44.319 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/The 100/Season 5/Episode 5 2020-06-16 12:01:44.339 Debug App: FolderImageProvider reports change to 4919 - /mnt/Streamer/סדרות/The 100/Season 5/Episode 6 2020-06-16 12:01:44.339 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/The 100/Season 5/Episode 6 2020-06-16 12:01:44.370 Debug App: FolderImageProvider reports change to 4920 - /mnt/Streamer/סדרות/The 100/Season 5/Episode 7 2020-06-16 12:01:44.370 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/The 100/Season 5/Episode 7 2020-06-16 12:01:44.371 Debug App: FolderImageProvider reports change to 4921 - /mnt/Streamer/סדרות/The 100/Season 5/Episode 8 2020-06-16 12:01:44.371 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/The 100/Season 5/Episode 8 2020-06-16 12:01:44.372 Debug App: FolderImageProvider reports change to 4922 - /mnt/Streamer/סדרות/The 100/Season 5/Episode 9 2020-06-16 12:01:44.372 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/The 100/Season 5/Episode 9 2020-06-16 12:01:45.460 Debug App: FolderImageProvider reports change to 10107 - /mnt/Streamer/סדרות/The Good Place/Season 4/Episode 1 2020-06-16 12:01:45.460 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/The Good Place/Season 4/Episode 1 2020-06-16 12:01:45.476 Debug App: FolderImageProvider reports change to 10108 - /mnt/Streamer/סדרות/The Good Place/Season 4/Episode 10 2020-06-16 12:01:45.476 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/The Good Place/Season 4/Episode 10 2020-06-16 12:01:45.510 Debug App: FolderImageProvider reports change to 10109 - /mnt/Streamer/סדרות/The Good Place/Season 4/Episode 11 2020-06-16 12:01:45.510 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/The Good Place/Season 4/Episode 11 2020-06-16 12:01:45.511 Debug App: FolderImageProvider reports change to 10110 - /mnt/Streamer/סדרות/The Good Place/Season 4/Episode 12 2020-06-16 12:01:45.511 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/The Good Place/Season 4/Episode 12 2020-06-16 12:01:45.512 Debug App: FolderImageProvider reports change to 10111 - /mnt/Streamer/סדרות/The Good Place/Season 4/Episode 13 2020-06-16 12:01:45.512 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/The Good Place/Season 4/Episode 13 2020-06-16 12:01:45.513 Debug App: FolderImageProvider reports change to 10112 - /mnt/Streamer/סדרות/The Good Place/Season 4/Episode 2 2020-06-16 12:01:45.513 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/The Good Place/Season 4/Episode 2 2020-06-16 12:01:45.514 Debug App: FolderImageProvider reports change to 10113 - /mnt/Streamer/סדרות/The Good Place/Season 4/Episode 3 2020-06-16 12:01:45.514 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/The Good Place/Season 4/Episode 3 2020-06-16 12:01:45.515 Debug App: FolderImageProvider reports change to 10114 - /mnt/Streamer/סדרות/The Good Place/Season 4/Episode 4 2020-06-16 12:01:45.515 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/The Good Place/Season 4/Episode 4 2020-06-16 12:01:45.516 Debug App: FolderImageProvider reports change to 10115 - /mnt/Streamer/סדרות/The Good Place/Season 4/Episode 5 2020-06-16 12:01:45.516 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/The Good Place/Season 4/Episode 5 2020-06-16 12:01:45.517 Debug App: FolderImageProvider reports change to 10116 - /mnt/Streamer/סדרות/The Good Place/Season 4/Episode 6 2020-06-16 12:01:45.517 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/The Good Place/Season 4/Episode 6 2020-06-16 12:01:45.531 Debug App: FolderImageProvider reports change to 10117 - /mnt/Streamer/סדרות/The Good Place/Season 4/Episode 7 2020-06-16 12:01:45.531 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/The Good Place/Season 4/Episode 7 2020-06-16 12:01:45.533 Debug App: FolderImageProvider reports change to 10118 - /mnt/Streamer/סדרות/The Good Place/Season 4/Episode 8 2020-06-16 12:01:45.533 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/The Good Place/Season 4/Episode 8 2020-06-16 12:01:45.534 Debug App: FolderImageProvider reports change to 10119 - /mnt/Streamer/סדרות/The Good Place/Season 4/Episode 9 2020-06-16 12:01:45.534 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/The Good Place/Season 4/Episode 9 2020-06-16 12:01:46.119 Debug App: FolderImageProvider reports change to 4531 - /mnt/Streamer/סדרות/Agents Of S.H.I.E.L.D/Season 5/Episode 10 2020-06-16 12:01:46.119 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Agents Of S.H.I.E.L.D/Season 5/Episode 10 2020-06-16 12:01:46.120 Debug App: FolderImageProvider reports change to 4532 - /mnt/Streamer/סדרות/Agents Of S.H.I.E.L.D/Season 5/Episode 11 2020-06-16 12:01:46.120 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Agents Of S.H.I.E.L.D/Season 5/Episode 11 2020-06-16 12:01:46.141 Debug App: FolderImageProvider reports change to 4533 - /mnt/Streamer/סדרות/Agents Of S.H.I.E.L.D/Season 5/Episode 12 2020-06-16 12:01:46.141 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Agents Of S.H.I.E.L.D/Season 5/Episode 12 2020-06-16 12:01:46.142 Debug App: FolderImageProvider reports change to 4534 - /mnt/Streamer/סדרות/Agents Of S.H.I.E.L.D/Season 5/Episode 13 2020-06-16 12:01:46.142 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Agents Of S.H.I.E.L.D/Season 5/Episode 13 2020-06-16 12:01:46.143 Debug App: FolderImageProvider reports change to 4535 - /mnt/Streamer/סדרות/Agents Of S.H.I.E.L.D/Season 5/Episode 14 2020-06-16 12:01:46.143 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Agents Of S.H.I.E.L.D/Season 5/Episode 14 2020-06-16 12:01:46.144 Debug App: FolderImageProvider reports change to 4536 - /mnt/Streamer/סדרות/Agents Of S.H.I.E.L.D/Season 5/Episode 15 2020-06-16 12:01:46.144 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Agents Of S.H.I.E.L.D/Season 5/Episode 15 2020-06-16 12:01:46.145 Debug App: FolderImageProvider reports change to 4537 - /mnt/Streamer/סדרות/Agents Of S.H.I.E.L.D/Season 5/Episode 16 2020-06-16 12:01:46.145 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Agents Of S.H.I.E.L.D/Season 5/Episode 16 2020-06-16 12:01:46.146 Debug App: FolderImageProvider reports change to 4538 - /mnt/Streamer/סדרות/Agents Of S.H.I.E.L.D/Season 5/Episode 17 2020-06-16 12:01:46.146 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Agents Of S.H.I.E.L.D/Season 5/Episode 17 2020-06-16 12:01:46.147 Debug App: FolderImageProvider reports change to 4539 - /mnt/Streamer/סדרות/Agents Of S.H.I.E.L.D/Season 5/Episode 18 2020-06-16 12:01:46.147 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Agents Of S.H.I.E.L.D/Season 5/Episode 18 2020-06-16 12:01:46.155 Debug App: FolderImageProvider reports change to 4540 - /mnt/Streamer/סדרות/Agents Of S.H.I.E.L.D/Season 5/Episode 19 2020-06-16 12:01:46.155 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Agents Of S.H.I.E.L.D/Season 5/Episode 19 2020-06-16 12:01:46.156 Debug App: FolderImageProvider reports change to 4541 - /mnt/Streamer/סדרות/Agents Of S.H.I.E.L.D/Season 5/Episode 20 2020-06-16 12:01:46.157 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Agents Of S.H.I.E.L.D/Season 5/Episode 20 2020-06-16 12:01:46.158 Debug App: FolderImageProvider reports change to 4542 - /mnt/Streamer/סדרות/Agents Of S.H.I.E.L.D/Season 5/Episode 21 2020-06-16 12:01:46.158 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Agents Of S.H.I.E.L.D/Season 5/Episode 21 2020-06-16 12:01:46.159 Debug App: FolderImageProvider reports change to 4543 - /mnt/Streamer/סדרות/Agents Of S.H.I.E.L.D/Season 5/Episode 22 2020-06-16 12:01:46.159 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Agents Of S.H.I.E.L.D/Season 5/Episode 22 2020-06-16 12:01:46.161 Debug App: FolderImageProvider reports change to 4547 - /mnt/Streamer/סדרות/Agents Of S.H.I.E.L.D/Season 5/Episode 6 2020-06-16 12:01:46.161 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Agents Of S.H.I.E.L.D/Season 5/Episode 6 2020-06-16 12:01:46.182 Debug App: FolderImageProvider reports change to 4548 - /mnt/Streamer/סדרות/Agents Of S.H.I.E.L.D/Season 5/Episode 7 2020-06-16 12:01:46.182 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Agents Of S.H.I.E.L.D/Season 5/Episode 7 2020-06-16 12:01:46.183 Debug App: FolderImageProvider reports change to 4549 - /mnt/Streamer/סדרות/Agents Of S.H.I.E.L.D/Season 5/Episode 8 2020-06-16 12:01:46.183 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Agents Of S.H.I.E.L.D/Season 5/Episode 8 2020-06-16 12:01:46.184 Debug App: FolderImageProvider reports change to 4550 - /mnt/Streamer/סדרות/Agents Of S.H.I.E.L.D/Season 5/Episode 9 2020-06-16 12:01:46.184 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Agents Of S.H.I.E.L.D/Season 5/Episode 9 2020-06-16 12:01:46.916 Debug App: FolderImageProvider reports change to 5470 - /mnt/Streamer/סדרות/Chernobyl/Season 1/Episode 2 2020-06-16 12:01:46.916 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Chernobyl/Season 1/Episode 2 2020-06-16 12:01:46.917 Debug App: FolderImageProvider reports change to 5471 - /mnt/Streamer/סדרות/Chernobyl/Season 1/Episode 3 2020-06-16 12:01:46.917 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Chernobyl/Season 1/Episode 3 2020-06-16 12:01:46.918 Debug App: FolderImageProvider reports change to 5472 - /mnt/Streamer/סדרות/Chernobyl/Season 1/Episode 4 2020-06-16 12:01:46.918 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Chernobyl/Season 1/Episode 4 2020-06-16 12:01:46.919 Debug App: FolderImageProvider reports change to 5473 - /mnt/Streamer/סדרות/Chernobyl/Season 1/Episode 5 2020-06-16 12:01:46.919 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Chernobyl/Season 1/Episode 5 2020-06-16 12:01:47.419 Debug App: FolderImageProvider reports change to 5495 - /mnt/Streamer/סדרות/Arrow/Season 7/Episode 1 2020-06-16 12:01:47.419 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Arrow/Season 7/Episode 1 2020-06-16 12:01:47.420 Debug App: FolderImageProvider reports change to 5496 - /mnt/Streamer/סדרות/Arrow/Season 7/Episode 10 2020-06-16 12:01:47.420 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Arrow/Season 7/Episode 10 2020-06-16 12:01:47.422 Debug App: FolderImageProvider reports change to 5497 - /mnt/Streamer/סדרות/Arrow/Season 7/Episode 11 2020-06-16 12:01:47.422 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Arrow/Season 7/Episode 11 2020-06-16 12:01:47.423 Debug App: FolderImageProvider reports change to 5498 - /mnt/Streamer/סדרות/Arrow/Season 7/Episode 12 2020-06-16 12:01:47.423 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Arrow/Season 7/Episode 12 2020-06-16 12:01:47.436 Debug App: FolderImageProvider reports change to 5499 - /mnt/Streamer/סדרות/Arrow/Season 7/Episode 13 2020-06-16 12:01:47.436 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Arrow/Season 7/Episode 13 2020-06-16 12:01:47.437 Debug App: FolderImageProvider reports change to 5500 - /mnt/Streamer/סדרות/Arrow/Season 7/Episode 14 2020-06-16 12:01:47.437 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Arrow/Season 7/Episode 14 2020-06-16 12:01:47.438 Debug App: FolderImageProvider reports change to 5501 - /mnt/Streamer/סדרות/Arrow/Season 7/Episode 15 2020-06-16 12:01:47.438 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Arrow/Season 7/Episode 15 2020-06-16 12:01:47.439 Debug App: FolderImageProvider reports change to 5502 - /mnt/Streamer/סדרות/Arrow/Season 7/Episode 16 2020-06-16 12:01:47.439 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Arrow/Season 7/Episode 16 2020-06-16 12:01:47.440 Debug App: FolderImageProvider reports change to 5503 - /mnt/Streamer/סדרות/Arrow/Season 7/Episode 17 2020-06-16 12:01:47.440 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Arrow/Season 7/Episode 17 2020-06-16 12:01:47.441 Debug App: FolderImageProvider reports change to 5504 - /mnt/Streamer/סדרות/Arrow/Season 7/Episode 18 2020-06-16 12:01:47.441 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Arrow/Season 7/Episode 18 2020-06-16 12:01:47.442 Debug App: FolderImageProvider reports change to 5505 - /mnt/Streamer/סדרות/Arrow/Season 7/Episode 19 2020-06-16 12:01:47.442 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Arrow/Season 7/Episode 19 2020-06-16 12:01:47.443 Debug App: FolderImageProvider reports change to 5506 - /mnt/Streamer/סדרות/Arrow/Season 7/Episode 2 2020-06-16 12:01:47.443 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Arrow/Season 7/Episode 2 2020-06-16 12:01:47.444 Debug App: FolderImageProvider reports change to 5507 - /mnt/Streamer/סדרות/Arrow/Season 7/Episode 20 2020-06-16 12:01:47.444 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Arrow/Season 7/Episode 20 2020-06-16 12:01:47.445 Debug App: FolderImageProvider reports change to 5508 - /mnt/Streamer/סדרות/Arrow/Season 7/Episode 21 2020-06-16 12:01:47.445 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Arrow/Season 7/Episode 21 2020-06-16 12:01:47.446 Debug App: FolderImageProvider reports change to 5509 - /mnt/Streamer/סדרות/Arrow/Season 7/Episode 22 2020-06-16 12:01:47.446 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Arrow/Season 7/Episode 22 2020-06-16 12:01:47.447 Debug App: FolderImageProvider reports change to 5510 - /mnt/Streamer/סדרות/Arrow/Season 7/Episode 3 2020-06-16 12:01:47.447 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Arrow/Season 7/Episode 3 2020-06-16 12:01:47.476 Debug App: FolderImageProvider reports change to 5511 - /mnt/Streamer/סדרות/Arrow/Season 7/Episode 4 2020-06-16 12:01:47.476 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Arrow/Season 7/Episode 4 2020-06-16 12:01:47.477 Debug App: FolderImageProvider reports change to 5512 - /mnt/Streamer/סדרות/Arrow/Season 7/Episode 5 2020-06-16 12:01:47.477 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Arrow/Season 7/Episode 5 2020-06-16 12:01:47.478 Debug App: FolderImageProvider reports change to 5513 - /mnt/Streamer/סדרות/Arrow/Season 7/Episode 6 2020-06-16 12:01:47.478 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Arrow/Season 7/Episode 6 2020-06-16 12:01:47.479 Debug App: FolderImageProvider reports change to 5514 - /mnt/Streamer/סדרות/Arrow/Season 7/Episode 7 2020-06-16 12:01:47.479 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Arrow/Season 7/Episode 7 2020-06-16 12:01:47.480 Debug App: FolderImageProvider reports change to 5515 - /mnt/Streamer/סדרות/Arrow/Season 7/Episode 8 2020-06-16 12:01:47.480 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Arrow/Season 7/Episode 8 2020-06-16 12:01:47.490 Debug App: FolderImageProvider reports change to 5516 - /mnt/Streamer/סדרות/Arrow/Season 7/Episode 9 2020-06-16 12:01:47.490 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Arrow/Season 7/Episode 9 2020-06-16 12:01:48.645 Debug App: FolderImageProvider reports change to 6201 - /mnt/Streamer/סדרות/Homeland/Season 1/Episode 10 2020-06-16 12:01:48.645 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 1/Episode 10 2020-06-16 12:01:48.646 Debug App: FolderImageProvider reports change to 6202 - /mnt/Streamer/סדרות/Homeland/Season 1/Episode 11 2020-06-16 12:01:48.646 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 1/Episode 11 2020-06-16 12:01:48.647 Debug App: FolderImageProvider reports change to 6203 - /mnt/Streamer/סדרות/Homeland/Season 1/Episode 12 2020-06-16 12:01:48.647 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 1/Episode 12 2020-06-16 12:01:48.694 Debug App: FolderImageProvider reports change to 6210 - /mnt/Streamer/סדרות/Homeland/Season 1/Episode 8 2020-06-16 12:01:48.694 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 1/Episode 8 2020-06-16 12:01:48.695 Debug App: FolderImageProvider reports change to 6211 - /mnt/Streamer/סדרות/Homeland/Season 1/Episode 9 2020-06-16 12:01:48.695 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 1/Episode 9 2020-06-16 12:01:48.735 Debug App: FolderImageProvider reports change to 6224 - /mnt/Streamer/סדרות/Homeland/Season 2/Episode 1 2020-06-16 12:01:48.735 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 2/Episode 1 2020-06-16 12:01:48.736 Debug App: FolderImageProvider reports change to 6225 - /mnt/Streamer/סדרות/Homeland/Season 2/Episode 10 2020-06-16 12:01:48.737 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 2/Episode 10 2020-06-16 12:01:48.738 Debug App: FolderImageProvider reports change to 6226 - /mnt/Streamer/סדרות/Homeland/Season 2/Episode 11 2020-06-16 12:01:48.738 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 2/Episode 11 2020-06-16 12:01:48.738 Debug App: FolderImageProvider reports change to 6227 - /mnt/Streamer/סדרות/Homeland/Season 2/Episode 12 2020-06-16 12:01:48.738 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 2/Episode 12 2020-06-16 12:01:48.739 Debug App: FolderImageProvider reports change to 6228 - /mnt/Streamer/סדרות/Homeland/Season 2/Episode 2 2020-06-16 12:01:48.739 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 2/Episode 2 2020-06-16 12:01:48.740 Debug App: FolderImageProvider reports change to 6229 - /mnt/Streamer/סדרות/Homeland/Season 2/Episode 3 2020-06-16 12:01:48.740 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 2/Episode 3 2020-06-16 12:01:48.741 Debug App: FolderImageProvider reports change to 6230 - /mnt/Streamer/סדרות/Homeland/Season 2/Episode 4 2020-06-16 12:01:48.741 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 2/Episode 4 2020-06-16 12:01:48.742 Debug App: FolderImageProvider reports change to 6231 - /mnt/Streamer/סדרות/Homeland/Season 2/Episode 5 2020-06-16 12:01:48.742 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 2/Episode 5 2020-06-16 12:01:48.747 Debug App: FolderImageProvider reports change to 6232 - /mnt/Streamer/סדרות/Homeland/Season 2/Episode 6 2020-06-16 12:01:48.747 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 2/Episode 6 2020-06-16 12:01:48.748 Debug App: FolderImageProvider reports change to 6233 - /mnt/Streamer/סדרות/Homeland/Season 2/Episode 7 2020-06-16 12:01:48.748 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 2/Episode 7 2020-06-16 12:01:48.749 Debug App: FolderImageProvider reports change to 6234 - /mnt/Streamer/סדרות/Homeland/Season 2/Episode 8 2020-06-16 12:01:48.749 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 2/Episode 8 2020-06-16 12:01:48.773 Debug App: FolderImageProvider reports change to 6235 - /mnt/Streamer/סדרות/Homeland/Season 2/Episode 9 2020-06-16 12:01:48.773 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 2/Episode 9 2020-06-16 12:01:48.814 Debug App: FolderImageProvider reports change to 6248 - /mnt/Streamer/סדרות/Homeland/Season 3/Episode 1 2020-06-16 12:01:48.814 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 3/Episode 1 2020-06-16 12:01:48.815 Debug App: FolderImageProvider reports change to 6249 - /mnt/Streamer/סדרות/Homeland/Season 3/Episode 10 2020-06-16 12:01:48.816 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 3/Episode 10 2020-06-16 12:01:48.817 Debug App: FolderImageProvider reports change to 6251 - /mnt/Streamer/סדרות/Homeland/Season 3/Episode 12 2020-06-16 12:01:48.817 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 3/Episode 12 2020-06-16 12:01:48.818 Debug App: FolderImageProvider reports change to 6252 - /mnt/Streamer/סדרות/Homeland/Season 3/Episode 2 2020-06-16 12:01:48.818 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 3/Episode 2 2020-06-16 12:01:48.819 Debug App: FolderImageProvider reports change to 6253 - /mnt/Streamer/סדרות/Homeland/Season 3/Episode 3 2020-06-16 12:01:48.819 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 3/Episode 3 2020-06-16 12:01:48.820 Debug App: FolderImageProvider reports change to 6254 - /mnt/Streamer/סדרות/Homeland/Season 3/Episode 4 2020-06-16 12:01:48.820 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 3/Episode 4 2020-06-16 12:01:48.821 Debug App: FolderImageProvider reports change to 6255 - /mnt/Streamer/סדרות/Homeland/Season 3/Episode 5 2020-06-16 12:01:48.821 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 3/Episode 5 2020-06-16 12:01:48.822 Debug App: FolderImageProvider reports change to 6256 - /mnt/Streamer/סדרות/Homeland/Season 3/Episode 6 2020-06-16 12:01:48.822 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 3/Episode 6 2020-06-16 12:01:48.823 Debug App: FolderImageProvider reports change to 6257 - /mnt/Streamer/סדרות/Homeland/Season 3/Episode 7 2020-06-16 12:01:48.823 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 3/Episode 7 2020-06-16 12:01:48.824 Debug App: FolderImageProvider reports change to 6258 - /mnt/Streamer/סדרות/Homeland/Season 3/Episode 8 2020-06-16 12:01:48.824 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 3/Episode 8 2020-06-16 12:01:48.825 Debug App: FolderImageProvider reports change to 6259 - /mnt/Streamer/סדרות/Homeland/Season 3/Episode 9 2020-06-16 12:01:48.825 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 3/Episode 9 2020-06-16 12:01:48.930 Debug App: FolderImageProvider reports change to 6272 - /mnt/Streamer/סדרות/Homeland/Season 4/Episode 1 2020-06-16 12:01:48.930 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 4/Episode 1 2020-06-16 12:01:48.931 Debug App: FolderImageProvider reports change to 6273 - /mnt/Streamer/סדרות/Homeland/Season 4/Episode 10 2020-06-16 12:01:48.931 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 4/Episode 10 2020-06-16 12:01:48.932 Debug App: FolderImageProvider reports change to 6274 - /mnt/Streamer/סדרות/Homeland/Season 4/Episode 11 2020-06-16 12:01:48.932 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 4/Episode 11 2020-06-16 12:01:48.933 Debug App: FolderImageProvider reports change to 6275 - /mnt/Streamer/סדרות/Homeland/Season 4/Episode 12 2020-06-16 12:01:48.933 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 4/Episode 12 2020-06-16 12:01:48.934 Debug App: FolderImageProvider reports change to 6276 - /mnt/Streamer/סדרות/Homeland/Season 4/Episode 2 2020-06-16 12:01:48.934 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 4/Episode 2 2020-06-16 12:01:48.935 Debug App: FolderImageProvider reports change to 6277 - /mnt/Streamer/סדרות/Homeland/Season 4/Episode 3 2020-06-16 12:01:48.935 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 4/Episode 3 2020-06-16 12:01:48.936 Debug App: FolderImageProvider reports change to 6278 - /mnt/Streamer/סדרות/Homeland/Season 4/Episode 4 2020-06-16 12:01:48.936 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 4/Episode 4 2020-06-16 12:01:48.937 Debug App: FolderImageProvider reports change to 6279 - /mnt/Streamer/סדרות/Homeland/Season 4/Episode 5 2020-06-16 12:01:48.937 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 4/Episode 5 2020-06-16 12:01:48.938 Debug App: FolderImageProvider reports change to 6280 - /mnt/Streamer/סדרות/Homeland/Season 4/Episode 6 2020-06-16 12:01:48.938 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 4/Episode 6 2020-06-16 12:01:48.939 Debug App: FolderImageProvider reports change to 6281 - /mnt/Streamer/סדרות/Homeland/Season 4/Episode 7 2020-06-16 12:01:48.939 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 4/Episode 7 2020-06-16 12:01:48.940 Debug App: FolderImageProvider reports change to 6282 - /mnt/Streamer/סדרות/Homeland/Season 4/Episode 8 2020-06-16 12:01:48.940 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 4/Episode 8 2020-06-16 12:01:48.941 Debug App: FolderImageProvider reports change to 6283 - /mnt/Streamer/סדרות/Homeland/Season 4/Episode 9 2020-06-16 12:01:48.941 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 4/Episode 9 2020-06-16 12:01:48.968 Debug App: FolderImageProvider reports change to 6296 - /mnt/Streamer/סדרות/Homeland/Season 5/Episode 1 2020-06-16 12:01:48.968 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 5/Episode 1 2020-06-16 12:01:48.969 Debug App: FolderImageProvider reports change to 6297 - /mnt/Streamer/סדרות/Homeland/Season 5/Episode 10 2020-06-16 12:01:48.970 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 5/Episode 10 2020-06-16 12:01:48.970 Debug App: FolderImageProvider reports change to 6298 - /mnt/Streamer/סדרות/Homeland/Season 5/Episode 11 2020-06-16 12:01:48.970 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 5/Episode 11 2020-06-16 12:01:48.973 Debug App: FolderImageProvider reports change to 6300 - /mnt/Streamer/סדרות/Homeland/Season 5/Episode 2 2020-06-16 12:01:48.974 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 5/Episode 2 2020-06-16 12:01:48.974 Debug App: FolderImageProvider reports change to 6301 - /mnt/Streamer/סדרות/Homeland/Season 5/Episode 3 2020-06-16 12:01:48.974 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 5/Episode 3 2020-06-16 12:01:48.994 Debug App: FolderImageProvider reports change to 6416 - /mnt/Streamer/סדרות/Homeland/Season 5/Episode 4 2020-06-16 12:01:48.994 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 5/Episode 4 2020-06-16 12:01:49.009 Debug App: FolderImageProvider reports change to 6417 - /mnt/Streamer/סדרות/Homeland/Season 5/Episode 5 2020-06-16 12:01:49.009 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 5/Episode 5 2020-06-16 12:01:49.026 Debug App: FolderImageProvider reports change to 6418 - /mnt/Streamer/סדרות/Homeland/Season 5/Episode 6 2020-06-16 12:01:49.026 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 5/Episode 6 2020-06-16 12:01:49.029 Debug App: FolderImageProvider reports change to 6423 - /mnt/Streamer/סדרות/Homeland/Season 5/Episode 7 2020-06-16 12:01:49.029 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 5/Episode 7 2020-06-16 12:01:49.030 Debug App: FolderImageProvider reports change to 6424 - /mnt/Streamer/סדרות/Homeland/Season 5/Episode 8 2020-06-16 12:01:49.030 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 5/Episode 8 2020-06-16 12:01:49.031 Debug App: FolderImageProvider reports change to 6425 - /mnt/Streamer/סדרות/Homeland/Season 5/Episode 9 2020-06-16 12:01:49.031 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 5/Episode 9 2020-06-16 12:01:49.058 Debug App: FolderImageProvider reports change to 6432 - /mnt/Streamer/סדרות/Homeland/Season 6/Episode 1 2020-06-16 12:01:49.058 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 6/Episode 1 2020-06-16 12:01:49.059 Debug App: FolderImageProvider reports change to 6433 - /mnt/Streamer/סדרות/Homeland/Season 6/Episode 10 2020-06-16 12:01:49.059 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 6/Episode 10 2020-06-16 12:01:49.060 Debug App: FolderImageProvider reports change to 6434 - /mnt/Streamer/סדרות/Homeland/Season 6/Episode 11 2020-06-16 12:01:49.060 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 6/Episode 11 2020-06-16 12:01:49.076 Debug App: FolderImageProvider reports change to 6435 - /mnt/Streamer/סדרות/Homeland/Season 6/Episode 12 2020-06-16 12:01:49.076 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 6/Episode 12 2020-06-16 12:01:49.077 Debug App: FolderImageProvider reports change to 6436 - /mnt/Streamer/סדרות/Homeland/Season 6/Episode 2 2020-06-16 12:01:49.077 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 6/Episode 2 2020-06-16 12:01:49.077 Debug App: FolderImageProvider reports change to 6437 - /mnt/Streamer/סדרות/Homeland/Season 6/Episode 3 2020-06-16 12:01:49.077 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 6/Episode 3 2020-06-16 12:01:49.078 Debug App: FolderImageProvider reports change to 6438 - /mnt/Streamer/סדרות/Homeland/Season 6/Episode 4 2020-06-16 12:01:49.078 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 6/Episode 4 2020-06-16 12:01:49.079 Debug App: FolderImageProvider reports change to 6439 - /mnt/Streamer/סדרות/Homeland/Season 6/Episode 5 2020-06-16 12:01:49.079 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 6/Episode 5 2020-06-16 12:01:49.080 Debug App: FolderImageProvider reports change to 6440 - /mnt/Streamer/סדרות/Homeland/Season 6/Episode 6 2020-06-16 12:01:49.080 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 6/Episode 6 2020-06-16 12:01:49.081 Debug App: FolderImageProvider reports change to 6441 - /mnt/Streamer/סדרות/Homeland/Season 6/Episode 7 2020-06-16 12:01:49.081 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 6/Episode 7 2020-06-16 12:01:49.082 Debug App: FolderImageProvider reports change to 6442 - /mnt/Streamer/סדרות/Homeland/Season 6/Episode 8 2020-06-16 12:01:49.082 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 6/Episode 8 2020-06-16 12:01:49.083 Debug App: FolderImageProvider reports change to 6443 - /mnt/Streamer/סדרות/Homeland/Season 6/Episode 9 2020-06-16 12:01:49.083 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 6/Episode 9 2020-06-16 12:01:49.101 Debug App: FolderImageProvider reports change to 6457 - /mnt/Streamer/סדרות/Homeland/Season 7/Episode 10 2020-06-16 12:01:49.101 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 7/Episode 10 2020-06-16 12:01:49.102 Debug App: FolderImageProvider reports change to 6458 - /mnt/Streamer/סדרות/Homeland/Season 7/Episode 11 2020-06-16 12:01:49.102 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 7/Episode 11 2020-06-16 12:01:49.103 Debug App: FolderImageProvider reports change to 6459 - /mnt/Streamer/סדרות/Homeland/Season 7/Episode 12 2020-06-16 12:01:49.103 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 7/Episode 12 2020-06-16 12:01:49.194 Debug App: FolderImageProvider reports change to 6466 - /mnt/Streamer/סדרות/Homeland/Season 7/Episode 8 2020-06-16 12:01:49.194 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 7/Episode 8 2020-06-16 12:01:49.195 Debug App: FolderImageProvider reports change to 6467 - /mnt/Streamer/סדרות/Homeland/Season 7/Episode 9 2020-06-16 12:01:49.195 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 7/Episode 9 2020-06-16 12:01:49.249 Debug App: FolderImageProvider reports change to 6480 - /mnt/Streamer/סדרות/Homeland/Season 8/Episode 1 2020-06-16 12:01:49.249 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 8/Episode 1 2020-06-16 12:01:49.250 Debug App: FolderImageProvider reports change to 6481 - /mnt/Streamer/סדרות/Homeland/Season 8/Episode 10 2020-06-16 12:01:49.250 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 8/Episode 10 2020-06-16 12:01:49.251 Debug App: FolderImageProvider reports change to 6482 - /mnt/Streamer/סדרות/Homeland/Season 8/Episode 11 2020-06-16 12:01:49.251 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 8/Episode 11 2020-06-16 12:01:49.251 Debug App: FolderImageProvider reports change to 6483 - /mnt/Streamer/סדרות/Homeland/Season 8/Episode 12 2020-06-16 12:01:49.251 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 8/Episode 12 2020-06-16 12:01:49.252 Debug App: FolderImageProvider reports change to 6484 - /mnt/Streamer/סדרות/Homeland/Season 8/Episode 2 2020-06-16 12:01:49.252 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 8/Episode 2 2020-06-16 12:01:49.274 Debug App: FolderImageProvider reports change to 6485 - /mnt/Streamer/סדרות/Homeland/Season 8/Episode 3 2020-06-16 12:01:49.274 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 8/Episode 3 2020-06-16 12:01:49.275 Debug App: FolderImageProvider reports change to 6486 - /mnt/Streamer/סדרות/Homeland/Season 8/Episode 4 2020-06-16 12:01:49.275 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 8/Episode 4 2020-06-16 12:01:49.275 Debug App: FolderImageProvider reports change to 6487 - /mnt/Streamer/סדרות/Homeland/Season 8/Episode 5 2020-06-16 12:01:49.275 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 8/Episode 5 2020-06-16 12:01:49.276 Debug App: FolderImageProvider reports change to 6488 - /mnt/Streamer/סדרות/Homeland/Season 8/Episode 6 2020-06-16 12:01:49.276 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 8/Episode 6 2020-06-16 12:01:49.277 Debug App: FolderImageProvider reports change to 6489 - /mnt/Streamer/סדרות/Homeland/Season 8/Episode 7 2020-06-16 12:01:49.277 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 8/Episode 7 2020-06-16 12:01:49.278 Debug App: FolderImageProvider reports change to 6490 - /mnt/Streamer/סדרות/Homeland/Season 8/Episode 8 2020-06-16 12:01:49.278 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 8/Episode 8 2020-06-16 12:01:49.278 Debug App: FolderImageProvider reports change to 6491 - /mnt/Streamer/סדרות/Homeland/Season 8/Episode 9 2020-06-16 12:01:49.278 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Homeland/Season 8/Episode 9 2020-06-16 12:01:49.938 Debug App: FolderImageProvider reports change to 7052 - /mnt/Streamer/סדרות/Stranger Things/Season 1/Episode 8 2020-06-16 12:01:49.938 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Stranger Things/Season 1/Episode 8 2020-06-16 12:01:49.968 Debug App: FolderImageProvider reports change to 7068 - /mnt/Streamer/סדרות/Stranger Things/Season 2/Episode 8 2020-06-16 12:01:49.968 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Stranger Things/Season 2/Episode 8 2020-06-16 12:01:49.969 Debug App: FolderImageProvider reports change to 7069 - /mnt/Streamer/סדרות/Stranger Things/Season 2/Episode 9 2020-06-16 12:01:49.969 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Stranger Things/Season 2/Episode 9 2020-06-16 12:01:50.015 Debug App: FolderImageProvider reports change to 7079 - /mnt/Streamer/סדרות/Stranger Things/Season 3/Episode 1 2020-06-16 12:01:50.015 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Stranger Things/Season 3/Episode 1 2020-06-16 12:01:50.016 Debug App: FolderImageProvider reports change to 7080 - /mnt/Streamer/סדרות/Stranger Things/Season 3/Episode 2 2020-06-16 12:01:50.017 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Stranger Things/Season 3/Episode 2 2020-06-16 12:01:50.018 Debug App: FolderImageProvider reports