PdroLucas 0 Posted June 1, 2020 Posted June 1, 2020 Meu conteúdo é em MKV e está muito pesado no servidor e então gostaria de converter para MP4. Possuo Emby Premiere, mas gostaria de saber, como converter todo o conteúdo de uma vez só. -- My content is in MKV and is very heavy on the server and then I would like to convert it to MP4. I have Emby Premiere, but I would like to know, how to convert all the content at once.
Luke 42239 Posted June 2, 2020 Posted June 2, 2020 Hi, you can try using the convert feature on a parent folder, and use the mobile conversion profile to convert to mp4. Please let us know if this helps. Thanks.
PdroLucas 0 Posted June 2, 2020 Author Posted June 2, 2020 Hi, you can try using the convert feature on a parent folder, and use the mobile conversion profile to convert to mp4. Please let us know if this helps. Thanks. Eu comprei o Emby Premiere para converter e me arrependi, pois a conversão é MUITO lenta. Vai demorar muitos e muitos dias para converter todo o conteúdo. -- I bought Emby Premiere to convert and I regretted that the conversion is VERY slow. It will take many, many days to convert all the content.
Luke 42239 Posted June 2, 2020 Posted June 2, 2020 It will go as fast as your machine is capable of converting it.
