Carlo 4561 Posted July 27, 2020 Posted July 27, 2020 Try a test. Pick one season and rename the ISO so that the first letter of the name is a dot "." That might cause Emby to skip those files.
mickle026 653 Posted August 5, 2020 Posted August 5, 2020 On 7/27/2020 at 9:55 PM, cayars said: Are these ISO files? No The subtitles obviously extract as they are there in the cache aleady extracted to whatever format that is. They are just not in srt format or whatever format they should be. It appears that they extract but fail the ffmpreg conversion to whatever format its being converted to. Quote Output #0, srt, to 'F:\Cache\cache\subtitles\b\bdfca1b4e85246019341b3e0e6f3c018_637304442981188417_0_0_0_False.srt': Output file #0 does not contain any stream
Luke 42203 Posted August 6, 2020 Posted August 6, 2020 @mickle026 I've merged your topic into here as it's discussing the same issue. Thanks !
JshKlsn 4 Posted August 26, 2020 Posted August 26, 2020 I get this error every single day on my server. I don't know why or how to stop it. It only affects this one single movie out of over 1,000.
Carlo 4561 Posted August 26, 2020 Posted August 26, 2020 Hi, Can you attach the the Emby Server log file.
Luke 42203 Posted August 26, 2020 Posted August 26, 2020 Quote I don't know why or how to stop it. Why - you enabled subtitle downloading. How to stop it - you can disable the feature. But please attach the emby server log so that we can see what's going on. Thanks.
JshKlsn 4 Posted August 27, 2020 Posted August 27, 2020 6 hours ago, Luke said: Why - you enabled subtitle downloading. How to stop it - you can disable the feature. But please attach the emby server log so that we can see what's going on. Thanks. I want the subtitles, I don't know how to stop this error. None of my other movies or shows have this problem, and I can't see a way for me to ignore Baywatch to stop this error, or why it even exists in the first place. I've attached the log, thank you. embyserver.txt
akilds 0 Posted August 27, 2020 Posted August 27, 2020 Presently, where do I click? At the point when I click on the connection "Parasite (2019) Bluray-1080p.pt-BR.srt", nothing occurs. I can see the caption see, close to it, ordinarily. Be that as it may, to download the SRT document, no utilization. snaptube vidmate word to pdf
Carlo 4561 Posted August 27, 2020 Posted August 27, 2020 Hi, After you have downloaded the sub you should be able to choose it from the drop down OR start playing the media and you can select the subtitle while playing from the bottom menu.
JshKlsn 4 Posted August 28, 2020 Posted August 28, 2020 9 hours ago, cayars said: Hi, After you have downloaded the sub you should be able to choose it from the drop down OR start playing the media and you can select the subtitle while playing from the bottom menu. I think that's a spambot. My issue however is still persistent.
Luke 42203 Posted September 2, 2020 Posted September 2, 2020 @mbc0 can you point me to your thread about your subtitle issue? I'd like to merge this into there. Thanks.
mbc0 68 Posted September 2, 2020 Author Posted September 2, 2020 4 hours ago, Luke said: @mbc0 can you point me to your thread about your subtitle issue? I'd like to merge this into there. Thanks. Sure
sebasmiles 8 Posted September 5, 2020 Posted September 5, 2020 @Luke Was this issue ever resolved? I am having a similar issue. In my case I have the option set to store the subtitles with the media files.
Luke 42203 Posted September 12, 2020 Posted September 12, 2020 This actually is not an extraction failure, the log message is incorrect. It's a conversion failure from the txt subtitles that were downloaded trying to convert them to srt.
Luke 42203 Posted September 12, 2020 Posted September 12, 2020 @JshKlsn I'm merging your topic in with mbc0's original topic. Please follow along there. Thanks.
Luke 42203 Posted September 12, 2020 Posted September 12, 2020 15 hours ago, Luke said: It's a conversion failure from the txt subtitles that were downloaded trying to convert them to srt. We're looking into resolving this for the next release. 2
jrhessey 21 Posted January 1, 2021 Posted January 1, 2021 I'm seeing this as well on a tv series in my collection.
Luke 42203 Posted January 12, 2021 Posted January 12, 2021 On 1/1/2021 at 10:40 AM, jrhessey said: I'm seeing this as well on a tv series in my collection. We'll take another look at it. Thanks for reporting.
Luke 42203 Posted January 14, 2021 Posted January 14, 2021 I believe the remaining issues with this should be cleared up for the next release of Emby Server. Thanks.
Shibboleth 13 Posted March 10, 2021 Posted March 10, 2021 (edited) -expunged to wait for next server update- Edited March 13, 2021 by Shibboleth to remove server logs etc
Luke 42203 Posted March 10, 2021 Posted March 10, 2021 I believe these should be cleared up with the next release of the server. Thanks. 1
