cnfsel 0 Posted June 12, 2020 Posted June 12, 2020 ipad air 3 client there will be obvious color blocks when playing some videos please see the attachment for the effect and video information
awkdk 3 Posted June 14, 2020 Posted June 14, 2020 Have you tried copying the movie to the iPad and playing it directly? It may be an iPad problem.
cnfsel 0 Posted June 15, 2020 Author Posted June 15, 2020 No, using nplayer to play, whether it is through the network or copied to the local, is completely normal.
cnfsel 0 Posted June 15, 2020 Author Posted June 15, 2020 10 hours ago, awkdk said: Have you tried copying the movie to the iPad and playing it directly? It may be an iPad problem. No, using nplayer to play, whether it is through the network or copied to the local, is completely normal.
Happy2Play 9811 Posted June 15, 2020 Posted June 15, 2020 What playback method is the client using during playback? Direct, Stream, Transcode
cnfsel 0 Posted June 15, 2020 Author Posted June 15, 2020 7 hours ago, Happy2Play said: What playback method is the client using during playback? Direct, Stream, Transcode Direct
cnfsel 0 Posted June 16, 2020 Author Posted June 16, 2020 7 hours ago, Luke said: What version of iOS are you running? 13.5.1
