Abobader 3485 Posted August 18, 2020 Author Posted August 18, 2020 Regarding the split did not test the mod action notify on it yet, I think you guys open here a thread and let like 2 or 3 members posts, then split and see if it notify. Regarding the "Split": First post will be the new OP of the new thread as you all know, and will not have followers from the thread it split from, as it become new thread.
Carlo 4561 Posted August 18, 2020 Posted August 18, 2020 (edited) Could a few people makes a couple posts. Anyone know and moderator jokes. Edited August 18, 2020 by cayars
softworkz 5133 Posted August 18, 2020 Posted August 18, 2020 I have received the following message: 9 hours ago, ebr said: Hello, We're informing you, moderator ebr performed the following action on the content added by you: Split a topic to Test topic for testing thread splits (2) from Test topic for testing thread splits.. A bus that is occupied by ten people stops at a bus stop. Eleven people get out. Three scientists comment on the event. The biologist: "They must have multiplied along the way." The physicist: "What the heck, ten perce Regards, Emby Community
Happy2Play 9811 Posted August 18, 2020 Posted August 18, 2020 Good to know all posters that get split, get notified. Not a big deal but the new topic has no follower.
softworkz 5133 Posted August 18, 2020 Posted August 18, 2020 Could you post something in the split out topic?
softworkz 5133 Posted August 19, 2020 Posted August 19, 2020 OK, so I didn't get notifications about posts in the new topic, but I'm not the OP. @Gilgamesh_48 - Did you get notifications about the new posts in the ....(2) topic?
Happy2Play 9811 Posted August 19, 2020 Posted August 19, 2020 I would think no one got notified as the only follower is cayars do to his setting of auto follow everything he post in.
Gilgamesh_48 1243 Posted August 19, 2020 Posted August 19, 2020 24 minutes ago, softworkz said: OK, so I didn't get notifications about posts in the new topic, but I'm not the OP. @Gilgamesh_48 - Did you get notifications about the new posts in the ....(2) topic? I did not and I would not expect to because I have set notifications off for that sort of thing. I only want to be notified for direct replies to me or direct messages or the like. I do not want to be notified for simple replies to treads I start or post in. When one of my posts gets moved, like it did here for testing, I want a notification like I received but generally I do not want to be notified for most things.
Abobader 3485 Posted August 19, 2020 Author Posted August 19, 2020 On 18/08/2020 at 03:50, Abobader said: Regarding the "Split": First post will be the new OP of the new thread as you all know, and will not have followers from the thread it split from, as it become new thread.
PenkethBoy 2068 Posted September 3, 2020 Posted September 3, 2020 @Abobader Just had an issue i was "quoting" a post from the second to last page - so end up at the bottom of that page when i hit save - nothing appears to happen - i.e. i did not get jumped/moved to the last page/end of thread this resulted in four duplicate posts - as i hit save four times - before i figured out that it had actually worked It might be related to the fact that the post i quoted was the last post in the second to last page - if that helps track it down
pwhodges 2033 Posted September 3, 2020 Posted September 3, 2020 I have had exactly that (just yesterday in fact) - I simply had not yet worked out the circumstances to report, but quoting a post near the end of the penultimate page was definitely in common. Paul 1
arrbee99 1836 Posted September 4, 2020 Posted September 4, 2020 Didn't post numbers get added a while ago, as they seem to have disappeared.
Happy2Play 9811 Posted September 4, 2020 Posted September 4, 2020 3 minutes ago, arrbee99 said: Didn't post numbers get added a while ago, as they seem to have disappeared. 1 1
arrbee99 1836 Posted September 4, 2020 Posted September 4, 2020 Buggeration. Its really handy. Sad face...
Carlo 4561 Posted September 4, 2020 Posted September 4, 2020 Not sure what the reason was specifically but I noticed a lot of duplicate numbers (one # per person who posted). 1
Abobader 3485 Posted September 5, 2020 Author Posted September 5, 2020 On 03/09/2020 at 19:26, PenkethBoy said: @Abobader Just had an issue i was "quoting" a post from the second to last page - so end up at the bottom of that page when i hit save - nothing appears to happen - i.e. i did not get jumped/moved to the last page/end of thread this resulted in four duplicate posts - as i hit save four times - before i figured out that it had actually worked It might be related to the fact that the post i quoted was the last post in the second to last page - if that helps track it down On 03/09/2020 at 20:30, pwhodges said: I have had exactly that (just yesterday in fact) - I simply had not yet worked out the circumstances to report, but quoting a post near the end of the penultimate page was definitely in common. Paul Good day, I recall it been reported before, dose this happens often or when it like late on time for USA (since we have task for DB backup that may case of this issue)? My best
Happy2Play 9811 Posted September 5, 2020 Posted September 5, 2020 (edited) 10 minutes ago, Abobader said: Good day, I recall it been reported before, dose this happens often or when it like late on time for USA (since we have task for DB backup that may case of this issue)? My best PenkethBoy's issue happened not long before the report here. (9/3/2020 at 9:26 AM) I deleted the post before this time. They are in deleted content panel "Problem transcoding when source file is h.265" Edited September 5, 2020 by Happy2Play
pwhodges 2033 Posted September 5, 2020 Posted September 5, 2020 This and the next post are my most recent occurrence (my time is BST). It's not an unusual time for me to be posting. Paul
PenkethBoy 2068 Posted September 5, 2020 Posted September 5, 2020 11 hours ago, Abobader said: Good day, I recall it been reported before, dose this happens often or when it like late on time for USA (since we have task for DB backup that may case of this issue)? My best Hi - nope dont think so for me - as i posted above in the early evening UK time - at 17:30 BST a few minutes after it happened I doubt very much it has anything to do with a backup Smells of a coding error/omission
Abobader 3485 Posted September 5, 2020 Author Posted September 5, 2020 Thanks all. Just want to be sure, what theme you using as well the web browser at the time you facing this, I just want to be sure for one thing. @PenkethBoy @pwhodges
PenkethBoy 2068 Posted September 5, 2020 Posted September 5, 2020 theme dark, chrome 85 official build
pwhodges 2033 Posted September 5, 2020 Posted September 5, 2020 Default theme (light, I suppose). Opera 70. Paul
Abobader 3485 Posted September 5, 2020 Author Posted September 5, 2020 Thanks. I will look to this tonight. Also, since we will update the forum software soon and the Dark theme will not work on the new forum build, I will disable it tonight while I test for the above issue. Sure I will bring another dark theme for whom want that. Thanks for the reporting the issue guys, well done. 1
arrbee99 1836 Posted September 5, 2020 Posted September 5, 2020 + 1 from Dark Theme fan. Don't worry, I'll remind you if you forget
