702enigma 0 Posted June 9, 2020 Posted June 9, 2020 I have the DVD version of Dragonball Kai and have DVD order selected as metadata choice. my format goes as follows I have a folder titled with the seasons and episodes within them like this. Season 1S01E01 S01E02 My issue is some are being moved to different seasons and when i go to the file and edit the metadata just for that file it shows the correct season number and episode but it places it into the wrong season. For instance this is season 2 and near the end of the season it shows episode 3 of of season five there And here you can see the metadata is correct and shows the correct season and episodes but still shows up in season 2
702enigma 0 Posted June 10, 2020 Author Posted June 10, 2020 Also I just noticed the files that are in the wrong season folder are showing up in the correct season folder as well so i dont know why its showing it in two location even
Happy2Play 9802 Posted June 10, 2020 Posted June 10, 2020 Minus me testing this series, my best guess is that order only appears on TVDB website and can not be pulled from their API. If that is the case there is nothing we can do until TVDB releases v4 of their api as discussed on their forum and other DVD order topics on our forum. What providers do you have enable and what order do you have them in? As TVDB and TMDB appear to provide different information. S05E03 are different in each site.
702enigma 0 Posted June 10, 2020 Author Posted June 10, 2020 (edited) I have all default providers enabled and regardless of which i choose it does the same thing so I guess im just waiting for the new api......is there a manual way of correcting this? Edited June 10, 2020 by 702enigma
