csimmons222 1 Posted June 2, 2020 Posted June 2, 2020 I am trying to setup Emby Server to run inside a Docker on my unRAID server. When I attempt to play back any video, I receive the following error: "No compatible streams are currently available. Please try again later or contact your system administrator for details." I was running Emby inside a Windows Server VM with no problems so I am a bit stumped on why I cannot get this to work on my unRAID server. Any help would be greatly appreciated. Attached are the log files. embyserver.txt hardware_detection-63726696441.txt embyserver-63726696420.txt
Luke 42246 Posted June 8, 2020 Posted June 8, 2020 Hi @@csimmons222 did you setup your emby server libraries using windows share paths?
Happy2Play 9814 Posted June 8, 2020 Posted June 8, 2020 I would say a issue with the paths used. 2020-06-02 01:25:09.041 Info LibraryMonitor: Skipping realtime monitor for smb://sim-unraid-01/Movies/Blu-Ray because the path does not exist 2020-06-02 01:25:09.067 Info LibraryMonitor: Skipping realtime monitor for smb://sim-unraid-01/Movies/Download because the path does not exist 2020-06-02 01:25:09.096 Info LibraryMonitor: Skipping realtime monitor for smb://sim-unraid-01/Television Shows because the path does not exist
Luke 42246 Posted June 9, 2020 Posted June 9, 2020 In any event, my suggestion is rather than add the windows paths to emby library setup, instead mount the network paths to a local path using the docker container. Then add those local paths to emby server. Please see if that helps. Thanks.
