Rapid TV 0 Posted June 11, 2020 Posted June 11, 2020 Hi, I need some help, whatever appears to have happened with your update last night all of my Emby users are showing Pin numbers on there screen this morning, at least a large majority of them and more are messaging me daily. I looked on my panel and the server is still showing over 480 Devices as I have a 500 Premiere Licence key but even though they are all valid on my server why is it the users are having to repin their devices, is this a glitch or something to do with whatever changes you made in the backend. On a separate note can an Emby Premiere key be used on more than one Emby server? For example could I upgrade to a 1,000 Licence device limit and use the premiere key on more than one server or is a Premiere key only allowed on one Emby server max? Thanks
ebr 16339 Posted June 13, 2020 Posted June 13, 2020 Hi. Some of the changes we made may require some people to re-login but that is all that should be required. There should be no impact on your license or device count. Did this get cleared up for you?
ebr 16339 Posted June 13, 2020 Posted June 13, 2020 On 6/11/2020 at 10:28 AM, Rapid TV said: On a separate note can an Emby Premiere key be used on more than one Emby server? Yes but the limit applies to the key, not the server. Is there a limit to Emby Premiere
