arrbee99 1836 Posted June 24, 2020 Posted June 24, 2020 Am really liking the dark theme, but It would be nice if possible if read items could be a bit more prominent - Maybe the title could be moved a little bit to the right and the 'xxxx replied to' also moved a bit right to line up with the title above it, so its easier to see the blue circle/star.
Abobader 3485 Posted June 24, 2020 Author Posted June 24, 2020 50 minutes ago, pwhodges said: has the first page made up entirely of pinned posts How about now?
miniliQuid 95 Posted June 24, 2020 Posted June 24, 2020 1 hour ago, Abobader said: It a build in with the Fluid view option. 57 minutes ago, pwhodges said: For those who haven't found the "fluid" option, here's a picture. When it's selected, you see all the unread posts in the forums selected on the right, all mixed up in time order from the most recent. The selection of forums I've made, by happy coincidence, has the first page made up entirely of pinned posts, so I've made a bookmark for the second page: Paul Thanks for the quick help both of you, that's what I needed
Happy2Play 9811 Posted June 24, 2020 Posted June 24, 2020 Looks like there needs to be some spacing added between Title and Prefix.
Abobader 3485 Posted June 24, 2020 Author Posted June 24, 2020 (edited) 6 minutes ago, Happy2Play said: Looks like there needs to be some spacing added between Title and Prefix. Where is that I should look at? Activity? Yes, Activity indeed. Edited June 24, 2020 by Abobader
pwhodges 2033 Posted June 24, 2020 Posted June 24, 2020 13 minutes ago, Abobader said: How about now? Aw! Now I've got to change my bookmark! It's better this way, though. Paul
crusher11 1143 Posted July 1, 2020 Posted July 1, 2020 One thing that bothers me with the new design is I can't tab to the post area from the thread title when starting a thread. I type in the title, hit 'tab', and it skips to the 'choose files...' link for selecting attachments instead of to the area to type my post. 1
Abobader 3485 Posted July 1, 2020 Author Posted July 1, 2020 3 hours ago, crusher11 said: One thing that bothers me with the new design is I can't tab to the post area from the thread title when starting a thread. I type in the title, hit 'tab', and it skips to the 'choose files...' link for selecting attachments instead of to the area to type my post. Can you post image about the first step.
crusher11 1143 Posted July 1, 2020 Posted July 1, 2020 You want an image of the "create a new thread" page? Because that's all I'm talking about.
Abobader 3485 Posted July 1, 2020 Author Posted July 1, 2020 Yes, since I do not see the issue you are facing.
Happy2Play 9811 Posted July 1, 2020 Posted July 1, 2020 25 minutes ago, Abobader said: Can you post image about the first step. There does not appear to be a way to tab from Title to text area. Only tested in Edge Version 83.0.478.56 1
abo-test 45 Posted July 1, 2020 Posted July 1, 2020 ah, I see what you mean now, I do not know if that from the Editor or the forum ... I report back on this. Thanks both.
crusher11 1143 Posted July 1, 2020 Posted July 1, 2020 Yes, pressing the tab key while in the "Title" field goes to the Tags and then Attachments, bypassing the post area.
ebr 16332 Posted July 1, 2020 Posted July 1, 2020 If you hit tab enough times don't you eventually end up in the main field?
Happy2Play 9811 Posted July 1, 2020 Posted July 1, 2020 4 minutes ago, ebr said: If you hit tab enough times don't you eventually end up in the main field? Don't know all the variables, but yes I had to hit tab 35 times to get to that field.
Abobader 3485 Posted July 1, 2020 Author Posted July 1, 2020 Yes, like 23 here, I looking to fix this. It work fine on the test forum, well that another build, so it must be a bug, we will see.
Abobader 3485 Posted July 1, 2020 Author Posted July 1, 2020 Sorry to say, this we can not do any thing about for this build, when we upgrade this will be fix.
Painkiller88 250 Posted July 1, 2020 Posted July 1, 2020 1 hour ago, Abobader said: Sorry to say, this we can not do any thing about for this build, when we upgrade this will be fix. maybe you can find a way to change the tabindex manually (don't know if this board software is open source)
Abobader 3485 Posted July 2, 2020 Author Posted July 2, 2020 Testing table ... One item 2 Items One Two Tow @softworkz As old request .. 1
sooty234 266 Posted July 4, 2020 Posted July 4, 2020 How do you insert pictures in a post? Any pictures I use just attach to the end of the post. What am I missing?
Abobader 3485 Posted July 4, 2020 Author Posted July 4, 2020 1 minute ago, sooty234 said: How do you insert pictures in a post? Any pictures I use just attach to the end of the post. What am I missing? Simply drag and drop image, that all. 1
EZEd 60 Posted July 9, 2020 Posted July 9, 2020 I created duplicate "Custom Streams" under My Activity Stream how do I get rid of the dupes?
ebr 16332 Posted July 9, 2020 Posted July 9, 2020 9 hours ago, EZEd said: I created duplicate "Custom Streams" under My Activity Stream how do I get rid of the dupes? 1
