revengineer 142 Posted June 2, 2020 Posted June 2, 2020 I encountered an issue with the TV guide in firefox browser with v4.4.3. When going to the guide and moving a few days ahead and then start scrolling the guide, the channel logos are missing. See screenshot below.
Robert X. Gonzalez 4 Posted June 3, 2020 Posted June 3, 2020 Agree. In addition, I can no longer scroll to the LEFT or the RIGHT as I used too. This I like doing to check in advance that day or two for particular episodes or movies I might want to record. It is locked in place for three hour segments.
revengineer 142 Posted June 3, 2020 Author Posted June 3, 2020 (edited) Seems to work fine on current Chrome. So from a sample of 2, the answer is yes, Firefox only. Edited June 3, 2020 by revengineer
Robert X. Gonzalez 4 Posted June 3, 2020 Posted June 3, 2020 Luke, I took a look at the bottom of the Guide, the scrolling can be done there. I just noticed it...did not realize that and was still looking for it at the top of the guide listings.
revengineer 142 Posted June 3, 2020 Author Posted June 3, 2020 Luke, I took a look at the bottom of the Guide, the scrolling can be done there. I just noticed it...did not realize that and was still looking for it at the top of the guide listings. Yes, I could not confirm your issue, scroll bar just changed location. But the issue with the channel logo is real and repeatable.
revengineer 142 Posted June 6, 2020 Author Posted June 6, 2020 @@Luke Were you able to reproduce this bug?
revengineer 142 Posted July 17, 2020 Author Posted July 17, 2020 I just installed the latest beta v4.5.0.14 and find that this is still an issue. This bug makes Firefox unusable for use with scheduling future live TV recordings. I find is sufficiently severe that a point release is warranted. Since this is apparently not happening please make sure that this get fixed for the next major release. Thank you.
Carlo 4561 Posted July 17, 2020 Posted July 17, 2020 I just tried this in firefox and for me it works the same in firefox as it does in chrome. The first column doesn't scroll but stays there with the logos.
revengineer 142 Posted July 18, 2020 Author Posted July 18, 2020 To reproduce, you need to load the guide, then select a day that is a fews days ahead, and THEN SCROLL DOWN. The logos are fine if you do not scroll down but scrolling is needed if you have many channels. I verified that this issue still exists using latest firefox on two different machines. @Luke previously acknowledged the problem. The problem still exists.
revengineer 142 Posted July 18, 2020 Author Posted July 18, 2020 Just tried a third machine in my household. Same issue. So I am not crazy.
Carlo 4561 Posted July 18, 2020 Posted July 18, 2020 58 minutes ago, revengineer said: Just tried a third machine in my household. Same issue. So I am not crazy. Did we rule that out already. LOL 1
revengineer 142 Posted July 19, 2020 Author Posted July 19, 2020 Yes, running the latest version: 78.0.2
revengineer 142 Posted September 23, 2020 Author Posted September 23, 2020 Same issue on 4.5.0.50. Firefox is now version 81.0 (most current at time of this posting). What's going on?
Luke 42244 Posted September 23, 2020 Posted September 23, 2020 I can reproduce this. It's an issue in Firefox's implementation of sticky positioning. Finding a workaround will potentially require reworking a fair amount of the guide so that's why I just haven't gotten to it yet.
revengineer 142 Posted September 23, 2020 Author Posted September 23, 2020 Thanks for confirming Luke. I understand it's about priorities. As long as it is on your radar and in the bug list, let's leave it at that. Keep up the good work! 1
Luke 42244 Posted October 22, 2020 Posted October 22, 2020 I think I found a hack to work around this. 1
