Hi Guys,
Is there a reason this has happened, and is there a setting to enforce posters are used as thumbnails for all?
If i delete and keep other artwork downloads turned off will the display revert back to poster.jpg?
Will that then interfere with the backdrops?
Thanks.
EDIT;
Library scan has just finished and has reverted thumbs back to their respective poster.jpg images.
Edited by Wobzy
HI there, are you all set now?
