nunu22 2 Posted June 2, 2020 Posted June 2, 2020 Hello everybody, i'am making some tests with LiveTV & HDHOMRUN (Dual tuner) The test case is as following: 1 multipex with multiple channels ( CH1 - CH2 - CH3 etc... ) start a recording on CH1 & CH2 1) the 2 HDHOMERUN leds (which indicate that tuner is busy) are ON. 2) i can watch CH1 & CH2 during recording 3) i can't read CH3 during CH1 & CH2 recoding. So it seems that emby is not able to optimize correctly HW ressources => the use of a single tuner for all channels that are in the multiplex. 1) only one led should be ON (only one multiplex used) 2) OK 3) CH3 should be able to be played, on same HDHOMERUN tuner same CH1 & CH2. I know that tvheadend is able to do so. Is it expected behaviour ? or any planned improvement ? regards
Luke 42244 Posted June 4, 2020 Posted June 4, 2020 Hi there, yes we plan on supporting multi-plex in future updates. thanks for the feedback.
nunu22 2 Posted June 4, 2020 Author Posted June 4, 2020 Thanks for your answer. Is there any date ? (this year, next year etc...) ?
