nurgemedia 7 Posted May 30, 2020 Posted May 30, 2020 (edited) Hi,I have not been able to update my added plugins or get the catalog to load, infinite loader animation.The server (DS918+, DSM 6.2.3-25426) has been powercyled and the latest 4.4.3.0 Emby update is applied. Emby has been restarted multiple times as well.The dashboard shows this error: Error: TrustFailure (Authentication failed, see inner exception.) at Emby.Server.Implementations.HttpClientManager.HttpClientManager.SendAsyncInternal (MediaBrowser.Common.Net.HttpRequestOptions options, System.String httpMethod) [0x00858] in <4b2b35e458474e708c04b3533f59ad82>:0 at Emby.Server.Implementations.HttpClientManager.HttpClientManager.SendAsync (MediaBrowser.Common.Net.HttpRequestOptions options, System.String httpMethod) [0x0009e] in <4b2b35e458474e708c04b3533f59ad82>:0 at Emby.Server.Implementations.Updates.InstallationManager.GetAvailablePackagesWithoutRegistrationInfo (System.Boolean enableCache, System.Threading.CancellationToken cancellationToken) [0x000da] in <4b2b35e458474e708c04b3533f59ad82>:0 at Emby.Server.Implementations.Updates.InstallationManager.GetAvailablePluginUpdates (System.Version applicationVersion, System.Threading.CancellationToken cancellationToken) [0x000a6] in <4b2b35e458474e708c04b3533f59ad82>:0 at Emby.Server.Implementations.ScheduledTasks.PluginUpdateTask.Execute (System.Threading.CancellationToken cancellationToken, System.IProgress`1[T] progress) [0x000a0] in <4b2b35e458474e708c04b3533f59ad82>:0 at Emby.Server.Implementations.ScheduledTasks.ScheduledTaskWorker.ExecuteInternal (MediaBrowser.Model.Tasks.TaskOptions options) [0x00195] in <4b2b35e458474e708c04b3533f59ad82>:0 And I have attached the most current server log.Any help would be greatly appreciated.Thanks! embyserver.txt Edited May 30, 2020 by nurgemedia 1
Seger 123 Posted May 30, 2020 Posted May 30, 2020 (edited) @@Luke @@FrostByte @@solabc16 can confirm it! Setting rights again via SSH or the DSM mask has not changed anything. I think it needs a hotfix, or is something offline right now? Regards, Seger Edited May 30, 2020 by Seger 2
Seger 123 Posted May 30, 2020 Posted May 30, 2020 (edited) Ssl error:1000007d:SSL routines:OPENSSL_internal:CERTIFICATE_VERIFY_FAILED Edited June 12, 2020 by Seger
Frostbach 0 Posted May 30, 2020 Posted May 30, 2020 I'm seeing this on a FreeNAS jail install as well. After digging into it a bit I think it is related to this CA Root expiring: https://support.sectigo.com/articles/Knowledge/Sectigo-AddTrust-External-CA-Root-Expiring-May-30-2020 I'm not sure what needs to be done to fix it, though.
Luke 42243 Posted May 30, 2020 Posted May 30, 2020 Yes we're looking into this. Thanks for reporting. 1
DJIemby 8 Posted May 30, 2020 Posted May 30, 2020 Thanks for looking into it Luke. Same situation on Xpenology Server just updated to 4.4.3.0.
DarWun 357 Posted May 30, 2020 Posted May 30, 2020 (edited) Yes we're looking into this. Thanks for reporting. Thanks @@Luke. I just came here to report the same thing. According to the alerts on the Emby dashboard, the plugin download failures started around 12hours ago on my Synology DS 918+ NAS. I'm not seeing the same alerts on my Windows 10 Emby server. Edited May 30, 2020 by DarWun
mythodeia 2 Posted May 30, 2020 Posted May 30, 2020 same here on a Synology DS118. everything was working until suddenly i got alerts of plugin update failures and the plugin catalog does not load
nurgemedia 7 Posted May 31, 2020 Author Posted May 31, 2020 Yes we're looking into this. Thanks for reporting. Thank you @@Luke!