change to 7081 - /mnt/Streamer/סדרות/Stranger Things/Season 3/Episode 3 2020-06-16 12:01:50.018 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Stranger Things/Season 3/Episode 3 2020-06-16 12:01:50.019 Debug App: FolderImageProvider reports change to 7082 - /mnt/Streamer/סדרות/Stranger Things/Season 3/Episode 4 2020-06-16 12:01:50.019 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Stranger Things/Season 3/Episode 4 2020-06-16 12:01:50.020 Debug App: FolderImageProvider reports change to 7083 - /mnt/Streamer/סדרות/Stranger Things/Season 3/Episode 5 2020-06-16 12:01:50.020 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Stranger Things/Season 3/Episode 5 2020-06-16 12:01:50.021 Debug App: FolderImageProvider reports change to 7084 - /mnt/Streamer/סדרות/Stranger Things/Season 3/Episode 6 2020-06-16 12:01:50.021 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Stranger Things/Season 3/Episode 6 2020-06-16 12:01:50.022 Debug App: FolderImageProvider reports change to 7085 - /mnt/Streamer/סדרות/Stranger Things/Season 3/Episode 7 2020-06-16 12:01:50.022 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Stranger Things/Season 3/Episode 7 2020-06-16 12:01:50.023 Debug App: FolderImageProvider reports change to 7086 - /mnt/Streamer/סדרות/Stranger Things/Season 3/Episode 8 2020-06-16 12:01:50.023 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Stranger Things/Season 3/Episode 8 2020-06-16 12:01:50.644 Debug App: FolderImageProvider reports change to 7197 - /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 1/Episode 1 2020-06-16 12:01:50.644 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 1/Episode 1 2020-06-16 12:01:50.645 Debug App: FolderImageProvider reports change to 7198 - /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 1/Episode 10 2020-06-16 12:01:50.645 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 1/Episode 10 2020-06-16 12:01:50.646 Debug App: FolderImageProvider reports change to 7199 - /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 1/Episode 11 2020-06-16 12:01:50.646 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 1/Episode 11 2020-06-16 12:01:50.646 Debug App: FolderImageProvider reports change to 7200 - /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 1/Episode 12 2020-06-16 12:01:50.646 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 1/Episode 12 2020-06-16 12:01:50.647 Debug App: FolderImageProvider reports change to 7201 - /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 1/Episode 13 2020-06-16 12:01:50.647 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 1/Episode 13 2020-06-16 12:01:50.648 Debug App: FolderImageProvider reports change to 7202 - /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 1/Episode 14 2020-06-16 12:01:50.648 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 1/Episode 14 2020-06-16 12:01:50.661 Debug App: FolderImageProvider reports change to 7203 - /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 1/Episode 15 2020-06-16 12:01:50.661 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 1/Episode 15 2020-06-16 12:01:50.662 Debug App: FolderImageProvider reports change to 7204 - /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 1/Episode 16 2020-06-16 12:01:50.662 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 1/Episode 16 2020-06-16 12:01:50.663 Debug App: FolderImageProvider reports change to 7205 - /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 1/Episode 17 2020-06-16 12:01:50.663 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 1/Episode 17 2020-06-16 12:01:50.664 Debug App: FolderImageProvider reports change to 7206 - /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 1/Episode 18 2020-06-16 12:01:50.664 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 1/Episode 18 2020-06-16 12:01:50.664 Debug App: FolderImageProvider reports change to 7207 - /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 1/Episode 19 2020-06-16 12:01:50.664 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 1/Episode 19 2020-06-16 12:01:50.665 Debug App: FolderImageProvider reports change to 7208 - /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 1/Episode 2 2020-06-16 12:01:50.665 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 1/Episode 2 2020-06-16 12:01:50.666 Debug App: FolderImageProvider reports change to 7209 - /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 1/Episode 20 2020-06-16 12:01:50.666 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 1/Episode 20 2020-06-16 12:01:50.667 Debug App: FolderImageProvider reports change to 7210 - /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 1/Episode 21 2020-06-16 12:01:50.667 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 1/Episode 21 2020-06-16 12:01:50.667 Debug App: FolderImageProvider reports change to 7211 - /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 1/Episode 22 2020-06-16 12:01:50.667 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 1/Episode 22 2020-06-16 12:01:50.668 Debug App: FolderImageProvider reports change to 7212 - /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 1/Episode 3 2020-06-16 12:01:50.668 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 1/Episode 3 2020-06-16 12:01:50.669 Debug App: FolderImageProvider reports change to 7213 - /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 1/Episode 4 2020-06-16 12:01:50.669 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 1/Episode 4 2020-06-16 12:01:50.669 Debug App: FolderImageProvider reports change to 7214 - /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 1/Episode 5 2020-06-16 12:01:50.670 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 1/Episode 5 2020-06-16 12:01:50.670 Debug App: FolderImageProvider reports change to 7215 - /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 1/Episode 6 2020-06-16 12:01:50.670 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 1/Episode 6 2020-06-16 12:01:50.671 Debug App: FolderImageProvider reports change to 7216 - /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 1/Episode 7 2020-06-16 12:01:50.671 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 1/Episode 7 2020-06-16 12:01:50.672 Debug App: FolderImageProvider reports change to 7217 - /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 1/Episode 8 2020-06-16 12:01:50.672 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 1/Episode 8 2020-06-16 12:01:50.673 Debug App: FolderImageProvider reports change to 7218 - /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 1/Episode 9 2020-06-16 12:01:50.673 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 1/Episode 9 2020-06-16 12:01:50.673 Debug App: FolderImageProvider reports change to 7219 - /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 2/Episode 1 2020-06-16 12:01:50.673 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 2/Episode 1 2020-06-16 12:01:50.674 Debug App: FolderImageProvider reports change to 7220 - /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 2/Episode 10 2020-06-16 12:01:50.674 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 2/Episode 10 2020-06-16 12:01:50.675 Debug App: FolderImageProvider reports change to 7221 - /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 2/Episode 11 2020-06-16 12:01:50.675 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 2/Episode 11 2020-06-16 12:01:50.676 Debug App: FolderImageProvider reports change to 7222 - /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 2/Episode 12 2020-06-16 12:01:50.676 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 2/Episode 12 2020-06-16 12:01:50.676 Debug App: FolderImageProvider reports change to 7223 - /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 2/Episode 13 2020-06-16 12:01:50.676 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 2/Episode 13 2020-06-16 12:01:50.677 Debug App: FolderImageProvider reports change to 7224 - /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 2/Episode 14 2020-06-16 12:01:50.677 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 2/Episode 14 2020-06-16 12:01:50.678 Debug App: FolderImageProvider reports change to 7225 - /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 2/Episode 15 2020-06-16 12:01:50.678 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 2/Episode 15 2020-06-16 12:01:50.678 Debug App: FolderImageProvider reports change to 7226 - /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 2/Episode 16 2020-06-16 12:01:50.679 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 2/Episode 16 2020-06-16 12:01:50.679 Debug App: FolderImageProvider reports change to 7227 - /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 2/Episode 17 2020-06-16 12:01:50.679 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 2/Episode 17 2020-06-16 12:01:50.680 Debug App: FolderImageProvider reports change to 7228 - /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 2/Episode 18 2020-06-16 12:01:50.680 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 2/Episode 18 2020-06-16 12:01:50.681 Debug App: FolderImageProvider reports change to 7229 - /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 2/Episode 19 2020-06-16 12:01:50.681 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 2/Episode 19 2020-06-16 12:01:50.682 Debug App: FolderImageProvider reports change to 7230 - /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 2/Episode 2 2020-06-16 12:01:50.682 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 2/Episode 2 2020-06-16 12:01:50.682 Debug App: FolderImageProvider reports change to 7231 - /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 2/Episode 20 2020-06-16 12:01:50.682 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 2/Episode 20 2020-06-16 12:01:50.683 Debug App: FolderImageProvider reports change to 7232 - /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 2/Episode 21 2020-06-16 12:01:50.683 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 2/Episode 21 2020-06-16 12:01:50.684 Debug App: FolderImageProvider reports change to 7233 - /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 2/Episode 22 2020-06-16 12:01:50.684 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 2/Episode 22 2020-06-16 12:01:50.684 Debug App: FolderImageProvider reports change to 7234 - /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 2/Episode 23 2020-06-16 12:01:50.685 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 2/Episode 23 2020-06-16 12:01:50.685 Debug App: FolderImageProvider reports change to 7235 - /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 2/Episode 3 2020-06-16 12:01:50.685 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 2/Episode 3 2020-06-16 12:01:50.686 Debug App: FolderImageProvider reports change to 7236 - /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 2/Episode 4 2020-06-16 12:01:50.686 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 2/Episode 4 2020-06-16 12:01:50.687 Debug App: FolderImageProvider reports change to 7237 - /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 2/Episode 5 2020-06-16 12:01:50.687 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 2/Episode 5 2020-06-16 12:01:50.687 Debug App: FolderImageProvider reports change to 7238 - /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 2/Episode 6 2020-06-16 12:01:50.687 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 2/Episode 6 2020-06-16 12:01:50.688 Debug App: FolderImageProvider reports change to 7239 - /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 2/Episode 7 2020-06-16 12:01:50.688 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 2/Episode 7 2020-06-16 12:01:50.689 Debug App: FolderImageProvider reports change to 7240 - /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 2/Episode 8 2020-06-16 12:01:50.689 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 2/Episode 8 2020-06-16 12:01:50.690 Debug App: FolderImageProvider reports change to 7241 - /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 2/Episode 9 2020-06-16 12:01:50.690 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 2/Episode 9 2020-06-16 12:01:50.964 Debug App: FolderImageProvider reports change to 7374 - /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 6/Episode 1 2020-06-16 12:01:50.964 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 6/Episode 1 2020-06-16 12:01:50.965 Debug App: FolderImageProvider reports change to 7375 - /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 6/Episode 10 2020-06-16 12:01:50.965 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 6/Episode 10 2020-06-16 12:01:50.965 Debug App: FolderImageProvider reports change to 7376 - /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 6/Episode 11 2020-06-16 12:01:50.965 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 6/Episode 11 2020-06-16 12:01:50.966 Debug App: FolderImageProvider reports change to 7377 - /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 6/Episode 12 2020-06-16 12:01:50.966 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 6/Episode 12 2020-06-16 12:01:50.967 Debug App: FolderImageProvider reports change to 7378 - /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 6/Episode 13 2020-06-16 12:01:50.967 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 6/Episode 13 2020-06-16 12:01:50.968 Debug App: FolderImageProvider reports change to 7379 - /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 6/Episode 14 2020-06-16 12:01:50.968 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 6/Episode 14 2020-06-16 12:01:50.968 Debug App: FolderImageProvider reports change to 7380 - /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 6/Episode 15 2020-06-16 12:01:50.968 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 6/Episode 15 2020-06-16 12:01:50.969 Debug App: FolderImageProvider reports change to 7381 - /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 6/Episode 16 2020-06-16 12:01:50.969 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 6/Episode 16 2020-06-16 12:01:50.970 Debug App: FolderImageProvider reports change to 7382 - /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 6/Episode 17 2020-06-16 12:01:50.970 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 6/Episode 17 2020-06-16 12:01:50.971 Debug App: FolderImageProvider reports change to 7383 - /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 6/Episode 18 2020-06-16 12:01:50.971 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 6/Episode 18 2020-06-16 12:01:50.971 Debug App: FolderImageProvider reports change to 7384 - /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 6/Episode 2 2020-06-16 12:01:50.971 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 6/Episode 2 2020-06-16 12:01:50.972 Debug App: FolderImageProvider reports change to 7385 - /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 6/Episode 3 2020-06-16 12:01:50.972 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 6/Episode 3 2020-06-16 12:01:50.973 Debug App: FolderImageProvider reports change to 7386 - /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 6/Episode 4 2020-06-16 12:01:50.973 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 6/Episode 4 2020-06-16 12:01:50.974 Debug App: FolderImageProvider reports change to 7387 - /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 6/Episode 5 2020-06-16 12:01:50.974 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 6/Episode 5 2020-06-16 12:01:50.974 Debug App: FolderImageProvider reports change to 7388 - /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 6/Episode 6 2020-06-16 12:01:50.974 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 6/Episode 6 2020-06-16 12:01:50.975 Debug App: FolderImageProvider reports change to 7389 - /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 6/Episode 7 2020-06-16 12:01:50.975 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 6/Episode 7 2020-06-16 12:01:50.976 Debug App: FolderImageProvider reports change to 7390 - /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 6/Episode 8 2020-06-16 12:01:50.976 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 6/Episode 8 2020-06-16 12:01:50.996 Debug App: FolderImageProvider reports change to 7391 - /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 6/Episode 9 2020-06-16 12:01:50.996 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/Brooklyn Nine-Nine/Season 6/Episode 9 2020-06-16 12:01:52.082 Debug App: FolderImageProvider reports change to 8807 - /mnt/Streamer/סדרות/American Housewife/Season 4/Episode 1 2020-06-16 12:01:52.082 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/American Housewife/Season 4/Episode 1 2020-06-16 12:01:52.083 Debug App: FolderImageProvider reports change to 8808 - /mnt/Streamer/סדרות/American Housewife/Season 4/Episode 10 2020-06-16 12:01:52.083 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/American Housewife/Season 4/Episode 10 2020-06-16 12:01:52.084 Debug App: FolderImageProvider reports change to 8809 - /mnt/Streamer/סדרות/American Housewife/Season 4/Episode 11 2020-06-16 12:01:52.084 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/American Housewife/Season 4/Episode 11 2020-06-16 12:01:52.084 Debug App: FolderImageProvider reports change to 8810 - /mnt/Streamer/סדרות/American Housewife/Season 4/Episode 12 2020-06-16 12:01:52.084 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/American Housewife/Season 4/Episode 12 2020-06-16 12:01:52.085 Debug App: FolderImageProvider reports change to 8811 - /mnt/Streamer/סדרות/American Housewife/Season 4/Episode 13 2020-06-16 12:01:52.085 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/American Housewife/Season 4/Episode 13 2020-06-16 12:01:52.086 Debug App: FolderImageProvider reports change to 8812 - /mnt/Streamer/סדרות/American Housewife/Season 4/Episode 14 2020-06-16 12:01:52.086 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/American Housewife/Season 4/Episode 14 2020-06-16 12:01:52.087 Debug App: FolderImageProvider reports change to 8813 - /mnt/Streamer/סדרות/American Housewife/Season 4/Episode 15 2020-06-16 12:01:52.087 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/American Housewife/Season 4/Episode 15 2020-06-16 12:01:52.087 Debug App: FolderImageProvider reports change to 8814 - /mnt/Streamer/סדרות/American Housewife/Season 4/Episode 16 2020-06-16 12:01:52.087 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/American Housewife/Season 4/Episode 16 2020-06-16 12:01:52.088 Debug App: FolderImageProvider reports change to 8815 - /mnt/Streamer/סדרות/American Housewife/Season 4/Episode 17 2020-06-16 12:01:52.088 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/American Housewife/Season 4/Episode 17 2020-06-16 12:01:52.089 Debug App: FolderImageProvider reports change to 8816 - /mnt/Streamer/סדרות/American Housewife/Season 4/Episode 18 2020-06-16 12:01:52.089 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/American Housewife/Season 4/Episode 18 2020-06-16 12:01:52.090 Debug App: FolderImageProvider reports change to 8817 - /mnt/Streamer/סדרות/American Housewife/Season 4/Episode 19 2020-06-16 12:01:52.090 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/American Housewife/Season 4/Episode 19 2020-06-16 12:01:52.090 Debug App: FolderImageProvider reports change to 8818 - /mnt/Streamer/סדרות/American Housewife/Season 4/Episode 2 2020-06-16 12:01:52.090 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/American Housewife/Season 4/Episode 2 2020-06-16 12:01:52.091 Debug App: FolderImageProvider reports change to 8819 - /mnt/Streamer/סדרות/American Housewife/Season 4/Episode 20 2020-06-16 12:01:52.091 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/American Housewife/Season 4/Episode 20 2020-06-16 12:01:52.092 Debug App: FolderImageProvider reports change to 8820 - /mnt/Streamer/סדרות/American Housewife/Season 4/Episode 21 2020-06-16 12:01:52.092 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/American Housewife/Season 4/Episode 21 2020-06-16 12:01:52.093 Debug App: FolderImageProvider reports change to 8821 - /mnt/Streamer/סדרות/American Housewife/Season 4/Episode 3 2020-06-16 12:01:52.093 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/American Housewife/Season 4/Episode 3 2020-06-16 12:01:52.093 Debug App: FolderImageProvider reports change to 8822 - /mnt/Streamer/סדרות/American Housewife/Season 4/Episode 4 2020-06-16 12:01:52.093 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/American Housewife/Season 4/Episode 4 2020-06-16 12:01:52.094 Debug App: FolderImageProvider reports change to 8823 - /mnt/Streamer/סדרות/American Housewife/Season 4/Episode 5 2020-06-16 12:01:52.094 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/American Housewife/Season 4/Episode 5 2020-06-16 12:01:52.095 Debug App: FolderImageProvider reports change to 8824 - /mnt/Streamer/סדרות/American Housewife/Season 4/Episode 6 2020-06-16 12:01:52.095 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/American Housewife/Season 4/Episode 6 2020-06-16 12:01:52.096 Debug App: FolderImageProvider reports change to 8825 - /mnt/Streamer/סדרות/American Housewife/Season 4/Episode 7 2020-06-16 12:01:52.096 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/American Housewife/Season 4/Episode 7 2020-06-16 12:01:52.096 Debug App: FolderImageProvider reports change to 8826 - /mnt/Streamer/סדרות/American Housewife/Season 4/Episode 8 2020-06-16 12:01:52.096 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/American Housewife/Season 4/Episode 8 2020-06-16 12:01:52.097 Debug App: FolderImageProvider reports change to 8827 - /mnt/Streamer/סדרות/American Housewife/Season 4/Episode 9 2020-06-16 12:01:52.097 Debug App: Running FolderImageProvider for /mnt/Streamer/סדרות/American Housewife/Season 4/Episode 9 2020-06-16 12:01:57.313 Debug App: FolderImageProvider reports change to 252 - /var/db/emby-server/root 2020-06-16 12:01:57.313 Debug App: Running FolderImageProvider for /var/db/emby-server/root 2020-06-16 12:01:57.314 Debug XmlSerializer: Deserializing file /var/db/emby-server/root/default/סדרות/options.xml 2020-06-16 12:01:57.315 Debug XmlSerializer: Deserializing file /var/db/emby-server/root/default/סרטי משפחה/options.xml 2020-06-16 12:01:57.316 Debug XmlSerializer: Deserializing file /var/db/emby-server/root/default/סרטי×/options.xml 2020-06-16 12:01:57.326 Debug XmlSerializer: Deserializing file /var/db/emby-server/root/default/סדרות/options.xml 2020-06-16 12:01:57.327 Debug XmlSerializer: Deserializing file /var/db/emby-server/root/default/סרטי משפחה/options.xml 2020-06-16 12:01:57.328 Debug XmlSerializer: Deserializing file /var/db/emby-server/root/default/סרטי×/options.xml 2020-06-16 12:01:57.328 Debug XmlSerializer: Deserializing file /var/db/emby-server/root/default/סדרות/options.xml 2020-06-16 12:01:57.329 Debug XmlSerializer: Deserializing file /var/db/emby-server/root/default/סדרות/options.xml 2020-06-16 12:01:57.330 Debug XmlSerializer: Deserializing file /var/db/emby-server/root/default/סרטי משפחה/options.xml 2020-06-16 12:01:57.331 Debug XmlSerializer: Deserializing file /var/db/emby-server/root/default/סרטי משפחה/options.xml 2020-06-16 12:01:57.332 Debug XmlSerializer: Deserializing file /var/db/emby-server/root/default/סרטי×/options.xml 2020-06-16 12:01:57.333 Debug XmlSerializer: Deserializing file /var/db/emby-server/root/default/סרטי×/options.xml 2020-06-16 12:01:57.336 Debug XmlSerializer: Deserializing file /var/db/emby-server/root/default/סדרות/options.xml 2020-06-16 12:01:57.336 Debug XmlSerializer: Deserializing file /var/db/emby-server/root/default/סדרות/options.xml 2020-06-16 12:01:57.338 Debug XmlSerializer: Deserializing file /var/db/emby-server/root/default/סרטי×/options.xml 2020-06-16 12:01:57.339 Debug XmlSerializer: Deserializing file /var/db/emby-server/root/default/סרטי×/options.xml 2020-06-16 12:01:57.341 Debug XmlSerializer: Deserializing file /var/db/emby-server/root/default/סרטי משפחה/options.xml 2020-06-16 12:01:57.342 Debug XmlSerializer: Deserializing file /var/db/emby-server/root/default/סרטי משפחה/options.xml 2020-06-16 12:01:57.343 Debug App: Running post-scan task TvdbPrescanTask 2020-06-16 12:01:57.348 Info HttpClient: HttpClientManager GET: https://thetvdb.com/api/Updates.php?type=all&time=1592211691 2020-06-16 12:02:00.240 Info App: Updating series from tvdb 311954, language he 2020-06-16 12:02:00.245 Info HttpClient: HttpClientManager GET: https://www.thetvdb.com/api/B89CE93890E9419B/series/311954/all/he.zip 2020-06-16 12:02:01.896 Info App: Updating series from tvdb 268592, language he 2020-06-16 12:02:01.897 Info HttpClient: HttpClientManager GET: https://www.thetvdb.com/api/B89CE93890E9419B/series/268592/all/he.zip 2020-06-16 12:02:02.520 Info App: Updating series from tvdb 247897, language he 2020-06-16 12:02:02.520 Info HttpClient: HttpClientManager GET: https://www.thetvdb.com/api/B89CE93890E9419B/series/247897/all/he.zip 2020-06-16 12:02:02.949 Info App: Updating series from tvdb 364928, language he 2020-06-16 12:02:02.949 Info HttpClient: HttpClientManager GET: https://www.thetvdb.com/api/B89CE93890E9419B/series/364928/all/he.zip 2020-06-16 12:02:03.681 Info App: Updating series from tvdb 342107, language he 2020-06-16 12:02:03.681 Info HttpClient: HttpClientManager GET: https://www.thetvdb.com/api/B89CE93890E9419B/series/342107/all/he.zip 2020-06-16 12:02:04.160 Info App: Updating series from tvdb 263365, language he 2020-06-16 12:02:04.161 Info HttpClient: HttpClientManager GET: https://www.thetvdb.com/api/B89CE93890E9419B/series/263365/all/he.zip 2020-06-16 12:02:04.636 Debug App: Running post-scan task ArtistsPostScanTask 2020-06-16 12:02:04.636 Debug App: Running post-scan task GenresPostScanTask 2020-06-16 12:02:04.640 Debug App: GenreImageProvider reports change to 2254 - /var/db/emby-server/metadata/Genre/מדע ×‘×“×™×•× ×™ 2020-06-16 12:02:04.640 Debug App: GenreImageProvider reports change to 2255 - /var/db/emby-server/metadata/Genre/מותחן 2020-06-16 12:02:04.641 Debug App: GenreImageProvider reports change to 2256 - /var/db/emby-server/metadata/Genre/מלחמה 2020-06-16 12:02:04.641 Debug App: GenreImageProvider reports change to 2257 - /var/db/emby-server/metadata/Genre/מסתורין 2020-06-16 12:02:04.642 Debug App: GenreImageProvider reports change to 2258 - /var/db/emby-server/metadata/Genre/משפחה 2020-06-16 12:02:04.642 Debug App: GenreImageProvider reports change to 2259 - /var/db/emby-server/metadata/Genre/×¤× ×˜×–×™×” 2020-06-16 12:02:04.643 Debug App: GenreImageProvider reports change to 2260 - /var/db/emby-server/metadata/Genre/פשע 2020-06-16 12:02:04.643 Debug App: GenreImageProvider reports change to 2261 - /var/db/emby-server/metadata/Genre/קומדיה 2020-06-16 12:02:04.665 Debug App: GenreImageProvider reports change to 2297 - /var/db/emby-server/metadata/Genre/×ימה 2020-06-16 12:02:04.666 Debug App: GenreImageProvider reports change to 2363 - /var/db/emby-server/metadata/Genre/×קשן 2020-06-16 12:02:04.666 Debug App: GenreImageProvider reports change to 2364 - /var/db/emby-server/metadata/Genre/דרמה 2020-06-16 12:02:04.667 Debug App: GenreImageProvider reports change to 2365 - /var/db/emby-server/metadata/Genre/הרפתק×ות 2020-06-16 12:02:04.670 Debug App: GenreImageProvider reports change to 5698 - /var/db/emby-server/metadata/Genre/Sci-Fi 2020-06-16 12:02:04.670 Debug App: Running GenreImageProvider for /var/db/emby-server/metadata/Genre/Sci-Fi 2020-06-16 12:02:04.673 Debug App: Running post-scan task StudiosPostScanTask 2020-06-16 12:02:04.744 Debug App: Running post-scan task TagsPostScanTask 2020-06-16 12:02:04.745 Debug App: Running post-scan task CleanDatabaseScheduledTask 2020-06-16 12:02:04.762 Debug TaskManager: Scan media library Completed after 0 minute(s) and 33 seconds 2020-06-16 14:21:52.236 Debug TaskManager: IntervalTrigger fired for task: Refresh Guide 2020-06-16 14:21:52.236 Debug TaskManager: Queueing task RefreshChannelsScheduledTask 2020-06-16 14:21:52.236 Debug TaskManager: Executing Refresh Guide 2020-06-16 14:21:55.383 Info LiveTvManager: Emby Live TV and DVR requires an active Emby Premiere subscription. 2020-06-16 14:21:55.386 Info LiveTV: Loading live tv data from /var/db/emby-server/data/livetv/seriestimers 2020-06-16 14:21:55.388 Debug TaskManager: Refresh Guide Completed after 0 minute(s) and 3 seconds 2020-06-16 16:30:06.247 Debug TaskManager: IntervalTrigger fired for task: Check for application updates 2020-06-16 16:30:06.247 Debug TaskManager: Queueing task SystemUpdateTask 2020-06-16 16:30:06.247 Debug TaskManager: Executing Check for application updates 2020-06-16 16:30:06.285 Info HttpClient: HttpClientManager GET: https://api.github.com/repos/MediaBrowser/Emby.Releases/releases 2020-06-16 16:30:07.740 Debug TaskManager: Check for application updates Completed after 0 minute(s) and 1 seconds 2020-06-16 16:30:10.496 Debug TaskManager: IntervalTrigger fired for task: Check for plugin updates 2020-06-16 16:30:10.496 Debug TaskManager: Queueing task PluginUpdateTask 2020-06-16 16:30:10.496 Debug TaskManager: Executing Check for plugin updates 2020-06-16 16:30:10.496 Info HttpClient: HttpClientManager GET: https://www.mb3admin.com/admin/service/EmbyPackages.json 2020-06-16 16:30:12.762 Debug TaskManager: Check for plugin updates Completed after 0 minute(s) and 2 seconds 2020-06-16 19:33:13.959 Info HttpServer: HTTP GET https://192.168.1.29:8920/. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 19:33:13.959 Info HttpServer: HTTP Response 302 to 192.168.1.2. Time: 0ms. https://192.168.1.29:8920/ 2020-06-16 19:33:14.612 Info HttpServer: HTTP GET https://192.168.1.29:8920/web/strings/he.json?v=1592325194539. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 19:33:14.613 Info HttpServer: HTTP GET https://192.168.1.29:8920/web/bower_components/emby-webcomponents/strings/he.json?v=1592325194539. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 19:33:14.636 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 23ms. https://192.168.1.29:8920/web/bower_components/emby-webcomponents/strings/he.json?v=1592325194539 2020-06-16 19:33:14.647 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 35ms. https://192.168.1.29:8920/web/strings/he.json?v=1592325194539 2020-06-16 19:33:14.917 Error HttpServer: Error in ProcessAccept *** Error Report *** Version: 4.4.2.0 Command line: /usr/local/lib/emby-server/system/EmbyServer.exe -os freebsd -ffdetect /usr/local/lib/emby-server/bin/ffdetect -ffmpeg /usr/local/lib/emby-server/bin/ffmpeg -ffprobe /usr/local/lib/emby-server/bin/ffprobe -programdata /var/db/emby-server -updatepackage emby-server-freebsd12_{version}_amd64.txz Operating system: Unix 11.3.9.0 64-Bit OS: True 64-Bit Process: True User Interactive: False Mono: 5.10.1.57 (5.10.1.57 Thu Apr 9 04:06:41 UTC 2020) Runtime: file:///usr/local/lib/mono/4.5/mscorlib.dll System.Environment.Version: 4.0.30319.42000 Processor count: 4 Program data path: /var/db/emby-server Application directory: /usr/local/lib/emby-server/system System.IO.IOException: System.IO.IOException: Remote prematurely closed connection. at Mono.Net.Security.AsyncProtocolRequest+<ProcessOperation>d__24.MoveNext () [0x000e7] in <b3922b7d60404fa9ae645f1fb97f5b6b>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0003e] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00028] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00008] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable+ConfiguredTaskAwaiter.GetResult () [0x00000] in <0e06830de9a44394a7e366951eabca52>:0 at Mono.Net.Security.AsyncProtocolRequest+<StartOperation>d__23.MoveNext () [0x0008b] in <b3922b7d60404fa9ae645f1fb97f5b6b>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <0e06830de9a44394a7e366951eabca52>:0 at Mono.Net.Security.MobileAuthenticatedStream+<ProcessAuthentication>d__47.MoveNext () [0x00254] in <b3922b7d60404fa9ae645f1fb97f5b6b>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0003e] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00028] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00008] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable+ConfiguredTaskAwaiter.GetResult () [0x00000] in <0e06830de9a44394a7e366951eabca52>:0 at SocketHttpListener.Net.HttpConnection+<Init>d__26.MoveNext () [0x000a5] in <5fc69e0598a34841a210f67306929617>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0003e] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00028] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00008] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable+ConfiguredTaskAwaiter.GetResult () [0x00000] in <0e06830de9a44394a7e366951eabca52>:0 at SocketHttpListener.Net.HttpEndPointListener+<ProcessAccept>d__21.MoveNext () [0x0015d] in <5fc69e0598a34841a210f67306929617>:0 Source: mscorlib TargetSite: Void Throw() 2020-06-16 19:33:14.944 Error HttpServer: Error in ProcessAccept *** Error Report *** Version: 4.4.2.0 Command line: /usr/local/lib/emby-server/system/EmbyServer.exe -os freebsd -ffdetect /usr/local/lib/emby-server/bin/ffdetect -ffmpeg /usr/local/lib/emby-server/bin/ffmpeg -ffprobe /usr/local/lib/emby-server/bin/ffprobe -programdata /var/db/emby-server -updatepackage emby-server-freebsd12_{version}_amd64.txz Operating system: Unix 11.3.9.0 64-Bit OS: True 64-Bit Process: True User Interactive: False Mono: 5.10.1.57 (5.10.1.57 Thu Apr 9 04:06:41 UTC 2020) Runtime: file:///usr/local/lib/mono/4.5/mscorlib.dll System.Environment.Version: 4.0.30319.42000 Processor count: 4 Program data path: /var/db/emby-server Application directory: /usr/local/lib/emby-server/system System.IO.IOException: System.IO.IOException: Remote prematurely closed connection. at Mono.Net.Security.AsyncProtocolRequest+<ProcessOperation>d__24.MoveNext () [0x000e7] in <b3922b7d60404fa9ae645f1fb97f5b6b>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0003e] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00028] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00008] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable+ConfiguredTaskAwaiter.GetResult () [0x00000] in <0e06830de9a44394a7e366951eabca52>:0 at Mono.Net.Security.AsyncProtocolRequest+<StartOperation>d__23.MoveNext () [0x0008b] in <b3922b7d60404fa9ae645f1fb97f5b6b>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <0e06830de9a44394a7e366951eabca52>:0 at Mono.Net.Security.MobileAuthenticatedStream+<ProcessAuthentication>d__47.MoveNext () [0x00254] in <b3922b7d60404fa9ae645f1fb97f5b6b>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0003e] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00028] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00008] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable+ConfiguredTaskAwaiter.GetResult () [0x00000] in <0e06830de9a44394a7e366951eabca52>:0 at SocketHttpListener.Net.HttpConnection+<Init>d__26.MoveNext () [0x000a5] in <5fc69e0598a34841a210f67306929617>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0003e] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00028] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00008] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable+ConfiguredTaskAwaiter.GetResult () [0x00000] in <0e06830de9a44394a7e366951eabca52>:0 at SocketHttpListener.Net.HttpEndPointListener+<ProcessAccept>d__21.MoveNext () [0x0015d] in <5fc69e0598a34841a210f67306929617>:0 Source: mscorlib TargetSite: Void Throw() 2020-06-16 19:33:14.945 Error HttpServer: Error in ProcessAccept *** Error Report *** Version: 4.4.2.0 Command line: /usr/local/lib/emby-server/system/EmbyServer.exe -os freebsd -ffdetect /usr/local/lib/emby-server/bin/ffdetect -ffmpeg /usr/local/lib/emby-server/bin/ffmpeg -ffprobe /usr/local/lib/emby-server/bin/ffprobe -programdata /var/db/emby-server -updatepackage emby-server-freebsd12_{version}_amd64.txz Operating system: Unix 11.3.9.0 64-Bit OS: True 64-Bit Process: True User Interactive: False Mono: 5.10.1.57 (5.10.1.57 Thu Apr 9 04:06:41 UTC 2020) Runtime: file:///usr/local/lib/mono/4.5/mscorlib.dll System.Environment.Version: 4.0.30319.42000 Processor count: 4 Program data path: /var/db/emby-server Application directory: /usr/local/lib/emby-server/system System.IO.IOException: System.IO.IOException: Remote prematurely closed connection. at Mono.Net.Security.AsyncProtocolRequest+<ProcessOperation>d__24.MoveNext () [0x000e7] in <b3922b7d60404fa9ae645f1fb97f5b6b>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0003e] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00028] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00008] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable+ConfiguredTaskAwaiter.GetResult () [0x00000] in <0e06830de9a44394a7e366951eabca52>:0 at Mono.Net.Security.AsyncProtocolRequest+<StartOperation>d__23.MoveNext () [0x0008b] in <b3922b7d60404fa9ae645f1fb97f5b6b>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <0e06830de9a44394a7e366951eabca52>:0 at Mono.Net.Security.MobileAuthenticatedStream+<ProcessAuthentication>d__47.MoveNext () [0x00254] in <b3922b7d60404fa9ae645f1fb97f5b6b>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0003e] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00028] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00008] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable+ConfiguredTaskAwaiter.GetResult () [0x00000] in <0e06830de9a44394a7e366951eabca52>:0 at SocketHttpListener.Net.HttpConnection+<Init>d__26.MoveNext () [0x000a5] in <5fc69e0598a34841a210f67306929617>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0003e] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00028] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00008] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable+ConfiguredTaskAwaiter.GetResult () [0x00000] in <0e06830de9a44394a7e366951eabca52>:0 at SocketHttpListener.Net.HttpEndPointListener+<ProcessAccept>d__21.MoveNext () [0x0015d] in <5fc69e0598a34841a210f67306929617>:0 Source: mscorlib TargetSite: Void Throw() 2020-06-16 19:33:14.945 Error HttpServer: Error in ProcessAccept *** Error Report *** Version: 4.4.2.0 Command line: /usr/local/lib/emby-server/system/EmbyServer.exe -os freebsd -ffdetect /usr/local/lib/emby-server/bin/ffdetect -ffmpeg /usr/local/lib/emby-server/bin/ffmpeg -ffprobe /usr/local/lib/emby-server/bin/ffprobe -programdata /var/db/emby-server -updatepackage emby-server-freebsd12_{version}_amd64.txz Operating system: Unix 11.3.9.0 64-Bit OS: True 64-Bit Process: True User Interactive: False Mono: 5.10.1.57 (5.10.1.57 Thu Apr 9 04:06:41 UTC 2020) Runtime: file:///usr/local/lib/mono/4.5/mscorlib.dll System.Environment.Version: 4.0.30319.42000 Processor count: 4 Program data path: /var/db/emby-server Application directory: /usr/local/lib/emby-server/system System.IO.IOException: System.IO.IOException: Remote prematurely closed connection. at Mono.Net.Security.AsyncProtocolRequest+<ProcessOperation>d__24.MoveNext () [0x000e7] in <b3922b7d60404fa9ae645f1fb97f5b6b>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0003e] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00028] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00008] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable+ConfiguredTaskAwaiter.GetResult () [0x00000] in <0e06830de9a44394a7e366951eabca52>:0 at Mono.Net.Security.AsyncProtocolRequest+<StartOperation>d__23.MoveNext () [0x0008b] in <b3922b7d60404fa9ae645f1fb97f5b6b>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <0e06830de9a44394a7e366951eabca52>:0 at Mono.Net.Security.MobileAuthenticatedStream+<ProcessAuthentication>d__47.MoveNext () [0x00254] in <b3922b7d60404fa9ae645f1fb97f5b6b>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0003e] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00028] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00008] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable+ConfiguredTaskAwaiter.GetResult () [0x00000] in <0e06830de9a44394a7e366951eabca52>:0 at SocketHttpListener.Net.HttpConnection+<Init>d__26.MoveNext () [0x000a5] in <5fc69e0598a34841a210f67306929617>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0003e] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00028] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00008] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable+ConfiguredTaskAwaiter.GetResult () [0x00000] in <0e06830de9a44394a7e366951eabca52>:0 at SocketHttpListener.Net.HttpEndPointListener+<ProcessAccept>d__21.MoveNext () [0x0015d] in <5fc69e0598a34841a210f67306929617>:0 Source: mscorlib TargetSite: Void Throw() 2020-06-16 19:33:14.966 Error HttpServer: Error in ProcessAccept *** Error Report *** Version: 4.4.2.0 Command line: /usr/local/lib/emby-server/system/EmbyServer.exe -os freebsd -ffdetect /usr/local/lib/emby-server/bin/ffdetect -ffmpeg /usr/local/lib/emby-server/bin/ffmpeg -ffprobe /usr/local/lib/emby-server/bin/ffprobe -programdata /var/db/emby-server -updatepackage emby-server-freebsd12_{version}_amd64.txz Operating system: Unix 11.3.9.0 64-Bit OS: True 64-Bit Process: True User Interactive: False Mono: 5.10.1.57 (5.10.1.57 Thu Apr 9 04:06:41 UTC 2020) Runtime: file:///usr/local/lib/mono/4.5/mscorlib.dll System.Environment.Version: 4.0.30319.42000 Processor count: 4 Program data path: /var/db/emby-server Application directory: /usr/local/lib/emby-server/system System.IO.IOException: System.IO.IOException: Authentication failed because the remote party has closed the transport stream. at Mono.Net.Security.MobileAuthenticatedStream.ProcessHandshake (Mono.Net.Security.AsyncOperationStatus status) [0x00027] in <b3922b7d60404fa9ae645f1fb97f5b6b>:0 at (wrapper remoting-invoke-with-check) Mono.Net.Security.MobileAuthenticatedStream.ProcessHandshake(Mono.Net.Security.AsyncOperationStatus) at Mono.Net.Security.AsyncHandshakeRequest.Run (Mono.Net.Security.AsyncOperationStatus status) [0x00006] in <b3922b7d60404fa9ae645f1fb97f5b6b>:0 at Mono.Net.Security.AsyncProtocolRequest+<ProcessOperation>d__24.MoveNext () [0x000ff] in <b3922b7d60404fa9ae645f1fb97f5b6b>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0003e] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00028] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00008] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable+ConfiguredTaskAwaiter.GetResult () [0x00000] in <0e06830de9a44394a7e366951eabca52>:0 at Mono.Net.Security.AsyncProtocolRequest+<StartOperation>d__23.MoveNext () [0x0008b] in <b3922b7d60404fa9ae645f1fb97f5b6b>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <0e06830de9a44394a7e366951eabca52>:0 at Mono.Net.Security.MobileAuthenticatedStream+<ProcessAuthentication>d__47.MoveNext () [0x00254] in <b3922b7d60404fa9ae645f1fb97f5b6b>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0003e] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00028] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00008] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable+ConfiguredTaskAwaiter.GetResult () [0x00000] in <0e06830de9a44394a7e366951eabca52>:0 at SocketHttpListener.Net.HttpConnection+<Init>d__26.MoveNext () [0x000a5] in <5fc69e0598a34841a210f67306929617>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0003e] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00028] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00008] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable+ConfiguredTaskAwaiter.GetResult () [0x00000] in <0e06830de9a44394a7e366951eabca52>:0 at SocketHttpListener.Net.HttpEndPointListener+<ProcessAccept>d__21.MoveNext () [0x0015d] in <5fc69e0598a34841a210f67306929617>:0 Source: mscorlib TargetSite: Void Throw() 2020-06-16 19:33:14.997 Error HttpServer: Error in ProcessAccept *** Error Report *** Version: 4.4.2.0 Command line: /usr/local/lib/emby-server/system/EmbyServer.exe -os freebsd -ffdetect /usr/local/lib/emby-server/bin/ffdetect -ffmpeg /usr/local/lib/emby-server/bin/ffmpeg -ffprobe /usr/local/lib/emby-server/bin/ffprobe -programdata /var/db/emby-server -updatepackage emby-server-freebsd12_{version}_amd64.txz Operating system: Unix 11.3.9.0 64-Bit OS: True 64-Bit Process: True User Interactive: False Mono: 5.10.1.57 (5.10.1.57 Thu Apr 9 04:06:41 UTC 2020) Runtime: file:///usr/local/lib/mono/4.5/mscorlib.dll System.Environment.Version: 4.0.30319.42000 Processor count: 4 Program data path: /var/db/emby-server Application directory: /usr/local/lib/emby-server/system System.IO.IOException: System.IO.IOException: Remote prematurely closed connection. at Mono.Net.Security.AsyncProtocolRequest+<ProcessOperation>d__24.MoveNext () [0x000e7] in <b3922b7d60404fa9ae645f1fb97f5b6b>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0003e] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00028] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00008] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable+ConfiguredTaskAwaiter.GetResult () [0x00000] in <0e06830de9a44394a7e366951eabca52>:0 at Mono.Net.Security.AsyncProtocolRequest+<StartOperation>d__23.MoveNext () [0x0008b] in <b3922b7d60404fa9ae645f1fb97f5b6b>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <0e06830de9a44394a7e366951eabca52>:0 at Mono.Net.Security.MobileAuthenticatedStream+<ProcessAuthentication>d__47.MoveNext () [0x00254] in <b3922b7d60404fa9ae645f1fb97f5b6b>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0003e] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00028] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00008] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable+ConfiguredTaskAwaiter.GetResult () [0x00000] in <0e06830de9a44394a7e366951eabca52>:0 at SocketHttpListener.Net.HttpConnection+<Init>d__26.MoveNext () [0x000a5] in <5fc69e0598a34841a210f67306929617>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0003e] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00028] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00008] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable+ConfiguredTaskAwaiter.GetResult () [0x00000] in <0e06830de9a44394a7e366951eabca52>:0 at SocketHttpListener.Net.HttpEndPointListener+<ProcessAccept>d__21.MoveNext () [0x0015d] in <5fc69e0598a34841a210f67306929617>:0 Source: mscorlib TargetSite: Void Throw() 2020-06-16 19:33:14.997 Error HttpServer: Error in ProcessAccept *** Error Report *** Version: 4.4.2.0 Command line: /usr/local/lib/emby-server/system/EmbyServer.exe -os freebsd -ffdetect /usr/local/lib/emby-server/bin/ffdetect -ffmpeg /usr/local/lib/emby-server/bin/ffmpeg -ffprobe /usr/local/lib/emby-server/bin/ffprobe -programdata /var/db/emby-server -updatepackage emby-server-freebsd12_{version}_amd64.txz Operating system: Unix 11.3.9.0 64-Bit OS: True 64-Bit Process: True User Interactive: False Mono: 5.10.1.57 (5.10.1.57 Thu Apr 9 04:06:41 UTC 2020) Runtime: file:///usr/local/lib/mono/4.5/mscorlib.dll System.Environment.Version: 4.0.30319.42000 Processor count: 4 Program data path: /var/db/emby-server Application directory: /usr/local/lib/emby-server/system System.IO.IOException: System.IO.IOException: Remote prematurely closed connection. at Mono.Net.Security.AsyncProtocolRequest+<ProcessOperation>d__24.MoveNext () [0x000e7] in <b3922b7d60404fa9ae645f1fb97f5b6b>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0003e] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00028] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00008] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable+ConfiguredTaskAwaiter.GetResult () [0x00000] in <0e06830de9a44394a7e366951eabca52>:0 at Mono.Net.Security.AsyncProtocolRequest+<StartOperation>d__23.MoveNext () [0x0008b] in <b3922b7d60404fa9ae645f1fb97f5b6b>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <0e06830de9a44394a7e366951eabca52>:0 at Mono.Net.Security.MobileAuthenticatedStream+<ProcessAuthentication>d__47.MoveNext () [0x00254] in <b3922b7d60404fa9ae645f1fb97f5b6b>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0003e] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00028] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00008] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable+ConfiguredTaskAwaiter.GetResult () [0x00000] in <0e06830de9a44394a7e366951eabca52>:0 at SocketHttpListener.Net.HttpConnection+<Init>d__26.MoveNext () [0x000a5] in <5fc69e0598a34841a210f67306929617>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0003e] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00028] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00008] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable+ConfiguredTaskAwaiter.GetResult () [0x00000] in <0e06830de9a44394a7e366951eabca52>:0 at SocketHttpListener.Net.HttpEndPointListener+<ProcessAccept>d__21.MoveNext () [0x0015d] in <5fc69e0598a34841a210f67306929617>:0 Source: mscorlib TargetSite: Void Throw() 2020-06-16 19:33:14.998 Error HttpServer: Error in ProcessAccept *** Error Report *** Version: 4.4.2.0 Command line: /usr/local/lib/emby-server/system/EmbyServer.exe -os freebsd -ffdetect /usr/local/lib/emby-server/bin/ffdetect -ffmpeg /usr/local/lib/emby-server/bin/ffmpeg -ffprobe /usr/local/lib/emby-server/bin/ffprobe -programdata /var/db/emby-server -updatepackage emby-server-freebsd12_{version}_amd64.txz Operating system: Unix 11.3.9.0 64-Bit OS: True 64-Bit Process: True User Interactive: False Mono: 5.10.1.57 (5.10.1.57 Thu Apr 9 04:06:41 UTC 2020) Runtime: file:///usr/local/lib/mono/4.5/mscorlib.dll System.Environment.Version: 4.0.30319.42000 Processor count: 4 Program data path: /var/db/emby-server Application directory: /usr/local/lib/emby-server/system System.IO.IOException: System.IO.IOException: Remote prematurely closed connection. at Mono.Net.Security.AsyncProtocolRequest+<ProcessOperation>d__24.MoveNext () [0x000e7] in <b3922b7d60404fa9ae645f1fb97f5b6b>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0003e] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00028] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00008] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable+ConfiguredTaskAwaiter.GetResult () [0x00000] in <0e06830de9a44394a7e366951eabca52>:0 at Mono.Net.Security.AsyncProtocolRequest+<StartOperation>d__23.MoveNext () [0x0008b] in <b3922b7d60404fa9ae645f1fb97f5b6b>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <0e06830de9a44394a7e366951eabca52>:0 at Mono.Net.Security.MobileAuthenticatedStream+<ProcessAuthentication>d__47.MoveNext () [0x00254] in <b3922b7d60404fa9ae645f1fb97f5b6b>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0003e] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00028] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00008] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable+ConfiguredTaskAwaiter.GetResult () [0x00000] in <0e06830de9a44394a7e366951eabca52>:0 at SocketHttpListener.Net.HttpConnection+<Init>d__26.MoveNext () [0x000a5] in <5fc69e0598a34841a210f67306929617>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0003e] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00028] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00008] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable+ConfiguredTaskAwaiter.GetResult () [0x00000] in <0e06830de9a44394a7e366951eabca52>:0 at SocketHttpListener.Net.HttpEndPointListener+<ProcessAccept>d__21.MoveNext () [0x0015d] in <5fc69e0598a34841a210f67306929617>:0 Source: mscorlib TargetSite: Void Throw() 2020-06-16 19:33:15.009 Error HttpServer: Error in ProcessAccept *** Error Report *** Version: 4.4.2.0 Command line: /usr/local/lib/emby-server/system/EmbyServer.exe -os freebsd -ffdetect /usr/local/lib/emby-server/bin/ffdetect -ffmpeg /usr/local/lib/emby-server/bin/ffmpeg -ffprobe /usr/local/lib/emby-server/bin/ffprobe -programdata /var/db/emby-server -updatepackage emby-server-freebsd12_{version}_amd64.txz Operating system: Unix 11.3.9.0 64-Bit OS: True 64-Bit Process: True User Interactive: False Mono: 5.10.1.57 (5.10.1.57 Thu Apr 9 04:06:41 UTC 2020) Runtime: file:///usr/local/lib/mono/4.5/mscorlib.dll System.Environment.Version: 4.0.30319.42000 Processor count: 4 Program data path: /var/db/emby-server Application directory: /usr/local/lib/emby-server/system System.IO.IOException: System.IO.IOException: Remote prematurely closed connection. at Mono.Net.Security.AsyncProtocolRequest+<ProcessOperation>d__24.MoveNext () [0x000e7] in <b3922b7d60404fa9ae645f1fb97f5b6b>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0003e] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00028] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00008] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable+ConfiguredTaskAwaiter.GetResult () [0x00000] in <0e06830de9a44394a7e366951eabca52>:0 at Mono.Net.Security.AsyncProtocolRequest+<StartOperation>d__23.MoveNext () [0x0008b] in <b3922b7d60404fa9ae645f1fb97f5b6b>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <0e06830de9a44394a7e366951eabca52>:0 at Mono.Net.Security.MobileAuthenticatedStream+<ProcessAuthentication>d__47.MoveNext () [0x00254] in <b3922b7d60404fa9ae645f1fb97f5b6b>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0003e] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00028] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00008] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable+ConfiguredTaskAwaiter.GetResult () [0x00000] in <0e06830de9a44394a7e366951eabca52>:0 at SocketHttpListener.Net.HttpConnection+<Init>d__26.MoveNext () [0x000a5] in <5fc69e0598a34841a210f67306929617>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0003e] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00028] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00008] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable+ConfiguredTaskAwaiter.GetResult () [0x00000] in <0e06830de9a44394a7e366951eabca52>:0 at SocketHttpListener.Net.HttpEndPointListener+<ProcessAccept>d__21.MoveNext () [0x0015d] in <5fc69e0598a34841a210f67306929617>:0 Source: mscorlib TargetSite: Void Throw() 2020-06-16 19:33:15.031 Error HttpServer: Error in ProcessAccept *** Error Report *** Version: 4.4.2.0 Command line: /usr/local/lib/emby-server/system/EmbyServer.exe -os freebsd -ffdetect /usr/local/lib/emby-server/bin/ffdetect -ffmpeg /usr/local/lib/emby-server/bin/ffmpeg -ffprobe /usr/local/lib/emby-server/bin/ffprobe -programdata /var/db/emby-server -updatepackage emby-server-freebsd12_{version}_amd64.txz Operating system: Unix 11.3.9.0 64-Bit OS: True 64-Bit Process: True User Interactive: False Mono: 5.10.1.57 (5.10.1.57 Thu Apr 9 04:06:41 UTC 2020) Runtime: file:///usr/local/lib/mono/4.5/mscorlib.dll System.Environment.Version: 4.0.30319.42000 Processor count: 4 Program data path: /var/db/emby-server Application directory: /usr/local/lib/emby-server/system System.IO.IOException: System.IO.IOException: Remote prematurely closed connection. at Mono.Net.Security.AsyncProtocolRequest+<ProcessOperation>d__24.MoveNext () [0x000e7] in <b3922b7d60404fa9ae645f1fb97f5b6b>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0003e] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00028] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00008] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable+ConfiguredTaskAwaiter.GetResult () [0x00000] in <0e06830de9a44394a7e366951eabca52>:0 at Mono.Net.Security.AsyncProtocolRequest+<StartOperation>d__23.MoveNext () [0x0008b] in <b3922b7d60404fa9ae645f1fb97f5b6b>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <0e06830de9a44394a7e366951eabca52>:0 at Mono.Net.Security.MobileAuthenticatedStream+<ProcessAuthentication>d__47.MoveNext () [0x00254] in <b3922b7d60404fa9ae645f1fb97f5b6b>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0003e] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00028] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00008] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable+ConfiguredTaskAwaiter.GetResult () [0x00000] in <0e06830de9a44394a7e366951eabca52>:0 at SocketHttpListener.Net.HttpConnection+<Init>d__26.MoveNext () [0x000a5] in <5fc69e0598a34841a210f67306929617>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0003e] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00028] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00008] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable+ConfiguredTaskAwaiter.GetResult () [0x00000] in <0e06830de9a44394a7e366951eabca52>:0 at SocketHttpListener.Net.HttpEndPointListener+<ProcessAccept>d__21.MoveNext () [0x0015d] in <5fc69e0598a34841a210f67306929617>:0 Source: mscorlib TargetSite: Void Throw() 2020-06-16 19:33:15.036 Error HttpServer: Error in ProcessAccept *** Error Report *** Version: 4.4.2.0 Command line: /usr/local/lib/emby-server/system/EmbyServer.exe -os freebsd -ffdetect /usr/local/lib/emby-server/bin/ffdetect -ffmpeg /usr/local/lib/emby-server/bin/ffmpeg -ffprobe /usr/local/lib/emby-server/bin/ffprobe -programdata /var/db/emby-server -updatepackage emby-server-freebsd12_{version}_amd64.txz Operating system: Unix 11.3.9.0 64-Bit OS: True 64-Bit Process: True User Interactive: False Mono: 5.10.1.57 (5.10.1.57 Thu Apr 9 04:06:41 UTC 2020) Runtime: file:///usr/local/lib/mono/4.5/mscorlib.dll System.Environment.Version: 4.0.30319.42000 Processor count: 4 Program data path: /var/db/emby-server Application directory: /usr/local/lib/emby-server/system System.Security.Authentication.AuthenticationException: System.Security.Authentication.AuthenticationException: A call to SSPI failed, see inner exception. ---> System.Net.Sockets.SocketException: Connection reset by peer at System.Net.Sockets.Socket.EndReceive (System.IAsyncResult asyncResult) [0x00012] in <b3922b7d60404fa9ae645f1fb97f5b6b>:0 at SocketHttpListener.SocketStream.EndRead (System.IAsyncResult asyncResult) [0x00000] in <5fc69e0598a34841a210f67306929617>:0 at System.IO.Stream+<>c.<BeginEndReadAsync>b__43_1 (System.IO.Stream stream, System.IAsyncResult asyncResult) [0x00000] in <0e06830de9a44394a7e366951eabca52>:0 at System.Threading.Tasks.TaskFactory`1+FromAsyncTrimPromise`1[TResult,TInstance].Complete (TInstance thisRef, System.Func`3[T1,T2,TResult] endMethod, System.IAsyncResult asyncResult, System.Boolean requiresSynchronization) [0x00000] in <0e06830de9a44394a7e366951eabca52>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0003e] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00028] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00008] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[TResult].GetResult () [0x00000] in <0e06830de9a44394a7e366951eabca52>:0 at Mono.Net.Security.MobileAuthenticatedStream+<InnerRead>d__66.MoveNext () [0x00104] in <b3922b7d60404fa9ae645f1fb97f5b6b>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0003e] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00028] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00008] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[TResult].GetResult () [0x00000] in <0e06830de9a44394a7e366951eabca52>:0 at Mono.Net.Security.AsyncProtocolRequest+<InnerRead>d__25.MoveNext () [0x000ac] in <b3922b7d60404fa9ae645f1fb97f5b6b>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0003e] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00028] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00008] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[TResult].GetResult () [0x00000] in <0e06830de9a44394a7e366951eabca52>:0 at Mono.Net.Security.AsyncProtocolRequest+<ProcessOperation>d__24.MoveNext () [0x00093] in <b3922b7d60404fa9ae645f1fb97f5b6b>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0003e] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00028] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00008] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable+ConfiguredTaskAwaiter.GetResult () [0x00000] in <0e06830de9a44394a7e366951eabca52>:0 at Mono.Net.Security.AsyncProtocolRequest+<StartOperation>d__23.MoveNext () [0x0008b] in <b3922b7d60404fa9ae645f1fb97f5b6b>:0 --- End of inner exception stack trace --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <0e06830de9a44394a7e366951eabca52>:0 at Mono.Net.Security.MobileAuthenticatedStream+<ProcessAuthentication>d__47.MoveNext () [0x00254] in <b3922b7d60404fa9ae645f1fb97f5b6b>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0003e] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00028] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00008] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable+ConfiguredTaskAwaiter.GetResult () [0x00000] in <0e06830de9a44394a7e366951eabca52>:0 at SocketHttpListener.Net.HttpConnection+<Init>d__26.MoveNext () [0x000a5] in <5fc69e0598a34841a210f67306929617>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0003e] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00028] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00008] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable+ConfiguredTaskAwaiter.GetResult () [0x00000] in <0e06830de9a44394a7e366951eabca52>:0 at SocketHttpListener.Net.HttpEndPointListener+<ProcessAccept>d__21.MoveNext () [0x0015d] in <5fc69e0598a34841a210f67306929617>:0 Source: mscorlib TargetSite: Void Throw() InnerException: System.Net.Sockets.SocketException: Connection reset by peer Source: mscorlib TargetSite: Void Throw() at System.Net.Sockets.Socket.EndReceive (System.IAsyncResult asyncResult) [0x00012] in <b3922b7d60404fa9ae645f1fb97f5b6b>:0 at SocketHttpListener.SocketStream.EndRead (System.IAsyncResult asyncResult) [0x00000] in <5fc69e0598a34841a210f67306929617>:0 at System.IO.Stream+<>c.<BeginEndReadAsync>b__43_1 (System.IO.Stream stream, System.IAsyncResult asyncResult) [0x00000] in <0e06830de9a44394a7e366951eabca52>:0 at System.Threading.Tasks.TaskFactory`1+FromAsyncTrimPromise`1[TResult,TInstance].Complete (TInstance thisRef, System.Func`3[T1,T2,TResult] endMethod, System.IAsyncResult asyncResult, System.Boolean requiresSynchronization) [0x00000] in <0e06830de9a44394a7e366951eabca52>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0003e] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00028] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00008] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[TResult].GetResult () [0x00000] in <0e06830de9a44394a7e366951eabca52>:0 at Mono.Net.Security.MobileAuthenticatedStream+<InnerRead>d__66.MoveNext () [0x00104] in <b3922b7d60404fa9ae645f1fb97f5b6b>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0003e] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00028] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00008] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[TResult].GetResult () [0x00000] in <0e06830de9a44394a7e366951eabca52>:0 at Mono.Net.Security.AsyncProtocolRequest+<InnerRead>d__25.MoveNext () [0x000ac] in <b3922b7d60404fa9ae645f1fb97f5b6b>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0003e] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00028] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00008] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[TResult].GetResult () [0x00000] in <0e06830de9a44394a7e366951eabca52>:0 at Mono.Net.Security.AsyncProtocolRequest+<ProcessOperation>d__24.MoveNext () [0x00093] in <b3922b7d60404fa9ae645f1fb97f5b6b>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0003e] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00028] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00008] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable+ConfiguredTaskAwaiter.GetResult () [0x00000] in <0e06830de9a44394a7e366951eabca52>:0 at Mono.Net.Security.AsyncProtocolRequest+<StartOperation>d__23.MoveNext () [0x0008b] in <b3922b7d60404fa9ae645f1fb97f5b6b>:0 2020-06-16 19:33:15.170 Debug XmlSerializer: Deserializing file /var/db/emby-server/config/branding.xml 2020-06-16 19:33:15.194 Error HttpServer: Error in ProcessAccept *** Error Report *** Version: 4.4.2.0 Command line: /usr/local/lib/emby-server/system/EmbyServer.exe -os freebsd -ffdetect /usr/local/lib/emby-server/bin/ffdetect -ffmpeg /usr/local/lib/emby-server/bin/ffmpeg -ffprobe /usr/local/lib/emby-server/bin/ffprobe -programdata /var/db/emby-server -updatepackage emby-server-freebsd12_{version}_amd64.txz Operating system: Unix 11.3.9.0 64-Bit OS: True 64-Bit Process: True User Interactive: False Mono: 5.10.1.57 (5.10.1.57 Thu Apr 9 04:06:41 UTC 2020) Runtime: file:///usr/local/lib/mono/4.5/mscorlib.dll System.Environment.Version: 4.0.30319.42000 Processor count: 4 Program data path: /var/db/emby-server Application directory: /usr/local/lib/emby-server/system System.IO.IOException: System.IO.IOException: Remote prematurely closed connection. at Mono.Net.Security.AsyncProtocolRequest+<ProcessOperation>d__24.MoveNext () [0x000e7] in <b3922b7d60404fa9ae645f1fb97f5b6b>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0003e] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00028] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00008] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable+ConfiguredTaskAwaiter.GetResult () [0x00000] in <0e06830de9a44394a7e366951eabca52>:0 at Mono.Net.Security.AsyncProtocolRequest+<StartOperation>d__23.MoveNext () [0x0008b] in <b3922b7d60404fa9ae645f1fb97f5b6b>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <0e06830de9a44394a7e366951eabca52>:0 at Mono.Net.Security.MobileAuthenticatedStream+<ProcessAuthentication>d__47.MoveNext () [0x00254] in <b3922b7d60404fa9ae645f1fb97f5b6b>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0003e] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00028] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00008] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable+ConfiguredTaskAwaiter.GetResult () [0x00000] in <0e06830de9a44394a7e366951eabca52>:0 at SocketHttpListener.Net.HttpConnection+<Init>d__26.MoveNext () [0x000a5] in <5fc69e0598a34841a210f67306929617>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0003e] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00028] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00008] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable+ConfiguredTaskAwaiter.GetResult () [0x00000] in <0e06830de9a44394a7e366951eabca52>:0 at SocketHttpListener.Net.HttpEndPointListener+<ProcessAccept>d__21.MoveNext () [0x0015d] in <5fc69e0598a34841a210f67306929617>:0 Source: mscorlib TargetSite: Void Throw() 2020-06-16 19:33:15.512 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/system/info/public. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 19:33:15.513 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 1ms. https://192.168.1.29:8920/emby/system/info/public 2020-06-16 19:33:15.547 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/System/Info. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 19:33:15.705 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 157ms. https://192.168.1.29:8920/emby/System/Info 2020-06-16 19:33:15.732 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/DisplayPreferences/usersettings?userId=65d0ee59448b4babb59b4bfba1ad3fcf&client=emby. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 19:33:15.740 Info HttpServer: WS https://192.168.1.29:8920/embywebsocket?api_key=1733ef2d1e0a4ffb856b3ddbbec9dcee&deviceId=TW96aWxsYS81LjAgKFdpbmRvd3MgTlQgMTAuMDsgV2luNjQ7IHg2NDsgcnY6NjUuMCkgR2Vja28vMjAxMDAxMDEgRmlyZWZveC82NS4wfDE1NDkwNTAyMzUyOTE1. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 19:33:15.741 Debug SessionManager: Creating new WebSocketController 2020-06-16 19:33:15.803 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 72ms. https://192.168.1.29:8920/emby/DisplayPreferences/usersettings?userId=65d0ee59448b4babb59b4bfba1ad3fcf&client=emby 2020-06-16 19:33:15.862 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Users/65d0ee59448b4babb59b4bfba1ad3fcf. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 19:33:15.864 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 1ms. https://192.168.1.29:8920/emby/Users/65d0ee59448b4babb59b4bfba1ad3fcf 2020-06-16 19:33:15.920 Info HttpServer: HTTP GET https://192.168.1.29:8920/web/modules/themes/dark/theme.json?v=4.4.2.0&r=0. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 19:33:15.920 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 1ms. https://192.168.1.29:8920/web/modules/themes/dark/theme.json?v=4.4.2.0&r=0 2020-06-16 19:33:15.923 Info HttpServer: HTTP POST https://192.168.1.29:8920/emby/Sessions/Capabilities/Full. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 19:33:15.943 Info HttpServer: HTTP Response 204 to 192.168.1.2. Time: 20ms. https://192.168.1.29:8920/emby/Sessions/Capabilities/Full 2020-06-16 19:33:15.992 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Users/65d0ee59448b4babb59b4bfba1ad3fcf/Views. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 19:33:15.994 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 2ms. https://192.168.1.29:8920/emby/Users/65d0ee59448b4babb59b4bfba1ad3fcf/Views 2020-06-16 19:33:16.051 Error HttpServer: Error in ProcessAccept *** Error Report *** Version: 4.4.2.0 Command line: /usr/local/lib/emby-server/system/EmbyServer.exe -os freebsd -ffdetect /usr/local/lib/emby-server/bin/ffdetect -ffmpeg /usr/local/lib/emby-server/bin/ffmpeg -ffprobe /usr/local/lib/emby-server/bin/ffprobe -programdata /var/db/emby-server -updatepackage emby-server-freebsd12_{version}_amd64.txz Operating system: Unix 11.3.9.0 64-Bit OS: True 64-Bit Process: True User Interactive: False Mono: 5.10.1.57 (5.10.1.57 Thu Apr 9 04:06:41 UTC 2020) Runtime: file:///usr/local/lib/mono/4.5/mscorlib.dll System.Environment.Version: 4.0.30319.42000 Processor count: 4 Program data path: /var/db/emby-server Application directory: /usr/local/lib/emby-server/system System.IO.IOException: System.IO.IOException: Remote prematurely closed connection. at Mono.Net.Security.AsyncProtocolRequest+<ProcessOperation>d__24.MoveNext () [0x000e7] in <b3922b7d60404fa9ae645f1fb97f5b6b>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0003e] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00028] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00008] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable+ConfiguredTaskAwaiter.GetResult () [0x00000] in <0e06830de9a44394a7e366951eabca52>:0 at Mono.Net.Security.AsyncProtocolRequest+<StartOperation>d__23.MoveNext () [0x0008b] in <b3922b7d60404fa9ae645f1fb97f5b6b>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <0e06830de9a44394a7e366951eabca52>:0 at Mono.Net.Security.MobileAuthenticatedStream+<ProcessAuthentication>d__47.MoveNext () [0x00254] in <b3922b7d60404fa9ae645f1fb97f5b6b>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0003e] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00028] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00008] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable+ConfiguredTaskAwaiter.GetResult () [0x00000] in <0e06830de9a44394a7e366951eabca52>:0 at SocketHttpListener.Net.HttpConnection+<Init>d__26.MoveNext () [0x000a5] in <5fc69e0598a34841a210f67306929617>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0003e] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00028] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00008] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable+ConfiguredTaskAwaiter.GetResult () [0x00000] in <0e06830de9a44394a7e366951eabca52>:0 at SocketHttpListener.Net.HttpEndPointListener+<ProcessAccept>d__21.MoveNext () [0x0015d] in <5fc69e0598a34841a210f67306929617>:0 Source: mscorlib TargetSite: Void Throw() 2020-06-16 19:33:16.066 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Users/65d0ee59448b4babb59b4bfba1ad3fcf/Items/Resume?Limit=12&Recursive=true&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo%2CProductionYear&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&EnableTotalRecordCount=false&MediaTypes=Video. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 19:33:16.068 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Users/65d0ee59448b4babb59b4bfba1ad3fcf/Items/Resume?Limit=12&Recursive=true&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo%2CProductionYear&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&EnableTotalRecordCount=false&MediaTypes=Audio. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 19:33:16.069 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 3ms. https://192.168.1.29:8920/emby/Users/65d0ee59448b4babb59b4bfba1ad3fcf/Items/Resume?Limit=12&Recursive=true&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo%2CProductionYear&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&EnableTotalRecordCount=false&MediaTypes=Video 2020-06-16 19:33:16.069 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 2ms. https://192.168.1.29:8920/emby/Users/65d0ee59448b4babb59b4bfba1ad3fcf/Items/Resume?Limit=12&Recursive=true&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo%2CProductionYear&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&EnableTotalRecordCount=false&MediaTypes=Audio 2020-06-16 19:33:17.236 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/ScheduledTasks. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 19:33:17.238 Debug App: ScheduledTasksWebSocketListener Begin transmitting over websocket to 192.168.1.2 2020-06-16 19:33:17.238 Debug App: ActivityLogWebSocketListener Begin transmitting over websocket to 192.168.1.2 2020-06-16 19:33:17.239 Debug App: ActivityLogWebSocketListener Begin transmitting over websocket to 192.168.1.2 2020-06-16 19:33:17.240 Debug App: SessionInfosWebSocketListener Begin transmitting over websocket to 192.168.1.2 2020-06-16 19:33:17.247 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/News/Product?StartIndex=0&Limit=4. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 19:33:17.251 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/System/Info. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 19:33:17.252 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/System/ActivityLog/Entries?StartIndex=0&Limit=4&MinDate=2020-06-09T16%3A33%3A17.167Z&hasUserId=false. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 19:33:17.252 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/System/ActivityLog/Entries?StartIndex=0&Limit=7&MinDate=2020-06-15T16%3A33%3A17.166Z&hasUserId=true. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 19:33:17.253 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 2ms. https://192.168.1.29:8920/emby/System/Info 2020-06-16 19:33:17.254 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/LiveTv/Recordings?UserId=65d0ee59448b4babb59b4bfba1ad3fcf&IsInProgress=true&Fields=CanDelete%2CPrimaryImageAspectRatio&EnableTotalRecordCount=false&EnableImageTypes=Primary%2CThumb%2CBackdrop. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 19:33:17.256 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/web/configurationpages?pageType=PluginConfiguration&EnableInMainMenu=true. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 19:33:17.284 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 30ms. https://192.168.1.29:8920/emby/LiveTv/Recordings?UserId=65d0ee59448b4babb59b4bfba1ad3fcf&IsInProgress=true&Fields=CanDelete%2CPrimaryImageAspectRatio&EnableTotalRecordCount=false&EnableImageTypes=Primary%2CThumb%2CBackdrop 2020-06-16 19:33:17.289 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 34ms. https://192.168.1.29:8920/emby/web/configurationpages?pageType=PluginConfiguration&EnableInMainMenu=true 2020-06-16 19:33:17.290 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Packages/Updates?PackageType=System. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 19:33:17.303 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 67ms. https://192.168.1.29:8920/emby/ScheduledTasks 2020-06-16 19:33:17.367 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 119ms. https://192.168.1.29:8920/emby/News/Product?StartIndex=0&Limit=4 2020-06-16 19:33:17.827 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 537ms. https://192.168.1.29:8920/emby/Packages/Updates?PackageType=System 2020-06-16 19:33:17.838 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 586ms. https://192.168.1.29:8920/emby/System/ActivityLog/Entries?StartIndex=0&Limit=4&MinDate=2020-06-09T16%3A33%3A17.167Z&hasUserId=false 2020-06-16 19:33:17.840 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 588ms. https://192.168.1.29:8920/emby/System/ActivityLog/Entries?StartIndex=0&Limit=7&MinDate=2020-06-15T16%3A33%3A17.166Z&hasUserId=true 2020-06-16 19:33:17.953 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Sessions?ActiveWithinSeconds=900. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 19:33:18.014 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 61ms. https://192.168.1.29:8920/emby/Sessions?ActiveWithinSeconds=900 2020-06-16 19:33:18.832 Debug App: ScheduledTasksWebSocketListener stop transmitting over websocket to 192.168.1.2 2020-06-16 19:33:18.832 Debug App: SessionInfosWebSocketListener stop transmitting over websocket to 192.168.1.2 2020-06-16 19:33:18.875 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/users. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 19:33:18.883 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 8ms. https://192.168.1.29:8920/emby/users 2020-06-16 19:33:25.112 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/System/Configuration. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 19:33:25.113 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Users/883af2911301488dadb02054b300057c. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 19:33:25.115 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 2ms. https://192.168.1.29:8920/emby/Users/883af2911301488dadb02054b300057c 2020-06-16 19:33:25.154 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 42ms. https://192.168.1.29:8920/emby/System/Configuration 2020-06-16 19:33:25.168 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Auth/Providers. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 19:33:25.168 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Library/MediaFolders?IsHidden=false. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 19:33:25.192 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 25ms. https://192.168.1.29:8920/emby/Library/MediaFolders?IsHidden=false 2020-06-16 19:33:25.203 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 35ms. https://192.168.1.29:8920/emby/Auth/Providers 2020-06-16 19:33:25.224 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Channels?SupportsMediaDeletion=true. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 19:33:25.227 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 3ms. https://192.168.1.29:8920/emby/Channels?SupportsMediaDeletion=true 2020-06-16 19:33:27.371 Debug App: ActivityLogWebSocketListener stop transmitting over websocket to 192.168.1.2 2020-06-16 19:33:27.371 Debug App: ActivityLogWebSocketListener stop transmitting over websocket to 192.168.1.2 2020-06-16 19:33:27.384 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Localization/ParentalRatings. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 19:33:27.400 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 16ms. https://192.168.1.29:8920/emby/Localization/ParentalRatings 2020-06-16 19:33:28.662 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/users. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 19:33:28.664 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 2ms. https://192.168.1.29:8920/emby/users 2020-06-16 19:33:29.281 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/System/Configuration. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 19:33:29.282 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 1ms. https://192.168.1.29:8920/emby/System/Configuration 2020-06-16 19:33:29.286 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Users/180ecb41e5414e68b771982532073857. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 19:33:29.286 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Auth/Providers. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 19:33:29.286 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Library/MediaFolders?IsHidden=false. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 19:33:29.287 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 1ms. https://192.168.1.29:8920/emby/Auth/Providers 2020-06-16 19:33:29.289 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 3ms. https://192.168.1.29:8920/emby/Users/180ecb41e5414e68b771982532073857 2020-06-16 19:33:29.291 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 5ms. https://192.168.1.29:8920/emby/Library/MediaFolders?IsHidden=false 2020-06-16 19:33:29.304 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Channels?SupportsMediaDeletion=true. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 19:33:29.305 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 1ms. https://192.168.1.29:8920/emby/Channels?SupportsMediaDeletion=true 2020-06-16 19:33:30.440 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Localization/ParentalRatings. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 19:33:30.441 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 1ms. https://192.168.1.29:8920/emby/Localization/ParentalRatings 2020-06-16 19:33:33.378 Info HttpServer: HTTP POST https://192.168.1.29:8920/emby/Users/180ecb41e5414e68b771982532073857/Policy. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 19:33:33.454 Debug XmlSerializer: Serializing to file /var/db/emby-server/config/users/180ecb41e5414e68b771982532073857/policy.xml 2020-06-16 19:33:33.458 Info HttpServer: HTTP Response 204 to 192.168.1.2. Time: 80ms. https://192.168.1.29:8920/emby/Users/180ecb41e5414e68b771982532073857/Policy 2020-06-16 19:33:35.130 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/users. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 19:33:35.132 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 2ms. https://192.168.1.29:8920/emby/users 2020-06-16 19:33:36.077 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/System/Configuration. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 19:33:36.077 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Users/180ecb41e5414e68b771982532073857. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 19:33:36.078 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 2ms. https://192.168.1.29:8920/emby/Users/180ecb41e5414e68b771982532073857 2020-06-16 19:33:36.080 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 3ms. https://192.168.1.29:8920/emby/System/Configuration 2020-06-16 19:33:36.099 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Auth/Providers. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 19:33:36.099 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Library/MediaFolders?IsHidden=false. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 19:33:36.100 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 1ms. https://192.168.1.29:8920/emby/Auth/Providers 2020-06-16 19:33:36.102 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 3ms. https://192.168.1.29:8920/emby/Library/MediaFolders?IsHidden=false 2020-06-16 19:33:36.128 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Channels?SupportsMediaDeletion=true. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 19:33:36.129 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 1ms. https://192.168.1.29:8920/emby/Channels?SupportsMediaDeletion=true 2020-06-16 19:33:36.718 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Localization/ParentalRatings. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 19:33:36.719 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 1ms. https://192.168.1.29:8920/emby/Localization/ParentalRatings 2020-06-16 19:33:38.837 Info HttpServer: HTTP POST https://192.168.1.29:8920/emby/Users/180ecb41e5414e68b771982532073857/Policy. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 19:33:38.839 Debug XmlSerializer: Serializing to file /var/db/emby-server/config/users/180ecb41e5414e68b771982532073857/policy.xml 2020-06-16 19:33:38.839 Info HttpServer: HTTP Response 204 to 192.168.1.2. Time: 2ms. https://192.168.1.29:8920/emby/Users/180ecb41e5414e68b771982532073857/Policy 2020-06-16 19:33:39.670 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/users. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 19:33:39.672 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 2ms. https://192.168.1.29:8920/emby/users 2020-06-16 19:33:41.011 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Library/MediaFolders?IsHidden=false. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 19:33:41.011 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/System/Configuration. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 19:33:41.011 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Auth/Providers. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 19:33:41.013 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 1ms. https://192.168.1.29:8920/emby/Auth/Providers 2020-06-16 19:33:41.014 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 2ms. https://192.168.1.29:8920/emby/System/Configuration 2020-06-16 19:33:41.016 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 5ms. https://192.168.1.29:8920/emby/Library/MediaFolders?IsHidden=false 2020-06-16 19:33:41.026 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Channels?SupportsMediaDeletion=true. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 19:33:41.039 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 13ms. https://192.168.1.29:8920/emby/Channels?SupportsMediaDeletion=true 2020-06-16 19:33:41.635 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Localization/ParentalRatings. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 19:33:41.636 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 1ms. https://192.168.1.29:8920/emby/Localization/ParentalRatings 2020-06-16 19:33:47.159 Info HttpServer: HTTP POST https://192.168.1.29:8920/emby/Users/883af2911301488dadb02054b300057c/Policy. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 19:33:47.163 Debug XmlSerializer: Serializing to file /var/db/emby-server/config/users/883af2911301488dadb02054b300057c/policy.xml 2020-06-16 19:33:47.166 Error HttpServer: Error processing request *** Error Report *** Version: 4.4.2.0 Command line: /usr/local/lib/emby-server/system/EmbyServer.exe -os freebsd -ffdetect /usr/local/lib/emby-server/bin/ffdetect -ffmpeg /usr/local/lib/emby-server/bin/ffmpeg -ffprobe /usr/local/lib/emby-server/bin/ffprobe -programdata /var/db/emby-server -updatepackage emby-server-freebsd12_{version}_amd64.txz Operating system: Unix 11.3.9.0 64-Bit OS: True 64-Bit Process: True User Interactive: False Mono: 5.10.1.57 (5.10.1.57 Thu Apr 9 04:06:41 UTC 2020) Runtime: file:///usr/local/lib/mono/4.5/mscorlib.dll System.Environment.Version: 4.0.30319.42000 Processor count: 4 Program data path: /var/db/emby-server Application directory: /usr/local/lib/emby-server/system System.UnauthorizedAccessException: System.UnauthorizedAccessException: Access to the path "/var/db/emby-server/config/users/883af2911301488dadb02054b300057c/policy.xml" is denied. at System.IO.FileStream..ctor (System.String path, System.IO.FileMode mode, System.IO.FileAccess access, System.IO.FileShare share, System.Int32 bufferSize, System.Boolean anonymous, System.IO.FileOptions options) [0x0019e] in <0e06830de9a44394a7e366951eabca52>:0 at System.IO.FileStream..ctor (System.String path, System.IO.FileMode mode) [0x00000] in <0e06830de9a44394a7e366951eabca52>:0 at (wrapper remoting-invoke-with-check) System.IO.FileStream..ctor(string,System.IO.FileMode) at Emby.Server.Implementations.Serialization.MyXmlSerializer.SerializeToFile (System.Object obj, System.String file) [0x0001a] in <3605319732a64e8282cfdf09a091f02e>:0 at Emby.Server.Implementations.Library.UserManager.UpdateUserPolicy (MediaBrowser.Controller.Entities.User user, MediaBrowser.Model.Users.UserPolicy userPolicy, System.Boolean fireEvent) [0x00060] in <3605319732a64e8282cfdf09a091f02e>:0 at Emby.Server.Implementations.Library.UserManager.UpdateUserPolicy (System.Int64 userId, MediaBrowser.Model.Users.UserPolicy userPolicy) [0x00008] in <3605319732a64e8282cfdf09a091f02e>:0 at MediaBrowser.Api.UserService.Post (MediaBrowser.Api.UpdateUserPolicy request) [0x0011b] in <0390257caaf74c7fb5e30cb51d35bfbc>:0 at (wrapper dynamic-method) System.Object.lambda_method(System.Runtime.CompilerServices.Closure,object,object) at Emby.Server.Implementations.Services.ServiceController+<>c__DisplayClass6_0.<VoidActionDelegate>b__0 (System.Object service, System.Object request) [0x00000] in <3605319732a64e8282cfdf09a091f02e>:0 at Emby.Server.Implementations.Services.ServiceController.Execute (Emby.Server.Implementations.HttpServer.HttpListenerHost appHost, System.Object requestDto, MediaBrowser.Model.Services.IRequest req) [0x00073] in <3605319732a64e8282cfdf09a091f02e>:0 at Emby.Server.Implementations.Services.ServiceHandler+<ProcessRequestAsync>d__4.MoveNext () [0x00168] in <3605319732a64e8282cfdf09a091f02e>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0003e] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00028] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00008] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable+ConfiguredTaskAwaiter.GetResult () [0x00000] in <0e06830de9a44394a7e366951eabca52>:0 at Emby.Server.Implementations.HttpServer.HttpListenerHost+<RequestHandler>d__46.MoveNext () [0x00b52] in <3605319732a64e8282cfdf09a091f02e>:0 Source: mscorlib TargetSite: Void Throw() 2020-06-16 19:33:47.166 Info HttpServer: HTTP Response 500 to 192.168.1.2. Time: 7ms. https://192.168.1.29:8920/emby/Users/883af2911301488dadb02054b300057c/Policy 2020-06-16 19:33:54.787 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/users. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 19:33:54.789 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 2ms. https://192.168.1.29:8920/emby/users 2020-06-16 19:33:56.216 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/System/Configuration. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 19:33:56.216 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Users/883af2911301488dadb02054b300057c. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 19:33:56.218 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 1ms. https://192.168.1.29:8920/emby/System/Configuration 2020-06-16 19:33:56.219 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 2ms. https://192.168.1.29:8920/emby/Users/883af2911301488dadb02054b300057c 2020-06-16 19:33:56.237 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Auth/Providers. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 19:33:56.238 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Library/MediaFolders?IsHidden=false. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 19:33:56.238 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 1ms. https://192.168.1.29:8920/emby/Auth/Providers 2020-06-16 19:33:56.240 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 3ms. https://192.168.1.29:8920/emby/Library/MediaFolders?IsHidden=false 2020-06-16 19:33:56.252 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Channels?SupportsMediaDeletion=true. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 19:33:56.253 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 1ms. https://192.168.1.29:8920/emby/Channels?SupportsMediaDeletion=true 2020-06-16 19:33:57.002 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Localization/ParentalRatings. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 19:33:57.003 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 1ms. https://192.168.1.29:8920/emby/Localization/ParentalRatings 2020-06-16 19:33:58.706 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/System/Configuration. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 19:33:58.707 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 1ms. https://192.168.1.29:8920/emby/System/Configuration 2020-06-16 19:33:58.769 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/System/Logs. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 19:33:58.968 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 199ms. https://192.168.1.29:8920/emby/System/Logs 2020-06-16 19:34:02.230 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/System/Logs/embyserver.txt. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 19:34:02.283 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 53ms. https://192.168.1.29:8920/emby/System/Logs/embyserver.txt 2020-06-16 19:34:02.366 Info HttpServer: HTTP GET https://192.168.1.29:8920/favicon.ico. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 19:34:02.389 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 24ms. https://192.168.1.29:8920/favicon.ico 2020-06-16 19:35:39.116 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Users/65d0ee59448b4babb59b4bfba1ad3fcf. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 19:35:39.116 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/users. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 19:35:39.118 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 2ms. https://192.168.1.29:8920/emby/Users/65d0ee59448b4babb59b4bfba1ad3fcf 2020-06-16 19:35:39.119 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 3ms. https://192.168.1.29:8920/emby/users 2020-06-16 19:35:40.001 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/System/Configuration. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 19:35:40.002 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 1ms. https://192.168.1.29:8920/emby/System/Configuration 2020-06-16 19:35:40.007 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Users/883af2911301488dadb02054b300057c. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 19:35:40.007 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Auth/Providers. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 19:35:40.008 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 2ms. https://192.168.1.29:8920/emby/Users/883af2911301488dadb02054b300057c 2020-06-16 19:35:40.010 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 3ms. https://192.168.1.29:8920/emby/Auth/Providers 2020-06-16 19:35:40.023 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Library/MediaFolders?IsHidden=false. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 19:35:40.025 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 2ms. https://192.168.1.29:8920/emby/Library/MediaFolders?IsHidden=false 2020-06-16 19:35:40.039 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Channels?SupportsMediaDeletion=true. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 19:35:40.040 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 1ms. https://192.168.1.29:8920/emby/Channels?SupportsMediaDeletion=true 2020-06-16 19:35:40.812 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Localization/ParentalRatings. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 19:35:40.813 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 1ms. https://192.168.1.29:8920/emby/Localization/ParentalRatings 2020-06-16 19:35:44.487 Info HttpServer: HTTP POST https://192.168.1.29:8920/emby/Users/883af2911301488dadb02054b300057c/Policy. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 19:35:44.488 Debug XmlSerializer: Serializing to file /var/db/emby-server/config/users/883af2911301488dadb02054b300057c/policy.xml 2020-06-16 19:35:44.490 Error HttpServer: Error processing request *** Error Report *** Version: 4.4.2.0 Command line: /usr/local/lib/emby-server/system/EmbyServer.exe -os freebsd -ffdetect /usr/local/lib/emby-server/bin/ffdetect -ffmpeg /usr/local/lib/emby-server/bin/ffmpeg -ffprobe /usr/local/lib/emby-server/bin/ffprobe -programdata /var/db/emby-server -updatepackage emby-server-freebsd12_{version}_amd64.txz Operating system: Unix 11.3.9.0 64-Bit OS: True 64-Bit Process: True User Interactive: False Mono: 5.10.1.57 (5.10.1.57 Thu Apr 9 04:06:41 UTC 2020) Runtime: file:///usr/local/lib/mono/4.5/mscorlib.dll System.Environment.Version: 4.0.30319.42000 Processor count: 4 Program data path: /var/db/emby-server Application directory: /usr/local/lib/emby-server/system System.UnauthorizedAccessException: System.UnauthorizedAccessException: Access to the path "/var/db/emby-server/config/users/883af2911301488dadb02054b300057c/policy.xml" is denied. at System.IO.FileStream..ctor (System.String path, System.IO.FileMode mode, System.IO.FileAccess access, System.IO.FileShare share, System.Int32 bufferSize, System.Boolean anonymous, System.IO.FileOptions options) [0x0019e] in <0e06830de9a44394a7e366951eabca52>:0 at System.IO.FileStream..ctor (System.String path, System.IO.FileMode mode) [0x00000] in <0e06830de9a44394a7e366951eabca52>:0 at (wrapper remoting-invoke-with-check) System.IO.FileStream..ctor(string,System.IO.FileMode) at Emby.Server.Implementations.Serialization.MyXmlSerializer.SerializeToFile (System.Object obj, System.String file) [0x0001a] in <3605319732a64e8282cfdf09a091f02e>:0 at Emby.Server.Implementations.Library.UserManager.UpdateUserPolicy (MediaBrowser.Controller.Entities.User user, MediaBrowser.Model.Users.UserPolicy userPolicy, System.Boolean fireEvent) [0x00060] in <3605319732a64e8282cfdf09a091f02e>:0 at Emby.Server.Implementations.Library.UserManager.UpdateUserPolicy (System.Int64 userId, MediaBrowser.Model.Users.UserPolicy userPolicy) [0x00008] in <3605319732a64e8282cfdf09a091f02e>:0 at MediaBrowser.Api.UserService.Post (MediaBrowser.Api.UpdateUserPolicy request) [0x0011b] in <0390257caaf74c7fb5e30cb51d35bfbc>:0 at (wrapper dynamic-method) System.Object.lambda_method(System.Runtime.CompilerServices.Closure,object,object) at Emby.Server.Implementations.Services.ServiceController+<>c__DisplayClass6_0.<VoidActionDelegate>b__0 (System.Object service, System.Object request) [0x00000] in <3605319732a64e8282cfdf09a091f02e>:0 at Emby.Server.Implementations.Services.ServiceController.Execute (Emby.Server.Implementations.HttpServer.HttpListenerHost appHost, System.Object requestDto, MediaBrowser.Model.Services.IRequest req) [0x00073] in <3605319732a64e8282cfdf09a091f02e>:0 at Emby.Server.Implementations.Services.ServiceHandler+<ProcessRequestAsync>d__4.MoveNext () [0x00168] in <3605319732a64e8282cfdf09a091f02e>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0003e] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00028] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00008] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable+ConfiguredTaskAwaiter.GetResult () [0x00000] in <0e06830de9a44394a7e366951eabca52>:0 at Emby.Server.Implementations.HttpServer.HttpListenerHost+<RequestHandler>d__46.MoveNext () [0x00b52] in <3605319732a64e8282cfdf09a091f02e>:0 Source: mscorlib TargetSite: Void Throw() 2020-06-16 19:35:44.490 Info HttpServer: HTTP Response 500 to 192.168.1.2. Time: 3ms. https://192.168.1.29:8920/emby/Users/883af2911301488dadb02054b300057c/Policy 2020-06-16 19:35:59.037 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/System/Logs/embyserver.txt. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 19:35:59.147 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 110ms. https://192.168.1.29:8920/emby/System/Logs/embyserver.txt 2020-06-16 19:35:59.260 Info HttpServer: HTTP GET https://192.168.1.29:8920/favicon.ico. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 19:35:59.262 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 1ms. https://192.168.1.29:8920/favicon.ico 2020-06-16 19:36:03.601 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/System/Configuration. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 19:36:03.603 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 1ms. https://192.168.1.29:8920/emby/System/Configuration 2020-06-16 19:36:03.615 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/System/Logs. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 19:36:03.617 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 2ms. https://192.168.1.29:8920/emby/System/Logs 2020-06-16 19:36:04.354 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/System/Logs/embyserver.txt. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 19:36:04.384 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 30ms. https://192.168.1.29:8920/emby/System/Logs/embyserver.txt 2020-06-16 19:36:22.708 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/System/Logs/embyserver-63727862400.txt. