rhinology 0 Posted June 13, 2020 Posted June 13, 2020 I have OMDb plugin installed (listed in My Plugins). I can confirm data is available on OMDb by using the "Examples" section on its homepage (REST API endpoint: http://www.omdbapi.com/?i=tt1032579). Using the exact same IMDb ID from #2 to search for metadata in "Identify" dialog, no result.
ebr 16310 Posted June 13, 2020 Posted June 13, 2020 Hi. How about on tmdb? Does the item exist there? (or TVdb if this is TV)
Luke 42211 Posted June 13, 2020 Posted June 13, 2020 What metadata fetchers are enabled for the library, and in what order?
Happy2Play 9802 Posted July 20, 2020 Posted July 20, 2020 On 6/12/2020 at 11:14 PM, rhinology said: I can confirm data is available on OMDb by using the "Examples" section on its homepage (REST API endpoint: http://www.omdbapi.com/?i=tt1032579). Best guess is that is ""Type":"episode"", Are you trying to identify a episode as a movie?
