mickle026 653 Posted June 11, 2020 Posted June 11, 2020 (edited) I am trying to rewrite a plugin to work clientside using ajax requests to control the flow of data so , but I have a problem. Item's are not running synchronously and I think its because of the ajax (apiclient) requests are usually async. I have tried adding async = false to the api call am I am wordering if the format is correct as if I log the 'i' in the for loop, the for loop continues and stacks up the api calls that then resolve when the loop is finished. What seems to be happening is that the loop is not waiting for the api (ajax) responses and continuing. ApiClient.getJSON(ApiClient.getUrl('MyPeople/GetPeopleInfo'), async = false).then(response => { My Code so far var loopcounter = 0; var xlog = ["MyPeople Log", "Created via Emby Plugin 'My People'"]; ApiClient.GetPeopleInfo = function () { // update placeholder section document.getElementById("xGetPeopleInfo").innerHTML = "Request is running...please wait.."; document.getElementById("xGetPeopleInfo1").innerHTML = "Querying Database for number of unique people id's. This might take a few minutes."; ApiClient.getJSON(ApiClient.getUrl('MyPeople/GetPeopleIDS'), async = false).then(response => { document.getElementById("xGetPeopleInfo").innerHTML = "Completed Database Query"; document.getElementById("report1").innerHTML = "<h3>There are <b>" + response + "</b> unique People to check.</h3>"; loopcounter = response; // need this for reporting information xlog.push("There are " + response + " unique People to check."); xlog.push("------------------------------------------------------------------"); var tmp; var i; // because external counter starts at 1 insted of 0 for (i = 1; i < loopcounter + 1; i++) { document.getElementById("xGetPeopleInfo2").innerHTML = ""; xlog.push("Currently processing person " + i + " of " + loopcounter + " records"); document.getElementById("xGetPeopleInfo").innerHTML = "Currently processing person <b>" + i + "</b> of <b>" + loopcounter + "</b> records"; document.getElementById("xGetPeopleInfo1").innerHTML = ""; // gets the persons Name ApiClient.getJSON(ApiClient.getUrl('MyPeople/ProcessID'), async = false).then(response => { document.getElementById("xGetPeopleInfo1").innerHTML = "<b>Person Name: </b>" + response; console.log("Person Name:" + response.toString()); xlog.push("Person Name:" + response.toString()); }).catch(e => { console.log(e); }); // write current operation to the html ApiClient.getJSON(ApiClient.getUrl('MyPeople/CheckFile'), async = false).then(response => { if (response == "File Does Not Exist!") { xlog.push(response); document.getElementById("xGetPeopleInfo2").innerHTML = "<b>Image Url Check: </b>" + response; // Still to Do ............. // // } else { xlog.push(response); document.getElementById("xGetPeopleInfo2").innerHTML = "<b>Image Url Check: </b>" + response; } }).catch(e => { console.log(e); }); xlog.push(tmp); // remove the item from the stack ApiClient.getJSON(ApiClient.getUrl('MyPeople/RemoveID'), async = false).then(response => { document.getElementById("xGetPeopleInfo2").innerHTML = response; xlog.push(response); }).catch(e => { console.log(e); }); } }).catch(e => { console.log(e); }); } I also have another problem in that I have an array that is a global var (xlog) where I want to push entries (text) so that I can create a log on the client via a download link. I can do the log and the download link to text file part, but I am having problems pushing entries to the array. The push works, but the variable is either empty or undefined. The xlog.push' es work at the beggining of the code, its when I enter an api call they don't Can anyone shed me some light where I am doing either thing wrong? Edited June 11, 2020 by mickle026
Luke 42239 Posted June 13, 2020 Posted June 13, 2020 You're running through the for loop starting off async operations, but not waiting on them to complete before moving to the next one in the list.