Solution bigjohn 754 Posted May 31, 2020 Solution Posted May 31, 2020 Please try loading the plugin catalog again and updating plugins, I think I've got this issue resolved. 3
Seger 123 Posted May 31, 2020 Posted May 31, 2020 Yes we're looking into this. Thanks for reporting. Hey @@Luke, can confirm the clean loading of the certificate! Great and beautiful Pentecost! Seger
DarWun 357 Posted May 31, 2020 Posted May 31, 2020 It's been fixed for me too. Thanks for the quick fix! 1
FrancoisB 0 Posted June 1, 2020 Posted June 1, 2020 (edited) Hello, I am unable to refresh the plugin catalog. My DS411 has been rebooted several times, and emby app restarted several times as well. I even deleted the cache via SSH. I am at a loss understanding what is going wrong I run Emby 4.4.3.0 on DSM 6.2.3-25426 embyserver.txt Edited June 1, 2020 by FrancoisB
amstelgr 0 Posted June 1, 2020 Posted June 1, 2020 (edited) Hi, you can fix that with me too. What do you need from me. Have the same problem for 1 month. Edited June 1, 2020 by amstelgr
nurgemedia 7 Posted June 1, 2020 Author Posted June 1, 2020 Please try loading the plugin catalog again and updating plugins, I think I've got this issue resolved. Confirmed everything is back to normal. Thank you @@bigjohn! 1
FrancoisB 0 Posted June 2, 2020 Posted June 2, 2020 Hello, I am unable to refresh the plugin catalog. My DS411 has been rebooted several times, and emby app restarted several times as well. I even deleted the cache via SSH. I am at a loss understanding what is going wrong I run Emby 4.4.3.0 on DSM 6.2.3-25426 I tried it all, with firewall off, no SSL, directly opened to the internet: no change. So I've been toying with mono via ssh. I think that what is the source of my issues. I am trying to refresh the cert chain and this is what I got. All mono commands I tried crashed the same way (cert-sync, certmgr) Example: YYYY@DiskStation:/var/packages/EmbyServer/target/mono/bin$ sudo ./certmgr -ssl -m https://video.XXXX.me Mono Certificate Manager - version 6.8.0.105 Manage X.509 certificates and CRL from stores. Copyright 2002, 2003 Motus Technologies. Copyright 2004-2008 Novell. BSD licensed. r4_conv_to_r8 R47 <- R44 * Assertion: should not be reached at decompose.c:1896 ================================================================= Native Crash Reporting ================================================================= Got a SIGABRT while executing native code. This usually indicates a fatal error in the mono runtime or one of the native libraries used by your application. ================================================================= ================================================================= Native stacktrace: ================================================================= (No frames) ================================================================= Telemetry Dumper: ================================================================= Pkilling 0x405fb440 from 0x40022c40 Could not exec mono-hang-watchdog, expected on path '/volume4/@appstore/EmbyServer/3rdparty/mono/6.8.0.105/etc/../bin/mono-hang-watchdog' (errno 8) Entering thread summarizer pause from 0x40022c40 Finished thread summarizer pause from 0x40022c40. Waiting for dumping threads to resume ================================================================= External Debugger Dump: ================================================================= mono_gdb_render_native_backtraces not supported on this platform, unable to find gdb or lldb ================================================================= Basic Fault Address Reporting ================================================================= Memory around native instruction pointer (0x4030a008):0x40309ff8 00 10 a0 e1 58 04 03 e5 43 7f a0 e3 00 00 00 ef ....X...C....... 0x4030a008 01 0a 70 e3 00 30 a0 e1 08 00 00 8a 03 00 a0 e1 ..p..0.......... 