GoofyCDN 2 Posted June 12, 2020 Posted June 12, 2020 Even since the switch to the new forums, whenever I get timed out I cannot log back in with my password. The window states they username and password are required after enter them and attempt to log in. If I select Reset Password, I get the email in my inbox and can then go and change the password which then logs me in. I have even gone into my profile and account and changed the password after going through the Reset Password process when not being able to log in.
Abobader 3485 Posted June 12, 2020 Posted June 12, 2020 What time out? Are you using some kind of proxy/VPN? I did not see this problem.
GoofyCDN 2 Posted June 12, 2020 Author Posted June 12, 2020 I am not using any kind of proxy or VPN. It times out after a couple of hours I believe. Also if I close my browser and and then reopen the browser and come back it doesn't accept my password either.
Solution GoofyCDN 2 Posted June 12, 2020 Author Solution Posted June 12, 2020 I'm sorry to have bothered you guys. I feel like an idiot now. I tried with another browser and it worked. It appears that my keepass that was auto populating the credentials had a typo in my user name, but I wasn't seeing it at first. Only when I went to another browser and had to manually enter the information did I notice the issue. Thanks for the quick responses, and again my apologies for time wasted
