negativzeroe 80 Posted June 4, 2020 Posted June 4, 2020 (edited) Is there a way to select a whole season or show and split versions apart en masse? And keep persistent across the show. Also, can I set only certain seasons to refresh images based on screen grab? Sent from my ONEPLUS A5000 using Tapatalk Edited June 5, 2020 by negativzeroe
Luke 42212 Posted June 5, 2020 Posted June 5, 2020 Hi, there currently is not. Are you trying to split episodes?
negativzeroe 80 Posted June 5, 2020 Author Posted June 5, 2020 (edited) I'm trying to split versions. Here is an example. Dragon Ball Z Dragon box has 7 volumes of the 291 episodes, Blu Ray has 9 volumes that match the seasons per tvdb. I have the box art scanned for the 7 volumes and under the series folder I have: Vol 1 [Dragon Box] Vol 1 [blu-Ray] etc. I'm organizing the dragon boxes so that they match what is actually in those boxes, so like S02E01 would be in vol 1, and this isn't a problem because when I name it properly, it pulls the metadata properly. If I go into each episode and select split versions apart, it does so and I can go into the blu ray volume to watch that version and the dragon box volume to watch that version - rather than going into the dragon box version and having it select the blu ray by default.I was just hoping I could select a season and order all episodes to split from their respective versions or set the show to not combine in the first place. The existing functionality does what I want, I just have to go into each of the 291 episodes to do it which is arduous.Edit, this would also solve my yugioh problem from before I think lol. Edited June 5, 2020 by negativzeroe
negativzeroe 80 Posted June 9, 2020 Author Posted June 9, 2020 @@Luke requesting this for a future update, just something simple like "ignore for this series" or something. Screenshot for example (These are all different actual sets).
Luke 42212 Posted June 9, 2020 Posted June 9, 2020 What you could also just do is disable the series folder grouping feature for the entire library.
negativzeroe 80 Posted June 9, 2020 Author Posted June 9, 2020 What you could also just do is disable the series folder grouping feature for the entire library. I'm finding this setting, and it's already disabled, other than that I'm not sure what you're referring to.
Luke 42212 Posted June 9, 2020 Posted June 9, 2020 Then I'm not quite sure what we're discussing here. Is it all one series folder?
negativzeroe 80 Posted June 22, 2020 Author Posted June 22, 2020 On 6/9/2020 at 1:33 PM, Luke said: Then I'm not quite sure what we're discussing here. Is it all one series folder? See screenshot in post 4. So I have three different versions of 1x01. If I want to separate them under what folder they are in, I can go into that episode and there is an option near the media info that says "Split Versions Apart" So now each version is only accessible in its own folder. What I'm asking for is the ability to go to the series view, then select the season folders and split all therein. If I do this one-by-one it does not stay persistent if I move anything around.
