Bakers 1 Posted June 5, 2020 Posted June 5, 2020 Just in case anyone is having a similar problem I installed the AMDGPU-PRO driver (20.10) on my Ubuntu server 18.04 installation. I found after a reboot that I had no hardware encoding anymore. Checking the logs said that there was an error "Opperation not permitted" with an error on accessing "/dev/dri/renderD128" The solution I found was to enable all users to access the render device. The permissions on "/dev/dri/renderD128" was 660. I changed it to 666 and now emby is detecting and properly hardware transcoding once again. simple command to execute: sudo chmod a+rw /dev/dri/renderD128
Bakers 1 Posted June 5, 2020 Author Posted June 5, 2020 Actually this is only a temporary fix, on a system reboot the permissions are reset and emby no longer can access the render driver. Here is the corrected permissions which work (after restarting only emby): ls -al /dev/dri/renderD128 crw-rw-rw-+ 1 root video 226, 128 Jun 5 03:37 /dev/dri/renderD128 The user Emby is a member of the group video so it should have access to this driver, but for some reason it does not. Is there a configuration setting I am missing somewhere to make this function correctly?
Bakers 1 Posted June 5, 2020 Author Posted June 5, 2020 BAZINGA!! I figured this out. There was a typo in my /etc/group file on the video line. Because of the typo, emby was not a member of the video group and thus did not have access to the hardware encoder driver. I corrected and after a reboot all is well. I was able to confirm with the following commands: $ members video emby $ groups emby emby : emby video If emby is not in the video group, it will not have proper access to the driver for VAAPI transcoding. This is a strange problem as the hardware encoding was working for months before this happened, I don't know why the system ignored the typo until now, but at least all is right with my emby server world once again.
Luke 42246 Posted June 5, 2020 Posted June 5, 2020 Hi, are you using our Ubuntu package, or our Docker container?
Bakers 1 Posted June 8, 2020 Author Posted June 8, 2020 Hi, are you using our Ubuntu package, or our Docker container? I use the Ubuntu package running on 18.04.
Luke 42246 Posted June 8, 2020 Posted June 8, 2020 @@cayars can make sure this is in the hardware acceleration setup guide. Thanks.
Carlo 4561 Posted June 8, 2020 Posted June 8, 2020 This is already included in our Knowledge Base article of how to setup Linux for Emby use with hardware Transcoding if you don't skip steps. https://support.emby.media/support/solutions/articles/44001160207-hardware-acceleration-on-linux There is a section of things needed to be done: Required Setup StepsThe steps for installing the Intel Media SDK may vary depending on your actual system. Please follow the instructions appropriate for your actual setup which you can find here: Getting Started Guide <-- specific instructions for add user to video group in this doc. Generic Installation for Intel® Media Server Studio Generic Linux* Intel® Media Server Studio Installation System Analyzer Utility for Linux In the Getting Started doc is: "Prerequisite Steps Add the user(s) who will run Intel® Media Server Studio – SDK applications to the video group $ usermod -a -G video [LOGIN]" 1