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 19:36:22.792 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 84ms. https://192.168.1.29:8920/emby/System/Logs/embyserver-63727862400.txt 2020-06-16 19:36:57.292 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Users/65d0ee59448b4babb59b4bfba1ad3fcf. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 19:36:57.294 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 2ms. https://192.168.1.29:8920/emby/Users/65d0ee59448b4babb59b4bfba1ad3fcf 2020-06-16 19:36:57.295 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/users. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 19:36:57.296 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 1ms. https://192.168.1.29:8920/emby/users 2020-06-16 19:36:58.993 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/System/Configuration. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 19:36:58.993 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Users/883af2911301488dadb02054b300057c. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 19:36:58.994 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 1ms. https://192.168.1.29:8920/emby/Users/883af2911301488dadb02054b300057c 2020-06-16 19:36:58.996 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 3ms. https://192.168.1.29:8920/emby/System/Configuration 2020-06-16 19:36:59.034 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Auth/Providers. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 19:36:59.034 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Library/MediaFolders?IsHidden=false. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 19:36:59.035 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 1ms. https://192.168.1.29:8920/emby/Auth/Providers 2020-06-16 19:36:59.038 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 4ms. https://192.168.1.29:8920/emby/Library/MediaFolders?IsHidden=false 2020-06-16 19:36:59.046 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Channels?SupportsMediaDeletion=true. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 19:36:59.047 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 1ms. https://192.168.1.29:8920/emby/Channels?SupportsMediaDeletion=true 2020-06-16 19:37:00.058 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Localization/ParentalRatings. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 19:37:00.060 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 2ms. https://192.168.1.29:8920/emby/Localization/ParentalRatings 2020-06-16 19:37:03.238 Info HttpServer: HTTP POST https://192.168.1.29:8920/emby/Users/883af2911301488dadb02054b300057c/Policy. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 19:37:03.239 Debug XmlSerializer: Serializing to file /var/db/emby-server/config/users/883af2911301488dadb02054b300057c/policy.xml 2020-06-16 19:37:03.241 Error HttpServer: Error processing request *** Error Report *** Version: 4.4.2.0 Command line: /usr/local/lib/emby-server/system/EmbyServer.exe -os freebsd -ffdetect /usr/local/lib/emby-server/bin/ffdetect -ffmpeg /usr/local/lib/emby-server/bin/ffmpeg -ffprobe /usr/local/lib/emby-server/bin/ffprobe -programdata /var/db/emby-server -updatepackage emby-server-freebsd12_{version}_amd64.txz Operating system: Unix 11.3.9.0 64-Bit OS: True 64-Bit Process: True User Interactive: False Mono: 5.10.1.57 (5.10.1.57 Thu Apr 9 04:06:41 UTC 2020) Runtime: file:///usr/local/lib/mono/4.5/mscorlib.dll System.Environment.Version: 4.0.30319.42000 Processor count: 4 Program data path: /var/db/emby-server Application directory: /usr/local/lib/emby-server/system System.UnauthorizedAccessException: System.UnauthorizedAccessException: Access to the path "/var/db/emby-server/config/users/883af2911301488dadb02054b300057c/policy.xml" is denied. at System.IO.FileStream..ctor (System.String path, System.IO.FileMode mode, System.IO.FileAccess access, System.IO.FileShare share, System.Int32 bufferSize, System.Boolean anonymous, System.IO.FileOptions options) [0x0019e] in <0e06830de9a44394a7e366951eabca52>:0 at System.IO.FileStream..ctor (System.String path, System.IO.FileMode mode) [0x00000] in <0e06830de9a44394a7e366951eabca52>:0 at (wrapper remoting-invoke-with-check) System.IO.FileStream..ctor(string,System.IO.FileMode) at Emby.Server.Implementations.Serialization.MyXmlSerializer.SerializeToFile (System.Object obj, System.String file) [0x0001a] in <3605319732a64e8282cfdf09a091f02e>:0 at Emby.Server.Implementations.Library.UserManager.UpdateUserPolicy (MediaBrowser.Controller.Entities.User user, MediaBrowser.Model.Users.UserPolicy userPolicy, System.Boolean fireEvent) [0x00060] in <3605319732a64e8282cfdf09a091f02e>:0 at Emby.Server.Implementations.Library.UserManager.UpdateUserPolicy (System.Int64 userId, MediaBrowser.Model.Users.UserPolicy userPolicy) [0x00008] in <3605319732a64e8282cfdf09a091f02e>:0 at MediaBrowser.Api.UserService.Post (MediaBrowser.Api.UpdateUserPolicy request) [0x0011b] in <0390257caaf74c7fb5e30cb51d35bfbc>:0 at (wrapper dynamic-method) System.Object.lambda_method(System.Runtime.CompilerServices.Closure,object,object) at Emby.Server.Implementations.Services.ServiceController+<>c__DisplayClass6_0.<VoidActionDelegate>b__0 (System.Object service, System.Object request) [0x00000] in <3605319732a64e8282cfdf09a091f02e>:0 at Emby.Server.Implementations.Services.ServiceController.Execute (Emby.Server.Implementations.HttpServer.HttpListenerHost appHost, System.Object requestDto, MediaBrowser.Model.Services.IRequest req) [0x00073] in <3605319732a64e8282cfdf09a091f02e>:0 at Emby.Server.Implementations.Services.ServiceHandler+<ProcessRequestAsync>d__4.MoveNext () [0x00168] in <3605319732a64e8282cfdf09a091f02e>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0003e] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00028] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00008] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable+ConfiguredTaskAwaiter.GetResult () [0x00000] in <0e06830de9a44394a7e366951eabca52>:0 at Emby.Server.Implementations.HttpServer.HttpListenerHost+<RequestHandler>d__46.MoveNext () [0x00b52] in <3605319732a64e8282cfdf09a091f02e>:0 Source: mscorlib TargetSite: Void Throw() 2020-06-16 19:37:03.241 Info HttpServer: HTTP Response 500 to 192.168.1.2. Time: 3ms. https://192.168.1.29:8920/emby/Users/883af2911301488dadb02054b300057c/Policy 2020-06-16 19:37:15.259 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Users/883af2911301488dadb02054b300057c. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 19:37:15.260 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 2ms. https://192.168.1.29:8920/emby/Users/883af2911301488dadb02054b300057c 2020-06-16 19:37:15.265 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Channels. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 19:37:15.267 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 1ms. https://192.168.1.29:8920/emby/Channels 2020-06-16 19:37:15.299 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Devices. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 19:37:16.167 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Localization/ParentalRatings. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 19:37:16.168 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 1ms. https://192.168.1.29:8920/emby/Localization/ParentalRatings 2020-06-16 19:37:16.351 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 1052ms. https://192.168.1.29:8920/emby/Devices 2020-06-16 19:37:16.370 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Library/SelectableMediaFolders. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 19:37:16.396 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 26ms. https://192.168.1.29:8920/emby/Library/SelectableMediaFolders 2020-06-16 19:37:21.791 Info HttpServer: HTTP POST https://192.168.1.29:8920/emby/Users/883af2911301488dadb02054b300057c/Policy. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 19:37:21.794 Debug XmlSerializer: Serializing to file /var/db/emby-server/config/users/883af2911301488dadb02054b300057c/policy.xml 2020-06-16 19:37:21.795 Error HttpServer: Error processing request *** Error Report *** Version: 4.4.2.0 Command line: /usr/local/lib/emby-server/system/EmbyServer.exe -os freebsd -ffdetect /usr/local/lib/emby-server/bin/ffdetect -ffmpeg /usr/local/lib/emby-server/bin/ffmpeg -ffprobe /usr/local/lib/emby-server/bin/ffprobe -programdata /var/db/emby-server -updatepackage emby-server-freebsd12_{version}_amd64.txz Operating system: Unix 11.3.9.0 64-Bit OS: True 64-Bit Process: True User Interactive: False Mono: 5.10.1.57 (5.10.1.57 Thu Apr 9 04:06:41 UTC 2020) Runtime: file:///usr/local/lib/mono/4.5/mscorlib.dll System.Environment.Version: 4.0.30319.42000 Processor count: 4 Program data path: /var/db/emby-server Application directory: /usr/local/lib/emby-server/system System.UnauthorizedAccessException: System.UnauthorizedAccessException: Access to the path "/var/db/emby-server/config/users/883af2911301488dadb02054b300057c/policy.xml" is denied. at System.IO.FileStream..ctor (System.String path, System.IO.FileMode mode, System.IO.FileAccess access, System.IO.FileShare share, System.Int32 bufferSize, System.Boolean anonymous, System.IO.FileOptions options) [0x0019e] in <0e06830de9a44394a7e366951eabca52>:0 at System.IO.FileStream..ctor (System.String path, System.IO.FileMode mode) [0x00000] in <0e06830de9a44394a7e366951eabca52>:0 at (wrapper remoting-invoke-with-check) System.IO.FileStream..ctor(string,System.IO.FileMode) at Emby.Server.Implementations.Serialization.MyXmlSerializer.SerializeToFile (System.Object obj, System.String file) [0x0001a] in <3605319732a64e8282cfdf09a091f02e>:0 at Emby.Server.Implementations.Library.UserManager.UpdateUserPolicy (MediaBrowser.Controller.Entities.User user, MediaBrowser.Model.Users.UserPolicy userPolicy, System.Boolean fireEvent) [0x00060] in <3605319732a64e8282cfdf09a091f02e>:0 at Emby.Server.Implementations.Library.UserManager.UpdateUserPolicy (System.Int64 userId, MediaBrowser.Model.Users.UserPolicy userPolicy) [0x00008] in <3605319732a64e8282cfdf09a091f02e>:0 at MediaBrowser.Api.UserService.Post (MediaBrowser.Api.UpdateUserPolicy request) [0x0011b] in <0390257caaf74c7fb5e30cb51d35bfbc>:0 at (wrapper dynamic-method) System.Object.lambda_method(System.Runtime.CompilerServices.Closure,object,object) at Emby.Server.Implementations.Services.ServiceController+<>c__DisplayClass6_0.<VoidActionDelegate>b__0 (System.Object service, System.Object request) [0x00000] in <3605319732a64e8282cfdf09a091f02e>:0 at Emby.Server.Implementations.Services.ServiceController.Execute (Emby.Server.Implementations.HttpServer.HttpListenerHost appHost, System.Object requestDto, MediaBrowser.Model.Services.IRequest req) [0x00073] in <3605319732a64e8282cfdf09a091f02e>:0 at Emby.Server.Implementations.Services.ServiceHandler+<ProcessRequestAsync>d__4.MoveNext () [0x00168] in <3605319732a64e8282cfdf09a091f02e>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0003e] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00028] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00008] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable+ConfiguredTaskAwaiter.GetResult () [0x00000] in <0e06830de9a44394a7e366951eabca52>:0 at Emby.Server.Implementations.HttpServer.HttpListenerHost+<RequestHandler>d__46.MoveNext () [0x00b52] in <3605319732a64e8282cfdf09a091f02e>:0 Source: mscorlib TargetSite: Void Throw() 2020-06-16 19:37:21.796 Info HttpServer: HTTP Response 500 to 192.168.1.2. Time: 5ms. https://192.168.1.29:8920/emby/Users/883af2911301488dadb02054b300057c/Policy 2020-06-16 19:38:33.846 Info HttpServer: HTTP GET https://192.168.1.29:8920/logs. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 19:38:33.846 Info HttpServer: HTTP Response 404 to 192.168.1.2. Time: 1ms. https://192.168.1.29:8920/logs 2020-06-16 19:38:38.267 Info HttpServer: HTTP GET https://192.168.1.29:8920/logs. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 19:38:38.268 Info HttpServer: HTTP Response 404 to 192.168.1.2. Time: 1ms. https://192.168.1.29:8920/logs 2020-06-16 19:38:47.322 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Users/65d0ee59448b4babb59b4bfba1ad3fcf. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 19:38:47.324 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 2ms. https://192.168.1.29:8920/emby/Users/65d0ee59448b4babb59b4bfba1ad3fcf 2020-06-16 19:38:47.331 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/System/Logs. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 19:38:47.331 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/System/Configuration. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 19:38:47.332 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 1ms. https://192.168.1.29:8920/emby/System/Configuration 2020-06-16 19:38:47.333 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 3ms. https://192.168.1.29:8920/emby/System/Logs 2020-06-16 19:38:49.753 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/System/Logs/embyserver.txt. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 19:38:49.770 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 17ms. https://192.168.1.29:8920/emby/System/Logs/embyserver.txt 2020-06-16 19:44:08.624 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Users/65d0ee59448b4babb59b4bfba1ad3fcf. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 19:44:08.650 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 26ms. https://192.168.1.29:8920/emby/Users/65d0ee59448b4babb59b4bfba1ad3fcf 2020-06-16 19:44:09.910 Debug App: SessionInfosWebSocketListener Begin transmitting over websocket to 192.168.1.2 2020-06-16 19:44:09.910 Debug App: ScheduledTasksWebSocketListener Begin transmitting over websocket to 192.168.1.2 2020-06-16 19:44:09.910 Debug App: ActivityLogWebSocketListener Begin transmitting over websocket to 192.168.1.2 2020-06-16 19:44:09.911 Debug App: ActivityLogWebSocketListener Begin transmitting over websocket to 192.168.1.2 2020-06-16 19:44:09.951 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/DisplayPreferences/usersettings?userId=65d0ee59448b4babb59b4bfba1ad3fcf&client=emby. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 19:44:09.952 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 2ms. https://192.168.1.29:8920/emby/DisplayPreferences/usersettings?userId=65d0ee59448b4babb59b4bfba1ad3fcf&client=emby 2020-06-16 19:44:09.954 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/System/ActivityLog/Entries?StartIndex=0&Limit=7&MinDate=2020-06-15T16%3A44%3A09.859Z&hasUserId=true. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 19:44:09.960 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 6ms. https://192.168.1.29:8920/emby/System/ActivityLog/Entries?StartIndex=0&Limit=7&MinDate=2020-06-15T16%3A44%3A09.859Z&hasUserId=true 2020-06-16 19:44:09.964 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/System/ActivityLog/Entries?StartIndex=0&Limit=4&MinDate=2020-06-09T16%3A44%3A09.859Z&hasUserId=false. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 19:44:09.965 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/ScheduledTasks. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 19:44:09.968 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 3ms. https://192.168.1.29:8920/emby/ScheduledTasks 2020-06-16 19:44:09.968 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 4ms. https://192.168.1.29:8920/emby/System/ActivityLog/Entries?StartIndex=0&Limit=4&MinDate=2020-06-09T16%3A44%3A09.859Z&hasUserId=false 2020-06-16 19:44:09.970 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/System/Info. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 19:44:09.970 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/News/Product?StartIndex=0&Limit=4. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 19:44:09.971 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/LiveTv/Recordings?UserId=65d0ee59448b4babb59b4bfba1ad3fcf&IsInProgress=true&Fields=CanDelete%2CPrimaryImageAspectRatio&EnableTotalRecordCount=false&EnableImageTypes=Primary%2CThumb%2CBackdrop. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 19:44:09.971 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 1ms. https://192.168.1.29:8920/emby/System/Info 2020-06-16 19:44:09.972 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 1ms. https://192.168.1.29:8920/emby/LiveTv/Recordings?UserId=65d0ee59448b4babb59b4bfba1ad3fcf&IsInProgress=true&Fields=CanDelete%2CPrimaryImageAspectRatio&EnableTotalRecordCount=false&EnableImageTypes=Primary%2CThumb%2CBackdrop 2020-06-16 19:44:10.016 Info HttpServer: HTTP POST https://192.168.1.29:8920/emby/Users/65d0ee59448b4babb59b4bfba1ad3fcf/Configuration. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 19:44:10.019 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Packages/Updates?PackageType=System. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 19:44:10.022 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 52ms. https://192.168.1.29:8920/emby/News/Product?StartIndex=0&Limit=4 2020-06-16 19:44:10.048 Debug XmlSerializer: Serializing to file /var/db/emby-server/config/users/65d0ee59448b4babb59b4bfba1ad3fcf/config.xml 2020-06-16 19:44:10.050 Error HttpServer: Error processing request *** Error Report *** Version: 4.4.2.0 Command line: /usr/local/lib/emby-server/system/EmbyServer.exe -os freebsd -ffdetect /usr/local/lib/emby-server/bin/ffdetect -ffmpeg /usr/local/lib/emby-server/bin/ffmpeg -ffprobe /usr/local/lib/emby-server/bin/ffprobe -programdata /var/db/emby-server -updatepackage emby-server-freebsd12_{version}_amd64.txz Operating system: Unix 11.3.9.0 64-Bit OS: True 64-Bit Process: True User Interactive: False Mono: 5.10.1.57 (5.10.1.57 Thu Apr 9 04:06:41 UTC 2020) Runtime: file:///usr/local/lib/mono/4.5/mscorlib.dll System.Environment.Version: 4.0.30319.42000 Processor count: 4 Program data path: /var/db/emby-server Application directory: /usr/local/lib/emby-server/system System.UnauthorizedAccessException: System.UnauthorizedAccessException: Access to the path "/var/db/emby-server/config/users/65d0ee59448b4babb59b4bfba1ad3fcf/config.xml" is denied. at System.IO.FileStream..ctor (System.String path, System.IO.FileMode mode, System.IO.FileAccess access, System.IO.FileShare share, System.Int32 bufferSize, System.Boolean anonymous, System.IO.FileOptions options) [0x0019e] in <0e06830de9a44394a7e366951eabca52>:0 at System.IO.FileStream..ctor (System.String path, System.IO.FileMode mode) [0x00000] in <0e06830de9a44394a7e366951eabca52>:0 at (wrapper remoting-invoke-with-check) System.IO.FileStream..ctor(string,System.IO.FileMode) at Emby.Server.Implementations.Serialization.MyXmlSerializer.SerializeToFile (System.Object obj, System.String file) [0x0001a] in <3605319732a64e8282cfdf09a091f02e>:0 at Emby.Server.Implementations.Library.UserManager.UpdateConfiguration (MediaBrowser.Controller.Entities.User user, MediaBrowser.Model.Configuration.UserConfiguration config, System.Boolean fireEvent) [0x00060] in <3605319732a64e8282cfdf09a091f02e>:0 at Emby.Server.Implementations.Library.UserManager.UpdateConfiguration (MediaBrowser.Controller.Entities.User user, MediaBrowser.Model.Configuration.UserConfiguration config) [0x00000] in <3605319732a64e8282cfdf09a091f02e>:0 at Emby.Server.Implementations.Library.UserManager.UpdateConfiguration (System.Int64 userId, MediaBrowser.Model.Configuration.UserConfiguration config) [0x00008] in <3605319732a64e8282cfdf09a091f02e>:0 at MediaBrowser.Api.UserService.Post (MediaBrowser.Api.UpdateUserConfiguration request) [0x0003d] in <0390257caaf74c7fb5e30cb51d35bfbc>:0 at (wrapper dynamic-method) System.Object.lambda_method(System.Runtime.CompilerServices.Closure,object,object) at Emby.Server.Implementations.Services.ServiceController+<>c__DisplayClass6_0.<VoidActionDelegate>b__0 (System.Object service, System.Object request) [0x00000] in <3605319732a64e8282cfdf09a091f02e>:0 at Emby.Server.Implementations.Services.ServiceController.Execute (Emby.Server.Implementations.HttpServer.HttpListenerHost appHost, System.Object requestDto, MediaBrowser.Model.Services.IRequest req) [0x00073] in <3605319732a64e8282cfdf09a091f02e>:0 at Emby.Server.Implementations.Services.ServiceHandler+<ProcessRequestAsync>d__4.MoveNext () [0x00168] in <3605319732a64e8282cfdf09a091f02e>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0003e] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00028] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00008] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable+ConfiguredTaskAwaiter.GetResult () [0x00000] in <0e06830de9a44394a7e366951eabca52>:0 at Emby.Server.Implementations.HttpServer.HttpListenerHost+<RequestHandler>d__46.MoveNext () [0x00b52] in <3605319732a64e8282cfdf09a091f02e>:0 Source: mscorlib TargetSite: Void Throw() 2020-06-16 19:44:10.050 Info HttpServer: HTTP Response 500 to 192.168.1.2. Time: 35ms. https://192.168.1.29:8920/emby/Users/65d0ee59448b4babb59b4bfba1ad3fcf/Configuration 2020-06-16 19:44:10.264 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 245ms. https://192.168.1.29:8920/emby/Packages/Updates?PackageType=System 2020-06-16 19:44:10.553 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Sessions?ActiveWithinSeconds=900. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 19:44:10.554 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 1ms. https://192.168.1.29:8920/emby/Sessions?ActiveWithinSeconds=900 2020-06-16 19:44:11.162 Debug SessionManager: Removing active session Firefox TW96aWxsYS81LjAgKFdpbmRvd3MgTlQgMTAuMDsgV2luNjQ7IHg2NDsgcnY6NjUuMCkgR2Vja28vMjAxMDAxMDEgRmlyZWZveC82NS4wfDE1NDkwNTAyMzUyOTE1 2020-06-16 19:44:11.163 Debug SessionManager: Disposing session controller WebSocketController 2020-06-16 20:36:35.803 Info HttpServer: HTTP GET https://192.168.1.29:8920/. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 20:36:35.803 Info HttpServer: HTTP Response 302 to 192.168.1.2. Time: 0ms. https://192.168.1.29:8920/ 2020-06-16 20:36:36.140 Info HttpServer: HTTP GET https://192.168.1.29:8920/web/modules/themes/logowhite.png. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 20:36:36.168 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 27ms. https://192.168.1.29:8920/web/modules/themes/logowhite.png 2020-06-16 20:36:36.419 Info HttpServer: HTTP GET https://192.168.1.29:8920/web/strings/he.json?v=1592328996353. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 20:36:36.419 Info HttpServer: HTTP GET https://192.168.1.29:8920/web/bower_components/emby-webcomponents/strings/he.json?v=1592328996353. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 20:36:36.444 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 25ms. https://192.168.1.29:8920/web/strings/he.json?v=1592328996353 2020-06-16 20:36:36.464 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 45ms. https://192.168.1.29:8920/web/bower_components/emby-webcomponents/strings/he.json?v=1592328996353 2020-06-16 20:36:36.977 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/system/info/public. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 20:36:36.978 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 1ms. https://192.168.1.29:8920/emby/system/info/public 2020-06-16 20:36:36.995 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/System/Info. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 20:36:37.056 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 61ms. https://192.168.1.29:8920/emby/System/Info 2020-06-16 20:36:37.070 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/DisplayPreferences/usersettings?userId=65d0ee59448b4babb59b4bfba1ad3fcf&client=emby. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 20:36:37.071 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 1ms. https://192.168.1.29:8920/emby/DisplayPreferences/usersettings?userId=65d0ee59448b4babb59b4bfba1ad3fcf&client=emby 2020-06-16 20:36:37.076 Info HttpServer: WS https://192.168.1.29:8920/embywebsocket?api_key=1733ef2d1e0a4ffb856b3ddbbec9dcee&deviceId=TW96aWxsYS81LjAgKFdpbmRvd3MgTlQgMTAuMDsgV2luNjQ7IHg2NDsgcnY6NjUuMCkgR2Vja28vMjAxMDAxMDEgRmlyZWZveC82NS4wfDE1NDkwNTAyMzUyOTE1. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 20:36:37.077 Debug SessionManager: Creating new WebSocketController 2020-06-16 20:36:37.155 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Users/65d0ee59448b4babb59b4bfba1ad3fcf. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 20:36:37.156 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 1ms. https://192.168.1.29:8920/emby/Users/65d0ee59448b4babb59b4bfba1ad3fcf 2020-06-16 20:36:37.235 Info HttpServer: HTTP GET https://192.168.1.29:8920/web/modules/themes/dark/theme.json?v=4.4.2.0&r=0. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 20:36:37.236 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 1ms. https://192.168.1.29:8920/web/modules/themes/dark/theme.json?v=4.4.2.0&r=0 2020-06-16 20:36:37.242 Error HttpServer: Error processing request *** Error Report *** Version: 4.4.2.0 Command line: /usr/local/lib/emby-server/system/EmbyServer.exe -os freebsd -ffdetect /usr/local/lib/emby-server/bin/ffdetect -ffmpeg /usr/local/lib/emby-server/bin/ffmpeg -ffprobe /usr/local/lib/emby-server/bin/ffprobe -programdata /var/db/emby-server -updatepackage emby-server-freebsd12_{version}_amd64.txz Operating system: Unix 11.3.9.0 64-Bit OS: True 64-Bit Process: True User Interactive: False Mono: 5.10.1.57 (5.10.1.57 Thu Apr 9 04:06:41 UTC 2020) Runtime: file:///usr/local/lib/mono/4.5/mscorlib.dll System.Environment.Version: 4.0.30319.42000 Processor count: 4 Program data path: /var/db/emby-server Application directory: /usr/local/lib/emby-server/system System.Security.Authentication.AuthenticationException: System.Security.Authentication.AuthenticationException: A call to SSPI failed, see inner exception. ---> System.Net.Sockets.SocketException: The socket has been shut down at System.Net.Sockets.Socket.EndSend (System.IAsyncResult asyncResult) [0x00012] in <b3922b7d60404fa9ae645f1fb97f5b6b>:0 at SocketHttpListener.SocketStream.EndWrite (System.IAsyncResult asyncResult) [0x00000] in <5fc69e0598a34841a210f67306929617>:0 at System.IO.Stream+<>c.<BeginEndWriteAsync>b__53_1 (System.IO.Stream stream, System.IAsyncResult asyncResult) [0x00000] in <0e06830de9a44394a7e366951eabca52>:0 at (wrapper delegate-invoke) System.Func`3[System.IO.Stream,System.IAsyncResult,System.Threading.Tasks.VoidTaskResult].invoke_TResult_T1_T2(System.IO.Stream,System.IAsyncResult) at System.Threading.Tasks.TaskFactory`1+FromAsyncTrimPromise`1[TResult,TInstance].Complete (TInstance thisRef, System.Func`3[T1,T2,TResult] endMethod, System.IAsyncResult asyncResult, System.Boolean requiresSynchronization) [0x00000] in <0e06830de9a44394a7e366951eabca52>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0003e] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00028] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00008] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable+ConfiguredTaskAwaiter.GetResult () [0x00000] in <0e06830de9a44394a7e366951eabca52>:0 at Mono.Net.Security.MobileAuthenticatedStream+<InnerWrite>d__67.MoveNext () [0x000d3] in <b3922b7d60404fa9ae645f1fb97f5b6b>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0003e] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00028] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00008] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable+ConfiguredTaskAwaiter.GetResult () [0x00000] in <0e06830de9a44394a7e366951eabca52>:0 at Mono.Net.Security.AsyncProtocolRequest+<ProcessOperation>d__24.MoveNext () [0x00196] in <b3922b7d60404fa9ae645f1fb97f5b6b>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0003e] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00028] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00008] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable+ConfiguredTaskAwaiter.GetResult () [0x00000] in <0e06830de9a44394a7e366951eabca52>:0 at Mono.Net.Security.AsyncProtocolRequest+<StartOperation>d__23.MoveNext () [0x0008b] in <b3922b7d60404fa9ae645f1fb97f5b6b>:0 --- End of inner exception stack trace --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <0e06830de9a44394a7e366951eabca52>:0 at Mono.Net.Security.MobileAuthenticatedStream+<StartOperation>d__58.MoveNext () [0x001bf] in <b3922b7d60404fa9ae645f1fb97f5b6b>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0003e] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00028] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00008] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.GetResult () [0x00000] in <0e06830de9a44394a7e366951eabca52>:0 at System.Threading.Tasks.TaskToApm.End (System.IAsyncResult asyncResult) [0x00029] in <0e06830de9a44394a7e366951eabca52>:0 at Mono.Net.Security.MobileAuthenticatedStream.EndWrite (System.IAsyncResult asyncResult) [0x00000] in <b3922b7d60404fa9ae645f1fb97f5b6b>:0 at System.Net.Security.SslStream.EndWrite (System.IAsyncResult asyncResult) [0x00006] in <b3922b7d60404fa9ae645f1fb97f5b6b>:0 at SocketHttpListener.Net.HttpResponseStream.EndWriteCore (System.IAsyncResult asyncResult) [0x00041] in <5fc69e0598a34841a210f67306929617>:0 at SocketHttpListener.Net.HttpResponseStream.EndWrite (System.IAsyncResult asyncResult) [0x0000e] in <5fc69e0598a34841a210f67306929617>:0 at System.IO.Stream+<>c.<BeginEndWriteAsync>b__53_1 (System.IO.Stream stream, System.IAsyncResult asyncResult) [0x00000] in <0e06830de9a44394a7e366951eabca52>:0 at (wrapper delegate-invoke) System.Func`3[System.IO.Stream,System.IAsyncResult,System.Threading.Tasks.VoidTaskResult].invoke_TResult_T1_T2(System.IO.Stream,System.IAsyncResult) at System.Threading.Tasks.TaskFactory`1+FromAsyncTrimPromise`1[TResult,TInstance].Complete (TInstance thisRef, System.Func`3[T1,T2,TResult] endMethod, System.IAsyncResult asyncResult, System.Boolean requiresSynchronization) [0x00000] in <0e06830de9a44394a7e366951eabca52>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0003e] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00028] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00008] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable+ConfiguredTaskAwaiter.GetResult () [0x00000] in <0e06830de9a44394a7e366951eabca52>:0 at System.IO.Stream+<CopyToAsyncInternal>d__27.MoveNext () [0x000a0] in <0e06830de9a44394a7e366951eabca52>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0003e] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00028] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00008] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable+ConfiguredTaskAwaiter.GetResult () [0x00000] in <0e06830de9a44394a7e366951eabca52>:0 at Emby.Server.Implementations.HttpServer.FileWriter+<WriteToAsync>d__43.MoveNext () [0x004af] in <3605319732a64e8282cfdf09a091f02e>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0003e] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00028] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00008] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable+ConfiguredTaskAwaiter.GetResult () [0x00000] in <0e06830de9a44394a7e366951eabca52>:0 at Emby.Server.Implementations.Services.ServiceHandler+<ProcessRequestAsync>d__4.MoveNext () [0x0026a] in <3605319732a64e8282cfdf09a091f02e>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0003e] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00028] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00008] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable+ConfiguredTaskAwaiter.GetResult () [0x00000] in <0e06830de9a44394a7e366951eabca52>:0 at Emby.Server.Implementations.HttpServer.HttpListenerHost+<RequestHandler>d__46.MoveNext () [0x00b52] in <3605319732a64e8282cfdf09a091f02e>:0 Source: mscorlib TargetSite: Void Throw() InnerException: System.Net.Sockets.SocketException: The socket has been shut down Source: mscorlib TargetSite: Void Throw() at System.Net.Sockets.Socket.EndSend (System.IAsyncResult asyncResult) [0x00012] in <b3922b7d60404fa9ae645f1fb97f5b6b>:0 at SocketHttpListener.SocketStream.EndWrite (System.IAsyncResult asyncResult) [0x00000] in <5fc69e0598a34841a210f67306929617>:0 at System.IO.Stream+<>c.<BeginEndWriteAsync>b__53_1 (System.IO.Stream stream, System.IAsyncResult asyncResult) [0x00000] in <0e06830de9a44394a7e366951eabca52>:0 at (wrapper delegate-invoke) System.Func`3[System.IO.Stream,System.IAsyncResult,System.Threading.Tasks.VoidTaskResult].invoke_TResult_T1_T2(System.IO.Stream,System.IAsyncResult) at System.Threading.Tasks.TaskFactory`1+FromAsyncTrimPromise`1[TResult,TInstance].Complete (TInstance thisRef, System.Func`3[T1,T2,TResult] endMethod, System.IAsyncResult asyncResult, System.Boolean requiresSynchronization) [0x00000] in <0e06830de9a44394a7e366951eabca52>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0003e] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00028] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00008] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable+ConfiguredTaskAwaiter.GetResult () [0x00000] in <0e06830de9a44394a7e366951eabca52>:0 at Mono.Net.Security.MobileAuthenticatedStream+<InnerWrite>d__67.MoveNext () [0x000d3] in <b3922b7d60404fa9ae645f1fb97f5b6b>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0003e] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00028] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00008] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable+ConfiguredTaskAwaiter.GetResult () [0x00000] in <0e06830de9a44394a7e366951eabca52>:0 at Mono.Net.Security.AsyncProtocolRequest+<ProcessOperation>d__24.MoveNext () [0x00196] in <b3922b7d60404fa9ae645f1fb97f5b6b>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0003e] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00028] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00008] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable+ConfiguredTaskAwaiter.GetResult () [0x00000] in <0e06830de9a44394a7e366951eabca52>:0 at Mono.Net.Security.AsyncProtocolRequest+<StartOperation>d__23.MoveNext () [0x0008b] in <b3922b7d60404fa9ae645f1fb97f5b6b>:0 2020-06-16 20:36:37.252 Info HttpServer: HTTP POST https://192.168.1.29:8920/emby/Sessions/Capabilities/Full. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 20:36:37.290 Info HttpServer: HTTP Response 204 to 192.168.1.2. Time: 38ms. https://192.168.1.29:8920/emby/Sessions/Capabilities/Full 2020-06-16 20:36:37.299 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Users/65d0ee59448b4babb59b4bfba1ad3fcf/Views. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 20:36:37.301 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 2ms. https://192.168.1.29:8920/emby/Users/65d0ee59448b4babb59b4bfba1ad3fcf/Views 2020-06-16 20:36:37.357 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Users/65d0ee59448b4babb59b4bfba1ad3fcf/Items/Resume?Limit=12&Recursive=true&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo%2CProductionYear&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&EnableTotalRecordCount=false&MediaTypes=Video. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 20:36:37.359 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Users/65d0ee59448b4babb59b4bfba1ad3fcf/Items/Resume?Limit=12&Recursive=true&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo%2CProductionYear&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&EnableTotalRecordCount=false&MediaTypes=Audio. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 20:36:37.360 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 3ms. https://192.168.1.29:8920/emby/Users/65d0ee59448b4babb59b4bfba1ad3fcf/Items/Resume?Limit=12&Recursive=true&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo%2CProductionYear&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&EnableTotalRecordCount=false&MediaTypes=Video 2020-06-16 20:36:37.361 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 2ms. https://192.168.1.29:8920/emby/Users/65d0ee59448b4babb59b4bfba1ad3fcf/Items/Resume?Limit=12&Recursive=true&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo%2CProductionYear&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&EnableTotalRecordCount=false&MediaTypes=Audio 2020-06-16 20:36:37.403 Error HttpServer: Error in ProcessAccept *** Error Report *** Version: 4.4.2.0 Command line: /usr/local/lib/emby-server/system/EmbyServer.exe -os freebsd -ffdetect /usr/local/lib/emby-server/bin/ffdetect -ffmpeg /usr/local/lib/emby-server/bin/ffmpeg -ffprobe /usr/local/lib/emby-server/bin/ffprobe -programdata /var/db/emby-server -updatepackage emby-server-freebsd12_{version}_amd64.txz Operating system: Unix 11.3.9.0 64-Bit OS: True 64-Bit Process: True User Interactive: False Mono: 5.10.1.57 (5.10.1.57 Thu Apr 9 04:06:41 UTC 2020) Runtime: file:///usr/local/lib/mono/4.5/mscorlib.dll System.Environment.Version: 4.0.30319.42000 Processor count: 4 Program data path: /var/db/emby-server Application directory: /usr/local/lib/emby-server/system System.IO.IOException: System.IO.IOException: Remote prematurely closed connection. at Mono.Net.Security.AsyncProtocolRequest+<ProcessOperation>d__24.MoveNext () [0x000e7] in <b3922b7d60404fa9ae645f1fb97f5b6b>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0003e] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00028] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00008] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable+ConfiguredTaskAwaiter.GetResult () [0x00000] in <0e06830de9a44394a7e366951eabca52>:0 at Mono.Net.Security.AsyncProtocolRequest+<StartOperation>d__23.MoveNext () [0x0008b] in <b3922b7d60404fa9ae645f1fb97f5b6b>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <0e06830de9a44394a7e366951eabca52>:0 at Mono.Net.Security.MobileAuthenticatedStream+<ProcessAuthentication>d__47.MoveNext () [0x00254] in <b3922b7d60404fa9ae645f1fb97f5b6b>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0003e] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00028] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00008] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable+ConfiguredTaskAwaiter.GetResult () [0x00000] in <0e06830de9a44394a7e366951eabca52>:0 at SocketHttpListener.Net.HttpConnection+<Init>d__26.MoveNext () [0x000a5] in <5fc69e0598a34841a210f67306929617>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0003e] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00028] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00008] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable+ConfiguredTaskAwaiter.GetResult () [0x00000] in <0e06830de9a44394a7e366951eabca52>:0 at SocketHttpListener.Net.HttpEndPointListener+<ProcessAccept>d__21.MoveNext () [0x0015d] in <5fc69e0598a34841a210f67306929617>:0 Source: mscorlib TargetSite: Void Throw() 2020-06-16 20:36:37.881 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Users/65d0ee59448b4babb59b4bfba1ad3fcf/Items/dfc3a7d9ae799d21d9beeb549a68b511. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 20:36:37.884 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 3ms. https://192.168.1.29:8920/emby/Users/65d0ee59448b4babb59b4bfba1ad3fcf/Items/dfc3a7d9ae799d21d9beeb549a68b511 2020-06-16 20:36:37.938 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Users/65d0ee59448b4babb59b4bfba1ad3fcf/Items?SortBy=SortName&SortOrder=Ascending&IncludeItemTypes=Series&Recursive=true&Fields=BasicSyncInfo%2CMediaSourceCount%2CPrimaryImageAspectRatio&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&StartIndex=0&Limit=50&ParentId=dfc3a7d9ae799d21d9beeb549a68b511. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 20:36:38.093 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 154ms. https://192.168.1.29:8920/emby/Users/65d0ee59448b4babb59b4bfba1ad3fcf/Items?SortBy=SortName&SortOrder=Ascending&IncludeItemTypes=Series&Recursive=true&Fields=BasicSyncInfo%2CMediaSourceCount%2CPrimaryImageAspectRatio&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&StartIndex=0&Limit=50&ParentId=dfc3a7d9ae799d21d9beeb549a68b511 2020-06-16 20:36:38.157 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Items/11085/Images/Primary?maxHeight=280&maxWidth=187&tag=1a1ee9063756ca2f7bbc4d0873decb62&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 20:36:38.160 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Items/8883/Images/Primary?maxHeight=275&maxWidth=187&tag=cf66e42cd4e3f40ac33b46d546ce0fcc&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 20:36:38.174 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Items/8618/Images/Primary?maxHeight=280&maxWidth=187&tag=724a95d1e0c149a240762f41fbac552a&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 20:36:38.175 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Items/10789/Images/Primary?maxHeight=280&maxWidth=187&tag=849d29f263bcbdbb1d07e59c3f6c2d3c&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 20:36:38.175 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Items/8844/Images/Primary?maxHeight=179&maxWidth=187&tag=ca89d1f2ca198aac7ad9648f6115dd8b&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 20:36:38.177 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Items/7190/Images/Primary?maxHeight=280&maxWidth=187&tag=0029f17a6dbdb01ee4d7f6b830fb83ac&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 20:36:38.273 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 99ms. https://192.168.1.29:8920/emby/Items/8618/Images/Primary?maxHeight=280&maxWidth=187&tag=724a95d1e0c149a240762f41fbac552a&quality=90 2020-06-16 20:36:38.274 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Items/7041/Images/Primary?maxHeight=280&maxWidth=187&tag=0175e381f4740628a4b21167ad9a8506&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 20:36:38.288 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 129ms. https://192.168.1.29:8920/emby/Items/8883/Images/Primary?maxHeight=275&maxWidth=187&tag=cf66e42cd4e3f40ac33b46d546ce0fcc&quality=90 2020-06-16 20:36:38.289 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Items/10853/Images/Primary?maxHeight=280&maxWidth=187&tag=027c9b85165ef749294faa5795e6a678&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 20:36:38.303 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 128ms. https://192.168.1.29:8920/emby/Items/10789/Images/Primary?maxHeight=280&maxWidth=187&tag=849d29f263bcbdbb1d07e59c3f6c2d3c&quality=90 2020-06-16 20:36:38.304 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Items/6194/Images/Primary?maxHeight=280&maxWidth=187&tag=5c019901804e0380171c4fa16b9d09e4&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 20:36:38.345 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 169ms. https://192.168.1.29:8920/emby/Items/8844/Images/Primary?maxHeight=179&maxWidth=187&tag=ca89d1f2ca198aac7ad9648f6115dd8b&quality=90 2020-06-16 20:36:38.345 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 169ms. https://192.168.1.29:8920/emby/Items/7190/Images/Primary?maxHeight=280&maxWidth=187&tag=0029f17a6dbdb01ee4d7f6b830fb83ac&quality=90 2020-06-16 20:36:38.346 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Items/5493/Images/Primary?maxHeight=280&maxWidth=187&tag=194a0656dab712d0bc59a3a228da2e53&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 20:36:38.348 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Items/3862/Images/Primary?maxHeight=280&maxWidth=187&tag=4a05fb7fcfc284492e86b05167b769b2&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 20:36:38.373 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 216ms. https://192.168.1.29:8920/emby/Items/11085/Images/Primary?maxHeight=280&maxWidth=187&tag=1a1ee9063756ca2f7bbc4d0873decb62&quality=90 2020-06-16 20:36:38.374 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Items/4203/Images/Primary?maxHeight=280&maxWidth=187&tag=15f770f22c22748fd3e7695be556485e&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 20:36:38.399 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 50ms. https://192.168.1.29:8920/emby/Items/3862/Images/Primary?maxHeight=280&maxWidth=187&tag=4a05fb7fcfc284492e86b05167b769b2&quality=90 2020-06-16 20:36:38.400 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Items/10499/Images/Primary?maxHeight=280&maxWidth=187&tag=a906777657098f14b910a9b77817f1e1&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 20:36:38.405 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 131ms. https://192.168.1.29:8920/emby/Items/7041/Images/Primary?maxHeight=280&maxWidth=187&tag=0175e381f4740628a4b21167ad9a8506&quality=90 2020-06-16 20:36:38.406 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Items/9441/Images/Primary?maxHeight=280&maxWidth=187&tag=65947bf9389eccad0df5d1145db64edf&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 20:36:38.435 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 132ms. https://192.168.1.29:8920/emby/Items/6194/Images/Primary?maxHeight=280&maxWidth=187&tag=5c019901804e0380171c4fa16b9d09e4&quality=90 2020-06-16 20:36:38.435 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 30ms. https://192.168.1.29:8920/emby/Items/9441/Images/Primary?maxHeight=280&maxWidth=187&tag=65947bf9389eccad0df5d1145db64edf&quality=90 2020-06-16 20:36:38.436 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Items/11035/Images/Primary?maxHeight=280&maxWidth=187&tag=75c6facedfe5b2204f2baf1b14dfd0a3&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 20:36:38.436 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Items/7486/Images/Primary?maxHeight=280&maxWidth=187&tag=a246d9da511dd069826be898d69bbe75&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 20:36:38.445 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 156ms. https://192.168.1.29:8920/emby/Items/10853/Images/Primary?maxHeight=280&maxWidth=187&tag=027c9b85165ef749294faa5795e6a678&quality=90 2020-06-16 20:36:38.447 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Items/9557/Images/Primary?maxHeight=280&maxWidth=187&tag=d5c21d0f3045eb825b3772101cc3cd89&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 20:36:38.461 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 87ms. https://192.168.1.29:8920/emby/Items/4203/Images/Primary?maxHeight=280&maxWidth=187&tag=15f770f22c22748fd3e7695be556485e&quality=90 2020-06-16 20:36:38.461 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 114ms. https://192.168.1.29:8920/emby/Items/5493/Images/Primary?maxHeight=280&maxWidth=187&tag=194a0656dab712d0bc59a3a228da2e53&quality=90 2020-06-16 20:36:38.463 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Items/7575/Images/Primary?maxHeight=280&maxWidth=187&tag=b2206a5eb4a09282718b562aa3233ca9&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 20:36:38.463 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Items/6873/Images/Primary?maxHeight=280&maxWidth=187&tag=884f4549051fd1a4aa2504e2c2796654&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 20:36:38.464 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 17ms. https://192.168.1.29:8920/emby/Items/9557/Images/Primary?maxHeight=280&maxWidth=187&tag=d5c21d0f3045eb825b3772101cc3cd89&quality=90 2020-06-16 20:36:38.466 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Items/8619/Images/Primary?maxHeight=280&maxWidth=187&tag=64536dfb7ec11d3ab412a9a7b030de9d&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 20:36:38.481 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 45ms. https://192.168.1.29:8920/emby/Items/11035/Images/Primary?maxHeight=280&maxWidth=187&tag=75c6facedfe5b2204f2baf1b14dfd0a3&quality=90 2020-06-16 20:36:38.482 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Items/4528/Images/Primary?maxHeight=280&maxWidth=187&tag=87f540a3cf35db7666c78ec4a57be53b&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 20:36:38.493 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 57ms. https://192.168.1.29:8920/emby/Items/7486/Images/Primary?maxHeight=280&maxWidth=187&tag=a246d9da511dd069826be898d69bbe75&quality=90 2020-06-16 20:36:38.494 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Items/5152/Images/Primary?maxHeight=280&maxWidth=187&tag=886c21241fa2e9c5ed765f442adeb2a2&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 20:36:38.513 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 50ms. https://192.168.1.29:8920/emby/Items/7575/Images/Primary?maxHeight=280&maxWidth=187&tag=b2206a5eb4a09282718b562aa3233ca9&quality=90 2020-06-16 20:36:38.513 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 47ms. https://192.168.1.29:8920/emby/Items/8619/Images/Primary?maxHeight=280&maxWidth=187&tag=64536dfb7ec11d3ab412a9a7b030de9d&quality=90 2020-06-16 20:36:38.513 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 19ms. https://192.168.1.29:8920/emby/Items/5152/Images/Primary?maxHeight=280&maxWidth=187&tag=886c21241fa2e9c5ed765f442adeb2a2&quality=90 2020-06-16 20:36:38.514 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Items/3861/Images/Primary?maxHeight=280&maxWidth=187&tag=5a6b5abb7e4a95be2fa6d49172365dd8&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 20:36:38.515 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Items/5467/Images/Primary?maxHeight=280&maxWidth=187&tag=79a02dc93b93bca2870a96f1cb9c52f6&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 20:36:38.516 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 2ms. https://192.168.1.29:8920/emby/Items/3861/Images/Primary?maxHeight=280&maxWidth=187&tag=5a6b5abb7e4a95be2fa6d49172365dd8&quality=90 2020-06-16 20:36:38.533 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 70ms. https://192.168.1.29:8920/emby/Items/6873/Images/Primary?maxHeight=280&maxWidth=187&tag=884f4549051fd1a4aa2504e2c2796654&quality=90 2020-06-16 20:36:38.545 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 63ms. https://192.168.1.29:8920/emby/Items/4528/Images/Primary?maxHeight=280&maxWidth=187&tag=87f540a3cf35db7666c78ec4a57be53b&quality=90 2020-06-16 20:36:38.553 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 38ms. https://192.168.1.29:8920/emby/Items/5467/Images/Primary?maxHeight=280&maxWidth=187&tag=79a02dc93b93bca2870a96f1cb9c52f6&quality=90 2020-06-16 20:36:38.587 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 187ms. https://192.168.1.29:8920/emby/Items/10499/Images/Primary?maxHeight=280&maxWidth=187&tag=a906777657098f14b910a9b77817f1e1&quality=90 2020-06-16 20:36:39.525 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Users/65d0ee59448b4babb59b4bfba1ad3fcf/Items/14265640a7420b35d3beaf575a4fbe20. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 20:36:39.527 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 2ms. https://192.168.1.29:8920/emby/Users/65d0ee59448b4babb59b4bfba1ad3fcf/Items/14265640a7420b35d3beaf575a4fbe20 2020-06-16 20:36:39.544 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Users/65d0ee59448b4babb59b4bfba1ad3fcf/Items?SortBy=SortName&SortOrder=Ascending&IncludeItemTypes=Movie&Recursive=true&Fields=BasicSyncInfo%2CMediaSourceCount%2CPrimaryImageAspectRatio%2CProductionYear&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&StartIndex=0&Limit=50&ParentId=14265640a7420b35d3beaf575a4fbe20. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 20:36:39.627 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 83ms. https://192.168.1.29:8920/emby/Users/65d0ee59448b4babb59b4bfba1ad3fcf/Items?SortBy=SortName&SortOrder=Ascending&IncludeItemTypes=Movie&Recursive=true&Fields=BasicSyncInfo%2CMediaSourceCount%2CPrimaryImageAspectRatio%2CProductionYear&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&StartIndex=0&Limit=50&ParentId=14265640a7420b35d3beaf575a4fbe20 2020-06-16 20:36:39.671 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Items/9261/Images/Primary?maxHeight=280&maxWidth=187&tag=8666787aed7fb262e306044b860aa306&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 20:36:39.673 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Items/6660/Images/Primary?maxHeight=280&maxWidth=187&tag=9cd3b2ed66525fab6fa1876d5eb00d1a&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 20:36:39.674 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Items/6661/Images/Primary?maxHeight=280&maxWidth=187&tag=5bafa96c0216dbef4c7f431862cfa1f0&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 20:36:39.677 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Items/6854/Images/Primary?maxHeight=280&maxWidth=187&tag=0f729b5f3b6177d5d57e5741cc6ded03&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 20:36:39.679 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Items/2567/Images/Primary?maxHeight=280&maxWidth=187&tag=c74c5c3611a0bafeb79fc22295873da0&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 20:36:39.685 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Items/2566/Images/Primary?maxHeight=280&maxWidth=187&tag=bbcf35cc97fa88f3dbd6a55dda15dacb&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 20:36:39.712 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 26ms. https://192.168.1.29:8920/emby/Items/2566/Images/Primary?maxHeight=280&maxWidth=187&tag=bbcf35cc97fa88f3dbd6a55dda15dacb&quality=90 2020-06-16 20:36:39.714 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Items/4311/Images/Primary?maxHeight=280&maxWidth=187&tag=d51cb3ff49d400590fdb1d29d131cf5a&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 20:36:39.717 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 38ms. https://192.168.1.29:8920/emby/Items/2567/Images/Primary?maxHeight=280&maxWidth=187&tag=c74c5c3611a0bafeb79fc22295873da0&quality=90 2020-06-16 20:36:39.720 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Items/5017/Images/Primary?maxHeight=280&maxWidth=187&tag=e8f5e115c5143b3ba566b356f6c0195e&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 20:36:39.729 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 52ms. https://192.168.1.29:8920/emby/Items/6854/Images/Primary?maxHeight=280&maxWidth=187&tag=0f729b5f3b6177d5d57e5741cc6ded03&quality=90 2020-06-16 20:36:39.729 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 55ms. https://192.168.1.29:8920/emby/Items/6661/Images/Primary?maxHeight=280&maxWidth=187&tag=5bafa96c0216dbef4c7f431862cfa1f0&quality=90 2020-06-16 20:36:39.731 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Items/10708/Images/Primary?maxHeight=280&maxWidth=187&tag=8bb84608804aa2019cda54d55f9f6393&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 20:36:39.732 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Items/2406/Images/Primary?maxHeight=280&maxWidth=187&tag=a7fd1e0044fd86a02d2a48ba880292ba&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 20:36:39.733 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 61ms. https://192.168.1.29:8920/emby/Items/6660/Images/Primary?maxHeight=280&maxWidth=187&tag=9cd3b2ed66525fab6fa1876d5eb00d1a&quality=90 2020-06-16 20:36:39.735 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Items/10751/Images/Primary?maxHeight=280&maxWidth=187&tag=7940568cc1229ecb40643a82f1b505e0&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 20:36:39.749 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 79ms. https://192.168.1.29:8920/emby/Items/9261/Images/Primary?maxHeight=280&maxWidth=187&tag=8666787aed7fb262e306044b860aa306&quality=90 2020-06-16 20:36:39.750 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Items/2402/Images/Primary?maxHeight=280&maxWidth=187&tag=f8fa0b1a68ec4d33a950b1b737895180&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 20:36:39.796 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 83ms. https://192.168.1.29:8920/emby/Items/4311/Images/Primary?maxHeight=280&maxWidth=187&tag=d51cb3ff49d400590fdb1d29d131cf5a&quality=90 2020-06-16 20:36:39.797 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 65ms. https://192.168.1.29:8920/emby/Items/2406/Images/Primary?maxHeight=280&maxWidth=187&tag=a7fd1e0044fd86a02d2a48ba880292ba&quality=90 2020-06-16 20:36:39.798 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Items/10142/Images/Primary?maxHeight=280&maxWidth=187&tag=20fda195d37c8962ae217a67b8510f35&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 20:36:39.798 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Items/9269/Images/Primary?maxHeight=280&maxWidth=187&tag=6cfdc783777369aa6b5ee6103daeda12&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 20:36:39.815 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 17ms. https://192.168.1.29:8920/emby/Items/10142/Images/Primary?maxHeight=280&maxWidth=187&tag=20fda195d37c8962ae217a67b8510f35&quality=90 2020-06-16 20:36:39.815 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 65ms. https://192.168.1.29:8920/emby/Items/2402/Images/Primary?maxHeight=280&maxWidth=187&tag=f8fa0b1a68ec4d33a950b1b737895180&quality=90 2020-06-16 20:36:39.817 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Items/6810/Images/Primary?maxHeight=280&maxWidth=187&tag=77354b889ccb920f29e1232a0a1b54e5&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 20:36:39.817 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Items/2405/Images/Primary?maxHeight=280&maxWidth=187&tag=f25b22e4e5a09958b82c6d17a7838364&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 20:36:39.882 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 65ms. https://192.168.1.29:8920/emby/Items/6810/Images/Primary?maxHeight=280&maxWidth=187&tag=77354b889ccb920f29e1232a0a1b54e5&quality=90 2020-06-16 20:36:39.882 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 152ms. https://192.168.1.29:8920/emby/Items/10708/Images/Primary?maxHeight=280&maxWidth=187&tag=8bb84608804aa2019cda54d55f9f6393&quality=90 2020-06-16 20:36:39.882 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 163ms. https://192.168.1.29:8920/emby/Items/5017/Images/Primary?maxHeight=280&maxWidth=187&tag=e8f5e115c5143b3ba566b356f6c0195e&quality=90 2020-06-16 20:36:39.882 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 148ms. https://192.168.1.29:8920/emby/Items/10751/Images/Primary?maxHeight=280&maxWidth=187&tag=7940568cc1229ecb40643a82f1b505e0&quality=90 2020-06-16 20:36:39.882 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 66ms. https://192.168.1.29:8920/emby/Items/2405/Images/Primary?maxHeight=280&maxWidth=187&tag=f25b22e4e5a09958b82c6d17a7838364&quality=90 2020-06-16 20:36:39.883 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Items/2426/Images/Primary?maxHeight=280&maxWidth=187&tag=4172a86df6b027f95507ce0688cb7dbb&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 20:36:39.883 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Items/9536/Images/Primary?maxHeight=280&maxWidth=187&tag=c53dcdd623e6022292d7ca511ca7ba78&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 20:36:39.883 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Items/2403/Images/Primary?maxHeight=280&maxWidth=187&tag=c6ec4dedca9c3ed82f0ab5732213628a&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 20:36:39.884 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Items/5018/Images/Primary?maxHeight=280&maxWidth=187&tag=058ab7bf96b570f65521732619408e6e&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 20:36:39.884 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Items/5637/Images/Primary?maxHeight=280&maxWidth=187&tag=cde13270c10b5cea7bba3a21fedc366e&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 20:36:39.897 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 99ms. https://192.168.1.29:8920/emby/Items/9269/Images/Primary?maxHeight=280&maxWidth=187&tag=6cfdc783777369aa6b5ee6103daeda12&quality=90 2020-06-16 20:36:39.899 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Items/2951/Images/Primary?maxHeight=280&maxWidth=187&tag=1b62e187f356f5568c30bc5ef38385d0&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 20:36:39.902 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 18ms. https://192.168.1.29:8920/emby/Items/5018/Images/Primary?maxHeight=280&maxWidth=187&tag=058ab7bf96b570f65521732619408e6e&quality=90 2020-06-16 20:36:39.903 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Items/2952/Images/Primary?maxHeight=280&maxWidth=187&tag=0baee20271a73aab994fdbdbcc2bdcc3&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 20:36:39.954 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 71ms. https://192.168.1.29:8920/emby/Items/9536/Images/Primary?maxHeight=280&maxWidth=187&tag=c53dcdd623e6022292d7ca511ca7ba78&quality=90 2020-06-16 20:36:39.954 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 71ms. https://192.168.1.29:8920/emby/Items/2426/Images/Primary?maxHeight=280&maxWidth=187&tag=4172a86df6b027f95507ce0688cb7dbb&quality=90 2020-06-16 20:36:39.955 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 70ms. https://192.168.1.29:8920/emby/Items/5637/Images/Primary?maxHeight=280&maxWidth=187&tag=cde13270c10b5cea7bba3a21fedc366e&quality=90 2020-06-16 20:36:39.955 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 55ms. https://192.168.1.29:8920/emby/Items/2951/Images/Primary?maxHeight=280&maxWidth=187&tag=1b62e187f356f5568c30bc5ef38385d0&quality=90 2020-06-16 20:36:39.955 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 71ms. https://192.168.1.29:8920/emby/Items/2403/Images/Primary?maxHeight=280&maxWidth=187&tag=c6ec4dedca9c3ed82f0ab5732213628a&quality=90 2020-06-16 20:36:39.955 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Items/2615/Images/Primary?maxHeight=280&maxWidth=187&tag=820734ddf16e2d2f1b628f00f636598b&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 20:36:39.956 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Items/Prefixes?IncludeItemTypes=Movie&Recursive=true&ParentId=14265640a7420b35d3beaf575a4fbe20&userId=65d0ee59448b4babb59b4bfba1ad3fcf. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 20:36:39.974 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 18ms. https://192.168.1.29:8920/emby/Items/Prefixes?IncludeItemTypes=Movie&Recursive=true&ParentId=14265640a7420b35d3beaf575a4fbe20&userId=65d0ee59448b4babb59b4bfba1ad3fcf 2020-06-16 20:36:39.975 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 71ms. https://192.168.1.29:8920/emby/Items/2952/Images/Primary?maxHeight=280&maxWidth=187&tag=0baee20271a73aab994fdbdbcc2bdcc3&quality=90 2020-06-16 20:36:40.003 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 47ms. https://192.168.1.29:8920/emby/Items/2615/Images/Primary?maxHeight=280&maxWidth=187&tag=820734ddf16e2d2f1b628f00f636598b&quality=90 2020-06-16 20:36:40.574 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Items/6170/Images/Primary?maxHeight=280&maxWidth=187&tag=2ac497b080b210fc08097b953ae35f4b&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 20:36:40.576 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Items/2431/Images/Primary?maxHeight=280&maxWidth=187&tag=5d28fbd7aba84448f8f7b86cf016160f&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 20:36:40.578 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Items/2432/Images/Primary?maxHeight=280&maxWidth=187&tag=abecf7b953d6b138a210e304ddf759f2&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 20:36:40.580 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Items/9265/Images/Primary?maxHeight=280&maxWidth=187&tag=7c72d42441e15601ae70b0c5b304e75c&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 20:36:40.582 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Items/9266/Images/Primary?maxHeight=280&maxWidth=187&tag=eb5ed53059ceebe72b6c685df4a7eb39&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 20:36:40.586 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Items/9267/Images/Primary?maxHeight=280&maxWidth=187&tag=4075103ba89a8f6298c0da59dca1e709&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 20:36:40.632 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 56ms. https://192.168.1.29:8920/emby/Items/2431/Images/Primary?maxHeight=280&maxWidth=187&tag=5d28fbd7aba84448f8f7b86cf016160f&quality=90 2020-06-16 20:36:40.633 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Items/11261/Images/Primary?maxHeight=280&maxWidth=187&tag=a906f810aee7c2b5790ee2c10e503ca1&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 20:36:40.642 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 60ms. https://192.168.1.29:8920/emby/Items/9266/Images/Primary?maxHeight=280&maxWidth=187&tag=eb5ed53059ceebe72b6c685df4a7eb39&quality=90 2020-06-16 20:36:40.642 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 62ms. https://192.168.1.29:8920/emby/Items/9265/Images/Primary?maxHeight=280&maxWidth=187&tag=7c72d42441e15601ae70b0c5b304e75c&quality=90 2020-06-16 20:36:40.643 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Items/2436/Images/Primary?maxHeight=280&maxWidth=187&tag=4e520b9e42c4bf17f70003ca8351c83a&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 20:36:40.648 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 63ms. https://192.168.1.29:8920/emby/Items/9267/Images/Primary?maxHeight=280&maxWidth=187&tag=4075103ba89a8f6298c0da59dca1e709&quality=90 2020-06-16 20:36:40.648 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 75ms. https://192.168.1.29:8920/emby/Items/6170/Images/Primary?maxHeight=280&maxWidth=187&tag=2ac497b080b210fc08097b953ae35f4b&quality=90 2020-06-16 20:36:40.658 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 24ms. https://192.168.1.29:8920/emby/Items/11261/Images/Primary?maxHeight=280&maxWidth=187&tag=a906f810aee7c2b5790ee2c10e503ca1&quality=90 2020-06-16 20:36:40.658 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 80ms. https://192.168.1.29:8920/emby/Items/2432/Images/Primary?maxHeight=280&maxWidth=187&tag=abecf7b953d6b138a210e304ddf759f2&quality=90 2020-06-16 20:36:40.784 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 141ms. https://192.168.1.29:8920/emby/Items/2436/Images/Primary?maxHeight=280&maxWidth=187&tag=4e520b9e42c4bf17f70003ca8351c83a&quality=90 2020-06-16 20:36:41.495 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Items/3232/Images/Primary?maxHeight=280&maxWidth=187&tag=ba99d085583f2564bdcb7adec2ce218c&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 20:36:41.496 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Items/3234/Images/Primary?maxHeight=280&maxWidth=187&tag=880cf6bb2006d98d8faa25adbacd3964&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 20:36:41.498 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Items/6502/Images/Primary?maxHeight=280&maxWidth=187&tag=c23ec342425c47454806ab090922910b&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 20:36:41.511 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Items/3233/Images/Primary?maxHeight=280&maxWidth=187&tag=e31af103d2cb890747d12ec1295a75ef&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 20:36:41.514 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Items/6543/Images/Primary?maxHeight=280&maxWidth=187&tag=4ced5ec5da61efc1f746012491acd6a5&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 20:36:41.514 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Items/4958/Images/Primary?maxHeight=280&maxWidth=187&tag=b1927bc785fec15c385e0b4d78abde81&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 20:36:41.539 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 25ms. https://192.168.1.29:8920/emby/Items/4958/Images/Primary?maxHeight=280&maxWidth=187&tag=b1927bc785fec15c385e0b4d78abde81&quality=90 2020-06-16 20:36:41.540 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Items/2394/Images/Primary?maxHeight=280&maxWidth=187&tag=dbe9815f429f2813864f9543112ab124&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 20:36:41.604 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 109ms. https://192.168.1.29:8920/emby/Items/3232/Images/Primary?maxHeight=280&maxWidth=187&tag=ba99d085583f2564bdcb7adec2ce218c&quality=90 2020-06-16 20:36:41.605 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Items/2413/Images/Primary?maxHeight=280&maxWidth=187&tag=973f2d1964df7aea769afd9aebe08f24&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 20:36:41.616 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 120ms. https://192.168.1.29:8920/emby/Items/3234/Images/Primary?maxHeight=280&maxWidth=187&tag=880cf6bb2006d98d8faa25adbacd3964&quality=90 2020-06-16 20:36:41.616 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 76ms. https://192.168.1.29:8920/emby/Items/2394/Images/Primary?maxHeight=280&maxWidth=187&tag=dbe9815f429f2813864f9543112ab124&quality=90 2020-06-16 20:36:41.616 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 102ms. https://192.168.1.29:8920/emby/Items/6543/Images/Primary?maxHeight=280&maxWidth=187&tag=4ced5ec5da61efc1f746012491acd6a5&quality=90 2020-06-16 20:36:41.634 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 135ms. https://192.168.1.29:8920/emby/Items/6502/Images/Primary?maxHeight=280&maxWidth=187&tag=c23ec342425c47454806ab090922910b&quality=90 2020-06-16 20:36:41.634 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 123ms. https://192.168.1.29:8920/emby/Items/3233/Images/Primary?maxHeight=280&maxWidth=187&tag=e31af103d2cb890747d12ec1295a75ef&quality=90 2020-06-16 20:36:41.664 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 59ms. https://192.168.1.29:8920/emby/Items/2413/Images/Primary?maxHeight=280&maxWidth=187&tag=973f2d1964df7aea769afd9aebe08f24&quality=90 2020-06-16 20:36:47.040 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Users/65d0ee59448b4babb59b4bfba1ad3fcf/Items?SortBy=PremiereDate%2CProductionYear%2CSortName&SortOrder=Descending&IncludeItemTypes=Movie&Recursive=true&Fields=BasicSyncInfo%2CMediaSourceCount%2CPrimaryImageAspectRatio%2CProductionYear&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&StartIndex=0&Limit=50&ParentId=14265640a7420b35d3beaf575a4fbe20. