Townsey 1 Posted June 9, 2020 Posted June 9, 2020 Running FreeNas lastest Version: FreeNAS-11.3-U3.2 Thats working fine have update the Jail via the Update button and that renewed the jail and replaced a couple of things. So I am happy that FreeNas is running fine. Emby is on 4.4.2.0 and appears to have no glitches and appears to do everything as normal. There is just one problem, I have very few films that have multi versions and in the past Emby has dealt with those in the way described in Folder Naming on the WiKI. So I have this new folder and have set it up in the way "I think" it should be, tell me if I am wrong. I use what is termed as a Complex Folder Structure so my naming in this case is as follows Films/ G/Gandhi (1982)/ Gandhi (1982) Gandhi (1982) - 720p Bluray H264.mp4 Gandhi (1982) Gandhi (1982) - 720p Bluray H264.srt Gandhi (1982) Gandhi (1982) - DVD cd1.avi Gandhi (1982) Gandhi (1982) - DVD cd2.avi Gandhi (1982) Gandhi (1982) - DVD cd3.avi When looking at the library after a re-scan there are two items listed with the same thumb nail pointing to each version. The way it used to work before is one thumb nail and a drop down menu in the description page allowing you to chose what version you would like to view. Attached is an extract of the log file at the time of the update to the Gandhi file. Any pointers please? Regards Townsey Emby Log Extract.txt
Luke 42238 Posted June 9, 2020 Posted June 9, 2020 Hi, there's a good chance this will be resolved as soon as the 4.4.3 update is available for FreeNAS. Thanks for the feedback.
Townsey 1 Posted June 9, 2020 Author Posted June 9, 2020 Ok Luke so there is an issue and its not my setup at fault, correct?
Luke 42238 Posted June 9, 2020 Posted June 9, 2020 Correct, although granted this example is a bit of a complex one, mixing both multi-part and multi-version.
Townsey 1 Posted June 9, 2020 Author Posted June 9, 2020 Correct, although granted this example is a bit of a complex one, mixing both multi-part and multi-version.