0x4030a018 80 80 bd e8 54 04 10 e5 00 00 50 e3 f5 ff ff ca ....T.....P..... 0x4030a028 02 31 d0 e3 00 00 60 12 01 00 a0 01 f1 ff ff ea .1....`......... ================================================================= Managed Stacktrace: ================================================================= at <unknown> <0xffffffff> at System.Collections.Hashtable:.ctor <0x0002b> at System.Configuration.Configuration:.ctor <0x0002f> at System.Configuration.InternalConfigurationFactory:Create <0x00077> at System.Configuration.ConfigurationManager:OpenExeConfigurationInternal <0x003e3> at System.Configuration.ClientConfigurationSystem:get_Configuration <0x00043> at System.Configuration.ClientConfigurationSystem:System.Configuration.Internal.IInternalConfigSystem.GetSection <0x00017> at System.Configuration.ConfigurationManager:GetSection <0x00037> at System.Net.Configuration.SettingsSectionInternal:get_Ipv6Enabled <0x00023> at System.Net.Sockets.Socket:InitializeSockets <0x000f7> at System.Net.Sockets.Socket:get_OSSupportsIPv4 <0x0000b> at System.Net.Sockets.Socket:get_FamilyHint <0x0000b> at System.Net.Dns:GetHostByName <0x00033> at System.Net.Dns:Resolve <0x0006f> at Mono.Tools.CertificateManager:GetCertificatesFromSslSession <0x00067> at Mono.Tools.CertificateManager:Ssl <0x00107> at Mono.Tools.CertificateManager:Main <0x005a7> at <Module>:runtime_invoke_void_object <0x000fb> ================================================================= Any ideas ?
bigjohn 754 Posted June 3, 2020 Posted June 3, 2020 Glad it is working for most. I'm not sure what might still be causing the error for some users. I believe I have done all that I can do on the server side, but I could certainly be wrong. I've tested all of our SSL domains using online certificate chain testers and all come out clean. 1
amstelgr 0 Posted June 3, 2020 Posted June 3, 2020 (edited) Error: TrustFailure (Authentication failed, see inner exception.)at Emby.Server.Implementations.HttpClientManager.HttpClientManager.SendAsyncInternal (MediaBrowser.Common.Net.HttpRequestOptions options, System.String httpMethod) [0x00858] in <4b2b35e458474e708c04b3533f59ad82>:0at Emby.Server.Implementations.HttpClientManager.HttpClientManager.SendAsync (MediaBrowser.Common.Net.HttpRequestOptions options, System.String httpMethod) [0x001f4] in <4b2b35e458474e708c04b3533f59ad82>:0at MediaBrowser.Common.Updates.GithubUpdater.CheckForUpdateResult (System.String organzation, System.String repository, System.Version minVersion, MediaBrowser.Model.Updates.PackageVersionClass updateLevel, System.String assetFilename, System.String packageName, System.String targetFilename, System.TimeSpan cacheLength, System.Threading.CancellationToken cancellationToken) [0x000f6] in <e30bc54a9b6b4a178546a5ec376a41f9>:0at Emby.Server.Implementations.ApplicationHost.CheckForApplicationUpdate (System.Threading.CancellationToken cancellationToken, System.IProgress`1[T] progress) [0x00157] in <4b2b35e458474e708c04b3533f59ad82>:0at Emby.Server.Implementations.ScheduledTasks.SystemUpdateTask.Execute (System.Threading.CancellationToken cancellationToken, System.IProgress`1[T] progress) [0x00086] in <4b2b35e458474e708c04b3533f59ad82>:0at Emby.Server.Implementations.ScheduledTasks.ScheduledTaskWorker.ExecuteInternal (MediaBrowser.Model.Tasks.TaskOptions options) [0x00195] in <4b2b35e458474e708c04b3533f59ad82>:0 </e30bc54a9b6b4a178546a5ec376a41f9> And what is this. I can not updates my applications, plugins can not insert my friend and i can not insert my premium key. Emby-Premiere-Schlüssel fehlt oder ist ungültig. Um einen Premium-Inhalt freizuschalten, wird ein aktives Emby-Premiere-Abo benötigt. Edited June 3, 2020 by amstelgr
amstelgr 0 Posted June 3, 2020 Posted June 3, 2020 (edited) DSM 6.2.3-25426 DS413j Edited June 3, 2020 by amstelgr