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 20:36:47.068 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 28ms. https://192.168.1.29:8920/emby/Users/65d0ee59448b4babb59b4bfba1ad3fcf/Items?SortBy=PremiereDate%2CProductionYear%2CSortName&SortOrder=Descending&IncludeItemTypes=Movie&Recursive=true&Fields=BasicSyncInfo%2CMediaSourceCount%2CPrimaryImageAspectRatio%2CProductionYear&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&StartIndex=0&Limit=50&ParentId=14265640a7420b35d3beaf575a4fbe20 2020-06-16 20:36:47.087 Info HttpServer: HTTP POST https://192.168.1.29:8920/emby/DisplayPreferences/usersettings?userId=65d0ee59448b4babb59b4bfba1ad3fcf&client=emby. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 20:36:47.104 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Items/10408/Images/Primary?maxHeight=280&maxWidth=187&tag=144305d4e3802c635f1b5260677a848f&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 20:36:47.104 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Items/10709/Images/Primary?maxHeight=280&maxWidth=187&tag=7e0037dce6d7a00518fa31c3b32d5e65&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 20:36:47.105 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Items/9492/Images/Primary?maxHeight=280&maxWidth=187&tag=a5a785f5733c273e130ff9d329756729&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 20:36:47.116 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Items/7507/Images/Primary?maxHeight=280&maxWidth=187&tag=0ffd5f6f13081b1b1540c309db98dbfa&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 20:36:47.117 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Items/7096/Images/Primary?maxHeight=280&maxWidth=187&tag=c4184c50f4fec5ed480b1059e7a895f3&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 20:36:47.128 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 24ms. https://192.168.1.29:8920/emby/Items/10408/Images/Primary?maxHeight=280&maxWidth=187&tag=144305d4e3802c635f1b5260677a848f&quality=90 2020-06-16 20:36:47.128 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 12ms. https://192.168.1.29:8920/emby/Items/7507/Images/Primary?maxHeight=280&maxWidth=187&tag=0ffd5f6f13081b1b1540c309db98dbfa&quality=90 2020-06-16 20:36:47.129 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Items/7473/Images/Primary?maxHeight=280&maxWidth=187&tag=f4ee34d557c683a4f1e3e376d8f495a8&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 20:36:47.130 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Items/11260/Images/Primary?maxHeight=280&maxWidth=187&tag=0339437b01cbed01f9db5cd2ccb0fda9&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 20:36:47.140 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 23ms. https://192.168.1.29:8920/emby/Items/7096/Images/Primary?maxHeight=280&maxWidth=187&tag=c4184c50f4fec5ed480b1059e7a895f3&quality=90 2020-06-16 20:36:47.141 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Items/7508/Images/Primary?maxHeight=280&maxWidth=187&tag=f42046ee2a1e59432420a6554d91b942&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 20:36:47.163 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 34ms. https://192.168.1.29:8920/emby/Items/7473/Images/Primary?maxHeight=280&maxWidth=187&tag=f4ee34d557c683a4f1e3e376d8f495a8&quality=90 2020-06-16 20:36:47.163 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 21ms. https://192.168.1.29:8920/emby/Items/7508/Images/Primary?maxHeight=280&maxWidth=187&tag=f42046ee2a1e59432420a6554d91b942&quality=90 2020-06-16 20:36:47.164 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Items/6574/Images/Primary?maxHeight=280&maxWidth=187&tag=36f31a72cb86f5b5a38f3b6da8561f38&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 20:36:47.164 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Items/5107/Images/Primary?maxHeight=280&maxWidth=187&tag=0d2f859a09f83503f17b588fe4f37a88&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 20:36:47.164 Info HttpServer: HTTP Response 204 to 192.168.1.2. Time: 78ms. https://192.168.1.29:8920/emby/DisplayPreferences/usersettings?userId=65d0ee59448b4babb59b4bfba1ad3fcf&client=emby 2020-06-16 20:36:47.165 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Items/5016/Images/Primary?maxHeight=280&maxWidth=187&tag=4e70e2f5e6980cb49159703835125783&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 20:36:47.175 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 71ms. https://192.168.1.29:8920/emby/Items/10709/Images/Primary?maxHeight=280&maxWidth=187&tag=7e0037dce6d7a00518fa31c3b32d5e65&quality=90 2020-06-16 20:36:47.176 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 10ms. https://192.168.1.29:8920/emby/Items/5016/Images/Primary?maxHeight=280&maxWidth=187&tag=4e70e2f5e6980cb49159703835125783&quality=90 2020-06-16 20:36:47.187 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 57ms. https://192.168.1.29:8920/emby/Items/11260/Images/Primary?maxHeight=280&maxWidth=187&tag=0339437b01cbed01f9db5cd2ccb0fda9&quality=90 2020-06-16 20:36:47.187 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 24ms. https://192.168.1.29:8920/emby/Items/6574/Images/Primary?maxHeight=280&maxWidth=187&tag=36f31a72cb86f5b5a38f3b6da8561f38&quality=90 2020-06-16 20:36:47.189 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 84ms. https://192.168.1.29:8920/emby/Items/9492/Images/Primary?maxHeight=280&maxWidth=187&tag=a5a785f5733c273e130ff9d329756729&quality=90 2020-06-16 20:36:47.194 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 31ms. https://192.168.1.29:8920/emby/Items/5107/Images/Primary?maxHeight=280&maxWidth=187&tag=0d2f859a09f83503f17b588fe4f37a88&quality=90 2020-06-16 20:36:49.469 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Users/65d0ee59448b4babb59b4bfba1ad3fcf/Items/10751. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 20:36:49.472 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Items/10751/ThemeMedia?UserId=65d0ee59448b4babb59b4bfba1ad3fcf&InheritFromParent=true&EnableThemeSongs=false&EnableThemeVideos=true. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 20:36:49.550 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 81ms. https://192.168.1.29:8920/emby/Users/65d0ee59448b4babb59b4bfba1ad3fcf/Items/10751 2020-06-16 20:36:49.565 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 93ms. https://192.168.1.29:8920/emby/Items/10751/ThemeMedia?UserId=65d0ee59448b4babb59b4bfba1ad3fcf&InheritFromParent=true&EnableThemeSongs=false&EnableThemeVideos=true 2020-06-16 20:36:49.581 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Items/10751/Images/Backdrop/0?tag=4c65f4805863d65c2b3d23af05332531&maxWidth=1600&quality=70. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 20:36:49.587 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Items/10751/Images/Logo?maxWidth=300&tag=68e017f07c605b9116c18690712b9add&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 20:36:49.639 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/System/Endpoint. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 20:36:49.640 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 1ms. https://192.168.1.29:8920/emby/System/Endpoint 2020-06-16 20:36:49.640 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Users/65d0ee59448b4babb59b4bfba1ad3fcf/Items/10751/SpecialFeatures. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 20:36:49.640 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Users/65d0ee59448b4babb59b4bfba1ad3fcf/Items?fields=PrimaryImageAspectRatio%2CUserData%2CCanDelete&EnableTotalRecordCount=false&IncludeItemTypes=Playlist%2CBoxSet&Recursive=true&SortBy=SortName&ListItemIds=10751. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 20:36:49.679 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Items/10751/Images/Primary?maxHeight=1200&maxWidth=800&tag=7940568cc1229ecb40643a82f1b505e0&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 20:36:49.679 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Items/10751/Similar?Limit=12&UserId=65d0ee59448b4babb59b4bfba1ad3fcf&ImageTypeLimit=1&Fields=PrimaryImageAspectRatio%2CUserData%2CCanDelete%2CProductionYear&EnableTotalRecordCount=false. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 20:36:49.679 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 39ms. https://192.168.1.29:8920/emby/Users/65d0ee59448b4babb59b4bfba1ad3fcf/Items/10751/SpecialFeatures 2020-06-16 20:36:49.711 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 71ms. https://192.168.1.29:8920/emby/Users/65d0ee59448b4babb59b4bfba1ad3fcf/Items?fields=PrimaryImageAspectRatio%2CUserData%2CCanDelete&EnableTotalRecordCount=false&IncludeItemTypes=Playlist%2CBoxSet&Recursive=true&SortBy=SortName&ListItemIds=10751 2020-06-16 20:36:49.712 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Items/10751/Similar?userId=65d0ee59448b4babb59b4bfba1ad3fcf&limit=12&fields=PrimaryImageAspectRatio%2CUserData%2CCanDelete%2CProductionYear&IncludeItemTypes=Program&EnableTotalRecordCount=false. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 20:36:49.717 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 6ms. https://192.168.1.29:8920/emby/Items/10751/Similar?userId=65d0ee59448b4babb59b4bfba1ad3fcf&limit=12&fields=PrimaryImageAspectRatio%2CUserData%2CCanDelete%2CProductionYear&IncludeItemTypes=Program&EnableTotalRecordCount=false 2020-06-16 20:36:49.718 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 39ms. https://192.168.1.29:8920/emby/Items/10751/Similar?Limit=12&UserId=65d0ee59448b4babb59b4bfba1ad3fcf&ImageTypeLimit=1&Fields=PrimaryImageAspectRatio%2CUserData%2CCanDelete%2CProductionYear&EnableTotalRecordCount=false 2020-06-16 20:36:49.729 Info HttpServer: HTTP POST https://192.168.1.29:8920/emby/Items/10751/PlaybackInfo?UserId=65d0ee59448b4babb59b4bfba1ad3fcf&StartTimeTicks=0&IsPlayback=false&AutoOpenLiveStream=false&MaxStreamingBitrate=60000000. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 20:36:49.731 Debug MediaInfoService: GetPostedPlaybackInfo request: {"Id":"10751","UserId":"65d0ee59448b4babb59b4bfba1ad3fcf","MaxStreamingBitrate":60000000,"StartTimeTicks":0,"DeviceProfile":{"EnableAlbumArtInDidl":false,"EnableSingleAlbumArtLimit":false,"EnableSingleSubtitleLimit":false,"SupportedMediaTypes":"Audio,Photo,Video","MaxAlbumArtWidth":0,"MaxAlbumArtHeight":0,"MaxStreamingBitrate":140000000,"MusicStreamingTranscodingBitrate":192000,"TimelineOffsetSeconds":0,"RequiresPlainVideoItems":false,"RequiresPlainFolders":false,"IgnoreTranscodeByteRangeRequests":false,"XmlRootAttributes":[],"DirectPlayProfiles":[{"Container":"mp4,m4v","AudioCodec":"aac,opus,flac,vorbis","VideoCodec":"h264,vp8,vp9","Type":"Video"},{"Container":"flv","AudioCodec":"aac,mp3","VideoCodec":"h264","Type":"Video"},{"Container":"mov","AudioCodec":"aac,opus,flac,vorbis","VideoCodec":"h264","Type":"Video"},{"Container":"opus","Type":"Audio"},{"Container":"mp3","AudioCodec":"mp3","Type":"Audio"},{"Container":"mp2,mp3","AudioCodec":"mp2","Type":"Audio"},{"Container":"m4a","AudioCodec":"aac","Type":"Audio"},{"Container":"flac","Type":"Audio"},{"Container":"alac","Type":"Audio"},{"Container":"m4a","AudioCodec":"alac","Type":"Audio"},{"Container":"webma,webm","Type":"Audio"},{"Container":"wav","AudioCodec":"PCM_S16LE","Type":"Audio"},{"Container":"ogg","Type":"Audio"},{"Container":"webm","AudioCodec":"vorbis,opus","VideoCodec":"VP8","Type":"Video"},{"Container":"webm","AudioCodec":"vorbis,opus","VideoCodec":"VP9","Type":"Video"}],"TranscodingProfiles":[{"Container":"aac","Type":"Audio","AudioCodec":"aac","Protocol":"hls","EstimateContentLength":false,"EnableMpegtsM2TsMode":false,"TranscodeSeekInfo":"Auto","CopyTimestamps":false,"Context":"Streaming","MaxAudioChannels":"2","MinSegments":1,"SegmentLength":0,"BreakOnNonKeyFrames":true},{"Container":"aac","Type":"Audio","AudioCodec":"aac","Protocol":"http","EstimateContentLength":false,"EnableMpegtsM2TsMode":false,"TranscodeSeekInfo":"Auto","CopyTimestamps":false,"Context":"Streaming","MaxAudioChannels":"2","MinSegments":0,"SegmentLength":0,"BreakOnNonKeyFrames":false},{"Container":"mp3","Type":"Audio","AudioCodec":"mp3","Protocol":"http","EstimateContentLength":false,"EnableMpegtsM2TsMode":false,"TranscodeSeekInfo":"Auto","CopyTimestamps":false,"Context":"Streaming","MaxAudioChannels":"2","MinSegments":0,"SegmentLength":0,"BreakOnNonKeyFrames":false},{"Container":"opus","Type":"Audio","AudioCodec":"opus","Protocol":"http","EstimateContentLength":false,"EnableMpegtsM2TsMode":false,"TranscodeSeekInfo":"Auto","CopyTimestamps":false,"Context":"Streaming","MaxAudioChannels":"2","MinSegments":0,"SegmentLength":0,"BreakOnNonKeyFrames":false},{"Container":"wav","Type":"Audio","AudioCodec":"wav","Protocol":"http","EstimateContentLength":false,"EnableMpegtsM2TsMode":false,"TranscodeSeekInfo":"Auto","CopyTimestamps":false,"Context":"Streaming","MaxAudioChannels":"2","MinSegments":0,"SegmentLength":0,"BreakOnNonKeyFrames":false},{"Container":"opus","Type":"Audio","AudioCodec":"opus","Protocol":"http","EstimateContentLength":false,"EnableMpegtsM2TsMode":false,"TranscodeSeekInfo":"Auto","CopyTimestamps":false,"Context":"Static","MaxAudioChannels":"2","MinSegments":0,"SegmentLength":0,"BreakOnNonKeyFrames":false},{"Container":"mp3","Type":"Audio","AudioCodec":"mp3","Protocol":"http","EstimateContentLength":false,"EnableMpegtsM2TsMode":false,"TranscodeSeekInfo":"Auto","CopyTimestamps":false,"Context":"Static","MaxAudioChannels":"2","MinSegments":0,"SegmentLength":0,"BreakOnNonKeyFrames":false},{"Container":"aac","Type":"Audio","AudioCodec":"aac","Protocol":"http","EstimateContentLength":false,"EnableMpegtsM2TsMode":false,"TranscodeSeekInfo":"Auto","CopyTimestamps":false,"Context":"Static","MaxAudioChannels":"2","MinSegments":0,"SegmentLength":0,"BreakOnNonKeyFrames":false},{"Container":"wav","Type":"Audio","AudioCodec":"wav","Protocol":"http","EstimateContentLength":false,"EnableMpegtsM2TsMode":false,"TranscodeSeekInfo":"Auto","CopyTimestamps":false,"Context":"Static","MaxAudioChannels":"2","MinSegments":0,"SegmentLength":0,"BreakOnNonKeyFrames":false},{"Container":"ts","Type":"Video","VideoCodec":"h264","AudioCodec":"aac","Protocol":"hls","EstimateContentLength":false,"EnableMpegtsM2TsMode":false,"TranscodeSeekInfo":"Auto","CopyTimestamps":false,"Context":"Streaming","MaxAudioChannels":"2","MinSegments":1,"SegmentLength":0,"BreakOnNonKeyFrames":true,"ManifestSubtitles":"vtt"},{"Container":"webm","Type":"Video","VideoCodec":"vpx","AudioCodec":"vorbis","Protocol":"http","EstimateContentLength":false,"EnableMpegtsM2TsMode":false,"TranscodeSeekInfo":"Auto","CopyTimestamps":false,"Context":"Streaming","MaxAudioChannels":"2","MinSegments":0,"SegmentLength":0,"BreakOnNonKeyFrames":false},{"Container":"mp4","Type":"Video","VideoCodec":"h264","AudioCodec":"aac,opus,flac,vorbis","Protocol":"http","EstimateContentLength":false,"EnableMpegtsM2TsMode":false,"TranscodeSeekInfo":"Auto","CopyTimestamps":false,"Context":"Static","MinSegments":0,"SegmentLength":0,"BreakOnNonKeyFrames":false}],"ContainerProfiles":[],"CodecProfiles":[{"Type":"VideoAudio","Conditions":[{"Condition":"Equals","Property":"IsSecondaryAudio","Value":"false","IsRequired":false}],"ApplyConditions":[],"Codec":"aac"},{"Type":"VideoAudio","Conditions":[{"Condition":"Equals","Property":"IsSecondaryAudio","Value":"false","IsRequired":false}],"ApplyConditions":[]},{"Type":"Video","Conditions":[{"Condition":"EqualsAny","Property":"VideoProfile","Value":"high|main|baseline|constrained baseline","IsRequired":false},{"Condition":"LessThanEqual","Property":"VideoLevel","Value":"52","IsRequired":false}],"ApplyConditions":[],"Codec":"h264"}],"ResponseProfiles":[{"Container":"m4v","Type":"Video","MimeType":"video/mp4","Conditions":[]}],"SubtitleProfiles":[{"Format":"vtt","Method":"Hls"},{"Format":"vtt","Method":"External"},{"Format":"ass","Method":"External"},{"Format":"ssa","Method":"External"}]},"EnableDirectPlay":true,"EnableDirectStream":true,"EnableTranscoding":true,"AllowVideoStreamCopy":true,"AllowAudioStreamCopy":true,"IsPlayback":false,"AutoOpenLiveStream":false,"DirectPlayProtocols":["Http"]} 2020-06-16 20:36:49.733 Info MediaInfoService: User policy for MYserverName. EnablePlaybackRemuxing: True EnableVideoPlaybackTranscoding: True EnableAudioPlaybackTranscoding: True 2020-06-16 20:36:49.735 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 6ms. https://192.168.1.29:8920/emby/Items/10751/PlaybackInfo?UserId=65d0ee59448b4babb59b4bfba1ad3fcf&StartTimeTicks=0&IsPlayback=false&AutoOpenLiveStream=false&MaxStreamingBitrate=60000000 2020-06-16 20:36:49.765 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Items/409/Images/Primary?maxWidth=187&tag=138c35d135f43181f4813562d99996c1&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 20:36:49.767 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Items/7509/Images/Primary?maxWidth=187&tag=caf9edd918c81733130cc756759b4998&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 20:36:49.769 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Items/10752/Images/Primary?maxWidth=187&tag=82021b14d43190b42339fb220dd8b833&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 20:36:49.954 Debug ImageProcessor: Image encoding took 184ms for /var/db/emby-server/metadata/library/94/94d2129d67af4592b5e4a045a39e8f51/folder.jpg 2020-06-16 20:36:49.956 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 187ms. https://192.168.1.29:8920/emby/Items/10752/Images/Primary?maxWidth=187&tag=82021b14d43190b42339fb220dd8b833&quality=90 2020-06-16 20:36:49.958 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Items/10753/Images/Primary?maxWidth=187&tag=dc1979477a400e472dfa8cf1388e6729&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 20:36:50.029 Debug ImageProcessor: Image encoding took 442ms for /var/db/emby-server/metadata/library/9a/9ae5b665d27e646d5b4bb6612193de20/logo.png 2020-06-16 20:36:50.030 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 444ms. https://192.168.1.29:8920/emby/Items/10751/Images/Logo?maxWidth=300&tag=68e017f07c605b9116c18690712b9add&quality=90 2020-06-16 20:36:50.032 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Items/5441/Images/Primary?maxWidth=187&tag=c00d5b6ebcb0505586f0344b1abbe22a&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 20:36:50.073 Debug ImageProcessor: Image encoding took 305ms for /var/db/emby-server/metadata/library/b9/b9714dbdbbc6456783ec079293d8f478/folder.jpg 2020-06-16 20:36:50.074 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 307ms. https://192.168.1.29:8920/emby/Items/7509/Images/Primary?maxWidth=187&tag=caf9edd918c81733130cc756759b4998&quality=90 2020-06-16 20:36:50.077 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Items/10754/Images/Primary?maxWidth=187&tag=df53efcf2cee680af6c90163982027f8&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 20:36:50.146 Debug ImageProcessor: Image encoding took 380ms for /var/db/emby-server/metadata/People/V/Vin Diesel/poster.jpg 2020-06-16 20:36:50.149 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 384ms. https://192.168.1.29:8920/emby/Items/409/Images/Primary?maxWidth=187&tag=138c35d135f43181f4813562d99996c1&quality=90 2020-06-16 20:36:50.173 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Items/10755/Images/Primary?maxWidth=187&tag=83a2c77c5a1a8150519da17ff9bc1565&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 20:36:50.207 Debug ImageProcessor: Image encoding took 129ms for /var/db/emby-server/metadata/library/c5/c5f5ba3d110141dfa03087853b1e7a36/folder.jpg 2020-06-16 20:36:50.209 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 133ms. https://192.168.1.29:8920/emby/Items/10754/Images/Primary?maxWidth=187&tag=df53efcf2cee680af6c90163982027f8&quality=90 2020-06-16 20:36:50.216 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Items/10756/Images/Primary?maxWidth=187&tag=4914aede7183f8b6d881a7dab0b88362&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 20:36:50.226 Debug ImageProcessor: Image encoding took 193ms for /var/db/emby-server/metadata/library/c3/c36083fa00644991b390eec4369e577f/folder.jpg 2020-06-16 20:36:50.227 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 195ms. https://192.168.1.29:8920/emby/Items/5441/Images/Primary?maxWidth=187&tag=c00d5b6ebcb0505586f0344b1abbe22a&quality=90 2020-06-16 20:36:50.228 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Items/41/Images/Primary?maxWidth=187&tag=0bb9c810f4ee104c07c55ea58c20bf5e&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 20:36:50.229 Debug ImageProcessor: Image encoding took 517ms for /var/db/emby-server/metadata/library/9a/9ae5b665d27e646d5b4bb6612193de20/poster.jpg 2020-06-16 20:36:50.236 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 557ms. https://192.168.1.29:8920/emby/Items/10751/Images/Primary?maxHeight=1200&maxWidth=800&tag=7940568cc1229ecb40643a82f1b505e0&quality=90 2020-06-16 20:36:50.265 Debug ImageProcessor: Image encoding took 91ms for /var/db/emby-server/metadata/library/8f/8fd66e6be76f41ad896ed77f9ff8c8d9/folder.jpg 2020-06-16 20:36:50.266 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 94ms. https://192.168.1.29:8920/emby/Items/10755/Images/Primary?maxWidth=187&tag=83a2c77c5a1a8150519da17ff9bc1565&quality=90 2020-06-16 20:36:50.354 Debug ImageProcessor: Image encoding took 136ms for /var/db/emby-server/metadata/library/1d/1dbc50c5605f4e02a17ba3ac341ff5e6/folder.jpg 2020-06-16 20:36:50.356 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 140ms. https://192.168.1.29:8920/emby/Items/10756/Images/Primary?maxWidth=187&tag=4914aede7183f8b6d881a7dab0b88362&quality=90 2020-06-16 20:36:50.525 Debug ImageProcessor: Image encoding took 296ms for /var/db/emby-server/metadata/People/T/Toby Kebbell/poster.jpg 2020-06-16 20:36:50.526 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 299ms. https://192.168.1.29:8920/emby/Items/41/Images/Primary?maxWidth=187&tag=0bb9c810f4ee104c07c55ea58c20bf5e&quality=90 2020-06-16 20:36:50.583 Debug ImageProcessor: Image encoding took 624ms for /var/db/emby-server/metadata/library/cd/cd657fa0aa044cbaa0ef95d9460249ea/folder.jpg 2020-06-16 20:36:50.584 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 627ms. https://192.168.1.29:8920/emby/Items/10753/Images/Primary?maxWidth=187&tag=dc1979477a400e472dfa8cf1388e6729&quality=90 2020-06-16 20:36:50.784 Debug ImageProcessor: Image encoding took 1203ms for /var/db/emby-server/metadata/library/9a/9ae5b665d27e646d5b4bb6612193de20/backdrop.jpg 2020-06-16 20:36:50.789 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 1208ms. https://192.168.1.29:8920/emby/Items/10751/Images/Backdrop/0?tag=4c65f4805863d65c2b3d23af05332531&maxWidth=1600&quality=70 2020-06-16 20:37:08.270 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Items/11261/ThemeMedia?UserId=65d0ee59448b4babb59b4bfba1ad3fcf&InheritFromParent=true&EnableThemeSongs=false&EnableThemeVideos=true. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 20:37:08.270 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Users/65d0ee59448b4babb59b4bfba1ad3fcf/Items/11261. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 20:37:08.357 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 87ms. https://192.168.1.29:8920/emby/Items/11261/ThemeMedia?UserId=65d0ee59448b4babb59b4bfba1ad3fcf&InheritFromParent=true&EnableThemeSongs=false&EnableThemeVideos=true 2020-06-16 20:37:08.370 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 99ms. https://192.168.1.29:8920/emby/Users/65d0ee59448b4babb59b4bfba1ad3fcf/Items/11261 2020-06-16 20:37:08.388 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Items/11261/Images/Backdrop/0?tag=245893282d639e889b9a4432913d231a&maxWidth=1600&quality=70. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 20:37:08.391 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Items/11261/Images/Logo?maxWidth=300&tag=ebbb3f8dcde8a0bd93ec89a01cb1b807&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 20:37:08.424 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Users/65d0ee59448b4babb59b4bfba1ad3fcf/Items/11261/SpecialFeatures. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 20:37:08.424 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Items/11261/Similar?Limit=12&UserId=65d0ee59448b4babb59b4bfba1ad3fcf&ImageTypeLimit=1&Fields=PrimaryImageAspectRatio%2CUserData%2CCanDelete%2CProductionYear&EnableTotalRecordCount=false. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 20:37:08.425 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Users/65d0ee59448b4babb59b4bfba1ad3fcf/Items?fields=PrimaryImageAspectRatio%2CUserData%2CCanDelete&EnableTotalRecordCount=false&IncludeItemTypes=Playlist%2CBoxSet&Recursive=true&SortBy=SortName&ListItemIds=11261. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 20:37:08.425 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 37ms. https://192.168.1.29:8920/emby/Items/11261/Images/Backdrop/0?tag=245893282d639e889b9a4432913d231a&maxWidth=1600&quality=70 2020-06-16 20:37:08.426 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 2ms. https://192.168.1.29:8920/emby/Users/65d0ee59448b4babb59b4bfba1ad3fcf/Items/11261/SpecialFeatures 2020-06-16 20:37:08.427 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 2ms. https://192.168.1.29:8920/emby/Users/65d0ee59448b4babb59b4bfba1ad3fcf/Items?fields=PrimaryImageAspectRatio%2CUserData%2CCanDelete&EnableTotalRecordCount=false&IncludeItemTypes=Playlist%2CBoxSet&Recursive=true&SortBy=SortName&ListItemIds=11261 2020-06-16 20:37:08.433 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 9ms. https://192.168.1.29:8920/emby/Items/11261/Similar?Limit=12&UserId=65d0ee59448b4babb59b4bfba1ad3fcf&ImageTypeLimit=1&Fields=PrimaryImageAspectRatio%2CUserData%2CCanDelete%2CProductionYear&EnableTotalRecordCount=false 2020-06-16 20:37:08.437 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 46ms. https://192.168.1.29:8920/emby/Items/11261/Images/Logo?maxWidth=300&tag=ebbb3f8dcde8a0bd93ec89a01cb1b807&quality=90 2020-06-16 20:37:08.438 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Items/11261/Similar?userId=65d0ee59448b4babb59b4bfba1ad3fcf&limit=12&fields=PrimaryImageAspectRatio%2CUserData%2CCanDelete%2CProductionYear&IncludeItemTypes=Program&EnableTotalRecordCount=false. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 20:37:08.440 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 2ms. https://192.168.1.29:8920/emby/Items/11261/Similar?userId=65d0ee59448b4babb59b4bfba1ad3fcf&limit=12&fields=PrimaryImageAspectRatio%2CUserData%2CCanDelete%2CProductionYear&IncludeItemTypes=Program&EnableTotalRecordCount=false 2020-06-16 20:37:08.468 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Items/11261/Images/Primary?maxHeight=1200&maxWidth=800&tag=a906f810aee7c2b5790ee2c10e503ca1&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 20:37:08.468 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Items/58/Images/Primary?maxWidth=187&tag=5bc5508ef3db43f4d0812d4d0ed10354&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 20:37:08.469 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Items/11415/Images/Primary?maxWidth=187&tag=6f49da9b907d6c3252eda25ee4d89c3a&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 20:37:08.469 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Items/11416/Images/Primary?maxWidth=187&tag=d5d1ac08048dc6a8d7418a50a8d68861&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 20:37:08.469 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Items/11417/Images/Primary?maxWidth=187&tag=5d70fa3df1958a58fb553dda7873e1a9&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 20:37:08.470 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Items/11418/Images/Primary?maxWidth=187&tag=d356f8931ef1182db1bd57a2786f918e&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 20:37:08.501 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 32ms. https://192.168.1.29:8920/emby/Items/58/Images/Primary?maxWidth=187&tag=5bc5508ef3db43f4d0812d4d0ed10354&quality=90 2020-06-16 20:37:08.501 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Items/8694/Images/Primary?maxWidth=187&tag=1b1557130fd1113129b2e4ca27040e05&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 20:37:08.559 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 90ms. https://192.168.1.29:8920/emby/Items/11416/Images/Primary?maxWidth=187&tag=d5d1ac08048dc6a8d7418a50a8d68861&quality=90 2020-06-16 20:37:08.559 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 89ms. https://192.168.1.29:8920/emby/Items/11418/Images/Primary?maxWidth=187&tag=d356f8931ef1182db1bd57a2786f918e&quality=90 2020-06-16 20:37:08.559 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 91ms. https://192.168.1.29:8920/emby/Items/11415/Images/Primary?maxWidth=187&tag=6f49da9b907d6c3252eda25ee4d89c3a&quality=90 2020-06-16 20:37:08.560 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 58ms. https://192.168.1.29:8920/emby/Items/8694/Images/Primary?maxWidth=187&tag=1b1557130fd1113129b2e4ca27040e05&quality=90 2020-06-16 20:37:08.560 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 91ms. https://192.168.1.29:8920/emby/Items/11417/Images/Primary?maxWidth=187&tag=5d70fa3df1958a58fb553dda7873e1a9&quality=90 2020-06-16 20:37:08.560 Info HttpServer: HTTP POST https://192.168.1.29:8920/emby/Items/11261/PlaybackInfo?UserId=65d0ee59448b4babb59b4bfba1ad3fcf&StartTimeTicks=0&IsPlayback=false&AutoOpenLiveStream=false&MaxStreamingBitrate=60000000. