jscoys 147 Posted July 13, 2014 Posted July 13, 2014 Hi, I don't know if it's the good section, but seems to be an Iphone/IPad problem with the webaccess from the server... As you can see on this video : https://www.youtube.com/watch?v=azm31ap2Y4s, there is a problem on Ipad and iphone when we want to change resolution or bitrate. It seems that the panel is actually in the foreground and can't be clicked. I don't thing it's only a problem on my IOS devices, but maybe someone could confirm that the issue is reproducible elsewhere.
Luke 42241 Posted July 13, 2014 Posted July 13, 2014 Once the current beta is moved to the stable channel it will be resolved. 1
jscoys 147 Posted July 13, 2014 Author Posted July 13, 2014 Yeah thank you I know. But with this app I have an other problem when you play movies with low bitrates (650kbps) as you can see there : http://youtu.be/VYijlE9Ez5c Sent from my iPad using Tapatalk
kreeturez 27 Posted July 15, 2014 Posted July 15, 2014 Yeah thank you I know. But with this app I have an other problem when you play movies with low bitrates (650kbps) as you can see there : http://youtu.be/VYijlE9Ez5c I get the feeling that you might experience that same kind of artifacting even in the web client at such a low bitrates... Perhaps try that same video at the lowest quality on a PC to be sure?
jscoys 147 Posted July 17, 2014 Author Posted July 17, 2014 Alas no... Check my thread here : http://mediabrowser.tv/community/index.php?/topic/8720-video-playback-problem-with-last-mediabrowser-ipad-app-version/ To Luke : with the latest beta released, all works like a charm! Thank you!
