Alan1234 0 Posted June 2, 2020 Posted June 2, 2020 Hi, I receive the Internal Error 500 when I try to change the password to a user using a generate api key (Advance -> Api Key). Instead when I use the Api key that swagger use I don't have problems. I can use the swagger's api key, but it changes every 2 days. Anyone has a solution? Thanks
PenkethBoy 2068 Posted June 2, 2020 Posted June 2, 2020 use the /user/authenticatebyname end point returns an access token - use this instead of the apikey generated via the UI Swagger is only for testing not production - hence why the key changes
Alan1234 0 Posted June 2, 2020 Author Posted June 2, 2020 (edited) When I try to generate it, I receive the error "Value cannot be null. (Parameter 'appName')" What is wrong? Edited June 2, 2020 by Alan1234
PenkethBoy 2068 Posted June 2, 2020 Posted June 2, 2020 did you fill in the headers and body thats needed along with admin username and password
ebr 16333 Posted June 2, 2020 Posted June 2, 2020 See the section on Authentication (as well as the other general API usage): https://github.com/MediaBrowser/Emby/wiki
Alan1234 0 Posted June 2, 2020 Author Posted June 2, 2020 (edited) did you fill in the headers and body thats needed along with admin username and password Yes sure My question is: Why the api that I generate doesn't work? Edited June 2, 2020 by Alan1234
Alan1234 0 Posted June 2, 2020 Author Posted June 2, 2020 Emby UserId="(guid)", Client="(string)", Device="(string)", DeviceId="(string)", Version="string", Token="(string)" This is the appName? I can't understand. If yes, what I need to put in "Token" and "Version"?
Solution PenkethBoy 2068 Posted June 2, 2020 Solution Posted June 2, 2020 put this in the text box Emby Client="Login-testing", Device="testing", DeviceId="4567", Version="1234" add your admin user and password below that and it will work 1
Alan1234 0 Posted June 2, 2020 Author Posted June 2, 2020 Yep, I have fix it, thanks to all. The error was that i put "Authorization=Emby Client="Login-testing", Device="testing", DeviceId="4567", Version="1234" " instead of "Emby Client="Login-testing", Device="testing", DeviceId="4567", Version="1234" " I hope that this will help others too!!
PenkethBoy 2068 Posted June 2, 2020 Posted June 2, 2020 becasue swagger adds the authorization to your string but in your code you need to add that yourself
