Chalklands 27 Posted June 7, 2020 Posted June 7, 2020 Hi, I'm using the firestick app. On the home screen I have the background set to blue radiance. which stays the same when I highlight Movies, TV Shows. and Trailers However when I highlight Music the background changes randomly to one of two of my own pictures. Is there a setting to change that anywhere? Thanks
Solution ebr 16338 Posted June 7, 2020 Solution Posted June 7, 2020 Hi. Yes, disable the option to "Show backdrop while browsing". This is off by default so you must have turned it on at some point. Please let us know if this solves your issue. Thanks. 1
Chalklands 27 Posted June 7, 2020 Author Posted June 7, 2020 (edited) Thanks, so I did. Another question though. If this option is enabled, why was it only showing backdrops for music and not movies etc. Also where are these backdrops coming from? Edited June 7, 2020 by Chalklands