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 20:37:08.562 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 94ms. https://192.168.1.29:8920/emby/Items/11261/Images/Primary?maxHeight=1200&maxWidth=800&tag=a906f810aee7c2b5790ee2c10e503ca1&quality=90 2020-06-16 20:37:08.562 Debug MediaInfoService: GetPostedPlaybackInfo request: {"Id":"11261","UserId":"65d0ee59448b4babb59b4bfba1ad3fcf","MaxStreamingBitrate":60000000,"StartTimeTicks":0,"DeviceProfile":{"EnableAlbumArtInDidl":false,"EnableSingleAlbumArtLimit":false,"EnableSingleSubtitleLimit":false,"SupportedMediaTypes":"Audio,Photo,Video","MaxAlbumArtWidth":0,"MaxAlbumArtHeight":0,"MaxStreamingBitrate":140000000,"MusicStreamingTranscodingBitrate":192000,"TimelineOffsetSeconds":0,"RequiresPlainVideoItems":false,"RequiresPlainFolders":false,"IgnoreTranscodeByteRangeRequests":false,"XmlRootAttributes":[],"DirectPlayProfiles":[{"Container":"mp4,m4v","AudioCodec":"aac,opus,flac,vorbis","VideoCodec":"h264,vp8,vp9","Type":"Video"},{"Container":"flv","AudioCodec":"aac,mp3","VideoCodec":"h264","Type":"Video"},{"Container":"mov","AudioCodec":"aac,opus,flac,vorbis","VideoCodec":"h264","Type":"Video"},{"Container":"opus","Type":"Audio"},{"Container":"mp3","AudioCodec":"mp3","Type":"Audio"},{"Container":"mp2,mp3","AudioCodec":"mp2","Type":"Audio"},{"Container":"m4a","AudioCodec":"aac","Type":"Audio"},{"Container":"flac","Type":"Audio"},{"Container":"alac","Type":"Audio"},{"Container":"m4a","AudioCodec":"alac","Type":"Audio"},{"Container":"webma,webm","Type":"Audio"},{"Container":"wav","AudioCodec":"PCM_S16LE","Type":"Audio"},{"Container":"ogg","Type":"Audio"},{"Container":"webm","AudioCodec":"vorbis,opus","VideoCodec":"VP8","Type":"Video"},{"Container":"webm","AudioCodec":"vorbis,opus","VideoCodec":"VP9","Type":"Video"}],"TranscodingProfiles":[{"Container":"aac","Type":"Audio","AudioCodec":"aac","Protocol":"hls","EstimateContentLength":false,"EnableMpegtsM2TsMode":false,"TranscodeSeekInfo":"Auto","CopyTimestamps":false,"Context":"Streaming","MaxAudioChannels":"2","MinSegments":1,"SegmentLength":0,"BreakOnNonKeyFrames":true},{"Container":"aac","Type":"Audio","AudioCodec":"aac","Protocol":"http","EstimateContentLength":false,"EnableMpegtsM2TsMode":false,"TranscodeSeekInfo":"Auto","CopyTimestamps":false,"Context":"Streaming","MaxAudioChannels":"2","MinSegments":0,"SegmentLength":0,"BreakOnNonKeyFrames":false},{"Container":"mp3","Type":"Audio","AudioCodec":"mp3","Protocol":"http","EstimateContentLength":false,"EnableMpegtsM2TsMode":false,"TranscodeSeekInfo":"Auto","CopyTimestamps":false,"Context":"Streaming","MaxAudioChannels":"2","MinSegments":0,"SegmentLength":0,"BreakOnNonKeyFrames":false},{"Container":"opus","Type":"Audio","AudioCodec":"opus","Protocol":"http","EstimateContentLength":false,"EnableMpegtsM2TsMode":false,"TranscodeSeekInfo":"Auto","CopyTimestamps":false,"Context":"Streaming","MaxAudioChannels":"2","MinSegments":0,"SegmentLength":0,"BreakOnNonKeyFrames":false},{"Container":"wav","Type":"Audio","AudioCodec":"wav","Protocol":"http","EstimateContentLength":false,"EnableMpegtsM2TsMode":false,"TranscodeSeekInfo":"Auto","CopyTimestamps":false,"Context":"Streaming","MaxAudioChannels":"2","MinSegments":0,"SegmentLength":0,"BreakOnNonKeyFrames":false},{"Container":"opus","Type":"Audio","AudioCodec":"opus","Protocol":"http","EstimateContentLength":false,"EnableMpegtsM2TsMode":false,"TranscodeSeekInfo":"Auto","CopyTimestamps":false,"Context":"Static","MaxAudioChannels":"2","MinSegments":0,"SegmentLength":0,"BreakOnNonKeyFrames":false},{"Container":"mp3","Type":"Audio","AudioCodec":"mp3","Protocol":"http","EstimateContentLength":false,"EnableMpegtsM2TsMode":false,"TranscodeSeekInfo":"Auto","CopyTimestamps":false,"Context":"Static","MaxAudioChannels":"2","MinSegments":0,"SegmentLength":0,"BreakOnNonKeyFrames":false},{"Container":"aac","Type":"Audio","AudioCodec":"aac","Protocol":"http","EstimateContentLength":false,"EnableMpegtsM2TsMode":false,"TranscodeSeekInfo":"Auto","CopyTimestamps":false,"Context":"Static","MaxAudioChannels":"2","MinSegments":0,"SegmentLength":0,"BreakOnNonKeyFrames":false},{"Container":"wav","Type":"Audio","AudioCodec":"wav","Protocol":"http","EstimateContentLength":false,"EnableMpegtsM2TsMode":false,"TranscodeSeekInfo":"Auto","CopyTimestamps":false,"Context":"Static","MaxAudioChannels":"2","MinSegments":0,"SegmentLength":0,"BreakOnNonKeyFrames":false},{"Container":"ts","Type":"Video","VideoCodec":"h264","AudioCodec":"aac","Protocol":"hls","EstimateContentLength":false,"EnableMpegtsM2TsMode":false,"TranscodeSeekInfo":"Auto","CopyTimestamps":false,"Context":"Streaming","MaxAudioChannels":"2","MinSegments":1,"SegmentLength":0,"BreakOnNonKeyFrames":true,"ManifestSubtitles":"vtt"},{"Container":"webm","Type":"Video","VideoCodec":"vpx","AudioCodec":"vorbis","Protocol":"http","EstimateContentLength":false,"EnableMpegtsM2TsMode":false,"TranscodeSeekInfo":"Auto","CopyTimestamps":false,"Context":"Streaming","MaxAudioChannels":"2","MinSegments":0,"SegmentLength":0,"BreakOnNonKeyFrames":false},{"Container":"mp4","Type":"Video","VideoCodec":"h264","AudioCodec":"aac,opus,flac,vorbis","Protocol":"http","EstimateContentLength":false,"EnableMpegtsM2TsMode":false,"TranscodeSeekInfo":"Auto","CopyTimestamps":false,"Context":"Static","MinSegments":0,"SegmentLength":0,"BreakOnNonKeyFrames":false}],"ContainerProfiles":[],"CodecProfiles":[{"Type":"VideoAudio","Conditions":[{"Condition":"Equals","Property":"IsSecondaryAudio","Value":"false","IsRequired":false}],"ApplyConditions":[],"Codec":"aac"},{"Type":"VideoAudio","Conditions":[{"Condition":"Equals","Property":"IsSecondaryAudio","Value":"false","IsRequired":false}],"ApplyConditions":[]},{"Type":"Video","Conditions":[{"Condition":"EqualsAny","Property":"VideoProfile","Value":"high|main|baseline|constrained baseline","IsRequired":false},{"Condition":"LessThanEqual","Property":"VideoLevel","Value":"52","IsRequired":false}],"ApplyConditions":[],"Codec":"h264"}],"ResponseProfiles":[{"Container":"m4v","Type":"Video","MimeType":"video/mp4","Conditions":[]}],"SubtitleProfiles":[{"Format":"vtt","Method":"Hls"},{"Format":"vtt","Method":"External"},{"Format":"ass","Method":"External"},{"Format":"ssa","Method":"External"}]},"EnableDirectPlay":true,"EnableDirectStream":true,"EnableTranscoding":true,"AllowVideoStreamCopy":true,"AllowAudioStreamCopy":true,"IsPlayback":false,"AutoOpenLiveStream":false,"DirectPlayProtocols":["Http"]} 2020-06-16 20:37:08.565 Info MediaInfoService: User policy for MYserverName. EnablePlaybackRemuxing: True EnableVideoPlaybackTranscoding: True EnableAudioPlaybackTranscoding: True 2020-06-16 20:37:08.566 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 6ms. https://192.168.1.29:8920/emby/Items/11261/PlaybackInfo?UserId=65d0ee59448b4babb59b4bfba1ad3fcf&StartTimeTicks=0&IsPlayback=false&AutoOpenLiveStream=false&MaxStreamingBitrate=60000000 2020-06-16 20:37:23.246 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Items/2404/Images/Primary?maxHeight=280&maxWidth=187&tag=6a580b63772893afbeee68f3c3b6507c&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 20:37:23.246 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Items/2438/Images/Primary?maxHeight=280&maxWidth=187&tag=2eba1d41ac3b0792899ed010b47f1aea&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 20:37:23.246 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Items/2411/Images/Primary?maxHeight=280&maxWidth=187&tag=9f91aee59fec27b9e5c5f86dbcd9b867&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 20:37:23.260 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 14ms. https://192.168.1.29:8920/emby/Items/2438/Images/Primary?maxHeight=280&maxWidth=187&tag=2eba1d41ac3b0792899ed010b47f1aea&quality=90 2020-06-16 20:37:23.274 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 28ms. https://192.168.1.29:8920/emby/Items/2404/Images/Primary?maxHeight=280&maxWidth=187&tag=6a580b63772893afbeee68f3c3b6507c&quality=90 2020-06-16 20:37:23.277 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 31ms. https://192.168.1.29:8920/emby/Items/2411/Images/Primary?maxHeight=280&maxWidth=187&tag=9f91aee59fec27b9e5c5f86dbcd9b867&quality=90 2020-06-16 20:40:37.021 Info HttpClient: HttpClientManager GET: https://emby.media/community/index.php?/blog/rss/1-media-browser-developers-blog 2020-06-16 20:52:28.345 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Users/65d0ee59448b4babb59b4bfba1ad3fcf/Items/Resume?Limit=12&Recursive=true&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo%2CProductionYear&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&EnableTotalRecordCount=false&MediaTypes=Video. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 20:52:28.345 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Users/65d0ee59448b4babb59b4bfba1ad3fcf. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 20:52:28.347 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Users/65d0ee59448b4babb59b4bfba1ad3fcf/Items/Resume?Limit=12&Recursive=true&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo%2CProductionYear&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&EnableTotalRecordCount=false&MediaTypes=Audio. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 20:52:28.348 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 2ms. https://192.168.1.29:8920/emby/Users/65d0ee59448b4babb59b4bfba1ad3fcf 2020-06-16 20:52:28.349 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 2ms. https://192.168.1.29:8920/emby/Users/65d0ee59448b4babb59b4bfba1ad3fcf/Items/Resume?Limit=12&Recursive=true&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo%2CProductionYear&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&EnableTotalRecordCount=false&MediaTypes=Audio 2020-06-16 20:52:28.352 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 7ms. https://192.168.1.29:8920/emby/Users/65d0ee59448b4babb59b4bfba1ad3fcf/Items/Resume?Limit=12&Recursive=true&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo%2CProductionYear&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&EnableTotalRecordCount=false&MediaTypes=Video 2020-06-16 20:52:29.226 Debug SessionManager: Removing active session Firefox TW96aWxsYS81LjAgKFdpbmRvd3MgTlQgMTAuMDsgV2luNjQ7IHg2NDsgcnY6NjUuMCkgR2Vja28vMjAxMDAxMDEgRmlyZWZveC82NS4wfDE1NDkwNTAyMzUyOTE1 2020-06-16 20:52:29.226 Debug SessionManager: Disposing session controller WebSocketController 2020-06-16 21:24:03.398 Info HttpServer: HTTP GET https://192.168.1.29:8920/. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 21:24:03.398 Info HttpServer: HTTP Response 302 to 192.168.1.2. Time: 0ms. https://192.168.1.29:8920/ 2020-06-16 21:24:03.862 Info HttpServer: HTTP GET https://192.168.1.29:8920/web/touchicon114.png. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 21:24:03.869 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 7ms. https://192.168.1.29:8920/web/touchicon114.png 2020-06-16 21:24:04.130 Info HttpServer: HTTP GET https://192.168.1.29:8920/web/strings/he.json?v=1592331844078. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 21:24:04.130 Info HttpServer: HTTP GET https://192.168.1.29:8920/web/bower_components/emby-webcomponents/strings/he.json?v=1592331844078. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 21:24:04.133 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 3ms. https://192.168.1.29:8920/web/strings/he.json?v=1592331844078 2020-06-16 21:24:04.133 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 3ms. https://192.168.1.29:8920/web/bower_components/emby-webcomponents/strings/he.json?v=1592331844078 2020-06-16 21:24:04.494 Error HttpServer: Error in ProcessAccept *** Error Report *** Version: 4.4.2.0 Command line: /usr/local/lib/emby-server/system/EmbyServer.exe -os freebsd -ffdetect /usr/local/lib/emby-server/bin/ffdetect -ffmpeg /usr/local/lib/emby-server/bin/ffmpeg -ffprobe /usr/local/lib/emby-server/bin/ffprobe -programdata /var/db/emby-server -updatepackage emby-server-freebsd12_{version}_amd64.txz Operating system: Unix 11.3.9.0 64-Bit OS: True 64-Bit Process: True User Interactive: False Mono: 5.10.1.57 (5.10.1.57 Thu Apr 9 04:06:41 UTC 2020) Runtime: file:///usr/local/lib/mono/4.5/mscorlib.dll System.Environment.Version: 4.0.30319.42000 Processor count: 4 Program data path: /var/db/emby-server Application directory: /usr/local/lib/emby-server/system System.IO.IOException: System.IO.IOException: Remote prematurely closed connection. at Mono.Net.Security.AsyncProtocolRequest+<ProcessOperation>d__24.MoveNext () [0x000e7] in <b3922b7d60404fa9ae645f1fb97f5b6b>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0003e] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00028] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00008] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable+ConfiguredTaskAwaiter.GetResult () [0x00000] in <0e06830de9a44394a7e366951eabca52>:0 at Mono.Net.Security.AsyncProtocolRequest+<StartOperation>d__23.MoveNext () [0x0008b] in <b3922b7d60404fa9ae645f1fb97f5b6b>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <0e06830de9a44394a7e366951eabca52>:0 at Mono.Net.Security.MobileAuthenticatedStream+<ProcessAuthentication>d__47.MoveNext () [0x00254] in <b3922b7d60404fa9ae645f1fb97f5b6b>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0003e] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00028] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00008] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable+ConfiguredTaskAwaiter.GetResult () [0x00000] in <0e06830de9a44394a7e366951eabca52>:0 at SocketHttpListener.Net.HttpConnection+<Init>d__26.MoveNext () [0x000a5] in <5fc69e0598a34841a210f67306929617>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0003e] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00028] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00008] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable+ConfiguredTaskAwaiter.GetResult () [0x00000] in <0e06830de9a44394a7e366951eabca52>:0 at SocketHttpListener.Net.HttpEndPointListener+<ProcessAccept>d__21.MoveNext () [0x0015d] in <5fc69e0598a34841a210f67306929617>:0 Source: mscorlib TargetSite: Void Throw() 2020-06-16 21:24:04.674 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/system/info/public. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 21:24:04.674 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 1ms. https://192.168.1.29:8920/emby/system/info/public 2020-06-16 21:24:04.796 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/System/Info. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 21:24:04.832 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 36ms. https://192.168.1.29:8920/emby/System/Info 2020-06-16 21:24:05.000 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/DisplayPreferences/usersettings?userId=65d0ee59448b4babb59b4bfba1ad3fcf&client=emby. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 21:24:05.002 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 2ms. https://192.168.1.29:8920/emby/DisplayPreferences/usersettings?userId=65d0ee59448b4babb59b4bfba1ad3fcf&client=emby 2020-06-16 21:24:05.004 Info HttpServer: WS https://192.168.1.29:8920/embywebsocket?api_key=1733ef2d1e0a4ffb856b3ddbbec9dcee&deviceId=TW96aWxsYS81LjAgKFdpbmRvd3MgTlQgMTAuMDsgV2luNjQ7IHg2NDsgcnY6NjUuMCkgR2Vja28vMjAxMDAxMDEgRmlyZWZveC82NS4wfDE1NDkwNTAyMzUyOTE1. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 21:24:05.004 Debug SessionManager: Creating new WebSocketController 2020-06-16 21:24:05.060 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Users/65d0ee59448b4babb59b4bfba1ad3fcf. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 21:24:05.062 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 1ms. https://192.168.1.29:8920/emby/Users/65d0ee59448b4babb59b4bfba1ad3fcf 2020-06-16 21:24:05.192 Error HttpServer: Error processing request *** Error Report *** Version: 4.4.2.0 Command line: /usr/local/lib/emby-server/system/EmbyServer.exe -os freebsd -ffdetect /usr/local/lib/emby-server/bin/ffdetect -ffmpeg /usr/local/lib/emby-server/bin/ffmpeg -ffprobe /usr/local/lib/emby-server/bin/ffprobe -programdata /var/db/emby-server -updatepackage emby-server-freebsd12_{version}_amd64.txz Operating system: Unix 11.3.9.0 64-Bit OS: True 64-Bit Process: True User Interactive: False Mono: 5.10.1.57 (5.10.1.57 Thu Apr 9 04:06:41 UTC 2020) Runtime: file:///usr/local/lib/mono/4.5/mscorlib.dll System.Environment.Version: 4.0.30319.42000 Processor count: 4 Program data path: /var/db/emby-server Application directory: /usr/local/lib/emby-server/system System.Security.Authentication.AuthenticationException: System.Security.Authentication.AuthenticationException: A call to SSPI failed, see inner exception. ---> System.Net.Sockets.SocketException: The socket has been shut down at System.Net.Sockets.Socket.EndSend (System.IAsyncResult asyncResult) [0x00012] in <b3922b7d60404fa9ae645f1fb97f5b6b>:0 at SocketHttpListener.SocketStream.EndWrite (System.IAsyncResult asyncResult) [0x00000] in <5fc69e0598a34841a210f67306929617>:0 at System.IO.Stream+<>c.<BeginEndWriteAsync>b__53_1 (System.IO.Stream stream, System.IAsyncResult asyncResult) [0x00000] in <0e06830de9a44394a7e366951eabca52>:0 at (wrapper delegate-invoke) System.Func`3[System.IO.Stream,System.IAsyncResult,System.Threading.Tasks.VoidTaskResult].invoke_TResult_T1_T2(System.IO.Stream,System.IAsyncResult) at System.Threading.Tasks.TaskFactory`1+FromAsyncTrimPromise`1[TResult,TInstance].Complete (TInstance thisRef, System.Func`3[T1,T2,TResult] endMethod, System.IAsyncResult asyncResult, System.Boolean requiresSynchronization) [0x00000] in <0e06830de9a44394a7e366951eabca52>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0003e] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00028] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00008] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable+ConfiguredTaskAwaiter.GetResult () [0x00000] in <0e06830de9a44394a7e366951eabca52>:0 at Mono.Net.Security.MobileAuthenticatedStream+<InnerWrite>d__67.MoveNext () [0x000d3] in <b3922b7d60404fa9ae645f1fb97f5b6b>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0003e] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00028] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00008] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable+ConfiguredTaskAwaiter.GetResult () [0x00000] in <0e06830de9a44394a7e366951eabca52>:0 at Mono.Net.Security.AsyncProtocolRequest+<ProcessOperation>d__24.MoveNext () [0x00196] in <b3922b7d60404fa9ae645f1fb97f5b6b>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0003e] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00028] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00008] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable+ConfiguredTaskAwaiter.GetResult () [0x00000] in <0e06830de9a44394a7e366951eabca52>:0 at Mono.Net.Security.AsyncProtocolRequest+<StartOperation>d__23.MoveNext () [0x0008b] in <b3922b7d60404fa9ae645f1fb97f5b6b>:0 --- End of inner exception stack trace --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <0e06830de9a44394a7e366951eabca52>:0 at Mono.Net.Security.MobileAuthenticatedStream+<StartOperation>d__58.MoveNext () [0x001bf] in <b3922b7d60404fa9ae645f1fb97f5b6b>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0003e] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00028] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00008] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.GetResult () [0x00000] in <0e06830de9a44394a7e366951eabca52>:0 at System.Threading.Tasks.TaskToApm.End (System.IAsyncResult asyncResult) [0x00029] in <0e06830de9a44394a7e366951eabca52>:0 at Mono.Net.Security.MobileAuthenticatedStream.EndWrite (System.IAsyncResult asyncResult) [0x00000] in <b3922b7d60404fa9ae645f1fb97f5b6b>:0 at System.Net.Security.SslStream.EndWrite (System.IAsyncResult asyncResult) [0x00006] in <b3922b7d60404fa9ae645f1fb97f5b6b>:0 at SocketHttpListener.Net.HttpResponseStream.EndWriteCore (System.IAsyncResult asyncResult) [0x00041] in <5fc69e0598a34841a210f67306929617>:0 at SocketHttpListener.Net.HttpResponseStream.EndWrite (System.IAsyncResult asyncResult) [0x0000e] in <5fc69e0598a34841a210f67306929617>:0 at System.IO.Stream+<>c.<BeginEndWriteAsync>b__53_1 (System.IO.Stream stream, System.IAsyncResult asyncResult) [0x00000] in <0e06830de9a44394a7e366951eabca52>:0 at (wrapper delegate-invoke) System.Func`3[System.IO.Stream,System.IAsyncResult,System.Threading.Tasks.VoidTaskResult].invoke_TResult_T1_T2(System.IO.Stream,System.IAsyncResult) at System.Threading.Tasks.TaskFactory`1+FromAsyncTrimPromise`1[TResult,TInstance].Complete (TInstance thisRef, System.Func`3[T1,T2,TResult] endMethod, System.IAsyncResult asyncResult, System.Boolean requiresSynchronization) [0x00000] in <0e06830de9a44394a7e366951eabca52>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0003e] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00028] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00008] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable+ConfiguredTaskAwaiter.GetResult () [0x00000] in <0e06830de9a44394a7e366951eabca52>:0 at System.IO.Stream+<CopyToAsyncInternal>d__27.MoveNext () [0x000a0] in <0e06830de9a44394a7e366951eabca52>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0003e] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00028] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00008] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable+ConfiguredTaskAwaiter.GetResult () [0x00000] in <0e06830de9a44394a7e366951eabca52>:0 at Emby.Server.Implementations.HttpServer.FileWriter+<WriteToAsync>d__43.MoveNext () [0x004af] in <3605319732a64e8282cfdf09a091f02e>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0003e] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00028] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00008] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable+ConfiguredTaskAwaiter.GetResult () [0x00000] in <0e06830de9a44394a7e366951eabca52>:0 at Emby.Server.Implementations.Services.ServiceHandler+<ProcessRequestAsync>d__4.MoveNext () [0x0026a] in <3605319732a64e8282cfdf09a091f02e>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0003e] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00028] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00008] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable+ConfiguredTaskAwaiter.GetResult () [0x00000] in <0e06830de9a44394a7e366951eabca52>:0 at Emby.Server.Implementations.HttpServer.HttpListenerHost+<RequestHandler>d__46.MoveNext () [0x00b52] in <3605319732a64e8282cfdf09a091f02e>:0 Source: mscorlib TargetSite: Void Throw() InnerException: System.Net.Sockets.SocketException: The socket has been shut down Source: mscorlib TargetSite: Void Throw() at System.Net.Sockets.Socket.EndSend (System.IAsyncResult asyncResult) [0x00012] in <b3922b7d60404fa9ae645f1fb97f5b6b>:0 at SocketHttpListener.SocketStream.EndWrite (System.IAsyncResult asyncResult) [0x00000] in <5fc69e0598a34841a210f67306929617>:0 at System.IO.Stream+<>c.<BeginEndWriteAsync>b__53_1 (System.IO.Stream stream, System.IAsyncResult asyncResult) [0x00000] in <0e06830de9a44394a7e366951eabca52>:0 at (wrapper delegate-invoke) System.Func`3[System.IO.Stream,System.IAsyncResult,System.Threading.Tasks.VoidTaskResult].invoke_TResult_T1_T2(System.IO.Stream,System.IAsyncResult) at System.Threading.Tasks.TaskFactory`1+FromAsyncTrimPromise`1[TResult,TInstance].Complete (TInstance thisRef, System.Func`3[T1,T2,TResult] endMethod, System.IAsyncResult asyncResult, System.Boolean requiresSynchronization) [0x00000] in <0e06830de9a44394a7e366951eabca52>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0003e] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00028] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00008] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable+ConfiguredTaskAwaiter.GetResult () [0x00000] in <0e06830de9a44394a7e366951eabca52>:0 at Mono.Net.Security.MobileAuthenticatedStream+<InnerWrite>d__67.MoveNext () [0x000d3] in <b3922b7d60404fa9ae645f1fb97f5b6b>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0003e] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00028] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00008] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable+ConfiguredTaskAwaiter.GetResult () [0x00000] in <0e06830de9a44394a7e366951eabca52>:0 at Mono.Net.Security.AsyncProtocolRequest+<ProcessOperation>d__24.MoveNext () [0x00196] in <b3922b7d60404fa9ae645f1fb97f5b6b>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0003e] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00028] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00008] in <0e06830de9a44394a7e366951eabca52>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable+ConfiguredTaskAwaiter.GetResult () [0x00000] in <0e06830de9a44394a7e366951eabca52>:0 at Mono.Net.Security.AsyncProtocolRequest+<StartOperation>d__23.MoveNext () [0x0008b] in <b3922b7d60404fa9ae645f1fb97f5b6b>:0 2020-06-16 21:24:05.458 Info HttpServer: HTTP POST https://192.168.1.29:8920/emby/Sessions/Capabilities/Full. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 21:24:05.460 Info HttpServer: HTTP Response 204 to 192.168.1.2. Time: 2ms. https://192.168.1.29:8920/emby/Sessions/Capabilities/Full 2020-06-16 21:24:05.531 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Users/65d0ee59448b4babb59b4bfba1ad3fcf/Views. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 21:24:05.533 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 2ms. https://192.168.1.29:8920/emby/Users/65d0ee59448b4babb59b4bfba1ad3fcf/Views 2020-06-16 21:24:05.599 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Users/65d0ee59448b4babb59b4bfba1ad3fcf/Items/Resume?Limit=12&Recursive=true&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo%2CProductionYear&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&EnableTotalRecordCount=false&MediaTypes=Video. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 21:24:05.603 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 4ms. https://192.168.1.29:8920/emby/Users/65d0ee59448b4babb59b4bfba1ad3fcf/Items/Resume?Limit=12&Recursive=true&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo%2CProductionYear&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&EnableTotalRecordCount=false&MediaTypes=Video 2020-06-16 21:24:05.608 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Users/65d0ee59448b4babb59b4bfba1ad3fcf/Items/Resume?Limit=12&Recursive=true&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo%2CProductionYear&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&EnableTotalRecordCount=false&MediaTypes=Audio. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 21:24:05.609 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 2ms. https://192.168.1.29:8920/emby/Users/65d0ee59448b4babb59b4bfba1ad3fcf/Items/Resume?Limit=12&Recursive=true&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo%2CProductionYear&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&EnableTotalRecordCount=false&MediaTypes=Audio 2020-06-16 21:24:07.195 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Items/14265640a7420b35d3beaf575a4fbe20/Images/Primary?maxHeight=187&maxWidth=187&tag=e2f81fc2e454aa3248e5a9e7c9c69133&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 21:24:07.195 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Items/dfc3a7d9ae799d21d9beeb549a68b511/Images/Primary?maxHeight=187&maxWidth=187&tag=ba3825a50343acb49424ad93786113ad&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 21:24:07.211 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 16ms. https://192.168.1.29:8920/emby/Items/dfc3a7d9ae799d21d9beeb549a68b511/Images/Primary?maxHeight=187&maxWidth=187&tag=ba3825a50343acb49424ad93786113ad&quality=90 2020-06-16 21:24:07.222 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 26ms. https://192.168.1.29:8920/emby/Items/14265640a7420b35d3beaf575a4fbe20/Images/Primary?maxHeight=187&maxWidth=187&tag=e2f81fc2e454aa3248e5a9e7c9c69133&quality=90 2020-06-16 21:25:05.527 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Users/65d0ee59448b4babb59b4bfba1ad3fcf. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 21:25:05.528 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 1ms. https://192.168.1.29:8920/emby/Users/65d0ee59448b4babb59b4bfba1ad3fcf 2020-06-16 21:25:05.590 Debug App: SessionInfosWebSocketListener Begin transmitting over websocket to 192.168.1.2 2020-06-16 21:25:05.590 Debug App: ScheduledTasksWebSocketListener Begin transmitting over websocket to 192.168.1.2 2020-06-16 21:25:05.608 Debug App: ActivityLogWebSocketListener Begin transmitting over websocket to 192.168.1.2 2020-06-16 21:25:05.609 Debug App: ActivityLogWebSocketListener Begin transmitting over websocket to 192.168.1.2 2020-06-16 21:25:05.619 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/ScheduledTasks. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 21:25:05.620 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/System/Info. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 21:25:05.621 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/System/ActivityLog/Entries?StartIndex=0&Limit=7&MinDate=2020-06-15T18%3A25%3A05.570Z&hasUserId=true. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 21:25:05.621 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 3ms. https://192.168.1.29:8920/emby/ScheduledTasks 2020-06-16 21:25:05.621 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 1ms. https://192.168.1.29:8920/emby/System/Info 2020-06-16 21:25:05.625 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/web/configurationpages?pageType=PluginConfiguration&EnableInMainMenu=true. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 21:25:05.625 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 4ms. https://192.168.1.29:8920/emby/System/ActivityLog/Entries?StartIndex=0&Limit=7&MinDate=2020-06-15T18%3A25%3A05.570Z&hasUserId=true 2020-06-16 21:25:05.626 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 1ms. https://192.168.1.29:8920/emby/web/configurationpages?pageType=PluginConfiguration&EnableInMainMenu=true 2020-06-16 21:25:05.627 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/System/ActivityLog/Entries?StartIndex=0&Limit=4&MinDate=2020-06-09T18%3A25%3A05.570Z&hasUserId=false. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 21:25:05.629 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/News/Product?StartIndex=0&Limit=4. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 21:25:05.630 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 3ms. https://192.168.1.29:8920/emby/System/ActivityLog/Entries?StartIndex=0&Limit=4&MinDate=2020-06-09T18%3A25%3A05.570Z&hasUserId=false 2020-06-16 21:25:05.634 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/LiveTv/Recordings?UserId=65d0ee59448b4babb59b4bfba1ad3fcf&IsInProgress=true&Fields=CanDelete%2CPrimaryImageAspectRatio&EnableTotalRecordCount=false&EnableImageTypes=Primary%2CThumb%2CBackdrop. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 21:25:05.635 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 1ms. https://192.168.1.29:8920/emby/LiveTv/Recordings?UserId=65d0ee59448b4babb59b4bfba1ad3fcf&IsInProgress=true&Fields=CanDelete%2CPrimaryImageAspectRatio&EnableTotalRecordCount=false&EnableImageTypes=Primary%2CThumb%2CBackdrop 2020-06-16 21:25:05.645 Info HttpServer: HTTP GET https://192.168.1.29:8920/web/modules/themes/logodark.png. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 21:25:05.654 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Packages/Updates?PackageType=System. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 21:25:05.658 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 30ms. https://192.168.1.29:8920/emby/News/Product?StartIndex=0&Limit=4 2020-06-16 21:25:05.678 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 33ms. https://192.168.1.29:8920/web/modules/themes/logodark.png 2020-06-16 21:25:05.866 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 212ms. https://192.168.1.29:8920/emby/Packages/Updates?PackageType=System 2020-06-16 21:25:06.328 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/Sessions?ActiveWithinSeconds=900. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 21:25:06.330 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 2ms. https://192.168.1.29:8920/emby/Sessions?ActiveWithinSeconds=900 2020-06-16 21:25:08.692 Debug App: SessionInfosWebSocketListener stop transmitting over websocket to 192.168.1.2 2020-06-16 21:25:08.693 Debug App: ScheduledTasksWebSocketListener stop transmitting over websocket to 192.168.1.2 2020-06-16 21:25:08.703 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/System/Configuration. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 21:25:08.704 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 1ms. https://192.168.1.29:8920/emby/System/Configuration 2020-06-16 21:25:08.723 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/System/Logs. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0 2020-06-16 21:25:08.807 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 84ms. https://192.168.1.29:8920/emby/System/Logs 2020-06-16 21:25:09.556 Info HttpServer: HTTP GET https://192.168.1.29:8920/emby/System/Logs/embyserver.txt. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0
Solution Duffyx 25 Posted June 17, 2020 Solution Posted June 17, 2020 (edited) System.UnauthorizedAccessException: System.UnauthorizedAccessException: Access to the path "/var/db/emby-server/config/users/883af2911301488dadb02054b300057c/policy.xml" is denied Its a simple permission error: please run "chown -R emby:emby /var/db/emby-server" Its funny how some are having these type of errors, the server doesn't change the ownership of the files on its own .... :-) Edited June 17, 2020 by Duffyx
Itay1778 0 Posted June 17, 2020 Author Posted June 17, 2020 44 minutes ago, Duffyx said: System.UnauthorizedAccessException: System.UnauthorizedAccessException: Access to the path "/var/db/emby-server/config/users/883af2911301488dadb02054b300057c/policy.xml" is denied Its a simple permission error: please run "chown -R emby:emby /var/db/emby-server" Its funny how some are having these type of errors, the server doesn't change the ownership of the files on its own .... Thanks!! The problem is fixed! I didn't think it would be that simple. The funny bit, I went through the log several times and didn't see it.... Thank you!!
Luke 42238 Posted June 28, 2020 Posted June 28, 2020 That's strange. Somehow the server lost write access to it's own config folder.
makarai 109 Posted July 22, 2020 Posted July 22, 2020 I am guessing he changed the uid of his emby user but forgot to change the folder ownership, he can share the output of "id emby"
